[petsc-dev] problem with hypre with '--with-openmp=1'
Mark Adams
mfadams at lbl.gov
Wed Jun 27 13:13:18 CDT 2018
On Wed, Jun 27, 2018 at 12:40 PM Satish Balay <balay at mcs.anl.gov> wrote:
> Configure Options: --configModules=PETSc.Configure
> --optionsModule=config.compilerOptions --with-cc=cc --with-cxx=CC
> --with-fc=ftn COPTFLAGS=" -g -fp-model fast -xMIC-AVX512 -qopt-report=5
> -hcpu=mic-knl -qopenmp-simd" CXXOPTFLAGS="-g -fp-model fast -xMIC-AVX512
> -qopt-report=5 -hcpu=mic-knl -qopenmp-simd" FOPTFLAGS=" -g -fp-model fast
> -xMIC-AVX512 -qopt-report=5 -hcpu=mic-knl -qopenmp-simd"
> --download-metis=1 --with-hypre-dir=/global/homes/m/madams/tmp/hypre
> --download-parmetis=1 --download-fblaslapack --with-debugging=0
> --with-mpiexec=srun --with-batch=0 --known-mpi-shared-libraries=1
> --known-64-bit-blas-indices=0 --with-64-bit-indices=0
> PETSC_ARCH=arch-cori-knl-opt-intel-omp --with-openmp=1 --download-p4est=0
> --prefix=/global/homes/m/madams/petsc_install/petsc-cori-knl-opt-intel-omp
> --download-hdf5
> Wo
> HYPRE: UserSpecified DirPath not found.. skipping:
> /global/homes/m/madams/tmp/hypre/lib
> /global/homes/m/madams/tmp/hypre/lib64
> What do you have for:
> ls /global/homes/m/madams/tmp/hypre
> ls /global/homes/m/madams/tmp/hypre/lib
11:11 2 cori07 ~$ ls /global/homes/m/madams/tmp/hypre
AUTOTEST CHANGELOG COPYING.LESSER COPYRIGHT INSTALL README docs src
11:11 cori07 ~$ ls /global/homes/m/madams/tmp/hypre/lib
ls: cannot access '/global/homes/m/madams/tmp/hypre/lib': No such file or
directory
Hypre puts everything in src. I see this the BuildSystem:
def formGNUConfigureArgs(self):
self.packageDir = os.path.join(self.packageDir,'src')
I figured this was trying to do this. lib is in src.
> Satish
> On Wed, 27 Jun 2018, Mark Adams wrote:
> > > In this case you can try:
> > > ./configure --download-hypre=1 --prefix=$HOME/soft/hypre
> --with-openmp=1
> > > PETSC_ARCH=arch-hypreinstall
> > > ./configure --with-hypre-dir=$HOME/soft/hypre
> > > PETSC_ARCH=my-regular-build-arch [and no openmp option]
> > > make PETSC_ARCH=my-regular-build-arch
> > This syntax for the hypre dir does not seem to work ...
> > > One caveat: sometimes - mixing openmp compiled code with non-openmp
> > > build of PETSc can give link errors [as compilers/linkers do different
> > > stuff internally during linktime] - so this might not always work.
> > > Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180627/d1e7da7c/attachment.html>
