[petsc-dev] VTK viewer design question
Stefano Zampini
stefano.zampini at gmail.com
Fri Jun 29 09:13:23 CDT 2018
Vec and DM classes should not be visible from Sys. This is why they are
PetscObject.
If they were visible, builds with --with-single-library=0 will be broken.
2018-06-29 17:06 GMT+03:00 Patrick Sanan <patrick.sanan at gmail.com>:
> I'm looking at the VTK viewer implementation and I notice that
> PetscViewerVTKAddField() [1]
> accepts a parameter which, despite being called "dm", is of type
> PetscObject.
> I think that this is used, amongst other things, to ensure that vectors
> being queued up to be written all come from the same DM.
> I'd like to relax this to only require that the vectors all come from
> *compatible* DMDAs, but this would require the DM API in vtkv.c.
> My questions: is this argument of type PetscObject for any reason other
> than not wanting to bother including petscdm.h ? Might this be something
> other than a DM in some case (and in which case, why is the argument called
> "dm")? Am I missing a reason that I'll get into trouble eventually if I
> change this?
> (Similar question for the "vec" argument).
> [1] http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/
> Viewer/PetscViewerVTKAddField.html
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180629/a3e960c7/attachment.html>
