[petsc-dev] problem with hypre with '--with-openmp=1'
Mark Adams
mfadams at lbl.gov
Fri Jun 22 18:27:57 CDT 2018
On Fri, Jun 22, 2018 at 4:39 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> > On Jun 22, 2018, at 3:33 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > We are using KNL (Cori) and hypre is not working when configured with
> '--with-openmp=1', even when not using threads (as far as I can tell, I
> never use threads).
> It does seem to run correctly without the --with-openmp option?
Yes. And I've run it through valgrind.
Ulrike: have you tested on KNL with openMP?
> PETSc code does not know about --with-openmp at all so my guess is some
> bug in the compiler when building hypre with OpenMP.
> Barry
> > Hypre is not converging, for instance with an optimized build:
> > srun -n 1 ./ex56 -pc_type hypre -ksp_monitor -ksp_converged_reason
> -ksp_type cg -pc_hypre_type boomeramg
> > OMP: Warning #239: KMP_AFFINITY: granularity=fine will be used.
> > 0 KSP Residual norm 7.366251922394e+22
> > 1 KSP Residual norm 3.676434682799e+22
> > Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 2
> > Interestingly in debug mode it almost looks good but it is dying:
> > 05:09 nid02516 maint *=
> ~/petsc_install/petsc/src/ksp/ksp/examples/tutorials$ make
> PETSC_DIR=/global/homes/m/madams/petsc_install/petsc-cori-knl-dbg64-intel-omp
> PETSC_ARCH="" run
> > 0 KSP Residual norm 7.882081712007e+02
> > 1 KSP Residual norm 2.500214073037e+02
> > 2 KSP Residual norm 3.371746347713e+01
> > 3 KSP Residual norm 2.918759396143e+00
> > 4 KSP Residual norm 9.006505495017e-01
> > Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 5
> > This test runs fine on Xeon nodes. I assume that Hypre has been tested
> on KNL. GAMG runs fine, of coarse and the initial residual is similar to
> this debug run.
> > Could PETSc be messing up the matrix conversion to hypre
> '--with-openmp=1' ?
> > Any ideas?
> > Thanks,
> > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180622/05b41449/attachment.html>
