[petsc-dev] VTK viewer design question
    Patrick Sanan
    patrick.sanan at gmail.com
    Fri Jun 29 10:40:17 CDT 2018
2018-06-29 17:15 GMT+02:00 Jed Brown <jed at jedbrown.org>:
> Stefano Zampini <stefano.zampini at gmail.com> writes:
> > Vec and DM classes should not be visible from Sys. This is why they are
> > PetscObject.
> > If they were visible, builds with --with-single-library=0 will be broken.
> > 2018-06-29 17:06 GMT+03:00 Patrick Sanan <patrick.sanan at gmail.com>:
> >> I'm looking at the VTK viewer implementation  and I notice that
> >> PetscViewerVTKAddField() [1]
> >> accepts a parameter which, despite being called "dm", is of type
> >> PetscObject.
> I would not object to moving vtkv.c into src/dm -- it isn't actually
> usable without DM.
Yeah, it seems like moving this logic somehow into the DM package (either
by moving the entire thing, or by introducing another callback?) is the
natural thing to do.
> >> I think that this is used, amongst other things, to ensure that vectors
> >> being queued up to be written all come from the same DM.
> >> I'd like to relax this to only require that the vectors all come from
> >> *compatible* DMDAs, but this would require the DM API in vtkv.c.
> Why?  The function is developer level and there is VecGetDM() to give
> the correct DM.  I would rather that PetscViewerVTKAddField_VTK change
> this logic to merely check for compatibility:
>   if (vtk->dm) {
>     if (dm != vtk->dm) SETERRQ(PetscObjectComm((
> PetscObject)viewer),PETSC_ERR_ARG_INCOMP,"Cannot write a field from more
> than one grid to the same VTK file");
This is what I actually do in my proof-of-concept hack. I hackily include
petscdm.h in vtkv.c, cast the arguments back to (DM), and use
DMGetCompatibility() instead of the check for identical DMs.
Later, I do use VecGetDM() to pull out the required dof/node, but this
happens in a callback defined in grvtk.c, which is in the DM package, so no
problem.
> >> My questions: is this argument of type PetscObject for any reason other
> >> than not wanting to bother including petscdm.h ? Might this be something
> >> other than a DM in some case (and in which case, why is the argument
> called
> >> "dm")? Am I missing a reason that I'll get into trouble eventually if I
> >> change this?
> >> (Similar question for the "vec" argument).
> >> [1] http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/
> >> Viewer/PetscViewerVTKAddField.html
> > Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180629/992448e1/attachment.html>
