[petsc-dev] problem with hypre with '--with-openmp=1'
Wed Jun 27 11:39:16 CDT 2018
Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --with-cc=cc --with-cxx=CC --with-fc=ftn COPTFLAGS="  -g -fp-model fast -xMIC-AVX512 -qopt-report=5  -hcpu=mic-knl -qopenmp-simd" CXXOPTFLAGS="-g -fp-model fast -xMIC-AVX512 -qopt-report=5  -hcpu=mic-knl -qopenmp-simd" FOPTFLAGS="  -g -fp-model fast -xMIC-AVX512 -qopt-report=5  -hcpu=mic-knl -qopenmp-simd" --download-metis=1 --with-hypre-dir=/global/homes/m/madams/tmp/hypre --download-parmetis=1 --download-fblaslapack --with-debugging=0 --with-mpiexec=srun --with-batch=0 --known-mpi-shared-libraries=1 --known-64-bit-blas-indices=0 --with-64-bit-indices=0 PETSC_ARCH=arch-cori-knl-opt-intel-omp --with-openmp=1 --download-p4est=0 --prefix=/global/homes/m/madams/petsc_install/petsc-cori-knl-opt-intel-omp --download-hdf5
Wo
              HYPRE: UserSpecified DirPath not found.. skipping: /global/homes/m/madams/tmp/hypre/lib
              HYPRE: UserSpecified DirPath not found.. skipping: /global/homes/m/madams/tmp/hypre/lib64
What do you have for:
ls /global/homes/m/madams/tmp/hypre
ls /global/homes/m/madams/tmp/hypre/lib
Satish
On Wed, 27 Jun 2018, Mark Adams wrote:
> > In this case you can try:
> > ./configure --download-hypre=1 --prefix=$HOME/soft/hypre --with-openmp=1
> > PETSC_ARCH=arch-hypreinstall
> > ./configure --with-hypre-dir=$HOME/soft/hypre
> > PETSC_ARCH=my-regular-build-arch [and no openmp option]
> > make PETSC_ARCH=my-regular-build-arch
> This syntax for the hypre dir does not seem to work ...
> > One caveat: sometimes - mixing openmp compiled code with non-openmp
> > build of PETSc can give link errors [as compilers/linkers do different
> > stuff internally during linktime] - so this might not always work.
> > Satish
