[petsc-dev] running test harness under batch system
Zhang, Hong
hongzhang at anl.gov
Mon Jun 25 12:03:30 CDT 2018
Yes, it is possible. I have run the test harness on cori submitting the following script
#!/bin/bash -l
#SBATCH -N 1 #Use 1 nodes
#SBATCH -t 02:00:00 #Set time limit
#SBATCH -p regular #Submit to the regular 'partition'
#SBATCH -C knl,quad,cache #Use KNL nodes
make PETSC_ARCH=arch-cori-avx512-opt MPIEXEC='srun -c 4 --cpu_bind=cores' -f gmakefile test
The most important thing is probably setting the MPIEXEC according to the system. But note that there are often limitations on number of nodes on large machines. For example, Theta requires a minimum of 128 nodes.
Hong (Mr.)
> On Jun 22, 2018, at 11:41 AM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> Has anyone run the entire test harness under a batch system? Is this possible, does it require specific commands that should be documented in the users manual?
> Thanks
> Barry
