[petsc-dev] Imbalance in MG
Junchao Zhang jczhang at mcs.anl.gov
Fri Jun 22 14:26:01 CDT 2018
I instrumented PCMGMCycle_Private() to pull out some info about the
matrices and VecScatters used in MatSOR_MPIAIJ, MatMultTranspose_MPIAIJ etc
at each multigrid level to see how imbalanced they are. In my test, I have
a 6 x 6 x 6 = 216 processor grid. Each processor has 30 x 30 x 30 grid
points.  The code uses 7-point stencil.  Except for some boundary points,
it looks the problem is perfectly balanced.  From the output, I can see
processors communicate with more and more neighbors as they enter coarser
grids. For example, non-boundary processors first have 6 face-neighbors,
then 18 edge-neighbors, then 26 vertex-neighbors, and then even more
neighbors. At some level, the grid is only on the first few processors and
others are idle. The communication pattern is also imbalanced. For example,
at level 3, I have
 2172 Entering MG level 3
 2605 doing MatRestrict
 2606 MatMultTranspose_MPIAIJ: on rank 0 mat has 59 rows, 284 nonzeros,
send 188 to 33 nbrs,recv 10 from 1 nbrs
 2607 MatMultTranspose_MPIAIJ: on rank 1 mat has 61 rows, 459 nonzeros,
send 237 to 38 nbrs,recv 25 from 2 nbrs
 2608 MatMultTranspose_MPIAIJ: on rank 2 mat has 62 rows, 519 nonzeros,
send 245 to 28 nbrs,recv 28 from 2 nbrs
 2609 MatMultTranspose_MPIAIJ: on rank 3 mat has 62 rows, 521 nonzeros,
send 316 to 47 nbrs,recv 15 from 1 nbrs
 2610 MatMultTranspose_MPIAIJ: on rank 4 mat has 62 rows, 525 nonzeros,
send 411 to 62 nbrs,recv 28 from 2 nbrs
 2611 MatMultTranspose_MPIAIJ: on rank 5 mat has 70 rows, 526 nonzeros,
send 424 to 49 nbrs,recv 26 from 2 nbrs
 2612 MatMultTranspose_MPIAIJ: on rank 6 mat has 63 rows, 503 nonzeros,
send 259 to 41 nbrs,recv 28 from 4 nbrs
 2613 MatMultTranspose_MPIAIJ: on rank 7 mat has 64 rows, 374 nonzeros,
send 349 to 62 nbrs,recv 32 from 4 nbrs
 2614 MatMultTranspose_MPIAIJ: on rank 8 mat has 67 rows, 461 nonzeros,
send 354 to 51 nbrs,recv 29 from 4 nbrs
 2615 MatMultTranspose_MPIAIJ: on rank 9 mat has 67 rows, 462 nonzeros,
send 274 to 42 nbrs,recv 31 from 4 nbrs
 2616 MatMultTranspose_MPIAIJ: on rank 10 mat has 67 rows, 458 nonzeros,
send 359 to 62 nbrs,recv 30 from 4 nbrs
 2617 MatMultTranspose_MPIAIJ: on rank 11 mat has 70 rows, 482 nonzeros,
send 364 to 51 nbrs,recv 25 from 4 nbrs
 2618 MatMultTranspose_MPIAIJ: on rank 12 mat has 61 rows, 469 nonzeros,
send 274 to 42 nbrs,recv 29 from 3 nbrs
 2619 MatMultTranspose_MPIAIJ: on rank 13 mat has 64 rows, 454 nonzeros,
send 359 to 62 nbrs,recv 32 from 3 nbrs
 2620 MatMultTranspose_MPIAIJ: on rank 14 mat has 64 rows, 556 nonzeros,
send 365 to 51 nbrs,recv 34 from 3 nbrs
 2621 MatMultTranspose_MPIAIJ: on rank 15 mat has 64 rows, 542 nonzeros,
send 322 to 31 nbrs,recv 36 from 3 nbrs
 2622 MatMultTranspose_MPIAIJ: on rank 16 mat has 64 rows, 531 nonzeros,
send 411 to 44 nbrs,recv 34 from 3 nbrs
 2623 MatMultTranspose_MPIAIJ: on rank 17 mat has 70 rows, 497 nonzeros,
send 476 to 36 nbrs,recv 28 from 4 nbrs
 2624 MatMultTranspose_MPIAIJ: on rank 18 mat has 61 rows, 426 nonzeros,
send 0 to 0 nbrs,recv 30 from 4 nbrs
 2625 MatMultTranspose_MPIAIJ: on rank 19 mat has 64 rows, 521 nonzeros,
send 0 to 0 nbrs,recv 31 from 4 nbrs
The machine has 36 cores per node.  It acts as if the first 18 processors
on the first node are sending small messages to the remaining processors.
Obviously, there is no way for this to be balanced. Does someone have good
explanations for that and  know options to get rid of these imbalance?  for
example, no idle processors, spread-out communications etc.
Thanks.
--Junchao Zhang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180622/81355ce0/attachment-0001.html>
using 216 of 216 processes
30^3 unknowns per processor
total system size: 180^3
mesh size: 0.0001
MatMult_MPIAIJ: on rank 0 mat has 27000 rows, 186300 nonzeros, send 2700 to 3 nbrs,recv 2700 from 3 nbrs
MatMult_MPIAIJ: on rank 1 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 2 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 3 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 4 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 5 mat has 27000 rows, 186300 nonzeros, send 2700 to 3 nbrs,recv 2700 from 3 nbrs
MatMult_MPIAIJ: on rank 6 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 7 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 8 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 9 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 10 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 11 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 12 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 13 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 14 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 15 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 16 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 17 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 18 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 19 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 20 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 21 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 22 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 23 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 24 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 25 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 26 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 27 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 28 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 29 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 30 mat has 27000 rows, 186300 nonzeros, send 2700 to 3 nbrs,recv 2700 from 3 nbrs
MatMult_MPIAIJ: on rank 31 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 32 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 33 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 34 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 35 mat has 27000 rows, 186300 nonzeros, send 2700 to 3 nbrs,recv 2700 from 3 nbrs
MatMult_MPIAIJ: on rank 36 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 37 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 38 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 39 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 40 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 41 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 42 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 43 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 44 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 45 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 46 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 47 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 48 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 49 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 50 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 51 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 52 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 53 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 54 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 55 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 56 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 57 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 58 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 59 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 60 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 61 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 62 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 63 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 64 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 65 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 66 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 67 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 68 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 69 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 70 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 71 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 72 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 73 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 74 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 75 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 76 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 77 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 78 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 79 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 80 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 81 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 82 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 83 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 84 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 85 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 86 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 87 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 88 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 89 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 90 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 91 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 92 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 93 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 94 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 95 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 96 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 97 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 98 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 99 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 100 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 101 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 102 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 103 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 104 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 105 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 106 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 107 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 108 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 109 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 110 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 111 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 112 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 113 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 114 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 115 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 116 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 117 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 118 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 119 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 120 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 121 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 122 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 123 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 124 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 125 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 126 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 127 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 128 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 129 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 130 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 131 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 132 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 133 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 134 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 135 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 136 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 137 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 138 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 139 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 140 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 141 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 142 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 143 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 144 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 145 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 146 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 147 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 148 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 149 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 150 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 151 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 152 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 153 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 154 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 155 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 156 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 157 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 158 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 159 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 160 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 161 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 162 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 163 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 164 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 165 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 166 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 167 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 168 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 169 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 170 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 171 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 172 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatMult_MPIAIJ: on rank 173 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 174 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 175 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 176 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 177 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 178 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 179 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 180 mat has 27000 rows, 186300 nonzeros, send 2700 to 3 nbrs,recv 2700 from 3 nbrs
MatMult_MPIAIJ: on rank 181 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 182 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 183 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 184 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 185 mat has 27000 rows, 186300 nonzeros, send 2700 to 3 nbrs,recv 2700 from 3 nbrs
MatMult_MPIAIJ: on rank 186 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 187 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 188 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 189 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 190 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 191 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 192 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 193 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 194 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 195 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 196 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 197 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 198 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 199 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 200 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 201 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 202 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 203 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 204 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 205 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 206 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 207 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 208 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatMult_MPIAIJ: on rank 209 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 210 mat has 27000 rows, 186300 nonzeros, send 2700 to 3 nbrs,recv 2700 from 3 nbrs
MatMult_MPIAIJ: on rank 211 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 212 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 213 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 214 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatMult_MPIAIJ: on rank 215 mat has 27000 rows, 186300 nonzeros, send 2700 to 3 nbrs,recv 2700 from 3 nbrs
Entering MG level 6
MatSOR_MPIAIJ: on rank 0 mat has 27000 rows, 186300 nonzeros, send 2700 to 3 nbrs,recv 2700 from 3 nbrs
MatSOR_MPIAIJ: on rank 1 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 2 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 3 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 4 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 5 mat has 27000 rows, 186300 nonzeros, send 2700 to 3 nbrs,recv 2700 from 3 nbrs
MatSOR_MPIAIJ: on rank 6 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 7 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 8 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 9 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 10 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 11 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 12 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 13 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 14 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 15 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 16 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 17 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 18 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 19 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 20 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 21 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 22 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 23 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 24 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 25 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 26 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 27 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 28 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 29 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 30 mat has 27000 rows, 186300 nonzeros, send 2700 to 3 nbrs,recv 2700 from 3 nbrs
MatSOR_MPIAIJ: on rank 31 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 32 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 33 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 34 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 35 mat has 27000 rows, 186300 nonzeros, send 2700 to 3 nbrs,recv 2700 from 3 nbrs
MatSOR_MPIAIJ: on rank 36 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 37 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 38 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 39 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 40 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 41 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 42 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 43 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 44 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 45 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 46 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 47 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 48 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 49 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 50 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 51 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 52 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 53 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 54 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 55 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 56 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 57 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 58 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 59 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 60 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 61 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 62 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 63 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 64 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 65 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 66 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 67 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 68 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 69 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 70 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 71 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 72 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 73 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 74 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 75 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 76 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 77 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 78 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 79 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 80 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 81 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 82 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 83 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 84 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 85 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 86 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 87 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 88 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 89 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 90 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 91 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 92 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 93 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 94 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 95 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 96 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 97 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 98 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 99 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 100 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 101 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 102 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 103 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 104 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 105 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 106 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 107 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 108 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 109 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 110 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 111 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 112 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 113 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 114 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 115 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 116 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 117 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 118 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 119 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 120 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 121 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 122 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 123 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 124 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 125 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 126 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 127 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 128 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 129 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 130 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 131 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 132 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 133 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 134 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 135 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 136 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 137 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 138 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 139 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 140 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 141 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 142 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 143 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 144 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 145 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 146 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 147 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 148 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 149 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 150 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 151 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 152 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 153 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 154 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 155 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 156 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 157 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 158 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 159 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 160 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 161 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 162 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 163 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 164 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 165 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 166 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 167 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 168 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 169 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 170 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 171 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 172 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 173 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 174 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 175 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 176 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 177 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 178 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 179 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 180 mat has 27000 rows, 186300 nonzeros, send 2700 to 3 nbrs,recv 2700 from 3 nbrs
MatSOR_MPIAIJ: on rank 181 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 182 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 183 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 184 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 185 mat has 27000 rows, 186300 nonzeros, send 2700 to 3 nbrs,recv 2700 from 3 nbrs
MatSOR_MPIAIJ: on rank 186 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 187 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 188 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 189 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 190 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 191 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 192 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 193 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 194 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 195 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 196 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 197 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 198 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 199 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 200 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 201 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 202 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 203 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 204 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 205 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 206 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 207 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 208 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 209 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 210 mat has 27000 rows, 186300 nonzeros, send 2700 to 3 nbrs,recv 2700 from 3 nbrs
MatSOR_MPIAIJ: on rank 211 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 212 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 213 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 214 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 215 mat has 27000 rows, 186300 nonzeros, send 2700 to 3 nbrs,recv 2700 from 3 nbrs
doing MatRestrict
MatMultTranspose_MPIAIJ: on rank 0 mat has 27000 rows, 75656 nonzeros, send 1176 to 3 nbrs,recv 1176 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 1 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 2 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 3 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 4 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 5 mat has 27000 rows, 75656 nonzeros, send 1176 to 3 nbrs,recv 1176 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 6 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 7 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 8 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 9 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 10 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 11 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 12 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 13 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 14 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 15 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 16 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 17 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 18 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 19 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 20 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 21 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 22 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 23 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 24 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 25 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 26 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 27 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 28 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 29 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 30 mat has 27000 rows, 75656 nonzeros, send 1176 to 3 nbrs,recv 1176 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 31 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 32 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 33 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 34 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 35 mat has 27000 rows, 75656 nonzeros, send 1176 to 3 nbrs,recv 1176 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 36 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 37 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 38 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 39 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 40 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 41 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 42 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 43 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 44 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 45 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 46 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 47 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 48 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 49 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 50 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 51 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 52 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 53 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 54 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 55 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 56 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 57 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 58 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 59 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 60 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 61 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 62 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 63 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 64 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 65 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 66 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 67 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 68 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 69 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 70 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 71 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 72 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 73 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 74 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 75 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 76 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 77 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 78 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 79 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 80 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 81 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 82 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 83 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 84 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 85 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 86 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 87 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 88 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 89 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 90 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 91 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 92 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 93 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 94 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 95 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 96 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 97 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 98 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 99 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 100 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 101 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 102 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 103 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 104 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 105 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 106 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 107 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 108 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 109 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 110 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 111 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 112 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 113 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 114 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 115 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 116 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 117 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 118 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 119 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 120 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 121 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 122 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 123 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 124 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 125 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 126 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 127 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 128 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 129 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 130 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 131 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 132 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 133 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 134 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 135 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 136 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 137 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 138 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 139 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 140 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 141 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 142 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 143 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 144 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 145 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 146 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 147 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 148 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 149 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 150 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 151 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 152 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 153 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 154 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 155 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 156 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 157 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 158 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 159 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 160 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 161 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 162 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 163 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 164 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 165 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 166 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 167 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 168 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 169 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 170 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 171 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 172 mat has 27000 rows, 94500 nonzeros, send 2700 to 6 nbrs,recv 2700 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 173 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 174 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 175 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 176 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 177 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 178 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 179 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 180 mat has 27000 rows, 75656 nonzeros, send 1176 to 3 nbrs,recv 1176 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 181 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 182 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 183 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 184 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 185 mat has 27000 rows, 75656 nonzeros, send 1176 to 3 nbrs,recv 1176 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 186 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 187 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 188 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 189 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 190 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 191 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 192 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 193 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 194 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 195 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 196 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 197 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 198 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 199 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 200 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 201 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 202 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 203 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 204 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 205 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 206 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 207 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 208 mat has 27000 rows, 87750 nonzeros, send 2130 to 5 nbrs,recv 2130 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 209 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 210 mat has 27000 rows, 75656 nonzeros, send 1176 to 3 nbrs,recv 1176 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 211 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 212 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 213 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 214 mat has 27000 rows, 81480 nonzeros, send 1624 to 4 nbrs,recv 1624 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 215 mat has 27000 rows, 75656 nonzeros, send 1176 to 3 nbrs,recv 1176 from 3 nbrs
Entering MG level 5
MatSOR_MPIAIJ: on rank 0 mat has 10976 rows, 201530 nonzeros, send 2394 to 6 nbrs,recv 2394 from 6 nbrs
MatSOR_MPIAIJ: on rank 1 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 2 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 3 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 4 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 5 mat has 10976 rows, 201530 nonzeros, send 2394 to 6 nbrs,recv 2394 from 6 nbrs
MatSOR_MPIAIJ: on rank 6 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 7 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 8 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 9 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 10 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 11 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 12 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 13 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 14 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 15 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 16 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 17 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 18 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 19 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 20 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 21 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 22 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 23 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 24 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 25 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 26 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 27 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 28 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 29 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 30 mat has 10976 rows, 201530 nonzeros, send 2394 to 6 nbrs,recv 2394 from 6 nbrs
MatSOR_MPIAIJ: on rank 31 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 32 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 33 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 34 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 35 mat has 10976 rows, 201530 nonzeros, send 2394 to 6 nbrs,recv 2394 from 6 nbrs
MatSOR_MPIAIJ: on rank 36 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 37 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 38 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 39 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 40 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 41 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 42 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 43 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 44 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 45 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 46 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 47 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 48 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 49 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 50 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 51 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 52 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 53 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 54 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 55 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 56 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 57 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 58 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 59 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 60 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 61 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 62 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 63 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 64 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 65 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 66 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 67 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 68 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 69 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 70 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 71 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 72 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 73 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 74 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 75 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 76 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 77 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 78 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 79 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 80 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 81 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 82 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 83 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 84 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 85 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 86 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 87 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 88 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 89 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 90 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 91 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 92 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 93 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 94 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 95 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 96 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 97 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 98 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 99 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 100 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 101 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 102 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 103 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 104 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 105 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 106 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 107 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 108 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 109 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 110 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 111 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 112 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 113 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 114 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 115 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 116 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 117 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 118 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 119 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 120 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 121 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 122 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 123 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 124 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 125 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 126 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 127 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 128 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 129 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 130 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 131 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 132 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 133 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 134 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 135 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 136 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 137 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 138 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 139 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 140 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 141 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 142 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 143 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 144 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 145 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 146 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 147 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 148 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 149 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 150 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 151 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 152 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 153 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 154 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 155 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 156 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 157 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 158 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 159 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 160 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 161 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 162 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 163 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 164 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 165 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 166 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 167 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 168 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 169 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 170 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 171 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 172 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 173 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 174 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 175 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 176 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 177 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 178 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 179 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 180 mat has 10976 rows, 201530 nonzeros, send 2394 to 6 nbrs,recv 2394 from 6 nbrs
MatSOR_MPIAIJ: on rank 181 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 182 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 183 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 184 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 185 mat has 10976 rows, 201530 nonzeros, send 2394 to 6 nbrs,recv 2394 from 6 nbrs
MatSOR_MPIAIJ: on rank 186 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 187 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 188 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 189 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 190 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 191 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 192 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 193 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 194 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 195 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 196 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 197 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 198 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 199 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 200 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 201 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 202 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 203 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 204 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 205 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 206 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 207 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 208 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 209 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 210 mat has 10976 rows, 201530 nonzeros, send 2394 to 6 nbrs,recv 2394 from 6 nbrs
MatSOR_MPIAIJ: on rank 211 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 212 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 213 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 214 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 215 mat has 10976 rows, 201530 nonzeros, send 2394 to 6 nbrs,recv 2394 from 6 nbrs
MatMult_MPIAIJ: on rank 0 mat has 10976 rows, 201530 nonzeros, send 2394 to 6 nbrs,recv 2394 from 6 nbrs
MatMult_MPIAIJ: on rank 1 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 2 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 3 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 4 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 5 mat has 10976 rows, 201530 nonzeros, send 2394 to 6 nbrs,recv 2394 from 6 nbrs
MatMult_MPIAIJ: on rank 6 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 7 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 8 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 9 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 10 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 11 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 12 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 13 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 14 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 15 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 16 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 17 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 18 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 19 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 20 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 21 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 22 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 23 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 24 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 25 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 26 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 27 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 28 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 29 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 30 mat has 10976 rows, 201530 nonzeros, send 2394 to 6 nbrs,recv 2394 from 6 nbrs
MatMult_MPIAIJ: on rank 31 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 32 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 33 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 34 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 35 mat has 10976 rows, 201530 nonzeros, send 2394 to 6 nbrs,recv 2394 from 6 nbrs
MatMult_MPIAIJ: on rank 36 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 37 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 38 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 39 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 40 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 41 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 42 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 43 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 44 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 45 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 46 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 47 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 48 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 49 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 50 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 51 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 52 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 53 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 54 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 55 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 56 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 57 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 58 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 59 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 60 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 61 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 62 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 63 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 64 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 65 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 66 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 67 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 68 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 69 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 70 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 71 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 72 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 73 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 74 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 75 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 76 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 77 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 78 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 79 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 80 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 81 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 82 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 83 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 84 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 85 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 86 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 87 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 88 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 89 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 90 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 91 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 92 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 93 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 94 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 95 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 96 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 97 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 98 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 99 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 100 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 101 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 102 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 103 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 104 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 105 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 106 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 107 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 108 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 109 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 110 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 111 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 112 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 113 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 114 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 115 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 116 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 117 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 118 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 119 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 120 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 121 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 122 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 123 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 124 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 125 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 126 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 127 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 128 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 129 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 130 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 131 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 132 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 133 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 134 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 135 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 136 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 137 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 138 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 139 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 140 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 141 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 142 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 143 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 144 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 145 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 146 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 147 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 148 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 149 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 150 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 151 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 152 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 153 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 154 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 155 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 156 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 157 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 158 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 159 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 160 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 161 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 162 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 163 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 164 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 165 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 166 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 167 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 168 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 169 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 170 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 171 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 172 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatMult_MPIAIJ: on rank 173 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 174 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 175 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 176 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 177 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 178 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 179 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 180 mat has 10976 rows, 201530 nonzeros, send 2394 to 6 nbrs,recv 2394 from 6 nbrs
MatMult_MPIAIJ: on rank 181 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 182 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 183 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 184 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 185 mat has 10976 rows, 201530 nonzeros, send 2394 to 6 nbrs,recv 2394 from 6 nbrs
MatMult_MPIAIJ: on rank 186 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 187 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 188 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 189 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 190 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 191 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 192 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 193 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 194 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 195 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 196 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 197 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 198 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 199 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 200 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 201 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 202 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 203 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 204 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 205 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 206 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 207 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 208 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatMult_MPIAIJ: on rank 209 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 210 mat has 10976 rows, 201530 nonzeros, send 2394 to 6 nbrs,recv 2394 from 6 nbrs
MatMult_MPIAIJ: on rank 211 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 212 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 213 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 214 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatMult_MPIAIJ: on rank 215 mat has 10976 rows, 201530 nonzeros, send 2394 to 6 nbrs,recv 2394 from 6 nbrs
doing MatRestrict
MatMultTranspose_MPIAIJ: on rank 0 mat has 10976 rows, 55562 nonzeros, send 308 to 6 nbrs,recv 317 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 1 mat has 11760 rows, 59655 nonzeros, send 380 to 7 nbrs,recv 428 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 2 mat has 11760 rows, 59569 nonzeros, send 386 to 7 nbrs,recv 408 from 8 nbrs
MatMultTranspose_MPIAIJ: on rank 3 mat has 11760 rows, 59569 nonzeros, send 386 to 7 nbrs,recv 408 from 8 nbrs
MatMultTranspose_MPIAIJ: on rank 4 mat has 11760 rows, 59569 nonzeros, send 386 to 7 nbrs,recv 408 from 8 nbrs
MatMultTranspose_MPIAIJ: on rank 5 mat has 10976 rows, 55652 nonzeros, send 282 to 3 nbrs,recv 293 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 6 mat has 11760 rows, 59818 nonzeros, send 400 to 8 nbrs,recv 437 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 7 mat has 12600 rows, 64206 nonzeros, send 538 to 11 nbrs,recv 545 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 8 mat has 12600 rows, 64206 nonzeros, send 538 to 11 nbrs,recv 546 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 9 mat has 12600 rows, 64206 nonzeros, send 538 to 11 nbrs,recv 546 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 10 mat has 12600 rows, 64206 nonzeros, send 538 to 11 nbrs,recv 546 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 11 mat has 11760 rows, 60028 nonzeros, send 416 to 7 nbrs,recv 414 from 8 nbrs
MatMultTranspose_MPIAIJ: on rank 12 mat has 11760 rows, 59811 nonzeros, send 400 to 8 nbrs,recv 425 from 8 nbrs
MatMultTranspose_MPIAIJ: on rank 13 mat has 12600 rows, 64194 nonzeros, send 538 to 11 nbrs,recv 545 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 14 mat has 12600 rows, 64251 nonzeros, send 538 to 11 nbrs,recv 547 from 12 nbrs
MatMultTranspose_MPIAIJ: on rank 15 mat has 12600 rows, 64251 nonzeros, send 538 to 11 nbrs,recv 547 from 12 nbrs
MatMultTranspose_MPIAIJ: on rank 16 mat has 12600 rows, 64251 nonzeros, send 538 to 11 nbrs,recv 547 from 12 nbrs
MatMultTranspose_MPIAIJ: on rank 17 mat has 11760 rows, 60025 nonzeros, send 416 to 7 nbrs,recv 406 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 18 mat has 11760 rows, 59811 nonzeros, send 400 to 8 nbrs,recv 425 from 8 nbrs
MatMultTranspose_MPIAIJ: on rank 19 mat has 12600 rows, 64194 nonzeros, send 538 to 11 nbrs,recv 545 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 20 mat has 12600 rows, 64251 nonzeros, send 538 to 11 nbrs,recv 547 from 12 nbrs
MatMultTranspose_MPIAIJ: on rank 21 mat has 12600 rows, 64251 nonzeros, send 538 to 11 nbrs,recv 547 from 12 nbrs
MatMultTranspose_MPIAIJ: on rank 22 mat has 12600 rows, 64251 nonzeros, send 538 to 11 nbrs,recv 547 from 12 nbrs
MatMultTranspose_MPIAIJ: on rank 23 mat has 11760 rows, 60025 nonzeros, send 416 to 7 nbrs,recv 406 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 24 mat has 11760 rows, 59811 nonzeros, send 400 to 8 nbrs,recv 425 from 8 nbrs
MatMultTranspose_MPIAIJ: on rank 25 mat has 12600 rows, 64194 nonzeros, send 538 to 11 nbrs,recv 545 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 26 mat has 12600 rows, 64251 nonzeros, send 538 to 11 nbrs,recv 547 from 12 nbrs
MatMultTranspose_MPIAIJ: on rank 27 mat has 12600 rows, 64251 nonzeros, send 538 to 11 nbrs,recv 547 from 12 nbrs
MatMultTranspose_MPIAIJ: on rank 28 mat has 12600 rows, 64251 nonzeros, send 538 to 11 nbrs,recv 547 from 12 nbrs
MatMultTranspose_MPIAIJ: on rank 29 mat has 11760 rows, 60025 nonzeros, send 416 to 7 nbrs,recv 406 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 30 mat has 10976 rows, 55655 nonzeros, send 287 to 4 nbrs,recv 306 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 31 mat has 11760 rows, 59816 nonzeros, send 416 to 7 nbrs,recv 413 from 8 nbrs
MatMultTranspose_MPIAIJ: on rank 32 mat has 11760 rows, 59825 nonzeros, send 416 to 7 nbrs,recv 406 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 33 mat has 11760 rows, 59825 nonzeros, send 416 to 7 nbrs,recv 406 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 34 mat has 11760 rows, 59825 nonzeros, send 416 to 7 nbrs,recv 406 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 35 mat has 10976 rows, 56000 nonzeros, send 336 to 6 nbrs,recv 272 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 36 mat has 11760 rows, 59683 nonzeros, send 415 to 9 nbrs,recv 440 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 37 mat has 12600 rows, 64137 nonzeros, send 548 to 10 nbrs,recv 560 from 13 nbrs
MatMultTranspose_MPIAIJ: on rank 38 mat has 12600 rows, 64086 nonzeros, send 549 to 10 nbrs,recv 560 from 12 nbrs
MatMultTranspose_MPIAIJ: on rank 39 mat has 12600 rows, 64086 nonzeros, send 549 to 10 nbrs,recv 560 from 12 nbrs
MatMultTranspose_MPIAIJ: on rank 40 mat has 12600 rows, 64086 nonzeros, send 549 to 10 nbrs,recv 560 from 12 nbrs
MatMultTranspose_MPIAIJ: on rank 41 mat has 11760 rows, 59710 nonzeros, send 426 to 8 nbrs,recv 418 from 8 nbrs
MatMultTranspose_MPIAIJ: on rank 42 mat has 12600 rows, 64211 nonzeros, send 547 to 11 nbrs,recv 574 from 13 nbrs
MatMultTranspose_MPIAIJ: on rank 43 mat has 13500 rows, 69044 nonzeros, send 709 to 16 nbrs,recv 708 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 44 mat has 13500 rows, 69061 nonzeros, send 710 to 16 nbrs,recv 708 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 45 mat has 13500 rows, 69061 nonzeros, send 710 to 16 nbrs,recv 708 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 46 mat has 13500 rows, 69061 nonzeros, send 710 to 16 nbrs,recv 708 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 47 mat has 12600 rows, 64414 nonzeros, send 559 to 10 nbrs,recv 555 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 48 mat has 12600 rows, 64204 nonzeros, send 548 to 11 nbrs,recv 560 from 12 nbrs
MatMultTranspose_MPIAIJ: on rank 49 mat has 13500 rows, 69056 nonzeros, send 708 to 15 nbrs,recv 707 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 50 mat has 13500 rows, 69123 nonzeros, send 709 to 15 nbrs,recv 706 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 51 mat has 13500 rows, 69123 nonzeros, send 709 to 15 nbrs,recv 706 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 52 mat has 13500 rows, 69123 nonzeros, send 709 to 15 nbrs,recv 706 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 53 mat has 12600 rows, 64419 nonzeros, send 559 to 10 nbrs,recv 545 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 54 mat has 12600 rows, 64204 nonzeros, send 548 to 11 nbrs,recv 560 from 12 nbrs
MatMultTranspose_MPIAIJ: on rank 55 mat has 13500 rows, 69056 nonzeros, send 708 to 15 nbrs,recv 707 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 56 mat has 13500 rows, 69123 nonzeros, send 709 to 15 nbrs,recv 706 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 57 mat has 13500 rows, 69123 nonzeros, send 709 to 15 nbrs,recv 706 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 58 mat has 13500 rows, 69123 nonzeros, send 709 to 15 nbrs,recv 706 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 59 mat has 12600 rows, 64419 nonzeros, send 559 to 10 nbrs,recv 545 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 60 mat has 12600 rows, 64204 nonzeros, send 548 to 11 nbrs,recv 560 from 12 nbrs
MatMultTranspose_MPIAIJ: on rank 61 mat has 13500 rows, 69056 nonzeros, send 708 to 15 nbrs,recv 707 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 62 mat has 13500 rows, 69123 nonzeros, send 709 to 15 nbrs,recv 706 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 63 mat has 13500 rows, 69123 nonzeros, send 709 to 15 nbrs,recv 706 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 64 mat has 13500 rows, 69123 nonzeros, send 709 to 15 nbrs,recv 706 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 65 mat has 12600 rows, 64419 nonzeros, send 559 to 10 nbrs,recv 545 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 66 mat has 11760 rows, 59724 nonzeros, send 420 to 9 nbrs,recv 422 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 67 mat has 12600 rows, 64328 nonzeros, send 558 to 10 nbrs,recv 553 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 68 mat has 12600 rows, 64347 nonzeros, send 559 to 10 nbrs,recv 545 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 69 mat has 12600 rows, 64347 nonzeros, send 559 to 10 nbrs,recv 545 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 70 mat has 12600 rows, 64347 nonzeros, send 559 to 10 nbrs,recv 545 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 71 mat has 11760 rows, 59971 nonzeros, send 446 to 8 nbrs,recv 401 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 72 mat has 11760 rows, 59658 nonzeros, send 403 to 9 nbrs,recv 427 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 73 mat has 12600 rows, 64109 nonzeros, send 535 to 9 nbrs,recv 559 from 12 nbrs
MatMultTranspose_MPIAIJ: on rank 74 mat has 12600 rows, 64088 nonzeros, send 535 to 10 nbrs,recv 548 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 75 mat has 12600 rows, 64088 nonzeros, send 535 to 10 nbrs,recv 548 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 76 mat has 12600 rows, 64088 nonzeros, send 535 to 10 nbrs,recv 548 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 77 mat has 11760 rows, 59632 nonzeros, send 414 to 8 nbrs,recv 401 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 78 mat has 12600 rows, 64158 nonzeros, send 529 to 11 nbrs,recv 553 from 12 nbrs
MatMultTranspose_MPIAIJ: on rank 79 mat has 13500 rows, 68936 nonzeros, send 698 to 16 nbrs,recv 688 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 80 mat has 13500 rows, 68959 nonzeros, send 698 to 16 nbrs,recv 694 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 81 mat has 13500 rows, 68959 nonzeros, send 698 to 16 nbrs,recv 694 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 82 mat has 13500 rows, 68959 nonzeros, send 698 to 16 nbrs,recv 694 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 83 mat has 12600 rows, 64257 nonzeros, send 554 to 10 nbrs,recv 549 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 84 mat has 12600 rows, 64154 nonzeros, send 529 to 11 nbrs,recv 543 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 85 mat has 13500 rows, 68945 nonzeros, send 697 to 15 nbrs,recv 692 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 86 mat has 13500 rows, 69018 nonzeros, send 697 to 15 nbrs,recv 697 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 87 mat has 13500 rows, 69018 nonzeros, send 697 to 15 nbrs,recv 697 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 88 mat has 13500 rows, 69018 nonzeros, send 697 to 15 nbrs,recv 697 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 89 mat has 12600 rows, 64263 nonzeros, send 554 to 10 nbrs,recv 545 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 90 mat has 12600 rows, 64154 nonzeros, send 529 to 11 nbrs,recv 543 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 91 mat has 13500 rows, 68945 nonzeros, send 697 to 15 nbrs,recv 692 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 92 mat has 13500 rows, 69018 nonzeros, send 697 to 15 nbrs,recv 697 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 93 mat has 13500 rows, 69018 nonzeros, send 697 to 15 nbrs,recv 697 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 94 mat has 13500 rows, 69018 nonzeros, send 697 to 15 nbrs,recv 697 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 95 mat has 12600 rows, 64263 nonzeros, send 554 to 10 nbrs,recv 545 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 96 mat has 12600 rows, 64154 nonzeros, send 529 to 11 nbrs,recv 543 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 97 mat has 13500 rows, 68945 nonzeros, send 697 to 15 nbrs,recv 692 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 98 mat has 13500 rows, 69018 nonzeros, send 697 to 15 nbrs,recv 697 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 99 mat has 13500 rows, 69018 nonzeros, send 697 to 15 nbrs,recv 697 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 100 mat has 13500 rows, 69018 nonzeros, send 697 to 15 nbrs,recv 697 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 101 mat has 12600 rows, 64263 nonzeros, send 554 to 10 nbrs,recv 545 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 102 mat has 11760 rows, 59684 nonzeros, send 407 to 9 nbrs,recv 413 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 103 mat has 12600 rows, 64236 nonzeros, send 554 to 10 nbrs,recv 546 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 104 mat has 12600 rows, 64263 nonzeros, send 554 to 10 nbrs,recv 545 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 105 mat has 12600 rows, 64263 nonzeros, send 554 to 10 nbrs,recv 545 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 106 mat has 12600 rows, 64263 nonzeros, send 554 to 10 nbrs,recv 545 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 107 mat has 11760 rows, 59820 nonzeros, send 446 to 8 nbrs,recv 404 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 108 mat has 11760 rows, 59658 nonzeros, send 403 to 9 nbrs,recv 427 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 109 mat has 12600 rows, 64109 nonzeros, send 535 to 9 nbrs,recv 559 from 12 nbrs
MatMultTranspose_MPIAIJ: on rank 110 mat has 12600 rows, 64088 nonzeros, send 535 to 10 nbrs,recv 548 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 111 mat has 12600 rows, 64088 nonzeros, send 535 to 10 nbrs,recv 548 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 112 mat has 12600 rows, 64088 nonzeros, send 535 to 10 nbrs,recv 548 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 113 mat has 11760 rows, 59632 nonzeros, send 414 to 8 nbrs,recv 401 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 114 mat has 12600 rows, 64158 nonzeros, send 529 to 11 nbrs,recv 553 from 12 nbrs
MatMultTranspose_MPIAIJ: on rank 115 mat has 13500 rows, 68936 nonzeros, send 698 to 16 nbrs,recv 688 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 116 mat has 13500 rows, 68959 nonzeros, send 698 to 16 nbrs,recv 694 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 117 mat has 13500 rows, 68959 nonzeros, send 698 to 16 nbrs,recv 694 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 118 mat has 13500 rows, 68959 nonzeros, send 698 to 16 nbrs,recv 694 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 119 mat has 12600 rows, 64257 nonzeros, send 554 to 10 nbrs,recv 549 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 120 mat has 12600 rows, 64154 nonzeros, send 529 to 11 nbrs,recv 543 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 121 mat has 13500 rows, 68945 nonzeros, send 697 to 15 nbrs,recv 692 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 122 mat has 13500 rows, 69018 nonzeros, send 697 to 15 nbrs,recv 697 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 123 mat has 13500 rows, 69018 nonzeros, send 697 to 15 nbrs,recv 697 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 124 mat has 13500 rows, 69018 nonzeros, send 697 to 15 nbrs,recv 697 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 125 mat has 12600 rows, 64263 nonzeros, send 554 to 10 nbrs,recv 545 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 126 mat has 12600 rows, 64154 nonzeros, send 529 to 11 nbrs,recv 543 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 127 mat has 13500 rows, 68945 nonzeros, send 697 to 15 nbrs,recv 692 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 128 mat has 13500 rows, 69018 nonzeros, send 697 to 15 nbrs,recv 697 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 129 mat has 13500 rows, 69018 nonzeros, send 697 to 15 nbrs,recv 697 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 130 mat has 13500 rows, 69018 nonzeros, send 697 to 15 nbrs,recv 697 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 131 mat has 12600 rows, 64263 nonzeros, send 554 to 10 nbrs,recv 545 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 132 mat has 12600 rows, 64154 nonzeros, send 529 to 11 nbrs,recv 543 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 133 mat has 13500 rows, 68945 nonzeros, send 697 to 15 nbrs,recv 692 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 134 mat has 13500 rows, 69018 nonzeros, send 697 to 15 nbrs,recv 697 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 135 mat has 13500 rows, 69018 nonzeros, send 697 to 15 nbrs,recv 697 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 136 mat has 13500 rows, 69018 nonzeros, send 697 to 15 nbrs,recv 697 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 137 mat has 12600 rows, 64263 nonzeros, send 554 to 10 nbrs,recv 545 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 138 mat has 11760 rows, 59684 nonzeros, send 407 to 9 nbrs,recv 413 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 139 mat has 12600 rows, 64236 nonzeros, send 554 to 10 nbrs,recv 546 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 140 mat has 12600 rows, 64263 nonzeros, send 554 to 10 nbrs,recv 545 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 141 mat has 12600 rows, 64263 nonzeros, send 554 to 10 nbrs,recv 545 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 142 mat has 12600 rows, 64263 nonzeros, send 554 to 10 nbrs,recv 545 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 143 mat has 11760 rows, 59820 nonzeros, send 446 to 8 nbrs,recv 404 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 144 mat has 11760 rows, 59658 nonzeros, send 403 to 9 nbrs,recv 427 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 145 mat has 12600 rows, 64109 nonzeros, send 535 to 9 nbrs,recv 559 from 12 nbrs
MatMultTranspose_MPIAIJ: on rank 146 mat has 12600 rows, 64088 nonzeros, send 535 to 10 nbrs,recv 548 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 147 mat has 12600 rows, 64088 nonzeros, send 535 to 10 nbrs,recv 548 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 148 mat has 12600 rows, 64088 nonzeros, send 535 to 10 nbrs,recv 548 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 149 mat has 11760 rows, 59632 nonzeros, send 414 to 8 nbrs,recv 401 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 150 mat has 12600 rows, 64158 nonzeros, send 529 to 11 nbrs,recv 553 from 12 nbrs
MatMultTranspose_MPIAIJ: on rank 151 mat has 13500 rows, 68936 nonzeros, send 698 to 16 nbrs,recv 688 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 152 mat has 13500 rows, 68959 nonzeros, send 698 to 16 nbrs,recv 694 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 153 mat has 13500 rows, 68959 nonzeros, send 698 to 16 nbrs,recv 694 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 154 mat has 13500 rows, 68959 nonzeros, send 698 to 16 nbrs,recv 694 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 155 mat has 12600 rows, 64257 nonzeros, send 554 to 10 nbrs,recv 549 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 156 mat has 12600 rows, 64154 nonzeros, send 529 to 11 nbrs,recv 543 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 157 mat has 13500 rows, 68945 nonzeros, send 697 to 15 nbrs,recv 692 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 158 mat has 13500 rows, 69018 nonzeros, send 697 to 15 nbrs,recv 697 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 159 mat has 13500 rows, 69018 nonzeros, send 697 to 15 nbrs,recv 697 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 160 mat has 13500 rows, 69018 nonzeros, send 697 to 15 nbrs,recv 697 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 161 mat has 12600 rows, 64263 nonzeros, send 554 to 10 nbrs,recv 545 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 162 mat has 12600 rows, 64154 nonzeros, send 529 to 11 nbrs,recv 543 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 163 mat has 13500 rows, 68945 nonzeros, send 697 to 15 nbrs,recv 692 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 164 mat has 13500 rows, 69018 nonzeros, send 697 to 15 nbrs,recv 697 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 165 mat has 13500 rows, 69018 nonzeros, send 697 to 15 nbrs,recv 697 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 166 mat has 13500 rows, 69018 nonzeros, send 697 to 15 nbrs,recv 697 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 167 mat has 12600 rows, 64263 nonzeros, send 554 to 10 nbrs,recv 545 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 168 mat has 12600 rows, 64154 nonzeros, send 529 to 11 nbrs,recv 543 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 169 mat has 13500 rows, 68945 nonzeros, send 697 to 15 nbrs,recv 692 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 170 mat has 13500 rows, 69018 nonzeros, send 697 to 15 nbrs,recv 697 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 171 mat has 13500 rows, 69018 nonzeros, send 697 to 15 nbrs,recv 697 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 172 mat has 13500 rows, 69018 nonzeros, send 697 to 15 nbrs,recv 697 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 173 mat has 12600 rows, 64263 nonzeros, send 554 to 10 nbrs,recv 545 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 174 mat has 11760 rows, 59684 nonzeros, send 407 to 9 nbrs,recv 413 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 175 mat has 12600 rows, 64236 nonzeros, send 554 to 10 nbrs,recv 546 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 176 mat has 12600 rows, 64263 nonzeros, send 554 to 10 nbrs,recv 545 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 177 mat has 12600 rows, 64263 nonzeros, send 554 to 10 nbrs,recv 545 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 178 mat has 12600 rows, 64263 nonzeros, send 554 to 10 nbrs,recv 545 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 179 mat has 11760 rows, 59820 nonzeros, send 446 to 8 nbrs,recv 404 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 180 mat has 10976 rows, 54635 nonzeros, send 285 to 6 nbrs,recv 309 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 181 mat has 11760 rows, 58645 nonzeros, send 389 to 6 nbrs,recv 423 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 182 mat has 11760 rows, 58605 nonzeros, send 388 to 6 nbrs,recv 411 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 183 mat has 11760 rows, 58605 nonzeros, send 388 to 6 nbrs,recv 411 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 184 mat has 11760 rows, 58605 nonzeros, send 388 to 6 nbrs,recv 411 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 185 mat has 10976 rows, 54571 nonzeros, send 299 to 5 nbrs,recv 285 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 186 mat has 11760 rows, 58798 nonzeros, send 401 to 7 nbrs,recv 427 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 187 mat has 12600 rows, 62995 nonzeros, send 561 to 13 nbrs,recv 537 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 188 mat has 12600 rows, 63047 nonzeros, send 554 to 13 nbrs,recv 543 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 189 mat has 12600 rows, 63047 nonzeros, send 554 to 13 nbrs,recv 543 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 190 mat has 12600 rows, 63047 nonzeros, send 554 to 13 nbrs,recv 543 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 191 mat has 11760 rows, 58801 nonzeros, send 433 to 8 nbrs,recv 416 from 8 nbrs
MatMultTranspose_MPIAIJ: on rank 192 mat has 11760 rows, 58798 nonzeros, send 401 to 7 nbrs,recv 419 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 193 mat has 12600 rows, 62985 nonzeros, send 561 to 13 nbrs,recv 542 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 194 mat has 12600 rows, 63086 nonzeros, send 554 to 13 nbrs,recv 548 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 195 mat has 12600 rows, 63086 nonzeros, send 554 to 13 nbrs,recv 548 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 196 mat has 12600 rows, 63086 nonzeros, send 554 to 13 nbrs,recv 548 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 197 mat has 11760 rows, 58794 nonzeros, send 433 to 8 nbrs,recv 415 from 8 nbrs
MatMultTranspose_MPIAIJ: on rank 198 mat has 11760 rows, 58798 nonzeros, send 401 to 7 nbrs,recv 419 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 199 mat has 12600 rows, 62985 nonzeros, send 561 to 13 nbrs,recv 542 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 200 mat has 12600 rows, 63086 nonzeros, send 554 to 13 nbrs,recv 548 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 201 mat has 12600 rows, 63086 nonzeros, send 554 to 13 nbrs,recv 548 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 202 mat has 12600 rows, 63086 nonzeros, send 554 to 13 nbrs,recv 548 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 203 mat has 11760 rows, 58794 nonzeros, send 433 to 8 nbrs,recv 415 from 8 nbrs
MatMultTranspose_MPIAIJ: on rank 204 mat has 11760 rows, 58798 nonzeros, send 401 to 7 nbrs,recv 419 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 205 mat has 12600 rows, 62985 nonzeros, send 561 to 13 nbrs,recv 542 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 206 mat has 12600 rows, 63086 nonzeros, send 554 to 13 nbrs,recv 548 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 207 mat has 12600 rows, 63086 nonzeros, send 554 to 13 nbrs,recv 548 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 208 mat has 12600 rows, 63086 nonzeros, send 554 to 13 nbrs,recv 548 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 209 mat has 11760 rows, 58794 nonzeros, send 433 to 8 nbrs,recv 415 from 8 nbrs
MatMultTranspose_MPIAIJ: on rank 210 mat has 10976 rows, 54719 nonzeros, send 299 to 6 nbrs,recv 299 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 211 mat has 11760 rows, 58689 nonzeros, send 441 to 9 nbrs,recv 408 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 212 mat has 11760 rows, 58743 nonzeros, send 434 to 9 nbrs,recv 407 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 213 mat has 11760 rows, 58743 nonzeros, send 434 to 9 nbrs,recv 407 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 214 mat has 11760 rows, 58743 nonzeros, send 434 to 9 nbrs,recv 407 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 215 mat has 10976 rows, 54738 nonzeros, send 345 to 7 nbrs,recv 284 from 6 nbrs
Entering MG level 4
MatSOR_MPIAIJ: on rank 0 mat has 1301 rows, 84970 nonzeros, send 851 to 7 nbrs,recv 889 from 7 nbrs
MatSOR_MPIAIJ: on rank 1 mat has 1386 rows, 93842 nonzeros, send 1150 to 11 nbrs,recv 1178 from 11 nbrs
MatSOR_MPIAIJ: on rank 2 mat has 1386 rows, 93653 nonzeros, send 1142 to 11 nbrs,recv 1158 from 11 nbrs
MatSOR_MPIAIJ: on rank 3 mat has 1386 rows, 93653 nonzeros, send 1142 to 11 nbrs,recv 1158 from 11 nbrs
MatSOR_MPIAIJ: on rank 4 mat has 1386 rows, 93653 nonzeros, send 1142 to 11 nbrs,recv 1158 from 11 nbrs
MatSOR_MPIAIJ: on rank 5 mat has 1372 rows, 89740 nonzeros, send 820 to 7 nbrs,recv 820 from 7 nbrs
MatSOR_MPIAIJ: on rank 6 mat has 1387 rows, 93939 nonzeros, send 1144 to 11 nbrs,recv 1163 from 11 nbrs
MatSOR_MPIAIJ: on rank 7 mat has 1490 rows, 104725 nonzeros, send 1557 to 17 nbrs,recv 1530 from 17 nbrs
MatSOR_MPIAIJ: on rank 8 mat has 1490 rows, 104752 nonzeros, send 1535 to 17 nbrs,recv 1533 from 17 nbrs
MatSOR_MPIAIJ: on rank 9 mat has 1490 rows, 104752 nonzeros, send 1535 to 17 nbrs,recv 1533 from 17 nbrs
MatSOR_MPIAIJ: on rank 10 mat has 1490 rows, 104751 nonzeros, send 1535 to 17 nbrs,recv 1533 from 17 nbrs
MatSOR_MPIAIJ: on rank 11 mat has 1470 rows, 100147 nonzeros, send 1156 to 11 nbrs,recv 1150 from 11 nbrs
MatSOR_MPIAIJ: on rank 12 mat has 1387 rows, 93912 nonzeros, send 1140 to 11 nbrs,recv 1158 from 11 nbrs
MatSOR_MPIAIJ: on rank 13 mat has 1490 rows, 104627 nonzeros, send 1523 to 17 nbrs,recv 1520 from 17 nbrs
MatSOR_MPIAIJ: on rank 14 mat has 1490 rows, 104714 nonzeros, send 1532 to 17 nbrs,recv 1530 from 17 nbrs
MatSOR_MPIAIJ: on rank 15 mat has 1490 rows, 104714 nonzeros, send 1532 to 17 nbrs,recv 1530 from 17 nbrs
MatSOR_MPIAIJ: on rank 16 mat has 1490 rows, 104713 nonzeros, send 1532 to 17 nbrs,recv 1530 from 17 nbrs
MatSOR_MPIAIJ: on rank 17 mat has 1470 rows, 100074 nonzeros, send 1159 to 11 nbrs,recv 1145 from 11 nbrs
MatSOR_MPIAIJ: on rank 18 mat has 1387 rows, 93912 nonzeros, send 1140 to 11 nbrs,recv 1158 from 11 nbrs
MatSOR_MPIAIJ: on rank 19 mat has 1490 rows, 104627 nonzeros, send 1523 to 17 nbrs,recv 1520 from 17 nbrs
MatSOR_MPIAIJ: on rank 20 mat has 1490 rows, 104714 nonzeros, send 1532 to 17 nbrs,recv 1530 from 17 nbrs
MatSOR_MPIAIJ: on rank 21 mat has 1490 rows, 104714 nonzeros, send 1532 to 17 nbrs,recv 1530 from 17 nbrs
MatSOR_MPIAIJ: on rank 22 mat has 1490 rows, 104713 nonzeros, send 1532 to 17 nbrs,recv 1530 from 17 nbrs
MatSOR_MPIAIJ: on rank 23 mat has 1470 rows, 100074 nonzeros, send 1159 to 11 nbrs,recv 1145 from 11 nbrs
MatSOR_MPIAIJ: on rank 24 mat has 1387 rows, 93912 nonzeros, send 1140 to 11 nbrs,recv 1158 from 11 nbrs
MatSOR_MPIAIJ: on rank 25 mat has 1490 rows, 104627 nonzeros, send 1523 to 17 nbrs,recv 1520 from 17 nbrs
MatSOR_MPIAIJ: on rank 26 mat has 1490 rows, 104714 nonzeros, send 1532 to 17 nbrs,recv 1530 from 17 nbrs
MatSOR_MPIAIJ: on rank 27 mat has 1490 rows, 104714 nonzeros, send 1532 to 17 nbrs,recv 1530 from 17 nbrs
MatSOR_MPIAIJ: on rank 28 mat has 1490 rows, 104713 nonzeros, send 1532 to 17 nbrs,recv 1530 from 17 nbrs
MatSOR_MPIAIJ: on rank 29 mat has 1470 rows, 100074 nonzeros, send 1159 to 11 nbrs,recv 1145 from 11 nbrs
MatSOR_MPIAIJ: on rank 30 mat has 1366 rows, 89582 nonzeros, send 821 to 7 nbrs,recv 827 from 7 nbrs
MatSOR_MPIAIJ: on rank 31 mat has 1470 rows, 100041 nonzeros, send 1157 to 11 nbrs,recv 1147 from 11 nbrs
MatSOR_MPIAIJ: on rank 32 mat has 1470 rows, 100066 nonzeros, send 1171 to 11 nbrs,recv 1151 from 11 nbrs
MatSOR_MPIAIJ: on rank 33 mat has 1470 rows, 100066 nonzeros, send 1171 to 11 nbrs,recv 1151 from 11 nbrs
MatSOR_MPIAIJ: on rank 34 mat has 1470 rows, 100067 nonzeros, send 1171 to 11 nbrs,recv 1151 from 11 nbrs
MatSOR_MPIAIJ: on rank 35 mat has 1470 rows, 97042 nonzeros, send 890 to 7 nbrs,recv 850 from 7 nbrs
MatSOR_MPIAIJ: on rank 36 mat has 1392 rows, 94953 nonzeros, send 1209 to 11 nbrs,recv 1261 from 11 nbrs
MatSOR_MPIAIJ: on rank 37 mat has 1497 rows, 105726 nonzeros, send 1647 to 17 nbrs,recv 1659 from 17 nbrs
MatSOR_MPIAIJ: on rank 38 mat has 1497 rows, 105644 nonzeros, send 1626 to 17 nbrs,recv 1649 from 17 nbrs
MatSOR_MPIAIJ: on rank 39 mat has 1497 rows, 105644 nonzeros, send 1626 to 17 nbrs,recv 1649 from 17 nbrs
MatSOR_MPIAIJ: on rank 40 mat has 1497 rows, 105644 nonzeros, send 1626 to 17 nbrs,recv 1649 from 17 nbrs
MatSOR_MPIAIJ: on rank 41 mat has 1477 rows, 101022 nonzeros, send 1265 to 11 nbrs,recv 1243 from 11 nbrs
MatSOR_MPIAIJ: on rank 42 mat has 1490 rows, 105099 nonzeros, send 1610 to 17 nbrs,recv 1624 from 17 nbrs
MatSOR_MPIAIJ: on rank 43 mat has 1603 rows, 117555 nonzeros, send 2138 to 26 nbrs,recv 2094 from 26 nbrs
MatSOR_MPIAIJ: on rank 44 mat has 1603 rows, 117614 nonzeros, send 2122 to 26 nbrs,recv 2093 from 26 nbrs
MatSOR_MPIAIJ: on rank 45 mat has 1603 rows, 117614 nonzeros, send 2122 to 26 nbrs,recv 2093 from 26 nbrs
MatSOR_MPIAIJ: on rank 46 mat has 1603 rows, 117613 nonzeros, send 2122 to 26 nbrs,recv 2092 from 26 nbrs
MatSOR_MPIAIJ: on rank 47 mat has 1575 rows, 112042 nonzeros, send 1659 to 17 nbrs,recv 1629 from 17 nbrs
MatSOR_MPIAIJ: on rank 48 mat has 1490 rows, 105092 nonzeros, send 1613 to 17 nbrs,recv 1616 from 17 nbrs
MatSOR_MPIAIJ: on rank 49 mat has 1603 rows, 117501 nonzeros, send 2112 to 26 nbrs,recv 2081 from 26 nbrs
MatSOR_MPIAIJ: on rank 50 mat has 1603 rows, 117611 nonzeros, send 2127 to 26 nbrs,recv 2088 from 26 nbrs
MatSOR_MPIAIJ: on rank 51 mat has 1603 rows, 117611 nonzeros, send 2127 to 26 nbrs,recv 2088 from 26 nbrs
MatSOR_MPIAIJ: on rank 52 mat has 1603 rows, 117610 nonzeros, send 2127 to 26 nbrs,recv 2087 from 26 nbrs
MatSOR_MPIAIJ: on rank 53 mat has 1575 rows, 111983 nonzeros, send 1670 to 17 nbrs,recv 1625 from 17 nbrs
MatSOR_MPIAIJ: on rank 54 mat has 1490 rows, 105092 nonzeros, send 1613 to 17 nbrs,recv 1616 from 17 nbrs
MatSOR_MPIAIJ: on rank 55 mat has 1603 rows, 117501 nonzeros, send 2112 to 26 nbrs,recv 2081 from 26 nbrs
MatSOR_MPIAIJ: on rank 56 mat has 1603 rows, 117611 nonzeros, send 2127 to 26 nbrs,recv 2088 from 26 nbrs
MatSOR_MPIAIJ: on rank 57 mat has 1603 rows, 117611 nonzeros, send 2127 to 26 nbrs,recv 2088 from 26 nbrs
MatSOR_MPIAIJ: on rank 58 mat has 1603 rows, 117610 nonzeros, send 2127 to 26 nbrs,recv 2087 from 26 nbrs
MatSOR_MPIAIJ: on rank 59 mat has 1575 rows, 111983 nonzeros, send 1670 to 17 nbrs,recv 1625 from 17 nbrs
MatSOR_MPIAIJ: on rank 60 mat has 1490 rows, 105092 nonzeros, send 1613 to 17 nbrs,recv 1616 from 17 nbrs
MatSOR_MPIAIJ: on rank 61 mat has 1603 rows, 117501 nonzeros, send 2112 to 26 nbrs,recv 2081 from 26 nbrs
MatSOR_MPIAIJ: on rank 62 mat has 1603 rows, 117611 nonzeros, send 2127 to 26 nbrs,recv 2088 from 26 nbrs
MatSOR_MPIAIJ: on rank 63 mat has 1603 rows, 117611 nonzeros, send 2127 to 26 nbrs,recv 2088 from 26 nbrs
MatSOR_MPIAIJ: on rank 64 mat has 1603 rows, 117610 nonzeros, send 2127 to 26 nbrs,recv 2087 from 26 nbrs
MatSOR_MPIAIJ: on rank 65 mat has 1575 rows, 111983 nonzeros, send 1670 to 17 nbrs,recv 1625 from 17 nbrs
MatSOR_MPIAIJ: on rank 66 mat has 1465 rows, 100012 nonzeros, send 1235 to 11 nbrs,recv 1226 from 11 nbrs
MatSOR_MPIAIJ: on rank 67 mat has 1575 rows, 111864 nonzeros, send 1648 to 17 nbrs,recv 1627 from 17 nbrs
MatSOR_MPIAIJ: on rank 68 mat has 1575 rows, 111919 nonzeros, send 1670 to 17 nbrs,recv 1630 from 17 nbrs
MatSOR_MPIAIJ: on rank 69 mat has 1575 rows, 111919 nonzeros, send 1670 to 17 nbrs,recv 1630 from 17 nbrs
MatSOR_MPIAIJ: on rank 70 mat has 1575 rows, 111920 nonzeros, send 1670 to 17 nbrs,recv 1631 from 17 nbrs
MatSOR_MPIAIJ: on rank 71 mat has 1561 rows, 107589 nonzeros, send 1307 to 11 nbrs,recv 1268 from 11 nbrs
MatSOR_MPIAIJ: on rank 72 mat has 1392 rows, 94852 nonzeros, send 1197 to 11 nbrs,recv 1264 from 11 nbrs
MatSOR_MPIAIJ: on rank 73 mat has 1497 rows, 105863 nonzeros, send 1620 to 17 nbrs,recv 1661 from 17 nbrs
MatSOR_MPIAIJ: on rank 74 mat has 1497 rows, 105834 nonzeros, send 1621 to 17 nbrs,recv 1652 from 17 nbrs
MatSOR_MPIAIJ: on rank 75 mat has 1497 rows, 105834 nonzeros, send 1621 to 17 nbrs,recv 1652 from 17 nbrs
MatSOR_MPIAIJ: on rank 76 mat has 1497 rows, 105834 nonzeros, send 1621 to 17 nbrs,recv 1652 from 17 nbrs
MatSOR_MPIAIJ: on rank 77 mat has 1477 rows, 101066 nonzeros, send 1263 to 11 nbrs,recv 1237 from 11 nbrs
MatSOR_MPIAIJ: on rank 78 mat has 1490 rows, 105062 nonzeros, send 1584 to 17 nbrs,recv 1616 from 17 nbrs
MatSOR_MPIAIJ: on rank 79 mat has 1603 rows, 117684 nonzeros, send 2112 to 26 nbrs,recv 2093 from 26 nbrs
MatSOR_MPIAIJ: on rank 80 mat has 1603 rows, 117713 nonzeros, send 2099 to 26 nbrs,recv 2099 from 26 nbrs
MatSOR_MPIAIJ: on rank 81 mat has 1603 rows, 117713 nonzeros, send 2099 to 26 nbrs,recv 2099 from 26 nbrs
MatSOR_MPIAIJ: on rank 82 mat has 1603 rows, 117713 nonzeros, send 2099 to 26 nbrs,recv 2099 from 26 nbrs
MatSOR_MPIAIJ: on rank 83 mat has 1575 rows, 112043 nonzeros, send 1656 to 17 nbrs,recv 1629 from 17 nbrs
MatSOR_MPIAIJ: on rank 84 mat has 1490 rows, 105011 nonzeros, send 1585 to 17 nbrs,recv 1619 from 17 nbrs
MatSOR_MPIAIJ: on rank 85 mat has 1603 rows, 117581 nonzeros, send 2086 to 26 nbrs,recv 2083 from 26 nbrs
MatSOR_MPIAIJ: on rank 86 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 87 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 88 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 89 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 90 mat has 1490 rows, 105011 nonzeros, send 1585 to 17 nbrs,recv 1619 from 17 nbrs
MatSOR_MPIAIJ: on rank 91 mat has 1603 rows, 117581 nonzeros, send 2086 to 26 nbrs,recv 2083 from 26 nbrs
MatSOR_MPIAIJ: on rank 92 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 93 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 94 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 95 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 96 mat has 1490 rows, 105011 nonzeros, send 1585 to 17 nbrs,recv 1619 from 17 nbrs
MatSOR_MPIAIJ: on rank 97 mat has 1603 rows, 117581 nonzeros, send 2086 to 26 nbrs,recv 2083 from 26 nbrs
MatSOR_MPIAIJ: on rank 98 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 99 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 100 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 101 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 102 mat has 1465 rows, 99937 nonzeros, send 1219 to 11 nbrs,recv 1224 from 11 nbrs
MatSOR_MPIAIJ: on rank 103 mat has 1575 rows, 111930 nonzeros, send 1641 to 17 nbrs,recv 1623 from 17 nbrs
MatSOR_MPIAIJ: on rank 104 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 105 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 106 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 107 mat has 1561 rows, 107458 nonzeros, send 1319 to 11 nbrs,recv 1264 from 11 nbrs
MatSOR_MPIAIJ: on rank 108 mat has 1392 rows, 94852 nonzeros, send 1197 to 11 nbrs,recv 1264 from 11 nbrs
MatSOR_MPIAIJ: on rank 109 mat has 1497 rows, 105863 nonzeros, send 1620 to 17 nbrs,recv 1661 from 17 nbrs
MatSOR_MPIAIJ: on rank 110 mat has 1497 rows, 105834 nonzeros, send 1621 to 17 nbrs,recv 1652 from 17 nbrs
MatSOR_MPIAIJ: on rank 111 mat has 1497 rows, 105834 nonzeros, send 1621 to 17 nbrs,recv 1652 from 17 nbrs
MatSOR_MPIAIJ: on rank 112 mat has 1497 rows, 105834 nonzeros, send 1621 to 17 nbrs,recv 1652 from 17 nbrs
MatSOR_MPIAIJ: on rank 113 mat has 1477 rows, 101066 nonzeros, send 1263 to 11 nbrs,recv 1237 from 11 nbrs
MatSOR_MPIAIJ: on rank 114 mat has 1490 rows, 105062 nonzeros, send 1584 to 17 nbrs,recv 1616 from 17 nbrs
MatSOR_MPIAIJ: on rank 115 mat has 1603 rows, 117684 nonzeros, send 2112 to 26 nbrs,recv 2093 from 26 nbrs
MatSOR_MPIAIJ: on rank 116 mat has 1603 rows, 117713 nonzeros, send 2099 to 26 nbrs,recv 2099 from 26 nbrs
MatSOR_MPIAIJ: on rank 117 mat has 1603 rows, 117713 nonzeros, send 2099 to 26 nbrs,recv 2099 from 26 nbrs
MatSOR_MPIAIJ: on rank 118 mat has 1603 rows, 117713 nonzeros, send 2099 to 26 nbrs,recv 2099 from 26 nbrs
MatSOR_MPIAIJ: on rank 119 mat has 1575 rows, 112043 nonzeros, send 1656 to 17 nbrs,recv 1629 from 17 nbrs
MatSOR_MPIAIJ: on rank 120 mat has 1490 rows, 105011 nonzeros, send 1585 to 17 nbrs,recv 1619 from 17 nbrs
MatSOR_MPIAIJ: on rank 121 mat has 1603 rows, 117581 nonzeros, send 2086 to 26 nbrs,recv 2083 from 26 nbrs
MatSOR_MPIAIJ: on rank 122 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 123 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 124 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 125 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 126 mat has 1490 rows, 105011 nonzeros, send 1585 to 17 nbrs,recv 1619 from 17 nbrs
MatSOR_MPIAIJ: on rank 127 mat has 1603 rows, 117581 nonzeros, send 2086 to 26 nbrs,recv 2083 from 26 nbrs
MatSOR_MPIAIJ: on rank 128 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 129 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 130 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 131 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 132 mat has 1490 rows, 105011 nonzeros, send 1585 to 17 nbrs,recv 1619 from 17 nbrs
MatSOR_MPIAIJ: on rank 133 mat has 1603 rows, 117581 nonzeros, send 2086 to 26 nbrs,recv 2083 from 26 nbrs
MatSOR_MPIAIJ: on rank 134 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 135 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 136 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 137 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 138 mat has 1465 rows, 99937 nonzeros, send 1219 to 11 nbrs,recv 1224 from 11 nbrs
MatSOR_MPIAIJ: on rank 139 mat has 1575 rows, 111930 nonzeros, send 1641 to 17 nbrs,recv 1623 from 17 nbrs
MatSOR_MPIAIJ: on rank 140 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 141 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 142 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 143 mat has 1561 rows, 107458 nonzeros, send 1319 to 11 nbrs,recv 1264 from 11 nbrs
MatSOR_MPIAIJ: on rank 144 mat has 1392 rows, 94852 nonzeros, send 1197 to 11 nbrs,recv 1264 from 11 nbrs
MatSOR_MPIAIJ: on rank 145 mat has 1497 rows, 105863 nonzeros, send 1620 to 17 nbrs,recv 1661 from 17 nbrs
MatSOR_MPIAIJ: on rank 146 mat has 1497 rows, 105834 nonzeros, send 1621 to 17 nbrs,recv 1652 from 17 nbrs
MatSOR_MPIAIJ: on rank 147 mat has 1497 rows, 105834 nonzeros, send 1621 to 17 nbrs,recv 1652 from 17 nbrs
MatSOR_MPIAIJ: on rank 148 mat has 1497 rows, 105834 nonzeros, send 1621 to 17 nbrs,recv 1652 from 17 nbrs
MatSOR_MPIAIJ: on rank 149 mat has 1477 rows, 101066 nonzeros, send 1263 to 11 nbrs,recv 1237 from 11 nbrs
MatSOR_MPIAIJ: on rank 150 mat has 1490 rows, 105062 nonzeros, send 1584 to 17 nbrs,recv 1616 from 17 nbrs
MatSOR_MPIAIJ: on rank 151 mat has 1603 rows, 117684 nonzeros, send 2112 to 26 nbrs,recv 2093 from 26 nbrs
MatSOR_MPIAIJ: on rank 152 mat has 1603 rows, 117713 nonzeros, send 2099 to 26 nbrs,recv 2099 from 26 nbrs
MatSOR_MPIAIJ: on rank 153 mat has 1603 rows, 117713 nonzeros, send 2099 to 26 nbrs,recv 2099 from 26 nbrs
MatSOR_MPIAIJ: on rank 154 mat has 1603 rows, 117713 nonzeros, send 2099 to 26 nbrs,recv 2099 from 26 nbrs
MatSOR_MPIAIJ: on rank 155 mat has 1575 rows, 112043 nonzeros, send 1656 to 17 nbrs,recv 1629 from 17 nbrs
MatSOR_MPIAIJ: on rank 156 mat has 1490 rows, 105011 nonzeros, send 1585 to 17 nbrs,recv 1619 from 17 nbrs
MatSOR_MPIAIJ: on rank 157 mat has 1603 rows, 117581 nonzeros, send 2086 to 26 nbrs,recv 2083 from 26 nbrs
MatSOR_MPIAIJ: on rank 158 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 159 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 160 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 161 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 162 mat has 1490 rows, 105011 nonzeros, send 1585 to 17 nbrs,recv 1619 from 17 nbrs
MatSOR_MPIAIJ: on rank 163 mat has 1603 rows, 117581 nonzeros, send 2086 to 26 nbrs,recv 2083 from 26 nbrs
MatSOR_MPIAIJ: on rank 164 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 165 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 166 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 167 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 168 mat has 1490 rows, 105011 nonzeros, send 1585 to 17 nbrs,recv 1619 from 17 nbrs
MatSOR_MPIAIJ: on rank 169 mat has 1603 rows, 117581 nonzeros, send 2086 to 26 nbrs,recv 2083 from 26 nbrs
MatSOR_MPIAIJ: on rank 170 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 171 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 172 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 173 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 174 mat has 1465 rows, 99937 nonzeros, send 1219 to 11 nbrs,recv 1224 from 11 nbrs
MatSOR_MPIAIJ: on rank 175 mat has 1575 rows, 111930 nonzeros, send 1641 to 17 nbrs,recv 1623 from 17 nbrs
MatSOR_MPIAIJ: on rank 176 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 177 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 178 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 179 mat has 1561 rows, 107458 nonzeros, send 1319 to 11 nbrs,recv 1264 from 11 nbrs
MatSOR_MPIAIJ: on rank 180 mat has 1300 rows, 84688 nonzeros, send 792 to 7 nbrs,recv 862 from 7 nbrs
MatSOR_MPIAIJ: on rank 181 mat has 1392 rows, 94335 nonzeros, send 1130 to 11 nbrs,recv 1168 from 11 nbrs
MatSOR_MPIAIJ: on rank 182 mat has 1392 rows, 94219 nonzeros, send 1134 to 11 nbrs,recv 1159 from 11 nbrs
MatSOR_MPIAIJ: on rank 183 mat has 1392 rows, 94219 nonzeros, send 1134 to 11 nbrs,recv 1159 from 11 nbrs
MatSOR_MPIAIJ: on rank 184 mat has 1392 rows, 94219 nonzeros, send 1134 to 11 nbrs,recv 1159 from 11 nbrs
MatSOR_MPIAIJ: on rank 185 mat has 1386 rows, 90713 nonzeros, send 864 to 7 nbrs,recv 827 from 7 nbrs
MatSOR_MPIAIJ: on rank 186 mat has 1398 rows, 94373 nonzeros, send 1094 to 11 nbrs,recv 1138 from 11 nbrs
MatSOR_MPIAIJ: on rank 187 mat has 1497 rows, 105206 nonzeros, send 1525 to 17 nbrs,recv 1540 from 17 nbrs
MatSOR_MPIAIJ: on rank 188 mat has 1497 rows, 105249 nonzeros, send 1516 to 17 nbrs,recv 1545 from 17 nbrs
MatSOR_MPIAIJ: on rank 189 mat has 1497 rows, 105249 nonzeros, send 1516 to 17 nbrs,recv 1545 from 17 nbrs
MatSOR_MPIAIJ: on rank 190 mat has 1497 rows, 105249 nonzeros, send 1516 to 17 nbrs,recv 1545 from 17 nbrs
MatSOR_MPIAIJ: on rank 191 mat has 1477 rows, 100737 nonzeros, send 1176 to 11 nbrs,recv 1155 from 11 nbrs
MatSOR_MPIAIJ: on rank 192 mat has 1398 rows, 94314 nonzeros, send 1091 to 11 nbrs,recv 1143 from 11 nbrs
MatSOR_MPIAIJ: on rank 193 mat has 1497 rows, 105090 nonzeros, send 1496 to 17 nbrs,recv 1531 from 17 nbrs
MatSOR_MPIAIJ: on rank 194 mat has 1497 rows, 105199 nonzeros, send 1509 to 17 nbrs,recv 1550 from 17 nbrs
MatSOR_MPIAIJ: on rank 195 mat has 1497 rows, 105199 nonzeros, send 1509 to 17 nbrs,recv 1550 from 17 nbrs
MatSOR_MPIAIJ: on rank 196 mat has 1497 rows, 105199 nonzeros, send 1509 to 17 nbrs,recv 1550 from 17 nbrs
MatSOR_MPIAIJ: on rank 197 mat has 1477 rows, 100652 nonzeros, send 1174 to 11 nbrs,recv 1160 from 11 nbrs
MatSOR_MPIAIJ: on rank 198 mat has 1398 rows, 94314 nonzeros, send 1091 to 11 nbrs,recv 1143 from 11 nbrs
MatSOR_MPIAIJ: on rank 199 mat has 1497 rows, 105090 nonzeros, send 1496 to 17 nbrs,recv 1531 from 17 nbrs
MatSOR_MPIAIJ: on rank 200 mat has 1497 rows, 105199 nonzeros, send 1509 to 17 nbrs,recv 1550 from 17 nbrs
MatSOR_MPIAIJ: on rank 201 mat has 1497 rows, 105199 nonzeros, send 1509 to 17 nbrs,recv 1550 from 17 nbrs
MatSOR_MPIAIJ: on rank 202 mat has 1497 rows, 105199 nonzeros, send 1509 to 17 nbrs,recv 1550 from 17 nbrs
MatSOR_MPIAIJ: on rank 203 mat has 1477 rows, 100652 nonzeros, send 1174 to 11 nbrs,recv 1160 from 11 nbrs
MatSOR_MPIAIJ: on rank 204 mat has 1398 rows, 94314 nonzeros, send 1091 to 11 nbrs,recv 1143 from 11 nbrs
MatSOR_MPIAIJ: on rank 205 mat has 1497 rows, 105090 nonzeros, send 1496 to 17 nbrs,recv 1531 from 17 nbrs
MatSOR_MPIAIJ: on rank 206 mat has 1497 rows, 105199 nonzeros, send 1509 to 17 nbrs,recv 1550 from 17 nbrs
MatSOR_MPIAIJ: on rank 207 mat has 1497 rows, 105199 nonzeros, send 1509 to 17 nbrs,recv 1550 from 17 nbrs
MatSOR_MPIAIJ: on rank 208 mat has 1497 rows, 105199 nonzeros, send 1509 to 17 nbrs,recv 1550 from 17 nbrs
MatSOR_MPIAIJ: on rank 209 mat has 1477 rows, 100652 nonzeros, send 1174 to 11 nbrs,recv 1160 from 11 nbrs
MatSOR_MPIAIJ: on rank 210 mat has 1380 rows, 90224 nonzeros, send 813 to 7 nbrs,recv 820 from 7 nbrs
MatSOR_MPIAIJ: on rank 211 mat has 1477 rows, 100583 nonzeros, send 1153 to 11 nbrs,recv 1159 from 11 nbrs
MatSOR_MPIAIJ: on rank 212 mat has 1477 rows, 100633 nonzeros, send 1172 to 11 nbrs,recv 1170 from 11 nbrs
MatSOR_MPIAIJ: on rank 213 mat has 1477 rows, 100633 nonzeros, send 1172 to 11 nbrs,recv 1170 from 11 nbrs
MatSOR_MPIAIJ: on rank 214 mat has 1477 rows, 100633 nonzeros, send 1172 to 11 nbrs,recv 1170 from 11 nbrs
MatSOR_MPIAIJ: on rank 215 mat has 1470 rows, 97109 nonzeros, send 906 to 7 nbrs,recv 863 from 7 nbrs
MatMult_MPIAIJ: on rank 0 mat has 1301 rows, 84970 nonzeros, send 851 to 7 nbrs,recv 889 from 7 nbrs
MatMult_MPIAIJ: on rank 1 mat has 1386 rows, 93842 nonzeros, send 1150 to 11 nbrs,recv 1178 from 11 nbrs
MatMult_MPIAIJ: on rank 2 mat has 1386 rows, 93653 nonzeros, send 1142 to 11 nbrs,recv 1158 from 11 nbrs
MatMult_MPIAIJ: on rank 3 mat has 1386 rows, 93653 nonzeros, send 1142 to 11 nbrs,recv 1158 from 11 nbrs
MatMult_MPIAIJ: on rank 4 mat has 1386 rows, 93653 nonzeros, send 1142 to 11 nbrs,recv 1158 from 11 nbrs
MatMult_MPIAIJ: on rank 5 mat has 1372 rows, 89740 nonzeros, send 820 to 7 nbrs,recv 820 from 7 nbrs
MatMult_MPIAIJ: on rank 6 mat has 1387 rows, 93939 nonzeros, send 1144 to 11 nbrs,recv 1163 from 11 nbrs
MatMult_MPIAIJ: on rank 7 mat has 1490 rows, 104725 nonzeros, send 1557 to 17 nbrs,recv 1530 from 17 nbrs
MatMult_MPIAIJ: on rank 8 mat has 1490 rows, 104752 nonzeros, send 1535 to 17 nbrs,recv 1533 from 17 nbrs
MatMult_MPIAIJ: on rank 9 mat has 1490 rows, 104752 nonzeros, send 1535 to 17 nbrs,recv 1533 from 17 nbrs
MatMult_MPIAIJ: on rank 10 mat has 1490 rows, 104751 nonzeros, send 1535 to 17 nbrs,recv 1533 from 17 nbrs
MatMult_MPIAIJ: on rank 11 mat has 1470 rows, 100147 nonzeros, send 1156 to 11 nbrs,recv 1150 from 11 nbrs
MatMult_MPIAIJ: on rank 12 mat has 1387 rows, 93912 nonzeros, send 1140 to 11 nbrs,recv 1158 from 11 nbrs
MatMult_MPIAIJ: on rank 13 mat has 1490 rows, 104627 nonzeros, send 1523 to 17 nbrs,recv 1520 from 17 nbrs
MatMult_MPIAIJ: on rank 14 mat has 1490 rows, 104714 nonzeros, send 1532 to 17 nbrs,recv 1530 from 17 nbrs
MatMult_MPIAIJ: on rank 15 mat has 1490 rows, 104714 nonzeros, send 1532 to 17 nbrs,recv 1530 from 17 nbrs
MatMult_MPIAIJ: on rank 16 mat has 1490 rows, 104713 nonzeros, send 1532 to 17 nbrs,recv 1530 from 17 nbrs
MatMult_MPIAIJ: on rank 17 mat has 1470 rows, 100074 nonzeros, send 1159 to 11 nbrs,recv 1145 from 11 nbrs
MatMult_MPIAIJ: on rank 18 mat has 1387 rows, 93912 nonzeros, send 1140 to 11 nbrs,recv 1158 from 11 nbrs
MatMult_MPIAIJ: on rank 19 mat has 1490 rows, 104627 nonzeros, send 1523 to 17 nbrs,recv 1520 from 17 nbrs
MatMult_MPIAIJ: on rank 20 mat has 1490 rows, 104714 nonzeros, send 1532 to 17 nbrs,recv 1530 from 17 nbrs
MatMult_MPIAIJ: on rank 21 mat has 1490 rows, 104714 nonzeros, send 1532 to 17 nbrs,recv 1530 from 17 nbrs
MatMult_MPIAIJ: on rank 22 mat has 1490 rows, 104713 nonzeros, send 1532 to 17 nbrs,recv 1530 from 17 nbrs
MatMult_MPIAIJ: on rank 23 mat has 1470 rows, 100074 nonzeros, send 1159 to 11 nbrs,recv 1145 from 11 nbrs
MatMult_MPIAIJ: on rank 24 mat has 1387 rows, 93912 nonzeros, send 1140 to 11 nbrs,recv 1158 from 11 nbrs
MatMult_MPIAIJ: on rank 25 mat has 1490 rows, 104627 nonzeros, send 1523 to 17 nbrs,recv 1520 from 17 nbrs
MatMult_MPIAIJ: on rank 26 mat has 1490 rows, 104714 nonzeros, send 1532 to 17 nbrs,recv 1530 from 17 nbrs
MatMult_MPIAIJ: on rank 27 mat has 1490 rows, 104714 nonzeros, send 1532 to 17 nbrs,recv 1530 from 17 nbrs
MatMult_MPIAIJ: on rank 28 mat has 1490 rows, 104713 nonzeros, send 1532 to 17 nbrs,recv 1530 from 17 nbrs
MatMult_MPIAIJ: on rank 29 mat has 1470 rows, 100074 nonzeros, send 1159 to 11 nbrs,recv 1145 from 11 nbrs
MatMult_MPIAIJ: on rank 30 mat has 1366 rows, 89582 nonzeros, send 821 to 7 nbrs,recv 827 from 7 nbrs
MatMult_MPIAIJ: on rank 31 mat has 1470 rows, 100041 nonzeros, send 1157 to 11 nbrs,recv 1147 from 11 nbrs
MatMult_MPIAIJ: on rank 32 mat has 1470 rows, 100066 nonzeros, send 1171 to 11 nbrs,recv 1151 from 11 nbrs
MatMult_MPIAIJ: on rank 33 mat has 1470 rows, 100066 nonzeros, send 1171 to 11 nbrs,recv 1151 from 11 nbrs
MatMult_MPIAIJ: on rank 34 mat has 1470 rows, 100067 nonzeros, send 1171 to 11 nbrs,recv 1151 from 11 nbrs
MatMult_MPIAIJ: on rank 35 mat has 1470 rows, 97042 nonzeros, send 890 to 7 nbrs,recv 850 from 7 nbrs
MatMult_MPIAIJ: on rank 36 mat has 1392 rows, 94953 nonzeros, send 1209 to 11 nbrs,recv 1261 from 11 nbrs
MatMult_MPIAIJ: on rank 37 mat has 1497 rows, 105726 nonzeros, send 1647 to 17 nbrs,recv 1659 from 17 nbrs
MatMult_MPIAIJ: on rank 38 mat has 1497 rows, 105644 nonzeros, send 1626 to 17 nbrs,recv 1649 from 17 nbrs
MatMult_MPIAIJ: on rank 39 mat has 1497 rows, 105644 nonzeros, send 1626 to 17 nbrs,recv 1649 from 17 nbrs
MatMult_MPIAIJ: on rank 40 mat has 1497 rows, 105644 nonzeros, send 1626 to 17 nbrs,recv 1649 from 17 nbrs
MatMult_MPIAIJ: on rank 41 mat has 1477 rows, 101022 nonzeros, send 1265 to 11 nbrs,recv 1243 from 11 nbrs
MatMult_MPIAIJ: on rank 42 mat has 1490 rows, 105099 nonzeros, send 1610 to 17 nbrs,recv 1624 from 17 nbrs
MatMult_MPIAIJ: on rank 43 mat has 1603 rows, 117555 nonzeros, send 2138 to 26 nbrs,recv 2094 from 26 nbrs
MatMult_MPIAIJ: on rank 44 mat has 1603 rows, 117614 nonzeros, send 2122 to 26 nbrs,recv 2093 from 26 nbrs
MatMult_MPIAIJ: on rank 45 mat has 1603 rows, 117614 nonzeros, send 2122 to 26 nbrs,recv 2093 from 26 nbrs
MatMult_MPIAIJ: on rank 46 mat has 1603 rows, 117613 nonzeros, send 2122 to 26 nbrs,recv 2092 from 26 nbrs
MatMult_MPIAIJ: on rank 47 mat has 1575 rows, 112042 nonzeros, send 1659 to 17 nbrs,recv 1629 from 17 nbrs
MatMult_MPIAIJ: on rank 48 mat has 1490 rows, 105092 nonzeros, send 1613 to 17 nbrs,recv 1616 from 17 nbrs
MatMult_MPIAIJ: on rank 49 mat has 1603 rows, 117501 nonzeros, send 2112 to 26 nbrs,recv 2081 from 26 nbrs
MatMult_MPIAIJ: on rank 50 mat has 1603 rows, 117611 nonzeros, send 2127 to 26 nbrs,recv 2088 from 26 nbrs
MatMult_MPIAIJ: on rank 51 mat has 1603 rows, 117611 nonzeros, send 2127 to 26 nbrs,recv 2088 from 26 nbrs
MatMult_MPIAIJ: on rank 52 mat has 1603 rows, 117610 nonzeros, send 2127 to 26 nbrs,recv 2087 from 26 nbrs
MatMult_MPIAIJ: on rank 53 mat has 1575 rows, 111983 nonzeros, send 1670 to 17 nbrs,recv 1625 from 17 nbrs
MatMult_MPIAIJ: on rank 54 mat has 1490 rows, 105092 nonzeros, send 1613 to 17 nbrs,recv 1616 from 17 nbrs
MatMult_MPIAIJ: on rank 55 mat has 1603 rows, 117501 nonzeros, send 2112 to 26 nbrs,recv 2081 from 26 nbrs
MatMult_MPIAIJ: on rank 56 mat has 1603 rows, 117611 nonzeros, send 2127 to 26 nbrs,recv 2088 from 26 nbrs
MatMult_MPIAIJ: on rank 57 mat has 1603 rows, 117611 nonzeros, send 2127 to 26 nbrs,recv 2088 from 26 nbrs
MatMult_MPIAIJ: on rank 58 mat has 1603 rows, 117610 nonzeros, send 2127 to 26 nbrs,recv 2087 from 26 nbrs
MatMult_MPIAIJ: on rank 59 mat has 1575 rows, 111983 nonzeros, send 1670 to 17 nbrs,recv 1625 from 17 nbrs
MatMult_MPIAIJ: on rank 60 mat has 1490 rows, 105092 nonzeros, send 1613 to 17 nbrs,recv 1616 from 17 nbrs
MatMult_MPIAIJ: on rank 61 mat has 1603 rows, 117501 nonzeros, send 2112 to 26 nbrs,recv 2081 from 26 nbrs
MatMult_MPIAIJ: on rank 62 mat has 1603 rows, 117611 nonzeros, send 2127 to 26 nbrs,recv 2088 from 26 nbrs
MatMult_MPIAIJ: on rank 63 mat has 1603 rows, 117611 nonzeros, send 2127 to 26 nbrs,recv 2088 from 26 nbrs
MatMult_MPIAIJ: on rank 64 mat has 1603 rows, 117610 nonzeros, send 2127 to 26 nbrs,recv 2087 from 26 nbrs
MatMult_MPIAIJ: on rank 65 mat has 1575 rows, 111983 nonzeros, send 1670 to 17 nbrs,recv 1625 from 17 nbrs
MatMult_MPIAIJ: on rank 66 mat has 1465 rows, 100012 nonzeros, send 1235 to 11 nbrs,recv 1226 from 11 nbrs
MatMult_MPIAIJ: on rank 67 mat has 1575 rows, 111864 nonzeros, send 1648 to 17 nbrs,recv 1627 from 17 nbrs
MatMult_MPIAIJ: on rank 68 mat has 1575 rows, 111919 nonzeros, send 1670 to 17 nbrs,recv 1630 from 17 nbrs
MatMult_MPIAIJ: on rank 69 mat has 1575 rows, 111919 nonzeros, send 1670 to 17 nbrs,recv 1630 from 17 nbrs
MatMult_MPIAIJ: on rank 70 mat has 1575 rows, 111920 nonzeros, send 1670 to 17 nbrs,recv 1631 from 17 nbrs
MatMult_MPIAIJ: on rank 71 mat has 1561 rows, 107589 nonzeros, send 1307 to 11 nbrs,recv 1268 from 11 nbrs
MatMult_MPIAIJ: on rank 72 mat has 1392 rows, 94852 nonzeros, send 1197 to 11 nbrs,recv 1264 from 11 nbrs
MatMult_MPIAIJ: on rank 73 mat has 1497 rows, 105863 nonzeros, send 1620 to 17 nbrs,recv 1661 from 17 nbrs
MatMult_MPIAIJ: on rank 74 mat has 1497 rows, 105834 nonzeros, send 1621 to 17 nbrs,recv 1652 from 17 nbrs
MatMult_MPIAIJ: on rank 75 mat has 1497 rows, 105834 nonzeros, send 1621 to 17 nbrs,recv 1652 from 17 nbrs
MatMult_MPIAIJ: on rank 76 mat has 1497 rows, 105834 nonzeros, send 1621 to 17 nbrs,recv 1652 from 17 nbrs
MatMult_MPIAIJ: on rank 77 mat has 1477 rows, 101066 nonzeros, send 1263 to 11 nbrs,recv 1237 from 11 nbrs
MatMult_MPIAIJ: on rank 78 mat has 1490 rows, 105062 nonzeros, send 1584 to 17 nbrs,recv 1616 from 17 nbrs
MatMult_MPIAIJ: on rank 79 mat has 1603 rows, 117684 nonzeros, send 2112 to 26 nbrs,recv 2093 from 26 nbrs
MatMult_MPIAIJ: on rank 80 mat has 1603 rows, 117713 nonzeros, send 2099 to 26 nbrs,recv 2099 from 26 nbrs
MatMult_MPIAIJ: on rank 81 mat has 1603 rows, 117713 nonzeros, send 2099 to 26 nbrs,recv 2099 from 26 nbrs
MatMult_MPIAIJ: on rank 82 mat has 1603 rows, 117713 nonzeros, send 2099 to 26 nbrs,recv 2099 from 26 nbrs
MatMult_MPIAIJ: on rank 83 mat has 1575 rows, 112043 nonzeros, send 1656 to 17 nbrs,recv 1629 from 17 nbrs
MatMult_MPIAIJ: on rank 84 mat has 1490 rows, 105011 nonzeros, send 1585 to 17 nbrs,recv 1619 from 17 nbrs
MatMult_MPIAIJ: on rank 85 mat has 1603 rows, 117581 nonzeros, send 2086 to 26 nbrs,recv 2083 from 26 nbrs
MatMult_MPIAIJ: on rank 86 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatMult_MPIAIJ: on rank 87 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatMult_MPIAIJ: on rank 88 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatMult_MPIAIJ: on rank 89 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatMult_MPIAIJ: on rank 90 mat has 1490 rows, 105011 nonzeros, send 1585 to 17 nbrs,recv 1619 from 17 nbrs
MatMult_MPIAIJ: on rank 91 mat has 1603 rows, 117581 nonzeros, send 2086 to 26 nbrs,recv 2083 from 26 nbrs
MatMult_MPIAIJ: on rank 92 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatMult_MPIAIJ: on rank 93 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatMult_MPIAIJ: on rank 94 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatMult_MPIAIJ: on rank 95 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatMult_MPIAIJ: on rank 96 mat has 1490 rows, 105011 nonzeros, send 1585 to 17 nbrs,recv 1619 from 17 nbrs
MatMult_MPIAIJ: on rank 97 mat has 1603 rows, 117581 nonzeros, send 2086 to 26 nbrs,recv 2083 from 26 nbrs
MatMult_MPIAIJ: on rank 98 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatMult_MPIAIJ: on rank 99 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatMult_MPIAIJ: on rank 100 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatMult_MPIAIJ: on rank 101 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatMult_MPIAIJ: on rank 102 mat has 1465 rows, 99937 nonzeros, send 1219 to 11 nbrs,recv 1224 from 11 nbrs
MatMult_MPIAIJ: on rank 103 mat has 1575 rows, 111930 nonzeros, send 1641 to 17 nbrs,recv 1623 from 17 nbrs
MatMult_MPIAIJ: on rank 104 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatMult_MPIAIJ: on rank 105 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatMult_MPIAIJ: on rank 106 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatMult_MPIAIJ: on rank 107 mat has 1561 rows, 107458 nonzeros, send 1319 to 11 nbrs,recv 1264 from 11 nbrs
MatMult_MPIAIJ: on rank 108 mat has 1392 rows, 94852 nonzeros, send 1197 to 11 nbrs,recv 1264 from 11 nbrs
MatMult_MPIAIJ: on rank 109 mat has 1497 rows, 105863 nonzeros, send 1620 to 17 nbrs,recv 1661 from 17 nbrs
MatMult_MPIAIJ: on rank 110 mat has 1497 rows, 105834 nonzeros, send 1621 to 17 nbrs,recv 1652 from 17 nbrs
MatMult_MPIAIJ: on rank 111 mat has 1497 rows, 105834 nonzeros, send 1621 to 17 nbrs,recv 1652 from 17 nbrs
MatMult_MPIAIJ: on rank 112 mat has 1497 rows, 105834 nonzeros, send 1621 to 17 nbrs,recv 1652 from 17 nbrs
MatMult_MPIAIJ: on rank 113 mat has 1477 rows, 101066 nonzeros, send 1263 to 11 nbrs,recv 1237 from 11 nbrs
MatMult_MPIAIJ: on rank 114 mat has 1490 rows, 105062 nonzeros, send 1584 to 17 nbrs,recv 1616 from 17 nbrs
MatMult_MPIAIJ: on rank 115 mat has 1603 rows, 117684 nonzeros, send 2112 to 26 nbrs,recv 2093 from 26 nbrs
MatMult_MPIAIJ: on rank 116 mat has 1603 rows, 117713 nonzeros, send 2099 to 26 nbrs,recv 2099 from 26 nbrs
MatMult_MPIAIJ: on rank 117 mat has 1603 rows, 117713 nonzeros, send 2099 to 26 nbrs,recv 2099 from 26 nbrs
MatMult_MPIAIJ: on rank 118 mat has 1603 rows, 117713 nonzeros, send 2099 to 26 nbrs,recv 2099 from 26 nbrs
MatMult_MPIAIJ: on rank 119 mat has 1575 rows, 112043 nonzeros, send 1656 to 17 nbrs,recv 1629 from 17 nbrs
MatMult_MPIAIJ: on rank 120 mat has 1490 rows, 105011 nonzeros, send 1585 to 17 nbrs,recv 1619 from 17 nbrs
MatMult_MPIAIJ: on rank 121 mat has 1603 rows, 117581 nonzeros, send 2086 to 26 nbrs,recv 2083 from 26 nbrs
MatMult_MPIAIJ: on rank 122 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatMult_MPIAIJ: on rank 123 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatMult_MPIAIJ: on rank 124 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatMult_MPIAIJ: on rank 125 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatMult_MPIAIJ: on rank 126 mat has 1490 rows, 105011 nonzeros, send 1585 to 17 nbrs,recv 1619 from 17 nbrs
MatMult_MPIAIJ: on rank 127 mat has 1603 rows, 117581 nonzeros, send 2086 to 26 nbrs,recv 2083 from 26 nbrs
MatMult_MPIAIJ: on rank 128 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatMult_MPIAIJ: on rank 129 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatMult_MPIAIJ: on rank 130 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatMult_MPIAIJ: on rank 131 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatMult_MPIAIJ: on rank 132 mat has 1490 rows, 105011 nonzeros, send 1585 to 17 nbrs,recv 1619 from 17 nbrs
MatMult_MPIAIJ: on rank 133 mat has 1603 rows, 117581 nonzeros, send 2086 to 26 nbrs,recv 2083 from 26 nbrs
MatMult_MPIAIJ: on rank 134 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatMult_MPIAIJ: on rank 135 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatMult_MPIAIJ: on rank 136 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatMult_MPIAIJ: on rank 137 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatMult_MPIAIJ: on rank 138 mat has 1465 rows, 99937 nonzeros, send 1219 to 11 nbrs,recv 1224 from 11 nbrs
MatMult_MPIAIJ: on rank 139 mat has 1575 rows, 111930 nonzeros, send 1641 to 17 nbrs,recv 1623 from 17 nbrs
MatMult_MPIAIJ: on rank 140 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatMult_MPIAIJ: on rank 141 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatMult_MPIAIJ: on rank 142 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatMult_MPIAIJ: on rank 143 mat has 1561 rows, 107458 nonzeros, send 1319 to 11 nbrs,recv 1264 from 11 nbrs
MatMult_MPIAIJ: on rank 144 mat has 1392 rows, 94852 nonzeros, send 1197 to 11 nbrs,recv 1264 from 11 nbrs
MatMult_MPIAIJ: on rank 145 mat has 1497 rows, 105863 nonzeros, send 1620 to 17 nbrs,recv 1661 from 17 nbrs
MatMult_MPIAIJ: on rank 146 mat has 1497 rows, 105834 nonzeros, send 1621 to 17 nbrs,recv 1652 from 17 nbrs
MatMult_MPIAIJ: on rank 147 mat has 1497 rows, 105834 nonzeros, send 1621 to 17 nbrs,recv 1652 from 17 nbrs
MatMult_MPIAIJ: on rank 148 mat has 1497 rows, 105834 nonzeros, send 1621 to 17 nbrs,recv 1652 from 17 nbrs
MatMult_MPIAIJ: on rank 149 mat has 1477 rows, 101066 nonzeros, send 1263 to 11 nbrs,recv 1237 from 11 nbrs
MatMult_MPIAIJ: on rank 150 mat has 1490 rows, 105062 nonzeros, send 1584 to 17 nbrs,recv 1616 from 17 nbrs
MatMult_MPIAIJ: on rank 151 mat has 1603 rows, 117684 nonzeros, send 2112 to 26 nbrs,recv 2093 from 26 nbrs
MatMult_MPIAIJ: on rank 152 mat has 1603 rows, 117713 nonzeros, send 2099 to 26 nbrs,recv 2099 from 26 nbrs
MatMult_MPIAIJ: on rank 153 mat has 1603 rows, 117713 nonzeros, send 2099 to 26 nbrs,recv 2099 from 26 nbrs
MatMult_MPIAIJ: on rank 154 mat has 1603 rows, 117713 nonzeros, send 2099 to 26 nbrs,recv 2099 from 26 nbrs
MatMult_MPIAIJ: on rank 155 mat has 1575 rows, 112043 nonzeros, send 1656 to 17 nbrs,recv 1629 from 17 nbrs
MatMult_MPIAIJ: on rank 156 mat has 1490 rows, 105011 nonzeros, send 1585 to 17 nbrs,recv 1619 from 17 nbrs
MatMult_MPIAIJ: on rank 157 mat has 1603 rows, 117581 nonzeros, send 2086 to 26 nbrs,recv 2083 from 26 nbrs
MatMult_MPIAIJ: on rank 158 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatMult_MPIAIJ: on rank 159 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatMult_MPIAIJ: on rank 160 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatMult_MPIAIJ: on rank 161 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatMult_MPIAIJ: on rank 162 mat has 1490 rows, 105011 nonzeros, send 1585 to 17 nbrs,recv 1619 from 17 nbrs
MatMult_MPIAIJ: on rank 163 mat has 1603 rows, 117581 nonzeros, send 2086 to 26 nbrs,recv 2083 from 26 nbrs
MatMult_MPIAIJ: on rank 164 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatMult_MPIAIJ: on rank 165 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatMult_MPIAIJ: on rank 166 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatMult_MPIAIJ: on rank 167 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatMult_MPIAIJ: on rank 168 mat has 1490 rows, 105011 nonzeros, send 1585 to 17 nbrs,recv 1619 from 17 nbrs
MatMult_MPIAIJ: on rank 169 mat has 1603 rows, 117581 nonzeros, send 2086 to 26 nbrs,recv 2083 from 26 nbrs
MatMult_MPIAIJ: on rank 170 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatMult_MPIAIJ: on rank 171 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatMult_MPIAIJ: on rank 172 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatMult_MPIAIJ: on rank 173 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatMult_MPIAIJ: on rank 174 mat has 1465 rows, 99937 nonzeros, send 1219 to 11 nbrs,recv 1224 from 11 nbrs
MatMult_MPIAIJ: on rank 175 mat has 1575 rows, 111930 nonzeros, send 1641 to 17 nbrs,recv 1623 from 17 nbrs
MatMult_MPIAIJ: on rank 176 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatMult_MPIAIJ: on rank 177 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatMult_MPIAIJ: on rank 178 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatMult_MPIAIJ: on rank 179 mat has 1561 rows, 107458 nonzeros, send 1319 to 11 nbrs,recv 1264 from 11 nbrs
MatMult_MPIAIJ: on rank 180 mat has 1300 rows, 84688 nonzeros, send 792 to 7 nbrs,recv 862 from 7 nbrs
MatMult_MPIAIJ: on rank 181 mat has 1392 rows, 94335 nonzeros, send 1130 to 11 nbrs,recv 1168 from 11 nbrs
MatMult_MPIAIJ: on rank 182 mat has 1392 rows, 94219 nonzeros, send 1134 to 11 nbrs,recv 1159 from 11 nbrs
MatMult_MPIAIJ: on rank 183 mat has 1392 rows, 94219 nonzeros, send 1134 to 11 nbrs,recv 1159 from 11 nbrs
MatMult_MPIAIJ: on rank 184 mat has 1392 rows, 94219 nonzeros, send 1134 to 11 nbrs,recv 1159 from 11 nbrs
MatMult_MPIAIJ: on rank 185 mat has 1386 rows, 90713 nonzeros, send 864 to 7 nbrs,recv 827 from 7 nbrs
MatMult_MPIAIJ: on rank 186 mat has 1398 rows, 94373 nonzeros, send 1094 to 11 nbrs,recv 1138 from 11 nbrs
MatMult_MPIAIJ: on rank 187 mat has 1497 rows, 105206 nonzeros, send 1525 to 17 nbrs,recv 1540 from 17 nbrs
MatMult_MPIAIJ: on rank 188 mat has 1497 rows, 105249 nonzeros, send 1516 to 17 nbrs,recv 1545 from 17 nbrs
MatMult_MPIAIJ: on rank 189 mat has 1497 rows, 105249 nonzeros, send 1516 to 17 nbrs,recv 1545 from 17 nbrs
MatMult_MPIAIJ: on rank 190 mat has 1497 rows, 105249 nonzeros, send 1516 to 17 nbrs,recv 1545 from 17 nbrs
MatMult_MPIAIJ: on rank 191 mat has 1477 rows, 100737 nonzeros, send 1176 to 11 nbrs,recv 1155 from 11 nbrs
MatMult_MPIAIJ: on rank 192 mat has 1398 rows, 94314 nonzeros, send 1091 to 11 nbrs,recv 1143 from 11 nbrs
MatMult_MPIAIJ: on rank 193 mat has 1497 rows, 105090 nonzeros, send 1496 to 17 nbrs,recv 1531 from 17 nbrs
MatMult_MPIAIJ: on rank 194 mat has 1497 rows, 105199 nonzeros, send 1509 to 17 nbrs,recv 1550 from 17 nbrs
MatMult_MPIAIJ: on rank 195 mat has 1497 rows, 105199 nonzeros, send 1509 to 17 nbrs,recv 1550 from 17 nbrs
MatMult_MPIAIJ: on rank 196 mat has 1497 rows, 105199 nonzeros, send 1509 to 17 nbrs,recv 1550 from 17 nbrs
MatMult_MPIAIJ: on rank 197 mat has 1477 rows, 100652 nonzeros, send 1174 to 11 nbrs,recv 1160 from 11 nbrs
MatMult_MPIAIJ: on rank 198 mat has 1398 rows, 94314 nonzeros, send 1091 to 11 nbrs,recv 1143 from 11 nbrs
MatMult_MPIAIJ: on rank 199 mat has 1497 rows, 105090 nonzeros, send 1496 to 17 nbrs,recv 1531 from 17 nbrs
MatMult_MPIAIJ: on rank 200 mat has 1497 rows, 105199 nonzeros, send 1509 to 17 nbrs,recv 1550 from 17 nbrs
MatMult_MPIAIJ: on rank 201 mat has 1497 rows, 105199 nonzeros, send 1509 to 17 nbrs,recv 1550 from 17 nbrs
MatMult_MPIAIJ: on rank 202 mat has 1497 rows, 105199 nonzeros, send 1509 to 17 nbrs,recv 1550 from 17 nbrs
MatMult_MPIAIJ: on rank 203 mat has 1477 rows, 100652 nonzeros, send 1174 to 11 nbrs,recv 1160 from 11 nbrs
MatMult_MPIAIJ: on rank 204 mat has 1398 rows, 94314 nonzeros, send 1091 to 11 nbrs,recv 1143 from 11 nbrs
MatMult_MPIAIJ: on rank 205 mat has 1497 rows, 105090 nonzeros, send 1496 to 17 nbrs,recv 1531 from 17 nbrs
MatMult_MPIAIJ: on rank 206 mat has 1497 rows, 105199 nonzeros, send 1509 to 17 nbrs,recv 1550 from 17 nbrs
MatMult_MPIAIJ: on rank 207 mat has 1497 rows, 105199 nonzeros, send 1509 to 17 nbrs,recv 1550 from 17 nbrs
MatMult_MPIAIJ: on rank 208 mat has 1497 rows, 105199 nonzeros, send 1509 to 17 nbrs,recv 1550 from 17 nbrs
MatMult_MPIAIJ: on rank 209 mat has 1477 rows, 100652 nonzeros, send 1174 to 11 nbrs,recv 1160 from 11 nbrs
MatMult_MPIAIJ: on rank 210 mat has 1380 rows, 90224 nonzeros, send 813 to 7 nbrs,recv 820 from 7 nbrs
MatMult_MPIAIJ: on rank 211 mat has 1477 rows, 100583 nonzeros, send 1153 to 11 nbrs,recv 1159 from 11 nbrs
MatMult_MPIAIJ: on rank 212 mat has 1477 rows, 100633 nonzeros, send 1172 to 11 nbrs,recv 1170 from 11 nbrs
MatMult_MPIAIJ: on rank 213 mat has 1477 rows, 100633 nonzeros, send 1172 to 11 nbrs,recv 1170 from 11 nbrs
MatMult_MPIAIJ: on rank 214 mat has 1477 rows, 100633 nonzeros, send 1172 to 11 nbrs,recv 1170 from 11 nbrs
MatMult_MPIAIJ: on rank 215 mat has 1470 rows, 97109 nonzeros, send 906 to 7 nbrs,recv 863 from 7 nbrs
doing MatRestrict
MatMultTranspose_MPIAIJ: on rank 0 mat has 1301 rows, 6042 nonzeros, send 32 to 6 nbrs,recv 69 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 1 mat has 1386 rows, 6732 nonzeros, send 49 to 6 nbrs,recv 85 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 2 mat has 1386 rows, 6834 nonzeros, send 55 to 8 nbrs,recv 86 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 3 mat has 1386 rows, 6835 nonzeros, send 55 to 8 nbrs,recv 86 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 4 mat has 1386 rows, 6874 nonzeros, send 56 to 8 nbrs,recv 87 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 5 mat has 1372 rows, 6675 nonzeros, send 44 to 5 nbrs,recv 61 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 6 mat has 1387 rows, 6730 nonzeros, send 51 to 7 nbrs,recv 76 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 7 mat has 1490 rows, 7165 nonzeros, send 94 to 13 nbrs,recv 99 from 13 nbrs
MatMultTranspose_MPIAIJ: on rank 8 mat has 1490 rows, 7247 nonzeros, send 98 to 13 nbrs,recv 109 from 14 nbrs
MatMultTranspose_MPIAIJ: on rank 9 mat has 1490 rows, 7247 nonzeros, send 98 to 13 nbrs,recv 109 from 14 nbrs
MatMultTranspose_MPIAIJ: on rank 10 mat has 1490 rows, 7237 nonzeros, send 98 to 13 nbrs,recv 109 from 14 nbrs
MatMultTranspose_MPIAIJ: on rank 11 mat has 1470 rows, 6843 nonzeros, send 67 to 6 nbrs,recv 81 from 8 nbrs
MatMultTranspose_MPIAIJ: on rank 12 mat has 1387 rows, 6685 nonzeros, send 50 to 7 nbrs,recv 83 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 13 mat has 1490 rows, 7217 nonzeros, send 88 to 12 nbrs,recv 101 from 13 nbrs
MatMultTranspose_MPIAIJ: on rank 14 mat has 1490 rows, 7173 nonzeros, send 92 to 13 nbrs,recv 101 from 14 nbrs
MatMultTranspose_MPIAIJ: on rank 15 mat has 1490 rows, 7188 nonzeros, send 92 to 13 nbrs,recv 102 from 14 nbrs
MatMultTranspose_MPIAIJ: on rank 16 mat has 1490 rows, 7140 nonzeros, send 93 to 13 nbrs,recv 102 from 13 nbrs
MatMultTranspose_MPIAIJ: on rank 17 mat has 1470 rows, 6877 nonzeros, send 65 to 6 nbrs,recv 79 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 18 mat has 1387 rows, 6688 nonzeros, send 50 to 7 nbrs,recv 82 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 19 mat has 1490 rows, 7198 nonzeros, send 88 to 12 nbrs,recv 99 from 13 nbrs
MatMultTranspose_MPIAIJ: on rank 20 mat has 1490 rows, 7171 nonzeros, send 92 to 13 nbrs,recv 103 from 14 nbrs
MatMultTranspose_MPIAIJ: on rank 21 mat has 1490 rows, 7186 nonzeros, send 92 to 13 nbrs,recv 104 from 14 nbrs
MatMultTranspose_MPIAIJ: on rank 22 mat has 1490 rows, 7146 nonzeros, send 93 to 13 nbrs,recv 104 from 13 nbrs
MatMultTranspose_MPIAIJ: on rank 23 mat has 1470 rows, 6877 nonzeros, send 65 to 6 nbrs,recv 79 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 24 mat has 1387 rows, 6688 nonzeros, send 50 to 7 nbrs,recv 82 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 25 mat has 1490 rows, 7191 nonzeros, send 88 to 12 nbrs,recv 99 from 13 nbrs
MatMultTranspose_MPIAIJ: on rank 26 mat has 1490 rows, 7157 nonzeros, send 91 to 12 nbrs,recv 102 from 13 nbrs
MatMultTranspose_MPIAIJ: on rank 27 mat has 1490 rows, 7172 nonzeros, send 91 to 12 nbrs,recv 103 from 13 nbrs
MatMultTranspose_MPIAIJ: on rank 28 mat has 1490 rows, 7139 nonzeros, send 92 to 12 nbrs,recv 103 from 12 nbrs
MatMultTranspose_MPIAIJ: on rank 29 mat has 1470 rows, 6877 nonzeros, send 65 to 6 nbrs,recv 79 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 30 mat has 1366 rows, 6502 nonzeros, send 42 to 4 nbrs,recv 59 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 31 mat has 1470 rows, 7040 nonzeros, send 68 to 7 nbrs,recv 78 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 32 mat has 1470 rows, 7056 nonzeros, send 68 to 7 nbrs,recv 82 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 33 mat has 1470 rows, 7040 nonzeros, send 68 to 7 nbrs,recv 81 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 34 mat has 1470 rows, 7091 nonzeros, send 70 to 8 nbrs,recv 82 from 8 nbrs
MatMultTranspose_MPIAIJ: on rank 35 mat has 1470 rows, 6917 nonzeros, send 58 to 5 nbrs,recv 54 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 36 mat has 1392 rows, 6416 nonzeros, send 60 to 8 nbrs,recv 80 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 37 mat has 1497 rows, 7178 nonzeros, send 88 to 13 nbrs,recv 102 from 14 nbrs
MatMultTranspose_MPIAIJ: on rank 38 mat has 1497 rows, 7286 nonzeros, send 82 to 12 nbrs,recv 101 from 14 nbrs
MatMultTranspose_MPIAIJ: on rank 39 mat has 1497 rows, 7286 nonzeros, send 82 to 12 nbrs,recv 101 from 14 nbrs
MatMultTranspose_MPIAIJ: on rank 40 mat has 1497 rows, 7183 nonzeros, send 79 to 12 nbrs,recv 100 from 14 nbrs
MatMultTranspose_MPIAIJ: on rank 41 mat has 1477 rows, 6937 nonzeros, send 72 to 7 nbrs,recv 77 from 8 nbrs
MatMultTranspose_MPIAIJ: on rank 42 mat has 1490 rows, 6901 nonzeros, send 73 to 12 nbrs,recv 92 from 12 nbrs
MatMultTranspose_MPIAIJ: on rank 43 mat has 1603 rows, 7501 nonzeros, send 118 to 19 nbrs,recv 106 from 12 nbrs
MatMultTranspose_MPIAIJ: on rank 44 mat has 1603 rows, 7637 nonzeros, send 119 to 18 nbrs,recv 114 from 14 nbrs
MatMultTranspose_MPIAIJ: on rank 45 mat has 1603 rows, 7637 nonzeros, send 119 to 18 nbrs,recv 114 from 14 nbrs
MatMultTranspose_MPIAIJ: on rank 46 mat has 1603 rows, 7626 nonzeros, send 116 to 18 nbrs,recv 115 from 14 nbrs
MatMultTranspose_MPIAIJ: on rank 47 mat has 1575 rows, 7354 nonzeros, send 101 to 13 nbrs,recv 89 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 48 mat has 1490 rows, 6918 nonzeros, send 78 to 13 nbrs,recv 91 from 13 nbrs
MatMultTranspose_MPIAIJ: on rank 49 mat has 1603 rows, 7553 nonzeros, send 113 to 19 nbrs,recv 108 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 50 mat has 1603 rows, 7589 nonzeros, send 109 to 18 nbrs,recv 112 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 51 mat has 1603 rows, 7591 nonzeros, send 109 to 18 nbrs,recv 113 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 52 mat has 1603 rows, 7572 nonzeros, send 107 to 18 nbrs,recv 115 from 16 nbrs
MatMultTranspose_MPIAIJ: on rank 53 mat has 1575 rows, 7389 nonzeros, send 102 to 13 nbrs,recv 87 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 54 mat has 1490 rows, 6918 nonzeros, send 78 to 13 nbrs,recv 91 from 13 nbrs
MatMultTranspose_MPIAIJ: on rank 55 mat has 1603 rows, 7548 nonzeros, send 112 to 19 nbrs,recv 109 from 16 nbrs
MatMultTranspose_MPIAIJ: on rank 56 mat has 1603 rows, 7582 nonzeros, send 108 to 18 nbrs,recv 112 from 16 nbrs
MatMultTranspose_MPIAIJ: on rank 57 mat has 1603 rows, 7584 nonzeros, send 108 to 18 nbrs,recv 113 from 16 nbrs
MatMultTranspose_MPIAIJ: on rank 58 mat has 1603 rows, 7572 nonzeros, send 107 to 18 nbrs,recv 115 from 16 nbrs
MatMultTranspose_MPIAIJ: on rank 59 mat has 1575 rows, 7389 nonzeros, send 102 to 13 nbrs,recv 87 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 60 mat has 1490 rows, 6918 nonzeros, send 78 to 13 nbrs,recv 91 from 13 nbrs
MatMultTranspose_MPIAIJ: on rank 61 mat has 1603 rows, 7527 nonzeros, send 114 to 19 nbrs,recv 108 from 16 nbrs
MatMultTranspose_MPIAIJ: on rank 62 mat has 1603 rows, 7561 nonzeros, send 109 to 18 nbrs,recv 111 from 16 nbrs
MatMultTranspose_MPIAIJ: on rank 63 mat has 1603 rows, 7563 nonzeros, send 109 to 18 nbrs,recv 112 from 16 nbrs
MatMultTranspose_MPIAIJ: on rank 64 mat has 1603 rows, 7549 nonzeros, send 108 to 18 nbrs,recv 114 from 16 nbrs
MatMultTranspose_MPIAIJ: on rank 65 mat has 1575 rows, 7394 nonzeros, send 102 to 13 nbrs,recv 86 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 66 mat has 1465 rows, 6753 nonzeros, send 68 to 8 nbrs,recv 74 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 67 mat has 1575 rows, 7384 nonzeros, send 103 to 13 nbrs,recv 89 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 68 mat has 1575 rows, 7429 nonzeros, send 106 to 14 nbrs,recv 90 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 69 mat has 1575 rows, 7429 nonzeros, send 106 to 14 nbrs,recv 90 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 70 mat has 1575 rows, 7449 nonzeros, send 105 to 13 nbrs,recv 93 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 71 mat has 1561 rows, 7152 nonzeros, send 100 to 9 nbrs,recv 61 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 72 mat has 1392 rows, 6651 nonzeros, send 56 to 8 nbrs,recv 81 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 73 mat has 1497 rows, 6992 nonzeros, send 82 to 12 nbrs,recv 101 from 14 nbrs
MatMultTranspose_MPIAIJ: on rank 74 mat has 1497 rows, 6982 nonzeros, send 82 to 12 nbrs,recv 98 from 14 nbrs
MatMultTranspose_MPIAIJ: on rank 75 mat has 1497 rows, 6982 nonzeros, send 82 to 12 nbrs,recv 98 from 14 nbrs
MatMultTranspose_MPIAIJ: on rank 76 mat has 1497 rows, 7007 nonzeros, send 82 to 12 nbrs,recv 98 from 14 nbrs
MatMultTranspose_MPIAIJ: on rank 77 mat has 1477 rows, 6797 nonzeros, send 74 to 7 nbrs,recv 75 from 8 nbrs
MatMultTranspose_MPIAIJ: on rank 78 mat has 1490 rows, 6970 nonzeros, send 78 to 12 nbrs,recv 92 from 13 nbrs
MatMultTranspose_MPIAIJ: on rank 79 mat has 1603 rows, 7516 nonzeros, send 117 to 15 nbrs,recv 115 from 16 nbrs
MatMultTranspose_MPIAIJ: on rank 80 mat has 1603 rows, 7550 nonzeros, send 116 to 15 nbrs,recv 115 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 81 mat has 1603 rows, 7550 nonzeros, send 116 to 15 nbrs,recv 115 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 82 mat has 1603 rows, 7534 nonzeros, send 120 to 16 nbrs,recv 109 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 83 mat has 1575 rows, 7143 nonzeros, send 97 to 12 nbrs,recv 84 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 84 mat has 1490 rows, 7001 nonzeros, send 80 to 12 nbrs,recv 93 from 14 nbrs
MatMultTranspose_MPIAIJ: on rank 85 mat has 1603 rows, 7575 nonzeros, send 110 to 14 nbrs,recv 117 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 86 mat has 1603 rows, 7520 nonzeros, send 110 to 14 nbrs,recv 112 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 87 mat has 1603 rows, 7520 nonzeros, send 110 to 14 nbrs,recv 112 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 88 mat has 1603 rows, 7493 nonzeros, send 114 to 15 nbrs,recv 107 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 89 mat has 1575 rows, 7165 nonzeros, send 96 to 11 nbrs,recv 81 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 90 mat has 1490 rows, 7001 nonzeros, send 80 to 12 nbrs,recv 93 from 14 nbrs
MatMultTranspose_MPIAIJ: on rank 91 mat has 1603 rows, 7575 nonzeros, send 110 to 14 nbrs,recv 117 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 92 mat has 1603 rows, 7520 nonzeros, send 110 to 14 nbrs,recv 112 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 93 mat has 1603 rows, 7520 nonzeros, send 110 to 14 nbrs,recv 112 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 94 mat has 1603 rows, 7493 nonzeros, send 114 to 15 nbrs,recv 107 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 95 mat has 1575 rows, 7165 nonzeros, send 96 to 11 nbrs,recv 81 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 96 mat has 1490 rows, 7002 nonzeros, send 80 to 12 nbrs,recv 93 from 14 nbrs
MatMultTranspose_MPIAIJ: on rank 97 mat has 1603 rows, 7572 nonzeros, send 110 to 14 nbrs,recv 117 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 98 mat has 1603 rows, 7518 nonzeros, send 110 to 14 nbrs,recv 112 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 99 mat has 1603 rows, 7518 nonzeros, send 110 to 14 nbrs,recv 112 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 100 mat has 1603 rows, 7491 nonzeros, send 114 to 15 nbrs,recv 107 from 17 nbrs
MatMultTranspose_MPIAIJ: on rank 101 mat has 1575 rows, 7167 nonzeros, send 96 to 11 nbrs,recv 81 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 102 mat has 1465 rows, 6765 nonzeros, send 69 to 7 nbrs,recv 69 from 8 nbrs
MatMultTranspose_MPIAIJ: on rank 103 mat has 1575 rows, 7294 nonzeros, send 96 to 9 nbrs,recv 87 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 104 mat has 1575 rows, 7275 nonzeros, send 96 to 10 nbrs,recv 85 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 105 mat has 1575 rows, 7275 nonzeros, send 96 to 10 nbrs,recv 85 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 106 mat has 1575 rows, 7318 nonzeros, send 96 to 10 nbrs,recv 86 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 107 mat has 1561 rows, 7078 nonzeros, send 94 to 9 nbrs,recv 59 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 108 mat has 1392 rows, 6676 nonzeros, send 55 to 8 nbrs,recv 83 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 109 mat has 1497 rows, 6974 nonzeros, send 81 to 12 nbrs,recv 98 from 13 nbrs
MatMultTranspose_MPIAIJ: on rank 110 mat has 1497 rows, 6950 nonzeros, send 83 to 12 nbrs,recv 96 from 13 nbrs
MatMultTranspose_MPIAIJ: on rank 111 mat has 1497 rows, 6950 nonzeros, send 83 to 12 nbrs,recv 96 from 13 nbrs
MatMultTranspose_MPIAIJ: on rank 112 mat has 1497 rows, 6990 nonzeros, send 83 to 12 nbrs,recv 98 from 13 nbrs
MatMultTranspose_MPIAIJ: on rank 113 mat has 1477 rows, 6785 nonzeros, send 71 to 7 nbrs,recv 73 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 114 mat has 1490 rows, 6965 nonzeros, send 79 to 12 nbrs,recv 95 from 13 nbrs
MatMultTranspose_MPIAIJ: on rank 115 mat has 1603 rows, 7508 nonzeros, send 117 to 16 nbrs,recv 114 from 16 nbrs
MatMultTranspose_MPIAIJ: on rank 116 mat has 1603 rows, 7545 nonzeros, send 117 to 16 nbrs,recv 114 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 117 mat has 1603 rows, 7545 nonzeros, send 117 to 16 nbrs,recv 114 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 118 mat has 1603 rows, 7537 nonzeros, send 120 to 17 nbrs,recv 110 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 119 mat has 1575 rows, 7106 nonzeros, send 96 to 12 nbrs,recv 82 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 120 mat has 1490 rows, 7000 nonzeros, send 81 to 12 nbrs,recv 97 from 14 nbrs
MatMultTranspose_MPIAIJ: on rank 121 mat has 1603 rows, 7563 nonzeros, send 110 to 15 nbrs,recv 116 from 16 nbrs
MatMultTranspose_MPIAIJ: on rank 122 mat has 1603 rows, 7512 nonzeros, send 111 to 15 nbrs,recv 111 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 123 mat has 1603 rows, 7512 nonzeros, send 111 to 15 nbrs,recv 111 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 124 mat has 1603 rows, 7487 nonzeros, send 115 to 16 nbrs,recv 108 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 125 mat has 1575 rows, 7137 nonzeros, send 94 to 11 nbrs,recv 79 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 126 mat has 1490 rows, 7000 nonzeros, send 81 to 12 nbrs,recv 97 from 14 nbrs
MatMultTranspose_MPIAIJ: on rank 127 mat has 1603 rows, 7563 nonzeros, send 110 to 15 nbrs,recv 116 from 16 nbrs
MatMultTranspose_MPIAIJ: on rank 128 mat has 1603 rows, 7512 nonzeros, send 111 to 15 nbrs,recv 111 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 129 mat has 1603 rows, 7512 nonzeros, send 111 to 15 nbrs,recv 111 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 130 mat has 1603 rows, 7487 nonzeros, send 115 to 16 nbrs,recv 108 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 131 mat has 1575 rows, 7137 nonzeros, send 94 to 11 nbrs,recv 79 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 132 mat has 1490 rows, 7001 nonzeros, send 81 to 12 nbrs,recv 97 from 14 nbrs
MatMultTranspose_MPIAIJ: on rank 133 mat has 1603 rows, 7563 nonzeros, send 110 to 15 nbrs,recv 116 from 16 nbrs
MatMultTranspose_MPIAIJ: on rank 134 mat has 1603 rows, 7512 nonzeros, send 111 to 15 nbrs,recv 111 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 135 mat has 1603 rows, 7512 nonzeros, send 111 to 15 nbrs,recv 111 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 136 mat has 1603 rows, 7487 nonzeros, send 115 to 16 nbrs,recv 108 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 137 mat has 1575 rows, 7137 nonzeros, send 94 to 11 nbrs,recv 79 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 138 mat has 1465 rows, 6767 nonzeros, send 69 to 7 nbrs,recv 72 from 8 nbrs
MatMultTranspose_MPIAIJ: on rank 139 mat has 1575 rows, 7319 nonzeros, send 96 to 9 nbrs,recv 89 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 140 mat has 1575 rows, 7292 nonzeros, send 96 to 10 nbrs,recv 86 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 141 mat has 1575 rows, 7292 nonzeros, send 96 to 10 nbrs,recv 86 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 142 mat has 1575 rows, 7328 nonzeros, send 96 to 10 nbrs,recv 86 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 143 mat has 1561 rows, 7054 nonzeros, send 92 to 9 nbrs,recv 55 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 144 mat has 1392 rows, 6676 nonzeros, send 55 to 8 nbrs,recv 83 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 145 mat has 1497 rows, 6974 nonzeros, send 81 to 12 nbrs,recv 98 from 13 nbrs
MatMultTranspose_MPIAIJ: on rank 146 mat has 1497 rows, 6950 nonzeros, send 83 to 12 nbrs,recv 96 from 13 nbrs
MatMultTranspose_MPIAIJ: on rank 147 mat has 1497 rows, 6950 nonzeros, send 83 to 12 nbrs,recv 96 from 13 nbrs
MatMultTranspose_MPIAIJ: on rank 148 mat has 1497 rows, 6990 nonzeros, send 83 to 12 nbrs,recv 98 from 13 nbrs
MatMultTranspose_MPIAIJ: on rank 149 mat has 1477 rows, 6785 nonzeros, send 71 to 7 nbrs,recv 73 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 150 mat has 1490 rows, 6965 nonzeros, send 79 to 12 nbrs,recv 95 from 13 nbrs
MatMultTranspose_MPIAIJ: on rank 151 mat has 1603 rows, 7508 nonzeros, send 117 to 16 nbrs,recv 114 from 16 nbrs
MatMultTranspose_MPIAIJ: on rank 152 mat has 1603 rows, 7545 nonzeros, send 117 to 16 nbrs,recv 114 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 153 mat has 1603 rows, 7545 nonzeros, send 117 to 16 nbrs,recv 114 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 154 mat has 1603 rows, 7537 nonzeros, send 120 to 17 nbrs,recv 110 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 155 mat has 1575 rows, 7106 nonzeros, send 96 to 12 nbrs,recv 82 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 156 mat has 1490 rows, 7000 nonzeros, send 81 to 12 nbrs,recv 97 from 14 nbrs
MatMultTranspose_MPIAIJ: on rank 157 mat has 1603 rows, 7563 nonzeros, send 110 to 15 nbrs,recv 116 from 16 nbrs
MatMultTranspose_MPIAIJ: on rank 158 mat has 1603 rows, 7512 nonzeros, send 111 to 15 nbrs,recv 111 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 159 mat has 1603 rows, 7512 nonzeros, send 111 to 15 nbrs,recv 111 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 160 mat has 1603 rows, 7487 nonzeros, send 115 to 16 nbrs,recv 108 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 161 mat has 1575 rows, 7137 nonzeros, send 94 to 11 nbrs,recv 79 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 162 mat has 1490 rows, 7000 nonzeros, send 81 to 12 nbrs,recv 97 from 14 nbrs
MatMultTranspose_MPIAIJ: on rank 163 mat has 1603 rows, 7563 nonzeros, send 110 to 15 nbrs,recv 116 from 16 nbrs
MatMultTranspose_MPIAIJ: on rank 164 mat has 1603 rows, 7512 nonzeros, send 111 to 15 nbrs,recv 111 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 165 mat has 1603 rows, 7512 nonzeros, send 111 to 15 nbrs,recv 111 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 166 mat has 1603 rows, 7487 nonzeros, send 115 to 16 nbrs,recv 108 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 167 mat has 1575 rows, 7137 nonzeros, send 94 to 11 nbrs,recv 79 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 168 mat has 1490 rows, 7001 nonzeros, send 81 to 12 nbrs,recv 97 from 14 nbrs
MatMultTranspose_MPIAIJ: on rank 169 mat has 1603 rows, 7563 nonzeros, send 110 to 15 nbrs,recv 116 from 16 nbrs
MatMultTranspose_MPIAIJ: on rank 170 mat has 1603 rows, 7512 nonzeros, send 111 to 15 nbrs,recv 111 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 171 mat has 1603 rows, 7512 nonzeros, send 111 to 15 nbrs,recv 111 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 172 mat has 1603 rows, 7487 nonzeros, send 115 to 16 nbrs,recv 108 from 15 nbrs
MatMultTranspose_MPIAIJ: on rank 173 mat has 1575 rows, 7137 nonzeros, send 94 to 11 nbrs,recv 79 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 174 mat has 1465 rows, 6767 nonzeros, send 69 to 7 nbrs,recv 72 from 8 nbrs
MatMultTranspose_MPIAIJ: on rank 175 mat has 1575 rows, 7319 nonzeros, send 96 to 9 nbrs,recv 89 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 176 mat has 1575 rows, 7292 nonzeros, send 96 to 10 nbrs,recv 86 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 177 mat has 1575 rows, 7292 nonzeros, send 96 to 10 nbrs,recv 86 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 178 mat has 1575 rows, 7328 nonzeros, send 96 to 10 nbrs,recv 86 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 179 mat has 1561 rows, 7054 nonzeros, send 92 to 9 nbrs,recv 55 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 180 mat has 1300 rows, 6091 nonzeros, send 43 to 5 nbrs,recv 60 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 181 mat has 1392 rows, 6561 nonzeros, send 66 to 6 nbrs,recv 72 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 182 mat has 1392 rows, 6451 nonzeros, send 64 to 7 nbrs,recv 68 from 8 nbrs
MatMultTranspose_MPIAIJ: on rank 183 mat has 1392 rows, 6451 nonzeros, send 64 to 7 nbrs,recv 68 from 8 nbrs
MatMultTranspose_MPIAIJ: on rank 184 mat has 1392 rows, 6449 nonzeros, send 67 to 7 nbrs,recv 67 from 8 nbrs
MatMultTranspose_MPIAIJ: on rank 185 mat has 1386 rows, 6298 nonzeros, send 54 to 4 nbrs,recv 50 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 186 mat has 1398 rows, 6431 nonzeros, send 68 to 7 nbrs,recv 67 from 8 nbrs
MatMultTranspose_MPIAIJ: on rank 187 mat has 1497 rows, 7056 nonzeros, send 109 to 12 nbrs,recv 82 from 11 nbrs
MatMultTranspose_MPIAIJ: on rank 188 mat has 1497 rows, 7112 nonzeros, send 109 to 12 nbrs,recv 83 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 189 mat has 1497 rows, 7112 nonzeros, send 109 to 12 nbrs,recv 83 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 190 mat has 1497 rows, 7049 nonzeros, send 107 to 12 nbrs,recv 84 from 8 nbrs
MatMultTranspose_MPIAIJ: on rank 191 mat has 1477 rows, 6938 nonzeros, send 94 to 8 nbrs,recv 54 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 192 mat has 1398 rows, 6467 nonzeros, send 67 to 7 nbrs,recv 69 from 8 nbrs
MatMultTranspose_MPIAIJ: on rank 193 mat has 1497 rows, 7118 nonzeros, send 103 to 11 nbrs,recv 86 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 194 mat has 1497 rows, 7112 nonzeros, send 103 to 11 nbrs,recv 84 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 195 mat has 1497 rows, 7112 nonzeros, send 103 to 11 nbrs,recv 84 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 196 mat has 1497 rows, 7036 nonzeros, send 102 to 11 nbrs,recv 85 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 197 mat has 1477 rows, 6809 nonzeros, send 90 to 8 nbrs,recv 55 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 198 mat has 1398 rows, 6467 nonzeros, send 67 to 7 nbrs,recv 69 from 8 nbrs
MatMultTranspose_MPIAIJ: on rank 199 mat has 1497 rows, 7118 nonzeros, send 103 to 11 nbrs,recv 86 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 200 mat has 1497 rows, 7112 nonzeros, send 103 to 11 nbrs,recv 84 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 201 mat has 1497 rows, 7112 nonzeros, send 103 to 11 nbrs,recv 84 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 202 mat has 1497 rows, 7036 nonzeros, send 102 to 11 nbrs,recv 85 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 203 mat has 1477 rows, 6809 nonzeros, send 90 to 8 nbrs,recv 55 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 204 mat has 1398 rows, 6467 nonzeros, send 67 to 7 nbrs,recv 69 from 8 nbrs
MatMultTranspose_MPIAIJ: on rank 205 mat has 1497 rows, 7119 nonzeros, send 103 to 11 nbrs,recv 87 from 10 nbrs
MatMultTranspose_MPIAIJ: on rank 206 mat has 1497 rows, 7113 nonzeros, send 103 to 11 nbrs,recv 85 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 207 mat has 1497 rows, 7113 nonzeros, send 103 to 11 nbrs,recv 85 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 208 mat has 1497 rows, 7037 nonzeros, send 102 to 11 nbrs,recv 86 from 9 nbrs
MatMultTranspose_MPIAIJ: on rank 209 mat has 1477 rows, 6809 nonzeros, send 90 to 8 nbrs,recv 55 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 210 mat has 1380 rows, 6432 nonzeros, send 56 to 4 nbrs,recv 50 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 211 mat has 1477 rows, 6882 nonzeros, send 99 to 8 nbrs,recv 65 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 212 mat has 1477 rows, 6869 nonzeros, send 96 to 8 nbrs,recv 65 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 213 mat has 1477 rows, 6869 nonzeros, send 96 to 8 nbrs,recv 65 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 214 mat has 1477 rows, 6891 nonzeros, send 96 to 8 nbrs,recv 64 from 7 nbrs
MatMultTranspose_MPIAIJ: on rank 215 mat has 1470 rows, 6924 nonzeros, send 87 to 7 nbrs,recv 34 from 4 nbrs
Entering MG level 3
MatSOR_MPIAIJ: on rank 0 mat has 59 rows, 3423 nonzeros, send 150 to 7 nbrs,recv 187 from 7 nbrs
MatSOR_MPIAIJ: on rank 1 mat has 61 rows, 4204 nonzeros, send 230 to 11 nbrs,recv 235 from 11 nbrs
MatSOR_MPIAIJ: on rank 2 mat has 62 rows, 4416 nonzeros, send 249 to 11 nbrs,recv 247 from 11 nbrs
MatSOR_MPIAIJ: on rank 3 mat has 62 rows, 4410 nonzeros, send 249 to 11 nbrs,recv 247 from 11 nbrs
MatSOR_MPIAIJ: on rank 4 mat has 62 rows, 4428 nonzeros, send 250 to 11 nbrs,recv 244 from 11 nbrs
MatSOR_MPIAIJ: on rank 5 mat has 70 rows, 4301 nonzeros, send 183 to 7 nbrs,recv 178 from 7 nbrs
MatSOR_MPIAIJ: on rank 6 mat has 63 rows, 4233 nonzeros, send 236 to 11 nbrs,recv 244 from 11 nbrs
MatSOR_MPIAIJ: on rank 7 mat has 64 rows, 5065 nonzeros, send 335 to 17 nbrs,recv 345 from 17 nbrs
MatSOR_MPIAIJ: on rank 8 mat has 67 rows, 5449 nonzeros, send 344 to 17 nbrs,recv 363 from 17 nbrs
MatSOR_MPIAIJ: on rank 9 mat has 67 rows, 5460 nonzeros, send 344 to 17 nbrs,recv 367 from 17 nbrs
MatSOR_MPIAIJ: on rank 10 mat has 67 rows, 5447 nonzeros, send 345 to 17 nbrs,recv 367 from 17 nbrs
MatSOR_MPIAIJ: on rank 11 mat has 70 rows, 4812 nonzeros, send 238 to 11 nbrs,recv 261 from 11 nbrs
MatSOR_MPIAIJ: on rank 12 mat has 61 rows, 4135 nonzeros, send 233 to 11 nbrs,recv 243 from 11 nbrs
MatSOR_MPIAIJ: on rank 13 mat has 64 rows, 5023 nonzeros, send 332 to 17 nbrs,recv 357 from 17 nbrs
MatSOR_MPIAIJ: on rank 14 mat has 64 rows, 5042 nonzeros, send 331 to 17 nbrs,recv 376 from 17 nbrs
MatSOR_MPIAIJ: on rank 15 mat has 64 rows, 5055 nonzeros, send 331 to 17 nbrs,recv 379 from 17 nbrs
MatSOR_MPIAIJ: on rank 16 mat has 64 rows, 5030 nonzeros, send 329 to 17 nbrs,recv 370 from 17 nbrs
MatSOR_MPIAIJ: on rank 17 mat has 70 rows, 4748 nonzeros, send 248 to 11 nbrs,recv 256 from 11 nbrs
MatSOR_MPIAIJ: on rank 18 mat has 61 rows, 4092 nonzeros, send 232 to 11 nbrs,recv 241 from 11 nbrs
MatSOR_MPIAIJ: on rank 19 mat has 64 rows, 5001 nonzeros, send 329 to 17 nbrs,recv 351 from 17 nbrs
MatSOR_MPIAIJ: on rank 20 mat has 64 rows, 5034 nonzeros, send 334 to 17 nbrs,recv 374 from 17 nbrs
MatSOR_MPIAIJ: on rank 21 mat has 64 rows, 5048 nonzeros, send 334 to 17 nbrs,recv 377 from 17 nbrs
MatSOR_MPIAIJ: on rank 22 mat has 64 rows, 5013 nonzeros, send 331 to 17 nbrs,recv 368 from 17 nbrs
MatSOR_MPIAIJ: on rank 23 mat has 70 rows, 4747 nonzeros, send 248 to 11 nbrs,recv 256 from 11 nbrs
MatSOR_MPIAIJ: on rank 24 mat has 61 rows, 4096 nonzeros, send 232 to 11 nbrs,recv 244 from 11 nbrs
MatSOR_MPIAIJ: on rank 25 mat has 64 rows, 5000 nonzeros, send 329 to 17 nbrs,recv 348 from 17 nbrs
MatSOR_MPIAIJ: on rank 26 mat has 64 rows, 5017 nonzeros, send 334 to 17 nbrs,recv 368 from 17 nbrs
MatSOR_MPIAIJ: on rank 27 mat has 64 rows, 5028 nonzeros, send 334 to 17 nbrs,recv 369 from 17 nbrs
MatSOR_MPIAIJ: on rank 28 mat has 64 rows, 5001 nonzeros, send 331 to 17 nbrs,recv 365 from 17 nbrs
MatSOR_MPIAIJ: on rank 29 mat has 70 rows, 4747 nonzeros, send 248 to 11 nbrs,recv 256 from 11 nbrs
MatSOR_MPIAIJ: on rank 30 mat has 69 rows, 4088 nonzeros, send 177 to 7 nbrs,recv 175 from 7 nbrs
MatSOR_MPIAIJ: on rank 31 mat has 70 rows, 4859 nonzeros, send 256 to 11 nbrs,recv 246 from 11 nbrs
MatSOR_MPIAIJ: on rank 32 mat has 69 rows, 4799 nonzeros, send 248 to 11 nbrs,recv 254 from 11 nbrs
MatSOR_MPIAIJ: on rank 33 mat has 69 rows, 4810 nonzeros, send 247 to 11 nbrs,recv 258 from 11 nbrs
MatSOR_MPIAIJ: on rank 34 mat has 70 rows, 4837 nonzeros, send 244 to 11 nbrs,recv 262 from 11 nbrs
MatSOR_MPIAIJ: on rank 35 mat has 80 rows, 4925 nonzeros, send 200 to 7 nbrs,recv 187 from 7 nbrs
MatSOR_MPIAIJ: on rank 36 mat has 61 rows, 4039 nonzeros, send 220 to 11 nbrs,recv 241 from 11 nbrs
MatSOR_MPIAIJ: on rank 37 mat has 65 rows, 5024 nonzeros, send 324 to 17 nbrs,recv 324 from 17 nbrs
MatSOR_MPIAIJ: on rank 38 mat has 64 rows, 5078 nonzeros, send 332 to 17 nbrs,recv 333 from 17 nbrs
MatSOR_MPIAIJ: on rank 39 mat has 64 rows, 5079 nonzeros, send 332 to 17 nbrs,recv 332 from 17 nbrs
MatSOR_MPIAIJ: on rank 40 mat has 63 rows, 4982 nonzeros, send 329 to 17 nbrs,recv 330 from 17 nbrs
MatSOR_MPIAIJ: on rank 41 mat has 71 rows, 4979 nonzeros, send 254 to 11 nbrs,recv 243 from 11 nbrs
MatSOR_MPIAIJ: on rank 42 mat has 59 rows, 4536 nonzeros, send 305 to 17 nbrs,recv 325 from 17 nbrs
MatSOR_MPIAIJ: on rank 43 mat has 66 rows, 5836 nonzeros, send 444 to 26 nbrs,recv 450 from 26 nbrs
MatSOR_MPIAIJ: on rank 44 mat has 66 rows, 5954 nonzeros, send 448 to 26 nbrs,recv 461 from 26 nbrs
MatSOR_MPIAIJ: on rank 45 mat has 66 rows, 5955 nonzeros, send 448 to 26 nbrs,recv 460 from 26 nbrs
MatSOR_MPIAIJ: on rank 46 mat has 65 rows, 5850 nonzeros, send 437 to 26 nbrs,recv 453 from 26 nbrs
MatSOR_MPIAIJ: on rank 47 mat has 69 rows, 5472 nonzeros, send 338 to 17 nbrs,recv 349 from 17 nbrs
MatSOR_MPIAIJ: on rank 48 mat has 60 rows, 4602 nonzeros, send 300 to 17 nbrs,recv 338 from 17 nbrs
MatSOR_MPIAIJ: on rank 49 mat has 66 rows, 5866 nonzeros, send 456 to 26 nbrs,recv 443 from 26 nbrs
MatSOR_MPIAIJ: on rank 50 mat has 66 rows, 5924 nonzeros, send 459 to 26 nbrs,recv 445 from 26 nbrs
MatSOR_MPIAIJ: on rank 51 mat has 66 rows, 5930 nonzeros, send 463 to 26 nbrs,recv 445 from 26 nbrs
MatSOR_MPIAIJ: on rank 52 mat has 65 rows, 5842 nonzeros, send 456 to 26 nbrs,recv 436 from 26 nbrs
MatSOR_MPIAIJ: on rank 53 mat has 70 rows, 5594 nonzeros, send 363 to 17 nbrs,recv 347 from 17 nbrs
MatSOR_MPIAIJ: on rank 54 mat has 60 rows, 4600 nonzeros, send 301 to 17 nbrs,recv 335 from 17 nbrs
MatSOR_MPIAIJ: on rank 55 mat has 66 rows, 5850 nonzeros, send 458 to 26 nbrs,recv 442 from 26 nbrs
MatSOR_MPIAIJ: on rank 56 mat has 66 rows, 5896 nonzeros, send 466 to 26 nbrs,recv 439 from 26 nbrs
MatSOR_MPIAIJ: on rank 57 mat has 66 rows, 5902 nonzeros, send 470 to 26 nbrs,recv 439 from 26 nbrs
MatSOR_MPIAIJ: on rank 58 mat has 65 rows, 5826 nonzeros, send 458 to 26 nbrs,recv 430 from 26 nbrs
MatSOR_MPIAIJ: on rank 59 mat has 70 rows, 5595 nonzeros, send 363 to 17 nbrs,recv 348 from 17 nbrs
MatSOR_MPIAIJ: on rank 60 mat has 60 rows, 4599 nonzeros, send 301 to 17 nbrs,recv 334 from 17 nbrs
MatSOR_MPIAIJ: on rank 61 mat has 66 rows, 5851 nonzeros, send 457 to 26 nbrs,recv 443 from 26 nbrs
MatSOR_MPIAIJ: on rank 62 mat has 66 rows, 5893 nonzeros, send 464 to 26 nbrs,recv 439 from 26 nbrs
MatSOR_MPIAIJ: on rank 63 mat has 66 rows, 5899 nonzeros, send 468 to 26 nbrs,recv 439 from 26 nbrs
MatSOR_MPIAIJ: on rank 64 mat has 65 rows, 5831 nonzeros, send 457 to 26 nbrs,recv 433 from 26 nbrs
MatSOR_MPIAIJ: on rank 65 mat has 70 rows, 5597 nonzeros, send 361 to 17 nbrs,recv 350 from 17 nbrs
MatSOR_MPIAIJ: on rank 66 mat has 68 rows, 4617 nonzeros, send 240 to 11 nbrs,recv 259 from 11 nbrs
MatSOR_MPIAIJ: on rank 67 mat has 72 rows, 5752 nonzeros, send 358 to 17 nbrs,recv 346 from 17 nbrs
MatSOR_MPIAIJ: on rank 68 mat has 72 rows, 5774 nonzeros, send 365 to 17 nbrs,recv 341 from 17 nbrs
MatSOR_MPIAIJ: on rank 69 mat has 72 rows, 5773 nonzeros, send 365 to 17 nbrs,recv 343 from 17 nbrs
MatSOR_MPIAIJ: on rank 70 mat has 72 rows, 5821 nonzeros, send 360 to 17 nbrs,recv 339 from 17 nbrs
MatSOR_MPIAIJ: on rank 71 mat has 84 rows, 5942 nonzeros, send 300 to 11 nbrs,recv 270 from 11 nbrs
MatSOR_MPIAIJ: on rank 72 mat has 62 rows, 4246 nonzeros, send 243 to 11 nbrs,recv 242 from 11 nbrs
MatSOR_MPIAIJ: on rank 73 mat has 62 rows, 4852 nonzeros, send 316 to 17 nbrs,recv 328 from 17 nbrs
MatSOR_MPIAIJ: on rank 74 mat has 61 rows, 4755 nonzeros, send 325 to 17 nbrs,recv 333 from 17 nbrs
MatSOR_MPIAIJ: on rank 75 mat has 61 rows, 4755 nonzeros, send 325 to 17 nbrs,recv 333 from 17 nbrs
MatSOR_MPIAIJ: on rank 76 mat has 61 rows, 4731 nonzeros, send 325 to 17 nbrs,recv 329 from 17 nbrs
MatSOR_MPIAIJ: on rank 77 mat has 71 rows, 4865 nonzeros, send 252 to 11 nbrs,recv 249 from 11 nbrs
MatSOR_MPIAIJ: on rank 78 mat has 61 rows, 4683 nonzeros, send 308 to 17 nbrs,recv 327 from 17 nbrs
MatSOR_MPIAIJ: on rank 79 mat has 66 rows, 5852 nonzeros, send 436 to 26 nbrs,recv 444 from 26 nbrs
MatSOR_MPIAIJ: on rank 80 mat has 66 rows, 5889 nonzeros, send 439 to 26 nbrs,recv 446 from 26 nbrs
MatSOR_MPIAIJ: on rank 81 mat has 66 rows, 5889 nonzeros, send 439 to 26 nbrs,recv 446 from 26 nbrs
MatSOR_MPIAIJ: on rank 82 mat has 67 rows, 5937 nonzeros, send 442 to 26 nbrs,recv 447 from 26 nbrs
MatSOR_MPIAIJ: on rank 83 mat has 70 rows, 5401 nonzeros, send 337 to 17 nbrs,recv 345 from 17 nbrs
MatSOR_MPIAIJ: on rank 84 mat has 62 rows, 4713 nonzeros, send 301 to 17 nbrs,recv 330 from 17 nbrs
MatSOR_MPIAIJ: on rank 85 mat has 65 rows, 5788 nonzeros, send 442 to 26 nbrs,recv 429 from 26 nbrs
MatSOR_MPIAIJ: on rank 86 mat has 65 rows, 5760 nonzeros, send 435 to 26 nbrs,recv 438 from 26 nbrs
MatSOR_MPIAIJ: on rank 87 mat has 65 rows, 5760 nonzeros, send 435 to 26 nbrs,recv 438 from 26 nbrs
MatSOR_MPIAIJ: on rank 88 mat has 66 rows, 5807 nonzeros, send 439 to 26 nbrs,recv 439 from 26 nbrs
MatSOR_MPIAIJ: on rank 89 mat has 71 rows, 5476 nonzeros, send 348 to 17 nbrs,recv 348 from 17 nbrs
MatSOR_MPIAIJ: on rank 90 mat has 62 rows, 4713 nonzeros, send 301 to 17 nbrs,recv 330 from 17 nbrs
MatSOR_MPIAIJ: on rank 91 mat has 65 rows, 5788 nonzeros, send 442 to 26 nbrs,recv 429 from 26 nbrs
MatSOR_MPIAIJ: on rank 92 mat has 65 rows, 5760 nonzeros, send 435 to 26 nbrs,recv 438 from 26 nbrs
MatSOR_MPIAIJ: on rank 93 mat has 65 rows, 5760 nonzeros, send 435 to 26 nbrs,recv 438 from 26 nbrs
MatSOR_MPIAIJ: on rank 94 mat has 66 rows, 5807 nonzeros, send 439 to 26 nbrs,recv 439 from 26 nbrs
MatSOR_MPIAIJ: on rank 95 mat has 71 rows, 5477 nonzeros, send 348 to 17 nbrs,recv 347 from 17 nbrs
MatSOR_MPIAIJ: on rank 96 mat has 62 rows, 4705 nonzeros, send 301 to 17 nbrs,recv 327 from 17 nbrs
MatSOR_MPIAIJ: on rank 97 mat has 65 rows, 5775 nonzeros, send 440 to 26 nbrs,recv 427 from 26 nbrs
MatSOR_MPIAIJ: on rank 98 mat has 65 rows, 5747 nonzeros, send 433 to 26 nbrs,recv 435 from 26 nbrs
MatSOR_MPIAIJ: on rank 99 mat has 65 rows, 5747 nonzeros, send 433 to 26 nbrs,recv 435 from 26 nbrs
MatSOR_MPIAIJ: on rank 100 mat has 66 rows, 5797 nonzeros, send 437 to 26 nbrs,recv 438 from 26 nbrs
MatSOR_MPIAIJ: on rank 101 mat has 71 rows, 5480 nonzeros, send 348 to 17 nbrs,recv 347 from 17 nbrs
MatSOR_MPIAIJ: on rank 102 mat has 69 rows, 4602 nonzeros, send 232 to 11 nbrs,recv 248 from 11 nbrs
MatSOR_MPIAIJ: on rank 103 mat has 71 rows, 5555 nonzeros, send 343 to 17 nbrs,recv 323 from 17 nbrs
MatSOR_MPIAIJ: on rank 104 mat has 71 rows, 5506 nonzeros, send 344 to 17 nbrs,recv 329 from 17 nbrs
MatSOR_MPIAIJ: on rank 105 mat has 71 rows, 5506 nonzeros, send 344 to 17 nbrs,recv 329 from 17 nbrs
MatSOR_MPIAIJ: on rank 106 mat has 72 rows, 5558 nonzeros, send 344 to 17 nbrs,recv 327 from 17 nbrs
MatSOR_MPIAIJ: on rank 107 mat has 82 rows, 5714 nonzeros, send 282 to 11 nbrs,recv 268 from 11 nbrs
MatSOR_MPIAIJ: on rank 108 mat has 62 rows, 4266 nonzeros, send 241 to 11 nbrs,recv 245 from 11 nbrs
MatSOR_MPIAIJ: on rank 109 mat has 62 rows, 4815 nonzeros, send 318 to 17 nbrs,recv 327 from 17 nbrs
MatSOR_MPIAIJ: on rank 110 mat has 61 rows, 4696 nonzeros, send 317 to 17 nbrs,recv 326 from 17 nbrs
MatSOR_MPIAIJ: on rank 111 mat has 61 rows, 4696 nonzeros, send 317 to 17 nbrs,recv 326 from 17 nbrs
MatSOR_MPIAIJ: on rank 112 mat has 61 rows, 4721 nonzeros, send 321 to 17 nbrs,recv 327 from 17 nbrs
MatSOR_MPIAIJ: on rank 113 mat has 71 rows, 4828 nonzeros, send 254 to 11 nbrs,recv 241 from 11 nbrs
MatSOR_MPIAIJ: on rank 114 mat has 61 rows, 4706 nonzeros, send 305 to 17 nbrs,recv 327 from 17 nbrs
MatSOR_MPIAIJ: on rank 115 mat has 66 rows, 5853 nonzeros, send 431 to 26 nbrs,recv 447 from 26 nbrs
MatSOR_MPIAIJ: on rank 116 mat has 66 rows, 5888 nonzeros, send 434 to 26 nbrs,recv 446 from 26 nbrs
MatSOR_MPIAIJ: on rank 117 mat has 66 rows, 5888 nonzeros, send 434 to 26 nbrs,recv 446 from 26 nbrs
MatSOR_MPIAIJ: on rank 118 mat has 67 rows, 5946 nonzeros, send 440 to 26 nbrs,recv 445 from 26 nbrs
MatSOR_MPIAIJ: on rank 119 mat has 70 rows, 5344 nonzeros, send 332 to 17 nbrs,recv 340 from 17 nbrs
MatSOR_MPIAIJ: on rank 120 mat has 62 rows, 4734 nonzeros, send 306 to 17 nbrs,recv 328 from 17 nbrs
MatSOR_MPIAIJ: on rank 121 mat has 65 rows, 5783 nonzeros, send 445 to 26 nbrs,recv 429 from 26 nbrs
MatSOR_MPIAIJ: on rank 122 mat has 65 rows, 5727 nonzeros, send 433 to 26 nbrs,recv 433 from 26 nbrs
MatSOR_MPIAIJ: on rank 123 mat has 65 rows, 5727 nonzeros, send 433 to 26 nbrs,recv 433 from 26 nbrs
MatSOR_MPIAIJ: on rank 124 mat has 66 rows, 5787 nonzeros, send 438 to 26 nbrs,recv 435 from 26 nbrs
MatSOR_MPIAIJ: on rank 125 mat has 71 rows, 5433 nonzeros, send 342 to 17 nbrs,recv 339 from 17 nbrs
MatSOR_MPIAIJ: on rank 126 mat has 62 rows, 4734 nonzeros, send 306 to 17 nbrs,recv 328 from 17 nbrs
MatSOR_MPIAIJ: on rank 127 mat has 65 rows, 5783 nonzeros, send 445 to 26 nbrs,recv 429 from 26 nbrs
MatSOR_MPIAIJ: on rank 128 mat has 65 rows, 5727 nonzeros, send 433 to 26 nbrs,recv 433 from 26 nbrs
MatSOR_MPIAIJ: on rank 129 mat has 65 rows, 5727 nonzeros, send 433 to 26 nbrs,recv 433 from 26 nbrs
MatSOR_MPIAIJ: on rank 130 mat has 66 rows, 5787 nonzeros, send 438 to 26 nbrs,recv 435 from 26 nbrs
MatSOR_MPIAIJ: on rank 131 mat has 71 rows, 5436 nonzeros, send 342 to 17 nbrs,recv 339 from 17 nbrs
MatSOR_MPIAIJ: on rank 132 mat has 62 rows, 4724 nonzeros, send 306 to 17 nbrs,recv 326 from 17 nbrs
MatSOR_MPIAIJ: on rank 133 mat has 65 rows, 5770 nonzeros, send 445 to 26 nbrs,recv 424 from 26 nbrs
MatSOR_MPIAIJ: on rank 134 mat has 65 rows, 5714 nonzeros, send 433 to 26 nbrs,recv 427 from 26 nbrs
MatSOR_MPIAIJ: on rank 135 mat has 65 rows, 5714 nonzeros, send 433 to 26 nbrs,recv 427 from 26 nbrs
MatSOR_MPIAIJ: on rank 136 mat has 66 rows, 5780 nonzeros, send 438 to 26 nbrs,recv 433 from 26 nbrs
MatSOR_MPIAIJ: on rank 137 mat has 71 rows, 5438 nonzeros, send 342 to 17 nbrs,recv 340 from 17 nbrs
MatSOR_MPIAIJ: on rank 138 mat has 69 rows, 4637 nonzeros, send 238 to 11 nbrs,recv 251 from 11 nbrs
MatSOR_MPIAIJ: on rank 139 mat has 71 rows, 5583 nonzeros, send 350 to 17 nbrs,recv 326 from 17 nbrs
MatSOR_MPIAIJ: on rank 140 mat has 71 rows, 5529 nonzeros, send 346 to 17 nbrs,recv 331 from 17 nbrs
MatSOR_MPIAIJ: on rank 141 mat has 71 rows, 5529 nonzeros, send 346 to 17 nbrs,recv 331 from 17 nbrs
MatSOR_MPIAIJ: on rank 142 mat has 72 rows, 5588 nonzeros, send 350 to 17 nbrs,recv 328 from 17 nbrs
MatSOR_MPIAIJ: on rank 143 mat has 82 rows, 5660 nonzeros, send 283 to 11 nbrs,recv 267 from 11 nbrs
MatSOR_MPIAIJ: on rank 144 mat has 62 rows, 4265 nonzeros, send 241 to 11 nbrs,recv 244 from 11 nbrs
MatSOR_MPIAIJ: on rank 145 mat has 62 rows, 4815 nonzeros, send 318 to 17 nbrs,recv 327 from 17 nbrs
MatSOR_MPIAIJ: on rank 146 mat has 61 rows, 4696 nonzeros, send 317 to 17 nbrs,recv 326 from 17 nbrs
MatSOR_MPIAIJ: on rank 147 mat has 61 rows, 4696 nonzeros, send 317 to 17 nbrs,recv 326 from 17 nbrs
MatSOR_MPIAIJ: on rank 148 mat has 61 rows, 4721 nonzeros, send 321 to 17 nbrs,recv 327 from 17 nbrs
MatSOR_MPIAIJ: on rank 149 mat has 71 rows, 4828 nonzeros, send 254 to 11 nbrs,recv 241 from 11 nbrs
MatSOR_MPIAIJ: on rank 150 mat has 61 rows, 4706 nonzeros, send 305 to 17 nbrs,recv 327 from 17 nbrs
MatSOR_MPIAIJ: on rank 151 mat has 66 rows, 5853 nonzeros, send 431 to 26 nbrs,recv 447 from 26 nbrs
MatSOR_MPIAIJ: on rank 152 mat has 66 rows, 5888 nonzeros, send 434 to 26 nbrs,recv 446 from 26 nbrs
MatSOR_MPIAIJ: on rank 153 mat has 66 rows, 5888 nonzeros, send 434 to 26 nbrs,recv 446 from 26 nbrs
MatSOR_MPIAIJ: on rank 154 mat has 67 rows, 5946 nonzeros, send 440 to 26 nbrs,recv 445 from 26 nbrs
MatSOR_MPIAIJ: on rank 155 mat has 70 rows, 5344 nonzeros, send 332 to 17 nbrs,recv 340 from 17 nbrs
MatSOR_MPIAIJ: on rank 156 mat has 62 rows, 4734 nonzeros, send 306 to 17 nbrs,recv 328 from 17 nbrs
MatSOR_MPIAIJ: on rank 157 mat has 65 rows, 5783 nonzeros, send 445 to 26 nbrs,recv 429 from 26 nbrs
MatSOR_MPIAIJ: on rank 158 mat has 65 rows, 5727 nonzeros, send 433 to 26 nbrs,recv 433 from 26 nbrs
MatSOR_MPIAIJ: on rank 159 mat has 65 rows, 5727 nonzeros, send 433 to 26 nbrs,recv 433 from 26 nbrs
MatSOR_MPIAIJ: on rank 160 mat has 66 rows, 5787 nonzeros, send 438 to 26 nbrs,recv 435 from 26 nbrs
MatSOR_MPIAIJ: on rank 161 mat has 71 rows, 5433 nonzeros, send 342 to 17 nbrs,recv 339 from 17 nbrs
MatSOR_MPIAIJ: on rank 162 mat has 62 rows, 4734 nonzeros, send 306 to 17 nbrs,recv 328 from 17 nbrs
MatSOR_MPIAIJ: on rank 163 mat has 65 rows, 5783 nonzeros, send 445 to 26 nbrs,recv 429 from 26 nbrs
MatSOR_MPIAIJ: on rank 164 mat has 65 rows, 5727 nonzeros, send 433 to 26 nbrs,recv 433 from 26 nbrs
MatSOR_MPIAIJ: on rank 165 mat has 65 rows, 5727 nonzeros, send 433 to 26 nbrs,recv 433 from 26 nbrs
MatSOR_MPIAIJ: on rank 166 mat has 66 rows, 5787 nonzeros, send 438 to 26 nbrs,recv 435 from 26 nbrs
MatSOR_MPIAIJ: on rank 167 mat has 71 rows, 5436 nonzeros, send 342 to 17 nbrs,recv 339 from 17 nbrs
MatSOR_MPIAIJ: on rank 168 mat has 62 rows, 4724 nonzeros, send 306 to 17 nbrs,recv 326 from 17 nbrs
MatSOR_MPIAIJ: on rank 169 mat has 65 rows, 5770 nonzeros, send 445 to 26 nbrs,recv 424 from 26 nbrs
MatSOR_MPIAIJ: on rank 170 mat has 65 rows, 5714 nonzeros, send 433 to 26 nbrs,recv 427 from 26 nbrs
MatSOR_MPIAIJ: on rank 171 mat has 65 rows, 5714 nonzeros, send 433 to 26 nbrs,recv 427 from 26 nbrs
MatSOR_MPIAIJ: on rank 172 mat has 66 rows, 5780 nonzeros, send 438 to 26 nbrs,recv 433 from 26 nbrs
MatSOR_MPIAIJ: on rank 173 mat has 71 rows, 5438 nonzeros, send 342 to 17 nbrs,recv 340 from 17 nbrs
MatSOR_MPIAIJ: on rank 174 mat has 69 rows, 4637 nonzeros, send 238 to 11 nbrs,recv 251 from 11 nbrs
MatSOR_MPIAIJ: on rank 175 mat has 71 rows, 5583 nonzeros, send 350 to 17 nbrs,recv 326 from 17 nbrs
MatSOR_MPIAIJ: on rank 176 mat has 71 rows, 5529 nonzeros, send 346 to 17 nbrs,recv 331 from 17 nbrs
MatSOR_MPIAIJ: on rank 177 mat has 71 rows, 5529 nonzeros, send 346 to 17 nbrs,recv 331 from 17 nbrs
MatSOR_MPIAIJ: on rank 178 mat has 72 rows, 5588 nonzeros, send 350 to 17 nbrs,recv 328 from 17 nbrs
MatSOR_MPIAIJ: on rank 179 mat has 82 rows, 5660 nonzeros, send 283 to 11 nbrs,recv 267 from 11 nbrs
MatSOR_MPIAIJ: on rank 180 mat has 62 rows, 3751 nonzeros, send 167 to 7 nbrs,recv 168 from 7 nbrs
MatSOR_MPIAIJ: on rank 181 mat has 66 rows, 4558 nonzeros, send 238 to 11 nbrs,recv 230 from 11 nbrs
MatSOR_MPIAIJ: on rank 182 mat has 64 rows, 4330 nonzeros, send 234 to 11 nbrs,recv 226 from 11 nbrs
MatSOR_MPIAIJ: on rank 183 mat has 64 rows, 4330 nonzeros, send 234 to 11 nbrs,recv 226 from 11 nbrs
MatSOR_MPIAIJ: on rank 184 mat has 65 rows, 4397 nonzeros, send 242 to 11 nbrs,recv 229 from 11 nbrs
MatSOR_MPIAIJ: on rank 185 mat has 75 rows, 4523 nonzeros, send 184 to 7 nbrs,recv 166 from 7 nbrs
MatSOR_MPIAIJ: on rank 186 mat has 68 rows, 4606 nonzeros, send 240 to 11 nbrs,recv 241 from 11 nbrs
MatSOR_MPIAIJ: on rank 187 mat has 74 rows, 5871 nonzeros, send 348 to 17 nbrs,recv 350 from 17 nbrs
MatSOR_MPIAIJ: on rank 188 mat has 74 rows, 5896 nonzeros, send 354 to 17 nbrs,recv 351 from 17 nbrs
MatSOR_MPIAIJ: on rank 189 mat has 74 rows, 5896 nonzeros, send 354 to 17 nbrs,recv 351 from 17 nbrs
MatSOR_MPIAIJ: on rank 190 mat has 72 rows, 5743 nonzeros, send 343 to 17 nbrs,recv 346 from 17 nbrs
MatSOR_MPIAIJ: on rank 191 mat has 84 rows, 5850 nonzeros, send 283 to 11 nbrs,recv 259 from 11 nbrs
MatSOR_MPIAIJ: on rank 192 mat has 68 rows, 4561 nonzeros, send 245 to 11 nbrs,recv 234 from 11 nbrs
MatSOR_MPIAIJ: on rank 193 mat has 73 rows, 5817 nonzeros, send 364 to 17 nbrs,recv 334 from 17 nbrs
MatSOR_MPIAIJ: on rank 194 mat has 73 rows, 5820 nonzeros, send 359 to 17 nbrs,recv 344 from 17 nbrs
MatSOR_MPIAIJ: on rank 195 mat has 73 rows, 5820 nonzeros, send 359 to 17 nbrs,recv 344 from 17 nbrs
MatSOR_MPIAIJ: on rank 196 mat has 71 rows, 5670 nonzeros, send 347 to 17 nbrs,recv 342 from 17 nbrs
MatSOR_MPIAIJ: on rank 197 mat has 80 rows, 5609 nonzeros, send 282 to 11 nbrs,recv 263 from 11 nbrs
MatSOR_MPIAIJ: on rank 198 mat has 68 rows, 4561 nonzeros, send 245 to 11 nbrs,recv 234 from 11 nbrs
MatSOR_MPIAIJ: on rank 199 mat has 73 rows, 5817 nonzeros, send 364 to 17 nbrs,recv 334 from 17 nbrs
MatSOR_MPIAIJ: on rank 200 mat has 73 rows, 5820 nonzeros, send 359 to 17 nbrs,recv 344 from 17 nbrs
MatSOR_MPIAIJ: on rank 201 mat has 73 rows, 5820 nonzeros, send 359 to 17 nbrs,recv 344 from 17 nbrs
MatSOR_MPIAIJ: on rank 202 mat has 71 rows, 5670 nonzeros, send 347 to 17 nbrs,recv 342 from 17 nbrs
MatSOR_MPIAIJ: on rank 203 mat has 80 rows, 5603 nonzeros, send 282 to 11 nbrs,recv 261 from 11 nbrs
MatSOR_MPIAIJ: on rank 204 mat has 68 rows, 4553 nonzeros, send 245 to 11 nbrs,recv 233 from 11 nbrs
MatSOR_MPIAIJ: on rank 205 mat has 73 rows, 5821 nonzeros, send 364 to 17 nbrs,recv 329 from 17 nbrs
MatSOR_MPIAIJ: on rank 206 mat has 73 rows, 5824 nonzeros, send 359 to 17 nbrs,recv 339 from 17 nbrs
MatSOR_MPIAIJ: on rank 207 mat has 73 rows, 5824 nonzeros, send 359 to 17 nbrs,recv 339 from 17 nbrs
MatSOR_MPIAIJ: on rank 208 mat has 71 rows, 5688 nonzeros, send 347 to 17 nbrs,recv 344 from 17 nbrs
MatSOR_MPIAIJ: on rank 209 mat has 80 rows, 5610 nonzeros, send 283 to 11 nbrs,recv 264 from 11 nbrs
MatSOR_MPIAIJ: on rank 210 mat has 78 rows, 4706 nonzeros, send 177 to 7 nbrs,recv 167 from 7 nbrs
MatSOR_MPIAIJ: on rank 211 mat has 79 rows, 5695 nonzeros, send 289 to 11 nbrs,recv 261 from 11 nbrs
MatSOR_MPIAIJ: on rank 212 mat has 79 rows, 5631 nonzeros, send 282 to 11 nbrs,recv 265 from 11 nbrs
MatSOR_MPIAIJ: on rank 213 mat has 79 rows, 5631 nonzeros, send 282 to 11 nbrs,recv 265 from 11 nbrs
MatSOR_MPIAIJ: on rank 214 mat has 81 rows, 5770 nonzeros, send 285 to 11 nbrs,recv 268 from 11 nbrs
MatSOR_MPIAIJ: on rank 215 mat has 94 rows, 5994 nonzeros, send 229 to 7 nbrs,recv 197 from 7 nbrs
MatMult_MPIAIJ: on rank 0 mat has 59 rows, 3423 nonzeros, send 150 to 7 nbrs,recv 187 from 7 nbrs
MatMult_MPIAIJ: on rank 1 mat has 61 rows, 4204 nonzeros, send 230 to 11 nbrs,recv 235 from 11 nbrs
MatMult_MPIAIJ: on rank 2 mat has 62 rows, 4416 nonzeros, send 249 to 11 nbrs,recv 247 from 11 nbrs
MatMult_MPIAIJ: on rank 3 mat has 62 rows, 4410 nonzeros, send 249 to 11 nbrs,recv 247 from 11 nbrs
MatMult_MPIAIJ: on rank 4 mat has 62 rows, 4428 nonzeros, send 250 to 11 nbrs,recv 244 from 11 nbrs
MatMult_MPIAIJ: on rank 5 mat has 70 rows, 4301 nonzeros, send 183 to 7 nbrs,recv 178 from 7 nbrs
MatMult_MPIAIJ: on rank 6 mat has 63 rows, 4233 nonzeros, send 236 to 11 nbrs,recv 244 from 11 nbrs
MatMult_MPIAIJ: on rank 7 mat has 64 rows, 5065 nonzeros, send 335 to 17 nbrs,recv 345 from 17 nbrs
MatMult_MPIAIJ: on rank 8 mat has 67 rows, 5449 nonzeros, send 344 to 17 nbrs,recv 363 from 17 nbrs
MatMult_MPIAIJ: on rank 9 mat has 67 rows, 5460 nonzeros, send 344 to 17 nbrs,recv 367 from 17 nbrs
MatMult_MPIAIJ: on rank 10 mat has 67 rows, 5447 nonzeros, send 345 to 17 nbrs,recv 367 from 17 nbrs
MatMult_MPIAIJ: on rank 11 mat has 70 rows, 4812 nonzeros, send 238 to 11 nbrs,recv 261 from 11 nbrs
MatMult_MPIAIJ: on rank 12 mat has 61 rows, 4135 nonzeros, send 233 to 11 nbrs,recv 243 from 11 nbrs
MatMult_MPIAIJ: on rank 13 mat has 64 rows, 5023 nonzeros, send 332 to 17 nbrs,recv 357 from 17 nbrs
MatMult_MPIAIJ: on rank 14 mat has 64 rows, 5042 nonzeros, send 331 to 17 nbrs,recv 376 from 17 nbrs
MatMult_MPIAIJ: on rank 15 mat has 64 rows, 5055 nonzeros, send 331 to 17 nbrs,recv 379 from 17 nbrs
MatMult_MPIAIJ: on rank 16 mat has 64 rows, 5030 nonzeros, send 329 to 17 nbrs,recv 370 from 17 nbrs
MatMult_MPIAIJ: on rank 17 mat has 70 rows, 4748 nonzeros, send 248 to 11 nbrs,recv 256 from 11 nbrs
MatMult_MPIAIJ: on rank 18 mat has 61 rows, 4092 nonzeros, send 232 to 11 nbrs,recv 241 from 11 nbrs
MatMult_MPIAIJ: on rank 19 mat has 64 rows, 5001 nonzeros, send 329 to 17 nbrs,recv 351 from 17 nbrs
MatMult_MPIAIJ: on rank 20 mat has 64 rows, 5034 nonzeros, send 334 to 17 nbrs,recv 374 from 17 nbrs
MatMult_MPIAIJ: on rank 21 mat has 64 rows, 5048 nonzeros, send 334 to 17 nbrs,recv 377 from 17 nbrs
MatMult_MPIAIJ: on rank 22 mat has 64 rows, 5013 nonzeros, send 331 to 17 nbrs,recv 368 from 17 nbrs
MatMult_MPIAIJ: on rank 23 mat has 70 rows, 4747 nonzeros, send 248 to 11 nbrs,recv 256 from 11 nbrs
MatMult_MPIAIJ: on rank 24 mat has 61 rows, 4096 nonzeros, send 232 to 11 nbrs,recv 244 from 11 nbrs
MatMult_MPIAIJ: on rank 25 mat has 64 rows, 5000 nonzeros, send 329 to 17 nbrs,recv 348 from 17 nbrs
MatMult_MPIAIJ: on rank 26 mat has 64 rows, 5017 nonzeros, send 334 to 17 nbrs,recv 368 from 17 nbrs
MatMult_MPIAIJ: on rank 27 mat has 64 rows, 5028 nonzeros, send 334 to 17 nbrs,recv 369 from 17 nbrs
MatMult_MPIAIJ: on rank 28 mat has 64 rows, 5001 nonzeros, send 331 to 17 nbrs,recv 365 from 17 nbrs
MatMult_MPIAIJ: on rank 29 mat has 70 rows, 4747 nonzeros, send 248 to 11 nbrs,recv 256 from 11 nbrs
MatMult_MPIAIJ: on rank 30 mat has 69 rows, 4088 nonzeros, send 177 to 7 nbrs,recv 175 from 7 nbrs
MatMult_MPIAIJ: on rank 31 mat has 70 rows, 4859 nonzeros, send 256 to 11 nbrs,recv 246 from 11 nbrs
MatMult_MPIAIJ: on rank 32 mat has 69 rows, 4799 nonzeros, send 248 to 11 nbrs,recv 254 from 11 nbrs
MatMult_MPIAIJ: on rank 33 mat has 69 rows, 4810 nonzeros, send 247 to 11 nbrs,recv 258 from 11 nbrs
MatMult_MPIAIJ: on rank 34 mat has 70 rows, 4837 nonzeros, send 244 to 11 nbrs,recv 262 from 11 nbrs
MatMult_MPIAIJ: on rank 35 mat has 80 rows, 4925 nonzeros, send 200 to 7 nbrs,recv 187 from 7 nbrs
MatMult_MPIAIJ: on rank 36 mat has 61 rows, 4039 nonzeros, send 220 to 11 nbrs,recv 241 from 11 nbrs
MatMult_MPIAIJ: on rank 37 mat has 65 rows, 5024 nonzeros, send 324 to 17 nbrs,recv 324 from 17 nbrs
MatMult_MPIAIJ: on rank 38 mat has 64 rows, 5078 nonzeros, send 332 to 17 nbrs,recv 333 from 17 nbrs
MatMult_MPIAIJ: on rank 39 mat has 64 rows, 5079 nonzeros, send 332 to 17 nbrs,recv 332 from 17 nbrs
MatMult_MPIAIJ: on rank 40 mat has 63 rows, 4982 nonzeros, send 329 to 17 nbrs,recv 330 from 17 nbrs
MatMult_MPIAIJ: on rank 41 mat has 71 rows, 4979 nonzeros, send 254 to 11 nbrs,recv 243 from 11 nbrs
MatMult_MPIAIJ: on rank 42 mat has 59 rows, 4536 nonzeros, send 305 to 17 nbrs,recv 325 from 17 nbrs
MatMult_MPIAIJ: on rank 43 mat has 66 rows, 5836 nonzeros, send 444 to 26 nbrs,recv 450 from 26 nbrs
MatMult_MPIAIJ: on rank 44 mat has 66 rows, 5954 nonzeros, send 448 to 26 nbrs,recv 461 from 26 nbrs
MatMult_MPIAIJ: on rank 45 mat has 66 rows, 5955 nonzeros, send 448 to 26 nbrs,recv 460 from 26 nbrs
MatMult_MPIAIJ: on rank 46 mat has 65 rows, 5850 nonzeros, send 437 to 26 nbrs,recv 453 from 26 nbrs
MatMult_MPIAIJ: on rank 47 mat has 69 rows, 5472 nonzeros, send 338 to 17 nbrs,recv 349 from 17 nbrs
MatMult_MPIAIJ: on rank 48 mat has 60 rows, 4602 nonzeros, send 300 to 17 nbrs,recv 338 from 17 nbrs
MatMult_MPIAIJ: on rank 49 mat has 66 rows, 5866 nonzeros, send 456 to 26 nbrs,recv 443 from 26 nbrs
MatMult_MPIAIJ: on rank 50 mat has 66 rows, 5924 nonzeros, send 459 to 26 nbrs,recv 445 from 26 nbrs
MatMult_MPIAIJ: on rank 51 mat has 66 rows, 5930 nonzeros, send 463 to 26 nbrs,recv 445 from 26 nbrs
MatMult_MPIAIJ: on rank 52 mat has 65 rows, 5842 nonzeros, send 456 to 26 nbrs,recv 436 from 26 nbrs
MatMult_MPIAIJ: on rank 53 mat has 70 rows, 5594 nonzeros, send 363 to 17 nbrs,recv 347 from 17 nbrs
MatMult_MPIAIJ: on rank 54 mat has 60 rows, 4600 nonzeros, send 301 to 17 nbrs,recv 335 from 17 nbrs
MatMult_MPIAIJ: on rank 55 mat has 66 rows, 5850 nonzeros, send 458 to 26 nbrs,recv 442 from 26 nbrs
MatMult_MPIAIJ: on rank 56 mat has 66 rows, 5896 nonzeros, send 466 to 26 nbrs,recv 439 from 26 nbrs
MatMult_MPIAIJ: on rank 57 mat has 66 rows, 5902 nonzeros, send 470 to 26 nbrs,recv 439 from 26 nbrs
MatMult_MPIAIJ: on rank 58 mat has 65 rows, 5826 nonzeros, send 458 to 26 nbrs,recv 430 from 26 nbrs
MatMult_MPIAIJ: on rank 59 mat has 70 rows, 5595 nonzeros, send 363 to 17 nbrs,recv 348 from 17 nbrs
MatMult_MPIAIJ: on rank 60 mat has 60 rows, 4599 nonzeros, send 301 to 17 nbrs,recv 334 from 17 nbrs
MatMult_MPIAIJ: on rank 61 mat has 66 rows, 5851 nonzeros, send 457 to 26 nbrs,recv 443 from 26 nbrs
MatMult_MPIAIJ: on rank 62 mat has 66 rows, 5893 nonzeros, send 464 to 26 nbrs,recv 439 from 26 nbrs
MatMult_MPIAIJ: on rank 63 mat has 66 rows, 5899 nonzeros, send 468 to 26 nbrs,recv 439 from 26 nbrs
MatMult_MPIAIJ: on rank 64 mat has 65 rows, 5831 nonzeros, send 457 to 26 nbrs,recv 433 from 26 nbrs
MatMult_MPIAIJ: on rank 65 mat has 70 rows, 5597 nonzeros, send 361 to 17 nbrs,recv 350 from 17 nbrs
MatMult_MPIAIJ: on rank 66 mat has 68 rows, 4617 nonzeros, send 240 to 11 nbrs,recv 259 from 11 nbrs
MatMult_MPIAIJ: on rank 67 mat has 72 rows, 5752 nonzeros, send 358 to 17 nbrs,recv 346 from 17 nbrs
MatMult_MPIAIJ: on rank 68 mat has 72 rows, 5774 nonzeros, send 365 to 17 nbrs,recv 341 from 17 nbrs
MatMult_MPIAIJ: on rank 69 mat has 72 rows, 5773 nonzeros, send 365 to 17 nbrs,recv 343 from 17 nbrs
MatMult_MPIAIJ: on rank 70 mat has 72 rows, 5821 nonzeros, send 360 to 17 nbrs,recv 339 from 17 nbrs
MatMult_MPIAIJ: on rank 71 mat has 84 rows, 5942 nonzeros, send 300 to 11 nbrs,recv 270 from 11 nbrs
MatMult_MPIAIJ: on rank 72 mat has 62 rows, 4246 nonzeros, send 243 to 11 nbrs,recv 242 from 11 nbrs
MatMult_MPIAIJ: on rank 73 mat has 62 rows, 4852 nonzeros, send 316 to 17 nbrs,recv 328 from 17 nbrs
MatMult_MPIAIJ: on rank 74 mat has 61 rows, 4755 nonzeros, send 325 to 17 nbrs,recv 333 from 17 nbrs
MatMult_MPIAIJ: on rank 75 mat has 61 rows, 4755 nonzeros, send 325 to 17 nbrs,recv 333 from 17 nbrs
MatMult_MPIAIJ: on rank 76 mat has 61 rows, 4731 nonzeros, send 325 to 17 nbrs,recv 329 from 17 nbrs
MatMult_MPIAIJ: on rank 77 mat has 71 rows, 4865 nonzeros, send 252 to 11 nbrs,recv 249 from 11 nbrs
MatMult_MPIAIJ: on rank 78 mat has 61 rows, 4683 nonzeros, send 308 to 17 nbrs,recv 327 from 17 nbrs
MatMult_MPIAIJ: on rank 79 mat has 66 rows, 5852 nonzeros, send 436 to 26 nbrs,recv 444 from 26 nbrs
MatMult_MPIAIJ: on rank 80 mat has 66 rows, 5889 nonzeros, send 439 to 26 nbrs,recv 446 from 26 nbrs
MatMult_MPIAIJ: on rank 81 mat has 66 rows, 5889 nonzeros, send 439 to 26 nbrs,recv 446 from 26 nbrs
MatMult_MPIAIJ: on rank 82 mat has 67 rows, 5937 nonzeros, send 442 to 26 nbrs,recv 447 from 26 nbrs
MatMult_MPIAIJ: on rank 83 mat has 70 rows, 5401 nonzeros, send 337 to 17 nbrs,recv 345 from 17 nbrs
MatMult_MPIAIJ: on rank 84 mat has 62 rows, 4713 nonzeros, send 301 to 17 nbrs,recv 330 from 17 nbrs
MatMult_MPIAIJ: on rank 85 mat has 65 rows, 5788 nonzeros, send 442 to 26 nbrs,recv 429 from 26 nbrs
MatMult_MPIAIJ: on rank 86 mat has 65 rows, 5760 nonzeros, send 435 to 26 nbrs,recv 438 from 26 nbrs
MatMult_MPIAIJ: on rank 87 mat has 65 rows, 5760 nonzeros, send 435 to 26 nbrs,recv 438 from 26 nbrs
MatMult_MPIAIJ: on rank 88 mat has 66 rows, 5807 nonzeros, send 439 to 26 nbrs,recv 439 from 26 nbrs
MatMult_MPIAIJ: on rank 89 mat has 71 rows, 5476 nonzeros, send 348 to 17 nbrs,recv 348 from 17 nbrs
MatMult_MPIAIJ: on rank 90 mat has 62 rows, 4713 nonzeros, send 301 to 17 nbrs,recv 330 from 17 nbrs
MatMult_MPIAIJ: on rank 91 mat has 65 rows, 5788 nonzeros, send 442 to 26 nbrs,recv 429 from 26 nbrs
MatMult_MPIAIJ: on rank 92 mat has 65 rows, 5760 nonzeros, send 435 to 26 nbrs,recv 438 from 26 nbrs
MatMult_MPIAIJ: on rank 93 mat has 65 rows, 5760 nonzeros, send 435 to 26 nbrs,recv 438 from 26 nbrs
MatMult_MPIAIJ: on rank 94 mat has 66 rows, 5807 nonzeros, send 439 to 26 nbrs,recv 439 from 26 nbrs
MatMult_MPIAIJ: on rank 95 mat has 71 rows, 5477 nonzeros, send 348 to 17 nbrs,recv 347 from 17 nbrs
MatMult_MPIAIJ: on rank 96 mat has 62 rows, 4705 nonzeros, send 301 to 17 nbrs,recv 327 from 17 nbrs
MatMult_MPIAIJ: on rank 97 mat has 65 rows, 5775 nonzeros, send 440 to 26 nbrs,recv 427 from 26 nbrs
MatMult_MPIAIJ: on rank 98 mat has 65 rows, 5747 nonzeros, send 433 to 26 nbrs,recv 435 from 26 nbrs
MatMult_MPIAIJ: on rank 99 mat has 65 rows, 5747 nonzeros, send 433 to 26 nbrs,recv 435 from 26 nbrs
MatMult_MPIAIJ: on rank 100 mat has 66 rows, 5797 nonzeros, send 437 to 26 nbrs,recv 438 from 26 nbrs
MatMult_MPIAIJ: on rank 101 mat has 71 rows, 5480 nonzeros, send 348 to 17 nbrs,recv 347 from 17 nbrs
MatMult_MPIAIJ: on rank 102 mat has 69 rows, 4602 nonzeros, send 232 to 11 nbrs,recv 248 from 11 nbrs
MatMult_MPIAIJ: on rank 103 mat has 71 rows, 5555 nonzeros, send 343 to 17 nbrs,recv 323 from 17 nbrs
MatMult_MPIAIJ: on rank 104 mat has 71 rows, 5506 nonzeros, send 344 to 17 nbrs,recv 329 from 17 nbrs
MatMult_MPIAIJ: on rank 105 mat has 71 rows, 5506 nonzeros, send 344 to 17 nbrs,recv 329 from 17 nbrs
MatMult_MPIAIJ: on rank 106 mat has 72 rows, 5558 nonzeros, send 344 to 17 nbrs,recv 327 from 17 nbrs
MatMult_MPIAIJ: on rank 107 mat has 82 rows, 5714 nonzeros, send 282 to 11 nbrs,recv 268 from 11 nbrs
MatMult_MPIAIJ: on rank 108 mat has 62 rows, 4266 nonzeros, send 241 to 11 nbrs,recv 245 from 11 nbrs
MatMult_MPIAIJ: on rank 109 mat has 62 rows, 4815 nonzeros, send 318 to 17 nbrs,recv 327 from 17 nbrs
MatMult_MPIAIJ: on rank 110 mat has 61 rows, 4696 nonzeros, send 317 to 17 nbrs,recv 326 from 17 nbrs
MatMult_MPIAIJ: on rank 111 mat has 61 rows, 4696 nonzeros, send 317 to 17 nbrs,recv 326 from 17 nbrs
MatMult_MPIAIJ: on rank 112 mat has 61 rows, 4721 nonzeros, send 321 to 17 nbrs,recv 327 from 17 nbrs
MatMult_MPIAIJ: on rank 113 mat has 71 rows, 4828 nonzeros, send 254 to 11 nbrs,recv 241 from 11 nbrs
MatMult_MPIAIJ: on rank 114 mat has 61 rows, 4706 nonzeros, send 305 to 17 nbrs,recv 327 from 17 nbrs
MatMult_MPIAIJ: on rank 115 mat has 66 rows, 5853 nonzeros, send 431 to 26 nbrs,recv 447 from 26 nbrs
MatMult_MPIAIJ: on rank 116 mat has 66 rows, 5888 nonzeros, send 434 to 26 nbrs,recv 446 from 26 nbrs
MatMult_MPIAIJ: on rank 117 mat has 66 rows, 5888 nonzeros, send 434 to 26 nbrs,recv 446 from 26 nbrs
MatMult_MPIAIJ: on rank 118 mat has 67 rows, 5946 nonzeros, send 440 to 26 nbrs,recv 445 from 26 nbrs
MatMult_MPIAIJ: on rank 119 mat has 70 rows, 5344 nonzeros, send 332 to 17 nbrs,recv 340 from 17 nbrs
MatMult_MPIAIJ: on rank 120 mat has 62 rows, 4734 nonzeros, send 306 to 17 nbrs,recv 328 from 17 nbrs
MatMult_MPIAIJ: on rank 121 mat has 65 rows, 5783 nonzeros, send 445 to 26 nbrs,recv 429 from 26 nbrs
MatMult_MPIAIJ: on rank 122 mat has 65 rows, 5727 nonzeros, send 433 to 26 nbrs,recv 433 from 26 nbrs
MatMult_MPIAIJ: on rank 123 mat has 65 rows, 5727 nonzeros, send 433 to 26 nbrs,recv 433 from 26 nbrs
MatMult_MPIAIJ: on rank 124 mat has 66 rows, 5787 nonzeros, send 438 to 26 nbrs,recv 435 from 26 nbrs
MatMult_MPIAIJ: on rank 125 mat has 71 rows, 5433 nonzeros, send 342 to 17 nbrs,recv 339 from 17 nbrs
MatMult_MPIAIJ: on rank 126 mat has 62 rows, 4734 nonzeros, send 306 to 17 nbrs,recv 328 from 17 nbrs
MatMult_MPIAIJ: on rank 127 mat has 65 rows, 5783 nonzeros, send 445 to 26 nbrs,recv 429 from 26 nbrs
MatMult_MPIAIJ: on rank 128 mat has 65 rows, 5727 nonzeros, send 433 to 26 nbrs,recv 433 from 26 nbrs
MatMult_MPIAIJ: on rank 129 mat has 65 rows, 5727 nonzeros, send 433 to 26 nbrs,recv 433 from 26 nbrs
MatMult_MPIAIJ: on rank 130 mat has 66 rows, 5787 nonzeros, send 438 to 26 nbrs,recv 435 from 26 nbrs
MatMult_MPIAIJ: on rank 131 mat has 71 rows, 5436 nonzeros, send 342 to 17 nbrs,recv 339 from 17 nbrs
MatMult_MPIAIJ: on rank 132 mat has 62 rows, 4724 nonzeros, send 306 to 17 nbrs,recv 326 from 17 nbrs
MatMult_MPIAIJ: on rank 133 mat has 65 rows, 5770 nonzeros, send 445 to 26 nbrs,recv 424 from 26 nbrs
MatMult_MPIAIJ: on rank 134 mat has 65 rows, 5714 nonzeros, send 433 to 26 nbrs,recv 427 from 26 nbrs
MatMult_MPIAIJ: on rank 135 mat has 65 rows, 5714 nonzeros, send 433 to 26 nbrs,recv 427 from 26 nbrs
MatMult_MPIAIJ: on rank 136 mat has 66 rows, 5780 nonzeros, send 438 to 26 nbrs,recv 433 from 26 nbrs
MatMult_MPIAIJ: on rank 137 mat has 71 rows, 5438 nonzeros, send 342 to 17 nbrs,recv 340 from 17 nbrs
MatMult_MPIAIJ: on rank 138 mat has 69 rows, 4637 nonzeros, send 238 to 11 nbrs,recv 251 from 11 nbrs
MatMult_MPIAIJ: on rank 139 mat has 71 rows, 5583 nonzeros, send 350 to 17 nbrs,recv 326 from 17 nbrs
MatMult_MPIAIJ: on rank 140 mat has 71 rows, 5529 nonzeros, send 346 to 17 nbrs,recv 331 from 17 nbrs
MatMult_MPIAIJ: on rank 141 mat has 71 rows, 5529 nonzeros, send 346 to 17 nbrs,recv 331 from 17 nbrs
MatMult_MPIAIJ: on rank 142 mat has 72 rows, 5588 nonzeros, send 350 to 17 nbrs,recv 328 from 17 nbrs
MatMult_MPIAIJ: on rank 143 mat has 82 rows, 5660 nonzeros, send 283 to 11 nbrs,recv 267 from 11 nbrs
MatMult_MPIAIJ: on rank 144 mat has 62 rows, 4265 nonzeros, send 241 to 11 nbrs,recv 244 from 11 nbrs
MatMult_MPIAIJ: on rank 145 mat has 62 rows, 4815 nonzeros, send 318 to 17 nbrs,recv 327 from 17 nbrs
MatMult_MPIAIJ: on rank 146 mat has 61 rows, 4696 nonzeros, send 317 to 17 nbrs,recv 326 from 17 nbrs
MatMult_MPIAIJ: on rank 147 mat has 61 rows, 4696 nonzeros, send 317 to 17 nbrs,recv 326 from 17 nbrs
MatMult_MPIAIJ: on rank 148 mat has 61 rows, 4721 nonzeros, send 321 to 17 nbrs,recv 327 from 17 nbrs
MatMult_MPIAIJ: on rank 149 mat has 71 rows, 4828 nonzeros, send 254 to 11 nbrs,recv 241 from 11 nbrs
MatMult_MPIAIJ: on rank 150 mat has 61 rows, 4706 nonzeros, send 305 to 17 nbrs,recv 327 from 17 nbrs
MatMult_MPIAIJ: on rank 151 mat has 66 rows, 5853 nonzeros, send 431 to 26 nbrs,recv 447 from 26 nbrs
MatMult_MPIAIJ: on rank 152 mat has 66 rows, 5888 nonzeros, send 434 to 26 nbrs,recv 446 from 26 nbrs
MatMult_MPIAIJ: on rank 153 mat has 66 rows, 5888 nonzeros, send 434 to 26 nbrs,recv 446 from 26 nbrs
MatMult_MPIAIJ: on rank 154 mat has 67 rows, 5946 nonzeros, send 440 to 26 nbrs,recv 445 from 26 nbrs
MatMult_MPIAIJ: on rank 155 mat has 70 rows, 5344 nonzeros, send 332 to 17 nbrs,recv 340 from 17 nbrs
MatMult_MPIAIJ: on rank 156 mat has 62 rows, 4734 nonzeros, send 306 to 17 nbrs,recv 328 from 17 nbrs
MatMult_MPIAIJ: on rank 157 mat has 65 rows, 5783 nonzeros, send 445 to 26 nbrs,recv 429 from 26 nbrs
MatMult_MPIAIJ: on rank 158 mat has 65 rows, 5727 nonzeros, send 433 to 26 nbrs,recv 433 from 26 nbrs
MatMult_MPIAIJ: on rank 159 mat has 65 rows, 5727 nonzeros, send 433 to 26 nbrs,recv 433 from 26 nbrs
MatMult_MPIAIJ: on rank 160 mat has 66 rows, 5787 nonzeros, send 438 to 26 nbrs,recv 435 from 26 nbrs
MatMult_MPIAIJ: on rank 161 mat has 71 rows, 5433 nonzeros, send 342 to 17 nbrs,recv 339 from 17 nbrs
MatMult_MPIAIJ: on rank 162 mat has 62 rows, 4734 nonzeros, send 306 to 17 nbrs,recv 328 from 17 nbrs
MatMult_MPIAIJ: on rank 163 mat has 65 rows, 5783 nonzeros, send 445 to 26 nbrs,recv 429 from 26 nbrs
MatMult_MPIAIJ: on rank 164 mat has 65 rows, 5727 nonzeros, send 433 to 26 nbrs,recv 433 from 26 nbrs
MatMult_MPIAIJ: on rank 165 mat has 65 rows, 5727 nonzeros, send 433 to 26 nbrs,recv 433 from 26 nbrs
MatMult_MPIAIJ: on rank 166 mat has 66 rows, 5787 nonzeros, send 438 to 26 nbrs,recv 435 from 26 nbrs
MatMult_MPIAIJ: on rank 167 mat has 71 rows, 5436 nonzeros, send 342 to 17 nbrs,recv 339 from 17 nbrs
MatMult_MPIAIJ: on rank 168 mat has 62 rows, 4724 nonzeros, send 306 to 17 nbrs,recv 326 from 17 nbrs
MatMult_MPIAIJ: on rank 169 mat has 65 rows, 5770 nonzeros, send 445 to 26 nbrs,recv 424 from 26 nbrs
MatMult_MPIAIJ: on rank 170 mat has 65 rows, 5714 nonzeros, send 433 to 26 nbrs,recv 427 from 26 nbrs
MatMult_MPIAIJ: on rank 171 mat has 65 rows, 5714 nonzeros, send 433 to 26 nbrs,recv 427 from 26 nbrs
MatMult_MPIAIJ: on rank 172 mat has 66 rows, 5780 nonzeros, send 438 to 26 nbrs,recv 433 from 26 nbrs
MatMult_MPIAIJ: on rank 173 mat has 71 rows, 5438 nonzeros, send 342 to 17 nbrs,recv 340 from 17 nbrs
MatMult_MPIAIJ: on rank 174 mat has 69 rows, 4637 nonzeros, send 238 to 11 nbrs,recv 251 from 11 nbrs
MatMult_MPIAIJ: on rank 175 mat has 71 rows, 5583 nonzeros, send 350 to 17 nbrs,recv 326 from 17 nbrs
MatMult_MPIAIJ: on rank 176 mat has 71 rows, 5529 nonzeros, send 346 to 17 nbrs,recv 331 from 17 nbrs
MatMult_MPIAIJ: on rank 177 mat has 71 rows, 5529 nonzeros, send 346 to 17 nbrs,recv 331 from 17 nbrs
MatMult_MPIAIJ: on rank 178 mat has 72 rows, 5588 nonzeros, send 350 to 17 nbrs,recv 328 from 17 nbrs
MatMult_MPIAIJ: on rank 179 mat has 82 rows, 5660 nonzeros, send 283 to 11 nbrs,recv 267 from 11 nbrs
MatMult_MPIAIJ: on rank 180 mat has 62 rows, 3751 nonzeros, send 167 to 7 nbrs,recv 168 from 7 nbrs
MatMult_MPIAIJ: on rank 181 mat has 66 rows, 4558 nonzeros, send 238 to 11 nbrs,recv 230 from 11 nbrs
MatMult_MPIAIJ: on rank 182 mat has 64 rows, 4330 nonzeros, send 234 to 11 nbrs,recv 226 from 11 nbrs
MatMult_MPIAIJ: on rank 183 mat has 64 rows, 4330 nonzeros, send 234 to 11 nbrs,recv 226 from 11 nbrs
MatMult_MPIAIJ: on rank 184 mat has 65 rows, 4397 nonzeros, send 242 to 11 nbrs,recv 229 from 11 nbrs
MatMult_MPIAIJ: on rank 185 mat has 75 rows, 4523 nonzeros, send 184 to 7 nbrs,recv 166 from 7 nbrs
MatMult_MPIAIJ: on rank 186 mat has 68 rows, 4606 nonzeros, send 240 to 11 nbrs,recv 241 from 11 nbrs
MatMult_MPIAIJ: on rank 187 mat has 74 rows, 5871 nonzeros, send 348 to 17 nbrs,recv 350 from 17 nbrs
MatMult_MPIAIJ: on rank 188 mat has 74 rows, 5896 nonzeros, send 354 to 17 nbrs,recv 351 from 17 nbrs
MatMult_MPIAIJ: on rank 189 mat has 74 rows, 5896 nonzeros, send 354 to 17 nbrs,recv 351 from 17 nbrs
MatMult_MPIAIJ: on rank 190 mat has 72 rows, 5743 nonzeros, send 343 to 17 nbrs,recv 346 from 17 nbrs
MatMult_MPIAIJ: on rank 191 mat has 84 rows, 5850 nonzeros, send 283 to 11 nbrs,recv 259 from 11 nbrs
MatMult_MPIAIJ: on rank 192 mat has 68 rows, 4561 nonzeros, send 245 to 11 nbrs,recv 234 from 11 nbrs
MatMult_MPIAIJ: on rank 193 mat has 73 rows, 5817 nonzeros, send 364 to 17 nbrs,recv 334 from 17 nbrs
MatMult_MPIAIJ: on rank 194 mat has 73 rows, 5820 nonzeros, send 359 to 17 nbrs,recv 344 from 17 nbrs
MatMult_MPIAIJ: on rank 195 mat has 73 rows, 5820 nonzeros, send 359 to 17 nbrs,recv 344 from 17 nbrs
MatMult_MPIAIJ: on rank 196 mat has 71 rows, 5670 nonzeros, send 347 to 17 nbrs,recv 342 from 17 nbrs
MatMult_MPIAIJ: on rank 197 mat has 80 rows, 5609 nonzeros, send 282 to 11 nbrs,recv 263 from 11 nbrs
MatMult_MPIAIJ: on rank 198 mat has 68 rows, 4561 nonzeros, send 245 to 11 nbrs,recv 234 from 11 nbrs
MatMult_MPIAIJ: on rank 199 mat has 73 rows, 5817 nonzeros, send 364 to 17 nbrs,recv 334 from 17 nbrs
MatMult_MPIAIJ: on rank 200 mat has 73 rows, 5820 nonzeros, send 359 to 17 nbrs,recv 344 from 17 nbrs
MatMult_MPIAIJ: on rank 201 mat has 73 rows, 5820 nonzeros, send 359 to 17 nbrs,recv 344 from 17 nbrs
MatMult_MPIAIJ: on rank 202 mat has 71 rows, 5670 nonzeros, send 347 to 17 nbrs,recv 342 from 17 nbrs
MatMult_MPIAIJ: on rank 203 mat has 80 rows, 5603 nonzeros, send 282 to 11 nbrs,recv 261 from 11 nbrs
MatMult_MPIAIJ: on rank 204 mat has 68 rows, 4553 nonzeros, send 245 to 11 nbrs,recv 233 from 11 nbrs
MatMult_MPIAIJ: on rank 205 mat has 73 rows, 5821 nonzeros, send 364 to 17 nbrs,recv 329 from 17 nbrs
MatMult_MPIAIJ: on rank 206 mat has 73 rows, 5824 nonzeros, send 359 to 17 nbrs,recv 339 from 17 nbrs
MatMult_MPIAIJ: on rank 207 mat has 73 rows, 5824 nonzeros, send 359 to 17 nbrs,recv 339 from 17 nbrs
MatMult_MPIAIJ: on rank 208 mat has 71 rows, 5688 nonzeros, send 347 to 17 nbrs,recv 344 from 17 nbrs
MatMult_MPIAIJ: on rank 209 mat has 80 rows, 5610 nonzeros, send 283 to 11 nbrs,recv 264 from 11 nbrs
MatMult_MPIAIJ: on rank 210 mat has 78 rows, 4706 nonzeros, send 177 to 7 nbrs,recv 167 from 7 nbrs
MatMult_MPIAIJ: on rank 211 mat has 79 rows, 5695 nonzeros, send 289 to 11 nbrs,recv 261 from 11 nbrs
MatMult_MPIAIJ: on rank 212 mat has 79 rows, 5631 nonzeros, send 282 to 11 nbrs,recv 265 from 11 nbrs
MatMult_MPIAIJ: on rank 213 mat has 79 rows, 5631 nonzeros, send 282 to 11 nbrs,recv 265 from 11 nbrs
MatMult_MPIAIJ: on rank 214 mat has 81 rows, 5770 nonzeros, send 285 to 11 nbrs,recv 268 from 11 nbrs
MatMult_MPIAIJ: on rank 215 mat has 94 rows, 5994 nonzeros, send 229 to 7 nbrs,recv 197 from 7 nbrs
doing MatRestrict
MatMultTranspose_MPIAIJ: on rank 0 mat has 59 rows, 284 nonzeros, send 188 to 33 nbrs,recv 10 from 1 nbrs
MatMultTranspose_MPIAIJ: on rank 1 mat has 61 rows, 459 nonzeros, send 237 to 38 nbrs,recv 25 from 2 nbrs
MatMultTranspose_MPIAIJ: on rank 2 mat has 62 rows, 519 nonzeros, send 245 to 28 nbrs,recv 28 from 2 nbrs
MatMultTranspose_MPIAIJ: on rank 3 mat has 62 rows, 521 nonzeros, send 316 to 47 nbrs,recv 15 from 1 nbrs
MatMultTranspose_MPIAIJ: on rank 4 mat has 62 rows, 525 nonzeros, send 411 to 62 nbrs,recv 28 from 2 nbrs
MatMultTranspose_MPIAIJ: on rank 5 mat has 70 rows, 526 nonzeros, send 424 to 49 nbrs,recv 26 from 2 nbrs
MatMultTranspose_MPIAIJ: on rank 6 mat has 63 rows, 503 nonzeros, send 259 to 41 nbrs,recv 28 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 7 mat has 64 rows, 374 nonzeros, send 349 to 62 nbrs,recv 32 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 8 mat has 67 rows, 461 nonzeros, send 354 to 51 nbrs,recv 29 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 9 mat has 67 rows, 462 nonzeros, send 274 to 42 nbrs,recv 31 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 10 mat has 67 rows, 458 nonzeros, send 359 to 62 nbrs,recv 30 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 11 mat has 70 rows, 482 nonzeros, send 364 to 51 nbrs,recv 25 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 12 mat has 61 rows, 469 nonzeros, send 274 to 42 nbrs,recv 29 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 13 mat has 64 rows, 454 nonzeros, send 359 to 62 nbrs,recv 32 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 14 mat has 64 rows, 556 nonzeros, send 365 to 51 nbrs,recv 34 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 15 mat has 64 rows, 542 nonzeros, send 322 to 31 nbrs,recv 36 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 16 mat has 64 rows, 531 nonzeros, send 411 to 44 nbrs,recv 34 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 17 mat has 70 rows, 497 nonzeros, send 476 to 36 nbrs,recv 28 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 18 mat has 61 rows, 426 nonzeros, send 0 to 0 nbrs,recv 30 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 19 mat has 64 rows, 521 nonzeros, send 0 to 0 nbrs,recv 31 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 20 mat has 64 rows, 529 nonzeros, send 0 to 0 nbrs,recv 35 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 21 mat has 64 rows, 526 nonzeros, send 0 to 0 nbrs,recv 34 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 22 mat has 64 rows, 505 nonzeros, send 0 to 0 nbrs,recv 32 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 23 mat has 70 rows, 485 nonzeros, send 0 to 0 nbrs,recv 28 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 24 mat has 61 rows, 410 nonzeros, send 0 to 0 nbrs,recv 28 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 25 mat has 64 rows, 498 nonzeros, send 0 to 0 nbrs,recv 28 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 26 mat has 64 rows, 513 nonzeros, send 0 to 0 nbrs,recv 34 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 27 mat has 64 rows, 511 nonzeros, send 0 to 0 nbrs,recv 33 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 28 mat has 64 rows, 481 nonzeros, send 0 to 0 nbrs,recv 31 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 29 mat has 70 rows, 464 nonzeros, send 0 to 0 nbrs,recv 29 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 30 mat has 69 rows, 475 nonzeros, send 0 to 0 nbrs,recv 24 from 2 nbrs
MatMultTranspose_MPIAIJ: on rank 31 mat has 70 rows, 532 nonzeros, send 0 to 0 nbrs,recv 28 from 2 nbrs
MatMultTranspose_MPIAIJ: on rank 32 mat has 69 rows, 543 nonzeros, send 0 to 0 nbrs,recv 28 from 2 nbrs
MatMultTranspose_MPIAIJ: on rank 33 mat has 69 rows, 562 nonzeros, send 0 to 0 nbrs,recv 29 from 2 nbrs
MatMultTranspose_MPIAIJ: on rank 34 mat has 70 rows, 537 nonzeros, send 0 to 0 nbrs,recv 29 from 2 nbrs
MatMultTranspose_MPIAIJ: on rank 35 mat has 80 rows, 505 nonzeros, send 0 to 0 nbrs,recv 26 from 2 nbrs
MatMultTranspose_MPIAIJ: on rank 36 mat has 61 rows, 438 nonzeros, send 0 to 0 nbrs,recv 26 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 37 mat has 65 rows, 376 nonzeros, send 0 to 0 nbrs,recv 28 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 38 mat has 64 rows, 516 nonzeros, send 0 to 0 nbrs,recv 31 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 39 mat has 64 rows, 501 nonzeros, send 0 to 0 nbrs,recv 32 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 40 mat has 63 rows, 472 nonzeros, send 0 to 0 nbrs,recv 31 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 41 mat has 71 rows, 509 nonzeros, send 0 to 0 nbrs,recv 26 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 42 mat has 59 rows, 351 nonzeros, send 0 to 0 nbrs,recv 33 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 43 mat has 66 rows, 454 nonzeros, send 0 to 0 nbrs,recv 27 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 44 mat has 66 rows, 508 nonzeros, send 0 to 0 nbrs,recv 32 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 45 mat has 66 rows, 484 nonzeros, send 0 to 0 nbrs,recv 29 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 46 mat has 65 rows, 474 nonzeros, send 0 to 0 nbrs,recv 27 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 47 mat has 69 rows, 485 nonzeros, send 0 to 0 nbrs,recv 28 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 48 mat has 60 rows, 385 nonzeros, send 0 to 0 nbrs,recv 33 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 49 mat has 66 rows, 498 nonzeros, send 0 to 0 nbrs,recv 32 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 50 mat has 66 rows, 490 nonzeros, send 0 to 0 nbrs,recv 34 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 51 mat has 66 rows, 484 nonzeros, send 0 to 0 nbrs,recv 34 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 52 mat has 65 rows, 482 nonzeros, send 0 to 0 nbrs,recv 31 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 53 mat has 70 rows, 502 nonzeros, send 0 to 0 nbrs,recv 28 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 54 mat has 60 rows, 387 nonzeros, send 0 to 0 nbrs,recv 31 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 55 mat has 66 rows, 467 nonzeros, send 0 to 0 nbrs,recv 31 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 56 mat has 66 rows, 480 nonzeros, send 0 to 0 nbrs,recv 32 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 57 mat has 66 rows, 479 nonzeros, send 0 to 0 nbrs,recv 32 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 58 mat has 65 rows, 477 nonzeros, send 0 to 0 nbrs,recv 30 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 59 mat has 70 rows, 502 nonzeros, send 0 to 0 nbrs,recv 28 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 60 mat has 60 rows, 457 nonzeros, send 0 to 0 nbrs,recv 29 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 61 mat has 66 rows, 430 nonzeros, send 0 to 0 nbrs,recv 24 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 62 mat has 66 rows, 446 nonzeros, send 0 to 0 nbrs,recv 26 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 63 mat has 66 rows, 445 nonzeros, send 0 to 0 nbrs,recv 27 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 64 mat has 65 rows, 449 nonzeros, send 0 to 0 nbrs,recv 28 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 65 mat has 70 rows, 479 nonzeros, send 0 to 0 nbrs,recv 27 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 66 mat has 68 rows, 412 nonzeros, send 0 to 0 nbrs,recv 21 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 67 mat has 72 rows, 512 nonzeros, send 0 to 0 nbrs,recv 22 from 2 nbrs
MatMultTranspose_MPIAIJ: on rank 68 mat has 72 rows, 505 nonzeros, send 0 to 0 nbrs,recv 26 from 2 nbrs
MatMultTranspose_MPIAIJ: on rank 69 mat has 72 rows, 506 nonzeros, send 0 to 0 nbrs,recv 26 from 2 nbrs
MatMultTranspose_MPIAIJ: on rank 70 mat has 72 rows, 490 nonzeros, send 0 to 0 nbrs,recv 28 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 71 mat has 84 rows, 548 nonzeros, send 0 to 0 nbrs,recv 26 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 72 mat has 62 rows, 466 nonzeros, send 0 to 0 nbrs,recv 28 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 73 mat has 62 rows, 448 nonzeros, send 0 to 0 nbrs,recv 29 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 74 mat has 61 rows, 376 nonzeros, send 0 to 0 nbrs,recv 30 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 75 mat has 61 rows, 390 nonzeros, send 0 to 0 nbrs,recv 30 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 76 mat has 61 rows, 375 nonzeros, send 0 to 0 nbrs,recv 25 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 77 mat has 71 rows, 461 nonzeros, send 0 to 0 nbrs,recv 25 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 78 mat has 61 rows, 418 nonzeros, send 0 to 0 nbrs,recv 34 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 79 mat has 66 rows, 476 nonzeros, send 0 to 0 nbrs,recv 30 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 80 mat has 66 rows, 494 nonzeros, send 0 to 0 nbrs,recv 29 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 81 mat has 66 rows, 488 nonzeros, send 0 to 0 nbrs,recv 28 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 82 mat has 67 rows, 444 nonzeros, send 0 to 0 nbrs,recv 23 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 83 mat has 70 rows, 401 nonzeros, send 0 to 0 nbrs,recv 24 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 84 mat has 62 rows, 479 nonzeros, send 0 to 0 nbrs,recv 33 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 85 mat has 65 rows, 491 nonzeros, send 0 to 0 nbrs,recv 31 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 86 mat has 65 rows, 478 nonzeros, send 0 to 0 nbrs,recv 30 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 87 mat has 65 rows, 484 nonzeros, send 0 to 0 nbrs,recv 31 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 88 mat has 66 rows, 462 nonzeros, send 0 to 0 nbrs,recv 26 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 89 mat has 71 rows, 445 nonzeros, send 0 to 0 nbrs,recv 25 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 90 mat has 62 rows, 461 nonzeros, send 0 to 0 nbrs,recv 32 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 91 mat has 65 rows, 475 nonzeros, send 0 to 0 nbrs,recv 29 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 92 mat has 65 rows, 487 nonzeros, send 0 to 0 nbrs,recv 31 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 93 mat has 65 rows, 494 nonzeros, send 0 to 0 nbrs,recv 32 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 94 mat has 66 rows, 474 nonzeros, send 0 to 0 nbrs,recv 27 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 95 mat has 71 rows, 445 nonzeros, send 0 to 0 nbrs,recv 25 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 96 mat has 62 rows, 499 nonzeros, send 0 to 0 nbrs,recv 29 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 97 mat has 65 rows, 429 nonzeros, send 0 to 0 nbrs,recv 25 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 98 mat has 65 rows, 456 nonzeros, send 0 to 0 nbrs,recv 27 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 99 mat has 65 rows, 462 nonzeros, send 0 to 0 nbrs,recv 28 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 100 mat has 66 rows, 454 nonzeros, send 0 to 0 nbrs,recv 26 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 101 mat has 71 rows, 452 nonzeros, send 0 to 0 nbrs,recv 26 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 102 mat has 69 rows, 497 nonzeros, send 0 to 0 nbrs,recv 23 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 103 mat has 71 rows, 443 nonzeros, send 0 to 0 nbrs,recv 24 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 104 mat has 71 rows, 447 nonzeros, send 0 to 0 nbrs,recv 25 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 105 mat has 71 rows, 447 nonzeros, send 0 to 0 nbrs,recv 25 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 106 mat has 72 rows, 450 nonzeros, send 0 to 0 nbrs,recv 26 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 107 mat has 82 rows, 502 nonzeros, send 0 to 0 nbrs,recv 24 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 108 mat has 62 rows, 462 nonzeros, send 0 to 0 nbrs,recv 29 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 109 mat has 62 rows, 456 nonzeros, send 0 to 0 nbrs,recv 31 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 110 mat has 61 rows, 399 nonzeros, send 0 to 0 nbrs,recv 30 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 111 mat has 61 rows, 416 nonzeros, send 0 to 0 nbrs,recv 30 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 112 mat has 61 rows, 435 nonzeros, send 0 to 0 nbrs,recv 23 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 113 mat has 71 rows, 453 nonzeros, send 0 to 0 nbrs,recv 25 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 114 mat has 61 rows, 440 nonzeros, send 0 to 0 nbrs,recv 35 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 115 mat has 66 rows, 499 nonzeros, send 0 to 0 nbrs,recv 30 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 116 mat has 66 rows, 534 nonzeros, send 0 to 0 nbrs,recv 30 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 117 mat has 66 rows, 530 nonzeros, send 0 to 0 nbrs,recv 28 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 118 mat has 67 rows, 467 nonzeros, send 0 to 0 nbrs,recv 25 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 119 mat has 70 rows, 423 nonzeros, send 0 to 0 nbrs,recv 22 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 120 mat has 62 rows, 551 nonzeros, send 0 to 0 nbrs,recv 34 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 121 mat has 65 rows, 486 nonzeros, send 0 to 0 nbrs,recv 31 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 122 mat has 65 rows, 461 nonzeros, send 0 to 0 nbrs,recv 29 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 123 mat has 65 rows, 472 nonzeros, send 0 to 0 nbrs,recv 31 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 124 mat has 66 rows, 453 nonzeros, send 0 to 0 nbrs,recv 27 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 125 mat has 71 rows, 457 nonzeros, send 0 to 0 nbrs,recv 26 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 126 mat has 62 rows, 512 nonzeros, send 0 to 0 nbrs,recv 33 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 127 mat has 65 rows, 462 nonzeros, send 0 to 0 nbrs,recv 29 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 128 mat has 65 rows, 470 nonzeros, send 0 to 0 nbrs,recv 31 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 129 mat has 65 rows, 482 nonzeros, send 0 to 0 nbrs,recv 33 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 130 mat has 66 rows, 468 nonzeros, send 0 to 0 nbrs,recv 29 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 131 mat has 71 rows, 457 nonzeros, send 0 to 0 nbrs,recv 26 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 132 mat has 62 rows, 512 nonzeros, send 0 to 0 nbrs,recv 30 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 133 mat has 65 rows, 436 nonzeros, send 0 to 0 nbrs,recv 25 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 134 mat has 65 rows, 445 nonzeros, send 0 to 0 nbrs,recv 27 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 135 mat has 65 rows, 454 nonzeros, send 0 to 0 nbrs,recv 29 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 136 mat has 66 rows, 446 nonzeros, send 0 to 0 nbrs,recv 27 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 137 mat has 71 rows, 457 nonzeros, send 0 to 0 nbrs,recv 26 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 138 mat has 69 rows, 483 nonzeros, send 0 to 0 nbrs,recv 23 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 139 mat has 71 rows, 444 nonzeros, send 0 to 0 nbrs,recv 23 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 140 mat has 71 rows, 448 nonzeros, send 0 to 0 nbrs,recv 24 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 141 mat has 71 rows, 448 nonzeros, send 0 to 0 nbrs,recv 24 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 142 mat has 72 rows, 433 nonzeros, send 0 to 0 nbrs,recv 23 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 143 mat has 82 rows, 478 nonzeros, send 0 to 0 nbrs,recv 22 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 144 mat has 62 rows, 475 nonzeros, send 0 to 0 nbrs,recv 30 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 145 mat has 62 rows, 457 nonzeros, send 0 to 0 nbrs,recv 31 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 146 mat has 61 rows, 395 nonzeros, send 0 to 0 nbrs,recv 29 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 147 mat has 61 rows, 412 nonzeros, send 0 to 0 nbrs,recv 29 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 148 mat has 61 rows, 412 nonzeros, send 0 to 0 nbrs,recv 22 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 149 mat has 71 rows, 461 nonzeros, send 0 to 0 nbrs,recv 26 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 150 mat has 61 rows, 441 nonzeros, send 0 to 0 nbrs,recv 34 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 151 mat has 66 rows, 499 nonzeros, send 0 to 0 nbrs,recv 30 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 152 mat has 66 rows, 534 nonzeros, send 0 to 0 nbrs,recv 30 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 153 mat has 66 rows, 529 nonzeros, send 0 to 0 nbrs,recv 28 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 154 mat has 67 rows, 461 nonzeros, send 0 to 0 nbrs,recv 25 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 155 mat has 70 rows, 424 nonzeros, send 0 to 0 nbrs,recv 23 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 156 mat has 62 rows, 544 nonzeros, send 0 to 0 nbrs,recv 33 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 157 mat has 65 rows, 485 nonzeros, send 0 to 0 nbrs,recv 31 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 158 mat has 65 rows, 461 nonzeros, send 0 to 0 nbrs,recv 29 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 159 mat has 65 rows, 473 nonzeros, send 0 to 0 nbrs,recv 31 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 160 mat has 66 rows, 454 nonzeros, send 0 to 0 nbrs,recv 27 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 161 mat has 71 rows, 458 nonzeros, send 0 to 0 nbrs,recv 27 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 162 mat has 62 rows, 509 nonzeros, send 0 to 0 nbrs,recv 31 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 163 mat has 65 rows, 461 nonzeros, send 0 to 0 nbrs,recv 29 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 164 mat has 65 rows, 470 nonzeros, send 0 to 0 nbrs,recv 31 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 165 mat has 65 rows, 482 nonzeros, send 0 to 0 nbrs,recv 33 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 166 mat has 66 rows, 468 nonzeros, send 0 to 0 nbrs,recv 29 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 167 mat has 71 rows, 458 nonzeros, send 0 to 0 nbrs,recv 27 from 6 nbrs
MatMultTranspose_MPIAIJ: on rank 168 mat has 62 rows, 510 nonzeros, send 0 to 0 nbrs,recv 29 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 169 mat has 65 rows, 436 nonzeros, send 0 to 0 nbrs,recv 25 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 170 mat has 65 rows, 445 nonzeros, send 0 to 0 nbrs,recv 27 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 171 mat has 65 rows, 454 nonzeros, send 0 to 0 nbrs,recv 29 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 172 mat has 66 rows, 446 nonzeros, send 0 to 0 nbrs,recv 27 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 173 mat has 71 rows, 458 nonzeros, send 0 to 0 nbrs,recv 27 from 5 nbrs
MatMultTranspose_MPIAIJ: on rank 174 mat has 69 rows, 488 nonzeros, send 0 to 0 nbrs,recv 24 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 175 mat has 71 rows, 446 nonzeros, send 0 to 0 nbrs,recv 24 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 176 mat has 71 rows, 447 nonzeros, send 0 to 0 nbrs,recv 24 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 177 mat has 71 rows, 447 nonzeros, send 0 to 0 nbrs,recv 24 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 178 mat has 72 rows, 432 nonzeros, send 0 to 0 nbrs,recv 23 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 179 mat has 82 rows, 479 nonzeros, send 0 to 0 nbrs,recv 23 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 180 mat has 62 rows, 396 nonzeros, send 0 to 0 nbrs,recv 23 from 2 nbrs
MatMultTranspose_MPIAIJ: on rank 181 mat has 66 rows, 483 nonzeros, send 0 to 0 nbrs,recv 23 from 2 nbrs
MatMultTranspose_MPIAIJ: on rank 182 mat has 64 rows, 479 nonzeros, send 0 to 0 nbrs,recv 25 from 2 nbrs
MatMultTranspose_MPIAIJ: on rank 183 mat has 64 rows, 463 nonzeros, send 0 to 0 nbrs,recv 26 from 2 nbrs
MatMultTranspose_MPIAIJ: on rank 184 mat has 65 rows, 425 nonzeros, send 0 to 0 nbrs,recv 22 from 2 nbrs
MatMultTranspose_MPIAIJ: on rank 185 mat has 75 rows, 467 nonzeros, send 0 to 0 nbrs,recv 24 from 2 nbrs
MatMultTranspose_MPIAIJ: on rank 186 mat has 68 rows, 460 nonzeros, send 0 to 0 nbrs,recv 27 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 187 mat has 74 rows, 543 nonzeros, send 0 to 0 nbrs,recv 25 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 188 mat has 74 rows, 574 nonzeros, send 0 to 0 nbrs,recv 26 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 189 mat has 74 rows, 581 nonzeros, send 0 to 0 nbrs,recv 25 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 190 mat has 72 rows, 477 nonzeros, send 0 to 0 nbrs,recv 24 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 191 mat has 84 rows, 510 nonzeros, send 0 to 0 nbrs,recv 24 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 192 mat has 68 rows, 548 nonzeros, send 0 to 0 nbrs,recv 28 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 193 mat has 73 rows, 487 nonzeros, send 0 to 0 nbrs,recv 26 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 194 mat has 73 rows, 512 nonzeros, send 0 to 0 nbrs,recv 28 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 195 mat has 73 rows, 553 nonzeros, send 0 to 0 nbrs,recv 29 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 196 mat has 71 rows, 521 nonzeros, send 0 to 0 nbrs,recv 29 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 197 mat has 80 rows, 490 nonzeros, send 0 to 0 nbrs,recv 24 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 198 mat has 68 rows, 482 nonzeros, send 0 to 0 nbrs,recv 23 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 199 mat has 73 rows, 511 nonzeros, send 0 to 0 nbrs,recv 26 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 200 mat has 73 rows, 584 nonzeros, send 0 to 0 nbrs,recv 29 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 201 mat has 73 rows, 581 nonzeros, send 0 to 0 nbrs,recv 31 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 202 mat has 71 rows, 529 nonzeros, send 0 to 0 nbrs,recv 29 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 203 mat has 80 rows, 476 nonzeros, send 0 to 0 nbrs,recv 22 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 204 mat has 68 rows, 488 nonzeros, send 0 to 0 nbrs,recv 24 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 205 mat has 73 rows, 498 nonzeros, send 0 to 0 nbrs,recv 28 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 206 mat has 73 rows, 506 nonzeros, send 0 to 0 nbrs,recv 27 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 207 mat has 73 rows, 515 nonzeros, send 0 to 0 nbrs,recv 28 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 208 mat has 71 rows, 463 nonzeros, send 0 to 0 nbrs,recv 25 from 4 nbrs
MatMultTranspose_MPIAIJ: on rank 209 mat has 80 rows, 487 nonzeros, send 0 to 0 nbrs,recv 24 from 3 nbrs
MatMultTranspose_MPIAIJ: on rank 210 mat has 78 rows, 515 nonzeros, send 0 to 0 nbrs,recv 22 from 2 nbrs
MatMultTranspose_MPIAIJ: on rank 211 mat has 79 rows, 484 nonzeros, send 0 to 0 nbrs,recv 23 from 2 nbrs
MatMultTranspose_MPIAIJ: on rank 212 mat has 79 rows, 543 nonzeros, send 0 to 0 nbrs,recv 24 from 2 nbrs
MatMultTranspose_MPIAIJ: on rank 213 mat has 79 rows, 538 nonzeros, send 0 to 0 nbrs,recv 24 from 2 nbrs
MatMultTranspose_MPIAIJ: on rank 214 mat has 81 rows, 518 nonzeros, send 0 to 0 nbrs,recv 25 from 2 nbrs
MatMultTranspose_MPIAIJ: on rank 215 mat has 94 rows, 564 nonzeros, send 0 to 0 nbrs,recv 26 from 2 nbrs
Entering MG level 2
MatSOR_MPIAIJ: on rank 0 mat has 49 rows, 3902 nonzeros, send 221 to 7 nbrs,recv 221 from 7 nbrs
MatSOR_MPIAIJ: on rank 1 mat has 48 rows, 4700 nonzeros, send 310 to 8 nbrs,recv 307 from 8 nbrs
MatSOR_MPIAIJ: on rank 2 mat has 63 rows, 5078 nonzeros, send 242 to 7 nbrs,recv 222 from 7 nbrs
MatSOR_MPIAIJ: on rank 3 mat has 51 rows, 5217 nonzeros, send 322 to 8 nbrs,recv 304 from 8 nbrs
MatSOR_MPIAIJ: on rank 4 mat has 51 rows, 6635 nonzeros, send 483 to 12 nbrs,recv 448 from 12 nbrs
MatSOR_MPIAIJ: on rank 5 mat has 59 rows, 6539 nonzeros, send 334 to 10 nbrs,recv 344 from 10 nbrs
MatSOR_MPIAIJ: on rank 6 mat has 45 rows, 4687 nonzeros, send 330 to 10 nbrs,recv 355 from 10 nbrs
MatSOR_MPIAIJ: on rank 7 mat has 48 rows, 6232 nonzeros, send 524 to 15 nbrs,recv 547 from 15 nbrs
MatSOR_MPIAIJ: on rank 8 mat has 56 rows, 6125 nonzeros, send 370 to 11 nbrs,recv 422 from 11 nbrs
MatSOR_MPIAIJ: on rank 9 mat has 46 rows, 4899 nonzeros, send 352 to 9 nbrs,recv 367 from 9 nbrs
MatSOR_MPIAIJ: on rank 10 mat has 48 rows, 6388 nonzeros, send 526 to 14 nbrs,recv 532 from 14 nbrs
MatSOR_MPIAIJ: on rank 11 mat has 57 rows, 6229 nonzeros, send 388 to 10 nbrs,recv 409 from 10 nbrs
MatSOR_MPIAIJ: on rank 12 mat has 46 rows, 4838 nonzeros, send 297 to 8 nbrs,recv 321 from 8 nbrs
MatSOR_MPIAIJ: on rank 13 mat has 48 rows, 6357 nonzeros, send 447 to 13 nbrs,recv 481 from 13 nbrs
MatSOR_MPIAIJ: on rank 14 mat has 57 rows, 6198 nonzeros, send 324 to 8 nbrs,recv 371 from 8 nbrs
MatSOR_MPIAIJ: on rank 15 mat has 72 rows, 5800 nonzeros, send 298 to 7 nbrs,recv 231 from 7 nbrs
MatSOR_MPIAIJ: on rank 16 mat has 68 rows, 7192 nonzeros, send 410 to 10 nbrs,recv 355 from 10 nbrs
MatSOR_MPIAIJ: on rank 17 mat has 91 rows, 7633 nonzeros, send 311 to 7 nbrs,recv 252 from 7 nbrs
MatSOR_MPIAIJ: on rank 18 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 19 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 20 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 21 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 22 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 23 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 24 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 25 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 26 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 27 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 28 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 29 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 30 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 31 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 32 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 33 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 34 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 35 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 36 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 37 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 38 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 39 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 40 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 41 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 42 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 43 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 44 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 45 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 46 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 47 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 48 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 49 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 50 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 51 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 52 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 53 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 54 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 55 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 56 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 57 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 58 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 59 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 60 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 61 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 62 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 63 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 64 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 65 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 66 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 67 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 68 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 69 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 70 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 71 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 72 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 73 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 74 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 75 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 76 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 77 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 78 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 79 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 80 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 81 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 82 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 83 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 84 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 85 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 86 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 87 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 88 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 89 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 90 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 91 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 92 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 93 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 94 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 95 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 96 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 97 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 98 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 99 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 100 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 101 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 102 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 103 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 104 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 105 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 106 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 107 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 108 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 109 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 110 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 111 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 112 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 113 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 114 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 115 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 116 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 117 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 118 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 119 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 120 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 121 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 122 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 123 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 124 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 125 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 126 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 127 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 128 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 129 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 130 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 131 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 132 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 133 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 134 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 135 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 136 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 137 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 138 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 139 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 140 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 141 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 142 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 143 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 144 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 145 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 146 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 147 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 148 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 149 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 150 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 151 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 152 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 153 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 154 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 155 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 156 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 157 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 158 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 159 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 160 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 161 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 162 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 163 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 164 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 165 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 166 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 167 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 168 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 169 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 170 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 171 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 172 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 173 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 174 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 175 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 176 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 177 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 178 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 179 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 180 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 181 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 182 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 183 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 184 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 185 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 186 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 187 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 188 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 189 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 190 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 191 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 192 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 193 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 194 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 195 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 196 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 197 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 198 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 199 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 200 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 201 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 202 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 203 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 204 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 205 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 206 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 207 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 208 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 209 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 210 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 211 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 212 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 213 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 214 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 215 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 0 mat has 49 rows, 3902 nonzeros, send 221 to 7 nbrs,recv 221 from 7 nbrs
MatMult_MPIAIJ: on rank 1 mat has 48 rows, 4700 nonzeros, send 310 to 8 nbrs,recv 307 from 8 nbrs
MatMult_MPIAIJ: on rank 2 mat has 63 rows, 5078 nonzeros, send 242 to 7 nbrs,recv 222 from 7 nbrs
MatMult_MPIAIJ: on rank 3 mat has 51 rows, 5217 nonzeros, send 322 to 8 nbrs,recv 304 from 8 nbrs
MatMult_MPIAIJ: on rank 4 mat has 51 rows, 6635 nonzeros, send 483 to 12 nbrs,recv 448 from 12 nbrs
MatMult_MPIAIJ: on rank 5 mat has 59 rows, 6539 nonzeros, send 334 to 10 nbrs,recv 344 from 10 nbrs
MatMult_MPIAIJ: on rank 6 mat has 45 rows, 4687 nonzeros, send 330 to 10 nbrs,recv 355 from 10 nbrs
MatMult_MPIAIJ: on rank 7 mat has 48 rows, 6232 nonzeros, send 524 to 15 nbrs,recv 547 from 15 nbrs
MatMult_MPIAIJ: on rank 8 mat has 56 rows, 6125 nonzeros, send 370 to 11 nbrs,recv 422 from 11 nbrs
MatMult_MPIAIJ: on rank 9 mat has 46 rows, 4899 nonzeros, send 352 to 9 nbrs,recv 367 from 9 nbrs
MatMult_MPIAIJ: on rank 10 mat has 48 rows, 6388 nonzeros, send 526 to 14 nbrs,recv 532 from 14 nbrs
MatMult_MPIAIJ: on rank 11 mat has 57 rows, 6229 nonzeros, send 388 to 10 nbrs,recv 409 from 10 nbrs
MatMult_MPIAIJ: on rank 12 mat has 46 rows, 4838 nonzeros, send 297 to 8 nbrs,recv 321 from 8 nbrs
MatMult_MPIAIJ: on rank 13 mat has 48 rows, 6357 nonzeros, send 447 to 13 nbrs,recv 481 from 13 nbrs
MatMult_MPIAIJ: on rank 14 mat has 57 rows, 6198 nonzeros, send 324 to 8 nbrs,recv 371 from 8 nbrs
MatMult_MPIAIJ: on rank 15 mat has 72 rows, 5800 nonzeros, send 298 to 7 nbrs,recv 231 from 7 nbrs
MatMult_MPIAIJ: on rank 16 mat has 68 rows, 7192 nonzeros, send 410 to 10 nbrs,recv 355 from 10 nbrs
MatMult_MPIAIJ: on rank 17 mat has 91 rows, 7633 nonzeros, send 311 to 7 nbrs,recv 252 from 7 nbrs
MatMult_MPIAIJ: on rank 18 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 19 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 20 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 21 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 22 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 23 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 24 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 25 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 26 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 27 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 28 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 29 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 30 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 31 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 32 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 33 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 34 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 35 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 36 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 37 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 38 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 39 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 40 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 41 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 42 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 43 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 44 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 45 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 46 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 47 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 48 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 49 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 50 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 51 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 52 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 53 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 54 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 55 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 56 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 57 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 58 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 59 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 60 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 61 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 62 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 63 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 64 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 65 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 66 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 67 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 68 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 69 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 70 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 71 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 72 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 73 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 74 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 75 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 76 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 77 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 78 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 79 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 80 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 81 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 82 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 83 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 84 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 85 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 86 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 87 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 88 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 89 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 90 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 91 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 92 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 93 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 94 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 95 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 96 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 97 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 98 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 99 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 100 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 101 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 102 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 103 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 104 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 105 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 106 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 107 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 108 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 109 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 110 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 111 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 112 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 113 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 114 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 115 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 116 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 117 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 118 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 119 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 120 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 121 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 122 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 123 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 124 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 125 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 126 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 127 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 128 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 129 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 130 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 131 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 132 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 133 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 134 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 135 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 136 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 137 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 138 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 139 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 140 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 141 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 142 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 143 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 144 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 145 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 146 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 147 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 148 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 149 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 150 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 151 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 152 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 153 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 154 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 155 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 156 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 157 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 158 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 159 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 160 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 161 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 162 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 163 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 164 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 165 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 166 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 167 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 168 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 169 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 170 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 171 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 172 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 173 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 174 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 175 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 176 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 177 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 178 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 179 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 180 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 181 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 182 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 183 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 184 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 185 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 186 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 187 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 188 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 189 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 190 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 191 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 192 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 193 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 194 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 195 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 196 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 197 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 198 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 199 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 200 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 201 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 202 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 203 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 204 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 205 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 206 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 207 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 208 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 209 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 210 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 211 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 212 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 213 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 214 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 215 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
doing MatRestrict
MatMultTranspose_MPIAIJ: on rank 0 mat has 49 rows, 340 nonzeros, send 571 to 17 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 1 mat has 48 rows, 329 nonzeros, send 0 to 0 nbrs,recv 31 from 1 nbrs
MatMultTranspose_MPIAIJ: on rank 2 mat has 63 rows, 398 nonzeros, send 0 to 0 nbrs,recv 28 from 1 nbrs
MatMultTranspose_MPIAIJ: on rank 3 mat has 51 rows, 425 nonzeros, send 0 to 0 nbrs,recv 27 from 1 nbrs
MatMultTranspose_MPIAIJ: on rank 4 mat has 51 rows, 406 nonzeros, send 0 to 0 nbrs,recv 36 from 1 nbrs
MatMultTranspose_MPIAIJ: on rank 5 mat has 59 rows, 474 nonzeros, send 0 to 0 nbrs,recv 32 from 1 nbrs
MatMultTranspose_MPIAIJ: on rank 6 mat has 45 rows, 318 nonzeros, send 0 to 0 nbrs,recv 32 from 1 nbrs
MatMultTranspose_MPIAIJ: on rank 7 mat has 48 rows, 413 nonzeros, send 0 to 0 nbrs,recv 41 from 1 nbrs
MatMultTranspose_MPIAIJ: on rank 8 mat has 56 rows, 404 nonzeros, send 0 to 0 nbrs,recv 34 from 1 nbrs
MatMultTranspose_MPIAIJ: on rank 9 mat has 46 rows, 350 nonzeros, send 0 to 0 nbrs,recv 34 from 1 nbrs
MatMultTranspose_MPIAIJ: on rank 10 mat has 48 rows, 380 nonzeros, send 0 to 0 nbrs,recv 42 from 1 nbrs
MatMultTranspose_MPIAIJ: on rank 11 mat has 57 rows, 396 nonzeros, send 0 to 0 nbrs,recv 34 from 1 nbrs
MatMultTranspose_MPIAIJ: on rank 12 mat has 46 rows, 297 nonzeros, send 0 to 0 nbrs,recv 29 from 1 nbrs
MatMultTranspose_MPIAIJ: on rank 13 mat has 48 rows, 471 nonzeros, send 0 to 0 nbrs,recv 39 from 1 nbrs
MatMultTranspose_MPIAIJ: on rank 14 mat has 57 rows, 472 nonzeros, send 0 to 0 nbrs,recv 36 from 1 nbrs
MatMultTranspose_MPIAIJ: on rank 15 mat has 72 rows, 502 nonzeros, send 0 to 0 nbrs,recv 27 from 1 nbrs
MatMultTranspose_MPIAIJ: on rank 16 mat has 68 rows, 502 nonzeros, send 0 to 0 nbrs,recv 36 from 1 nbrs
MatMultTranspose_MPIAIJ: on rank 17 mat has 91 rows, 614 nonzeros, send 0 to 0 nbrs,recv 33 from 1 nbrs
MatMultTranspose_MPIAIJ: on rank 18 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 19 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 20 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 21 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 22 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 23 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 24 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 25 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 26 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 27 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 28 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 29 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 30 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 31 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 32 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 33 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 34 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 35 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 36 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 37 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 38 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 39 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 40 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 41 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 42 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 43 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 44 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 45 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 46 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 47 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 48 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 49 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 50 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 51 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 52 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 53 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 54 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 55 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 56 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 57 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 58 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 59 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 60 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 61 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 62 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 63 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 64 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 65 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 66 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 67 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 68 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 69 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 70 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 71 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 72 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 73 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 74 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 75 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 76 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 77 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 78 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 79 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 80 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 81 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 82 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 83 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 84 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 85 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 86 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 87 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 88 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 89 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 90 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 91 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 92 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 93 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 94 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 95 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 96 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 97 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 98 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 99 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 100 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 101 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 102 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 103 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 104 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 105 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 106 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 107 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 108 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 109 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 110 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 111 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 112 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 113 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 114 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 115 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 116 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 117 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 118 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 119 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 120 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 121 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 122 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 123 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 124 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 125 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 126 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 127 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 128 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 129 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 130 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 131 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 132 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 133 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 134 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 135 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 136 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 137 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 138 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 139 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 140 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 141 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 142 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 143 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 144 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 145 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 146 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 147 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 148 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 149 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 150 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 151 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 152 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 153 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 154 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 155 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 156 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 157 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 158 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 159 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 160 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 161 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 162 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 163 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 164 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 165 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 166 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 167 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 168 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 169 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 170 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 171 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 172 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 173 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 174 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 175 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 176 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 177 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 178 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 179 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 180 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 181 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 182 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 183 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 184 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 185 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 186 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 187 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 188 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 189 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 190 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 191 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 192 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 193 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 194 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 195 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 196 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 197 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 198 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 199 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 200 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 201 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 202 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 203 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 204 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 205 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 206 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 207 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 208 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 209 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 210 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 211 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 212 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 213 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 214 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 215 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
Entering MG level 1
MatSOR_MPIAIJ: on rank 0 mat has 82 rows, 5282 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 1 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 2 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 3 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 4 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 5 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 6 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 7 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 8 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 9 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 10 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 11 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 12 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 13 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 14 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 15 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 16 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 17 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 18 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 19 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 20 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 21 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 22 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 23 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 24 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 25 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 26 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 27 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 28 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 29 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 30 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 31 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 32 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 33 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 34 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 35 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 36 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 37 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 38 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 39 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 40 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 41 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 42 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 43 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 44 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 45 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 46 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 47 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 48 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 49 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 50 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 51 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 52 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 53 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 54 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 55 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 56 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 57 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 58 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 59 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 60 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 61 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 62 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 63 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 64 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 65 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 66 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 67 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 68 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 69 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 70 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 71 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 72 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 73 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 74 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 75 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 76 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 77 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 78 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 79 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 80 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 81 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 82 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 83 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 84 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 85 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 86 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 87 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 88 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 89 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 90 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 91 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 92 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 93 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 94 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 95 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 96 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 97 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 98 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 99 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 100 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 101 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 102 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 103 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 104 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 105 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 106 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 107 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 108 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 109 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 110 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 111 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 112 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 113 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 114 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 115 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 116 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 117 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 118 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 119 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 120 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 121 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 122 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 123 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 124 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 125 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 126 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 127 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 128 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 129 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 130 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 131 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 132 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 133 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 134 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 135 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 136 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 137 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 138 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 139 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 140 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 141 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 142 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 143 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 144 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 145 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 146 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 147 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 148 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 149 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 150 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 151 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 152 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 153 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 154 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 155 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 156 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 157 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 158 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 159 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 160 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 161 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 162 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 163 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 164 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 165 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 166 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 167 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 168 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 169 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 170 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 171 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 172 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 173 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 174 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 175 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 176 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 177 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 178 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 179 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 180 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 181 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 182 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 183 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 184 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 185 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 186 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 187 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 188 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 189 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 190 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 191 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 192 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 193 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 194 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 195 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 196 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 197 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 198 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 199 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 200 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 201 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 202 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 203 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 204 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 205 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 206 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 207 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 208 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 209 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 210 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 211 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 212 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 213 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 214 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 215 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 0 mat has 82 rows, 5282 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 1 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 2 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 3 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 4 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 5 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 6 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 7 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 8 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 9 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 10 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 11 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 12 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 13 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 14 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 15 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 16 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 17 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 18 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 19 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 20 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 21 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 22 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 23 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 24 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 25 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 26 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 27 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 28 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 29 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 30 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 31 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 32 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 33 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 34 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 35 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 36 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 37 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 38 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 39 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 40 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 41 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 42 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 43 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 44 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 45 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 46 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 47 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 48 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 49 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 50 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 51 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 52 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 53 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 54 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 55 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 56 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 57 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 58 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 59 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 60 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 61 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 62 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 63 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 64 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 65 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 66 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 67 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 68 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 69 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 70 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 71 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 72 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 73 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 74 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 75 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 76 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 77 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 78 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 79 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 80 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 81 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 82 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 83 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 84 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 85 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 86 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 87 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 88 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 89 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 90 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 91 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 92 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 93 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 94 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 95 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 96 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 97 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 98 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 99 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 100 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 101 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 102 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 103 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 104 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 105 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 106 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 107 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 108 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 109 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 110 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 111 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 112 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 113 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 114 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 115 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 116 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 117 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 118 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 119 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 120 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 121 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 122 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 123 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 124 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 125 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 126 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 127 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 128 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 129 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 130 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 131 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 132 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 133 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 134 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 135 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 136 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 137 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 138 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 139 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 140 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 141 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 142 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 143 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 144 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 145 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 146 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 147 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 148 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 149 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 150 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 151 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 152 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 153 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 154 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 155 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 156 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 157 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 158 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 159 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 160 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 161 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 162 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 163 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 164 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 165 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 166 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 167 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 168 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 169 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 170 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 171 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 172 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 173 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 174 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 175 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 176 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 177 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 178 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 179 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 180 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 181 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 182 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 183 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 184 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 185 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 186 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 187 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 188 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 189 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 190 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 191 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 192 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 193 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 194 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 195 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 196 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 197 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 198 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 199 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 200 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 201 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 202 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 203 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 204 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 205 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 206 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 207 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 208 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 209 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 210 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 211 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 212 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 213 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 214 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMult_MPIAIJ: on rank 215 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
doing MatRestrict
MatMultTranspose_MPIAIJ: on rank 0 mat has 82 rows, 372 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 1 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 2 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 3 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 4 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 5 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 6 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 7 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 8 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 9 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 10 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 11 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 12 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 13 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 14 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 15 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 16 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 17 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 18 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 19 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 20 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 21 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 22 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 23 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 24 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 25 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 26 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 27 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 28 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 29 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 30 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 31 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 32 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 33 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 34 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 35 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 36 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 37 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 38 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 39 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 40 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 41 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 42 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 43 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 44 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 45 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 46 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 47 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 48 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 49 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 50 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 51 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 52 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 53 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 54 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 55 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 56 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 57 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 58 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 59 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 60 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 61 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 62 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 63 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 64 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 65 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 66 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 67 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 68 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 69 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 70 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 71 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 72 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 73 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 74 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 75 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 76 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 77 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 78 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 79 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 80 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 81 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 82 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 83 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 84 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 85 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 86 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 87 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 88 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 89 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 90 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 91 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 92 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 93 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 94 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 95 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 96 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 97 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 98 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 99 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 100 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 101 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 102 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 103 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 104 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 105 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 106 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 107 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 108 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 109 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 110 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 111 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 112 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 113 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 114 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 115 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 116 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 117 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 118 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 119 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 120 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 121 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 122 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 123 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 124 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 125 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 126 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 127 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 128 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 129 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 130 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 131 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 132 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 133 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 134 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 135 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 136 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 137 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 138 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 139 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 140 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 141 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 142 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 143 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 144 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 145 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 146 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 147 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 148 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 149 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 150 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 151 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 152 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 153 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 154 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 155 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 156 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 157 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 158 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 159 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 160 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 161 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 162 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 163 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 164 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 165 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 166 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 167 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 168 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 169 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 170 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 171 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 172 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 173 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 174 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 175 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 176 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 177 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 178 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 179 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 180 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 181 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 182 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 183 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 184 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 185 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 186 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 187 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 188 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 189 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 190 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 191 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 192 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 193 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 194 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 195 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 196 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 197 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 198 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 199 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 200 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 201 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 202 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 203 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 204 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 205 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 206 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 207 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 208 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 209 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 210 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 211 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 212 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 213 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 214 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatMultTranspose_MPIAIJ: on rank 215 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
Entering MG level 0
Leaving MG level 0
doing MatInterpolateAdd
MatSOR_MPIAIJ: on rank 0 mat has 82 rows, 5282 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 1 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 2 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 3 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 4 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 5 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 6 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 7 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 8 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 9 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 10 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 11 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 12 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 13 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 14 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 15 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 16 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 17 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 18 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 19 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 20 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 21 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 22 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 23 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 24 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 25 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 26 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 27 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 28 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 29 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 30 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 31 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 32 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 33 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 34 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 35 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 36 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 37 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 38 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 39 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 40 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 41 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 42 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 43 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 44 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 45 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 46 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 47 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 48 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 49 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 50 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 51 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 52 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 53 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 54 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 55 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 56 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 57 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 58 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 59 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 60 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 61 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 62 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 63 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 64 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 65 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 66 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 67 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 68 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 69 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 70 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 71 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 72 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 73 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 74 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 75 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 76 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 77 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 78 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 79 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 80 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 81 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 82 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 83 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 84 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 85 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 86 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 87 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 88 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 89 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 90 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 91 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 92 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 93 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 94 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 95 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 96 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 97 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 98 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 99 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 100 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 101 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 102 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 103 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 104 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 105 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 106 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 107 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 108 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 109 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 110 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 111 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 112 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 113 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 114 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 115 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 116 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 117 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 118 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 119 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 120 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 121 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 122 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 123 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 124 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 125 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 126 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 127 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 128 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 129 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 130 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 131 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 132 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 133 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 134 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 135 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 136 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 137 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 138 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 139 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 140 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 141 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 142 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 143 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 144 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 145 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 146 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 147 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 148 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 149 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 150 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 151 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 152 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 153 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 154 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 155 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 156 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 157 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 158 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 159 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 160 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 161 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 162 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 163 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 164 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 165 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 166 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 167 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 168 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 169 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 170 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 171 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 172 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 173 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 174 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 175 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 176 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 177 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 178 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 179 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 180 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 181 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 182 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 183 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 184 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 185 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 186 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 187 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 188 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 189 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 190 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 191 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 192 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 193 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 194 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 195 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 196 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 197 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 198 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 199 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 200 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 201 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 202 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 203 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 204 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 205 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 206 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 207 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 208 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 209 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 210 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 211 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 212 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 213 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 214 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
MatSOR_MPIAIJ: on rank 215 mat has 0 rows, 0 nonzeros, send 0 to 0 nbrs,recv 0 from 0 nbrs
Leaving MG level 1
MatSOR_MPIAIJ: on rank 0 mat has 49 rows, 3902 nonzeros, send 221 to 7 nbrs,recv 221 from 7 nbrs
MatSOR_MPIAIJ: on rank 1 mat has 48 rows, 4700 nonzeros, send 310 to 8 nbrs,recv 307 from 8 nbrs
MatSOR_MPIAIJ: on rank 2 mat has 63 rows, 5078 nonzeros, send 242 to 7 nbrs,recv 222 from 7 nbrs
MatSOR_MPIAIJ: on rank 3 mat has 51 rows, 5217 nonzeros, send 322 to 8 nbrs,recv 304 from 8 nbrs
MatSOR_MPIAIJ: on rank 4 mat has 51 rows, 6635 nonzeros, send 483 to 12 nbrs,recv 448 from 12 nbrs
MatSOR_MPIAIJ: on rank 5 mat has 59 rows, 6539 nonzeros, send 334 to 10 nbrs,recv 344 from 10 nbrs
MatSOR_MPIAIJ: on rank 6 mat has 45 rows, 4687 nonzeros, send 330 to 10 nbrs,recv 355 from 10 nbrs
MatSOR_MPIAIJ: on rank 7 mat has 48 rows, 6232 nonzeros, send 524 to 15 nbrs,recv 547 from 15 nbrs
MatSOR_MPIAIJ: on rank 8 mat has 56 rows, 6125 nonzeros, send 370 to 11 nbrs,recv 422 from 11 nbrs
MatSOR_MPIAIJ: on rank 9 mat has 46 rows, 4899 nonzeros, send 352 to 9 nbrs,recv 367 from 9 nbrs
MatSOR_MPIAIJ: on rank 10 mat has 48 rows, 6388 nonzeros, send 526 to 14 nbrs,recv 532 from 14 nbrs
MatSOR_MPIAIJ: on rank 11 mat has 57 rows, 6229 nonzeros, send 388 to 10 nbrs,recv 409 from 10 nbrs
MatSOR_MPIAIJ: on rank 12 mat has 46 rows, 4838 nonzeros, send 297 to 8 nbrs,recv 321 from 8 nbrs
MatSOR_MPIAIJ: on rank 13 mat has 48 rows, 6357 nonzeros, send 447 to 13 nbrs,recv 481 from 13 nbrs
MatSOR_MPIAIJ: on rank 14 mat has 57 rows, 6198 nonzeros, send 324 to 8 nbrs,recv 371 from 8 nbrs
MatSOR_MPIAIJ: on rank 15 mat has 72 rows, 5800 nonzeros, send 298 to 7 nbrs,recv 231 from 7 nbrs
MatSOR_MPIAIJ: on rank 16 mat has 68 rows, 7192 nonzeros, send 410 to 10 nbrs,recv 355 from 10 nbrs
MatSOR_MPIAIJ: on rank 17 mat has 91 rows, 7633 nonzeros, send 311 to 7 nbrs,recv 252 from 7 nbrs
Leaving MG level 2
MatSOR_MPIAIJ: on rank 0 mat has 59 rows, 3423 nonzeros, send 150 to 7 nbrs,recv 187 from 7 nbrs
MatSOR_MPIAIJ: on rank 1 mat has 61 rows, 4204 nonzeros, send 230 to 11 nbrs,recv 235 from 11 nbrs
MatSOR_MPIAIJ: on rank 2 mat has 62 rows, 4416 nonzeros, send 249 to 11 nbrs,recv 247 from 11 nbrs
MatSOR_MPIAIJ: on rank 3 mat has 62 rows, 4410 nonzeros, send 249 to 11 nbrs,recv 247 from 11 nbrs
MatSOR_MPIAIJ: on rank 4 mat has 62 rows, 4428 nonzeros, send 250 to 11 nbrs,recv 244 from 11 nbrs
MatSOR_MPIAIJ: on rank 5 mat has 70 rows, 4301 nonzeros, send 183 to 7 nbrs,recv 178 from 7 nbrs
MatSOR_MPIAIJ: on rank 6 mat has 63 rows, 4233 nonzeros, send 236 to 11 nbrs,recv 244 from 11 nbrs
MatSOR_MPIAIJ: on rank 7 mat has 64 rows, 5065 nonzeros, send 335 to 17 nbrs,recv 345 from 17 nbrs
MatSOR_MPIAIJ: on rank 8 mat has 67 rows, 5449 nonzeros, send 344 to 17 nbrs,recv 363 from 17 nbrs
MatSOR_MPIAIJ: on rank 9 mat has 67 rows, 5460 nonzeros, send 344 to 17 nbrs,recv 367 from 17 nbrs
MatSOR_MPIAIJ: on rank 10 mat has 67 rows, 5447 nonzeros, send 345 to 17 nbrs,recv 367 from 17 nbrs
MatSOR_MPIAIJ: on rank 11 mat has 70 rows, 4812 nonzeros, send 238 to 11 nbrs,recv 261 from 11 nbrs
MatSOR_MPIAIJ: on rank 12 mat has 61 rows, 4135 nonzeros, send 233 to 11 nbrs,recv 243 from 11 nbrs
MatSOR_MPIAIJ: on rank 13 mat has 64 rows, 5023 nonzeros, send 332 to 17 nbrs,recv 357 from 17 nbrs
MatSOR_MPIAIJ: on rank 14 mat has 64 rows, 5042 nonzeros, send 331 to 17 nbrs,recv 376 from 17 nbrs
MatSOR_MPIAIJ: on rank 15 mat has 64 rows, 5055 nonzeros, send 331 to 17 nbrs,recv 379 from 17 nbrs
MatSOR_MPIAIJ: on rank 16 mat has 64 rows, 5030 nonzeros, send 329 to 17 nbrs,recv 370 from 17 nbrs
MatSOR_MPIAIJ: on rank 17 mat has 70 rows, 4748 nonzeros, send 248 to 11 nbrs,recv 256 from 11 nbrs
MatSOR_MPIAIJ: on rank 18 mat has 61 rows, 4092 nonzeros, send 232 to 11 nbrs,recv 241 from 11 nbrs
MatSOR_MPIAIJ: on rank 19 mat has 64 rows, 5001 nonzeros, send 329 to 17 nbrs,recv 351 from 17 nbrs
MatSOR_MPIAIJ: on rank 20 mat has 64 rows, 5034 nonzeros, send 334 to 17 nbrs,recv 374 from 17 nbrs
MatSOR_MPIAIJ: on rank 21 mat has 64 rows, 5048 nonzeros, send 334 to 17 nbrs,recv 377 from 17 nbrs
MatSOR_MPIAIJ: on rank 22 mat has 64 rows, 5013 nonzeros, send 331 to 17 nbrs,recv 368 from 17 nbrs
MatSOR_MPIAIJ: on rank 23 mat has 70 rows, 4747 nonzeros, send 248 to 11 nbrs,recv 256 from 11 nbrs
MatSOR_MPIAIJ: on rank 24 mat has 61 rows, 4096 nonzeros, send 232 to 11 nbrs,recv 244 from 11 nbrs
MatSOR_MPIAIJ: on rank 25 mat has 64 rows, 5000 nonzeros, send 329 to 17 nbrs,recv 348 from 17 nbrs
MatSOR_MPIAIJ: on rank 26 mat has 64 rows, 5017 nonzeros, send 334 to 17 nbrs,recv 368 from 17 nbrs
MatSOR_MPIAIJ: on rank 27 mat has 64 rows, 5028 nonzeros, send 334 to 17 nbrs,recv 369 from 17 nbrs
MatSOR_MPIAIJ: on rank 28 mat has 64 rows, 5001 nonzeros, send 331 to 17 nbrs,recv 365 from 17 nbrs
MatSOR_MPIAIJ: on rank 29 mat has 70 rows, 4747 nonzeros, send 248 to 11 nbrs,recv 256 from 11 nbrs
MatSOR_MPIAIJ: on rank 30 mat has 69 rows, 4088 nonzeros, send 177 to 7 nbrs,recv 175 from 7 nbrs
MatSOR_MPIAIJ: on rank 31 mat has 70 rows, 4859 nonzeros, send 256 to 11 nbrs,recv 246 from 11 nbrs
MatSOR_MPIAIJ: on rank 32 mat has 69 rows, 4799 nonzeros, send 248 to 11 nbrs,recv 254 from 11 nbrs
MatSOR_MPIAIJ: on rank 33 mat has 69 rows, 4810 nonzeros, send 247 to 11 nbrs,recv 258 from 11 nbrs
MatSOR_MPIAIJ: on rank 34 mat has 70 rows, 4837 nonzeros, send 244 to 11 nbrs,recv 262 from 11 nbrs
MatSOR_MPIAIJ: on rank 35 mat has 80 rows, 4925 nonzeros, send 200 to 7 nbrs,recv 187 from 7 nbrs
MatSOR_MPIAIJ: on rank 36 mat has 61 rows, 4039 nonzeros, send 220 to 11 nbrs,recv 241 from 11 nbrs
MatSOR_MPIAIJ: on rank 37 mat has 65 rows, 5024 nonzeros, send 324 to 17 nbrs,recv 324 from 17 nbrs
MatSOR_MPIAIJ: on rank 38 mat has 64 rows, 5078 nonzeros, send 332 to 17 nbrs,recv 333 from 17 nbrs
MatSOR_MPIAIJ: on rank 39 mat has 64 rows, 5079 nonzeros, send 332 to 17 nbrs,recv 332 from 17 nbrs
MatSOR_MPIAIJ: on rank 40 mat has 63 rows, 4982 nonzeros, send 329 to 17 nbrs,recv 330 from 17 nbrs
MatSOR_MPIAIJ: on rank 41 mat has 71 rows, 4979 nonzeros, send 254 to 11 nbrs,recv 243 from 11 nbrs
MatSOR_MPIAIJ: on rank 42 mat has 59 rows, 4536 nonzeros, send 305 to 17 nbrs,recv 325 from 17 nbrs
MatSOR_MPIAIJ: on rank 43 mat has 66 rows, 5836 nonzeros, send 444 to 26 nbrs,recv 450 from 26 nbrs
MatSOR_MPIAIJ: on rank 44 mat has 66 rows, 5954 nonzeros, send 448 to 26 nbrs,recv 461 from 26 nbrs
MatSOR_MPIAIJ: on rank 45 mat has 66 rows, 5955 nonzeros, send 448 to 26 nbrs,recv 460 from 26 nbrs
MatSOR_MPIAIJ: on rank 46 mat has 65 rows, 5850 nonzeros, send 437 to 26 nbrs,recv 453 from 26 nbrs
MatSOR_MPIAIJ: on rank 47 mat has 69 rows, 5472 nonzeros, send 338 to 17 nbrs,recv 349 from 17 nbrs
MatSOR_MPIAIJ: on rank 48 mat has 60 rows, 4602 nonzeros, send 300 to 17 nbrs,recv 338 from 17 nbrs
MatSOR_MPIAIJ: on rank 49 mat has 66 rows, 5866 nonzeros, send 456 to 26 nbrs,recv 443 from 26 nbrs
MatSOR_MPIAIJ: on rank 50 mat has 66 rows, 5924 nonzeros, send 459 to 26 nbrs,recv 445 from 26 nbrs
MatSOR_MPIAIJ: on rank 51 mat has 66 rows, 5930 nonzeros, send 463 to 26 nbrs,recv 445 from 26 nbrs
MatSOR_MPIAIJ: on rank 52 mat has 65 rows, 5842 nonzeros, send 456 to 26 nbrs,recv 436 from 26 nbrs
MatSOR_MPIAIJ: on rank 53 mat has 70 rows, 5594 nonzeros, send 363 to 17 nbrs,recv 347 from 17 nbrs
MatSOR_MPIAIJ: on rank 54 mat has 60 rows, 4600 nonzeros, send 301 to 17 nbrs,recv 335 from 17 nbrs
MatSOR_MPIAIJ: on rank 55 mat has 66 rows, 5850 nonzeros, send 458 to 26 nbrs,recv 442 from 26 nbrs
MatSOR_MPIAIJ: on rank 56 mat has 66 rows, 5896 nonzeros, send 466 to 26 nbrs,recv 439 from 26 nbrs
MatSOR_MPIAIJ: on rank 57 mat has 66 rows, 5902 nonzeros, send 470 to 26 nbrs,recv 439 from 26 nbrs
MatSOR_MPIAIJ: on rank 58 mat has 65 rows, 5826 nonzeros, send 458 to 26 nbrs,recv 430 from 26 nbrs
MatSOR_MPIAIJ: on rank 59 mat has 70 rows, 5595 nonzeros, send 363 to 17 nbrs,recv 348 from 17 nbrs
MatSOR_MPIAIJ: on rank 60 mat has 60 rows, 4599 nonzeros, send 301 to 17 nbrs,recv 334 from 17 nbrs
MatSOR_MPIAIJ: on rank 61 mat has 66 rows, 5851 nonzeros, send 457 to 26 nbrs,recv 443 from 26 nbrs
MatSOR_MPIAIJ: on rank 62 mat has 66 rows, 5893 nonzeros, send 464 to 26 nbrs,recv 439 from 26 nbrs
MatSOR_MPIAIJ: on rank 63 mat has 66 rows, 5899 nonzeros, send 468 to 26 nbrs,recv 439 from 26 nbrs
MatSOR_MPIAIJ: on rank 64 mat has 65 rows, 5831 nonzeros, send 457 to 26 nbrs,recv 433 from 26 nbrs
MatSOR_MPIAIJ: on rank 65 mat has 70 rows, 5597 nonzeros, send 361 to 17 nbrs,recv 350 from 17 nbrs
MatSOR_MPIAIJ: on rank 66 mat has 68 rows, 4617 nonzeros, send 240 to 11 nbrs,recv 259 from 11 nbrs
MatSOR_MPIAIJ: on rank 67 mat has 72 rows, 5752 nonzeros, send 358 to 17 nbrs,recv 346 from 17 nbrs
MatSOR_MPIAIJ: on rank 68 mat has 72 rows, 5774 nonzeros, send 365 to 17 nbrs,recv 341 from 17 nbrs
MatSOR_MPIAIJ: on rank 69 mat has 72 rows, 5773 nonzeros, send 365 to 17 nbrs,recv 343 from 17 nbrs
MatSOR_MPIAIJ: on rank 70 mat has 72 rows, 5821 nonzeros, send 360 to 17 nbrs,recv 339 from 17 nbrs
MatSOR_MPIAIJ: on rank 71 mat has 84 rows, 5942 nonzeros, send 300 to 11 nbrs,recv 270 from 11 nbrs
MatSOR_MPIAIJ: on rank 72 mat has 62 rows, 4246 nonzeros, send 243 to 11 nbrs,recv 242 from 11 nbrs
MatSOR_MPIAIJ: on rank 73 mat has 62 rows, 4852 nonzeros, send 316 to 17 nbrs,recv 328 from 17 nbrs
MatSOR_MPIAIJ: on rank 74 mat has 61 rows, 4755 nonzeros, send 325 to 17 nbrs,recv 333 from 17 nbrs
MatSOR_MPIAIJ: on rank 75 mat has 61 rows, 4755 nonzeros, send 325 to 17 nbrs,recv 333 from 17 nbrs
MatSOR_MPIAIJ: on rank 76 mat has 61 rows, 4731 nonzeros, send 325 to 17 nbrs,recv 329 from 17 nbrs
MatSOR_MPIAIJ: on rank 77 mat has 71 rows, 4865 nonzeros, send 252 to 11 nbrs,recv 249 from 11 nbrs
MatSOR_MPIAIJ: on rank 78 mat has 61 rows, 4683 nonzeros, send 308 to 17 nbrs,recv 327 from 17 nbrs
MatSOR_MPIAIJ: on rank 79 mat has 66 rows, 5852 nonzeros, send 436 to 26 nbrs,recv 444 from 26 nbrs
MatSOR_MPIAIJ: on rank 80 mat has 66 rows, 5889 nonzeros, send 439 to 26 nbrs,recv 446 from 26 nbrs
MatSOR_MPIAIJ: on rank 81 mat has 66 rows, 5889 nonzeros, send 439 to 26 nbrs,recv 446 from 26 nbrs
MatSOR_MPIAIJ: on rank 82 mat has 67 rows, 5937 nonzeros, send 442 to 26 nbrs,recv 447 from 26 nbrs
MatSOR_MPIAIJ: on rank 83 mat has 70 rows, 5401 nonzeros, send 337 to 17 nbrs,recv 345 from 17 nbrs
MatSOR_MPIAIJ: on rank 84 mat has 62 rows, 4713 nonzeros, send 301 to 17 nbrs,recv 330 from 17 nbrs
MatSOR_MPIAIJ: on rank 85 mat has 65 rows, 5788 nonzeros, send 442 to 26 nbrs,recv 429 from 26 nbrs
MatSOR_MPIAIJ: on rank 86 mat has 65 rows, 5760 nonzeros, send 435 to 26 nbrs,recv 438 from 26 nbrs
MatSOR_MPIAIJ: on rank 87 mat has 65 rows, 5760 nonzeros, send 435 to 26 nbrs,recv 438 from 26 nbrs
MatSOR_MPIAIJ: on rank 88 mat has 66 rows, 5807 nonzeros, send 439 to 26 nbrs,recv 439 from 26 nbrs
MatSOR_MPIAIJ: on rank 89 mat has 71 rows, 5476 nonzeros, send 348 to 17 nbrs,recv 348 from 17 nbrs
MatSOR_MPIAIJ: on rank 90 mat has 62 rows, 4713 nonzeros, send 301 to 17 nbrs,recv 330 from 17 nbrs
MatSOR_MPIAIJ: on rank 91 mat has 65 rows, 5788 nonzeros, send 442 to 26 nbrs,recv 429 from 26 nbrs
MatSOR_MPIAIJ: on rank 92 mat has 65 rows, 5760 nonzeros, send 435 to 26 nbrs,recv 438 from 26 nbrs
MatSOR_MPIAIJ: on rank 93 mat has 65 rows, 5760 nonzeros, send 435 to 26 nbrs,recv 438 from 26 nbrs
MatSOR_MPIAIJ: on rank 94 mat has 66 rows, 5807 nonzeros, send 439 to 26 nbrs,recv 439 from 26 nbrs
MatSOR_MPIAIJ: on rank 95 mat has 71 rows, 5477 nonzeros, send 348 to 17 nbrs,recv 347 from 17 nbrs
MatSOR_MPIAIJ: on rank 96 mat has 62 rows, 4705 nonzeros, send 301 to 17 nbrs,recv 327 from 17 nbrs
MatSOR_MPIAIJ: on rank 97 mat has 65 rows, 5775 nonzeros, send 440 to 26 nbrs,recv 427 from 26 nbrs
MatSOR_MPIAIJ: on rank 98 mat has 65 rows, 5747 nonzeros, send 433 to 26 nbrs,recv 435 from 26 nbrs
MatSOR_MPIAIJ: on rank 99 mat has 65 rows, 5747 nonzeros, send 433 to 26 nbrs,recv 435 from 26 nbrs
MatSOR_MPIAIJ: on rank 100 mat has 66 rows, 5797 nonzeros, send 437 to 26 nbrs,recv 438 from 26 nbrs
MatSOR_MPIAIJ: on rank 101 mat has 71 rows, 5480 nonzeros, send 348 to 17 nbrs,recv 347 from 17 nbrs
MatSOR_MPIAIJ: on rank 102 mat has 69 rows, 4602 nonzeros, send 232 to 11 nbrs,recv 248 from 11 nbrs
MatSOR_MPIAIJ: on rank 103 mat has 71 rows, 5555 nonzeros, send 343 to 17 nbrs,recv 323 from 17 nbrs
MatSOR_MPIAIJ: on rank 104 mat has 71 rows, 5506 nonzeros, send 344 to 17 nbrs,recv 329 from 17 nbrs
MatSOR_MPIAIJ: on rank 105 mat has 71 rows, 5506 nonzeros, send 344 to 17 nbrs,recv 329 from 17 nbrs
MatSOR_MPIAIJ: on rank 106 mat has 72 rows, 5558 nonzeros, send 344 to 17 nbrs,recv 327 from 17 nbrs
MatSOR_MPIAIJ: on rank 107 mat has 82 rows, 5714 nonzeros, send 282 to 11 nbrs,recv 268 from 11 nbrs
MatSOR_MPIAIJ: on rank 108 mat has 62 rows, 4266 nonzeros, send 241 to 11 nbrs,recv 245 from 11 nbrs
MatSOR_MPIAIJ: on rank 109 mat has 62 rows, 4815 nonzeros, send 318 to 17 nbrs,recv 327 from 17 nbrs
MatSOR_MPIAIJ: on rank 110 mat has 61 rows, 4696 nonzeros, send 317 to 17 nbrs,recv 326 from 17 nbrs
MatSOR_MPIAIJ: on rank 111 mat has 61 rows, 4696 nonzeros, send 317 to 17 nbrs,recv 326 from 17 nbrs
MatSOR_MPIAIJ: on rank 112 mat has 61 rows, 4721 nonzeros, send 321 to 17 nbrs,recv 327 from 17 nbrs
MatSOR_MPIAIJ: on rank 113 mat has 71 rows, 4828 nonzeros, send 254 to 11 nbrs,recv 241 from 11 nbrs
MatSOR_MPIAIJ: on rank 114 mat has 61 rows, 4706 nonzeros, send 305 to 17 nbrs,recv 327 from 17 nbrs
MatSOR_MPIAIJ: on rank 115 mat has 66 rows, 5853 nonzeros, send 431 to 26 nbrs,recv 447 from 26 nbrs
MatSOR_MPIAIJ: on rank 116 mat has 66 rows, 5888 nonzeros, send 434 to 26 nbrs,recv 446 from 26 nbrs
MatSOR_MPIAIJ: on rank 117 mat has 66 rows, 5888 nonzeros, send 434 to 26 nbrs,recv 446 from 26 nbrs
MatSOR_MPIAIJ: on rank 118 mat has 67 rows, 5946 nonzeros, send 440 to 26 nbrs,recv 445 from 26 nbrs
MatSOR_MPIAIJ: on rank 119 mat has 70 rows, 5344 nonzeros, send 332 to 17 nbrs,recv 340 from 17 nbrs
MatSOR_MPIAIJ: on rank 120 mat has 62 rows, 4734 nonzeros, send 306 to 17 nbrs,recv 328 from 17 nbrs
MatSOR_MPIAIJ: on rank 121 mat has 65 rows, 5783 nonzeros, send 445 to 26 nbrs,recv 429 from 26 nbrs
MatSOR_MPIAIJ: on rank 122 mat has 65 rows, 5727 nonzeros, send 433 to 26 nbrs,recv 433 from 26 nbrs
MatSOR_MPIAIJ: on rank 123 mat has 65 rows, 5727 nonzeros, send 433 to 26 nbrs,recv 433 from 26 nbrs
MatSOR_MPIAIJ: on rank 124 mat has 66 rows, 5787 nonzeros, send 438 to 26 nbrs,recv 435 from 26 nbrs
MatSOR_MPIAIJ: on rank 125 mat has 71 rows, 5433 nonzeros, send 342 to 17 nbrs,recv 339 from 17 nbrs
MatSOR_MPIAIJ: on rank 126 mat has 62 rows, 4734 nonzeros, send 306 to 17 nbrs,recv 328 from 17 nbrs
MatSOR_MPIAIJ: on rank 127 mat has 65 rows, 5783 nonzeros, send 445 to 26 nbrs,recv 429 from 26 nbrs
MatSOR_MPIAIJ: on rank 128 mat has 65 rows, 5727 nonzeros, send 433 to 26 nbrs,recv 433 from 26 nbrs
MatSOR_MPIAIJ: on rank 129 mat has 65 rows, 5727 nonzeros, send 433 to 26 nbrs,recv 433 from 26 nbrs
MatSOR_MPIAIJ: on rank 130 mat has 66 rows, 5787 nonzeros, send 438 to 26 nbrs,recv 435 from 26 nbrs
MatSOR_MPIAIJ: on rank 131 mat has 71 rows, 5436 nonzeros, send 342 to 17 nbrs,recv 339 from 17 nbrs
MatSOR_MPIAIJ: on rank 132 mat has 62 rows, 4724 nonzeros, send 306 to 17 nbrs,recv 326 from 17 nbrs
MatSOR_MPIAIJ: on rank 133 mat has 65 rows, 5770 nonzeros, send 445 to 26 nbrs,recv 424 from 26 nbrs
MatSOR_MPIAIJ: on rank 134 mat has 65 rows, 5714 nonzeros, send 433 to 26 nbrs,recv 427 from 26 nbrs
MatSOR_MPIAIJ: on rank 135 mat has 65 rows, 5714 nonzeros, send 433 to 26 nbrs,recv 427 from 26 nbrs
MatSOR_MPIAIJ: on rank 136 mat has 66 rows, 5780 nonzeros, send 438 to 26 nbrs,recv 433 from 26 nbrs
MatSOR_MPIAIJ: on rank 137 mat has 71 rows, 5438 nonzeros, send 342 to 17 nbrs,recv 340 from 17 nbrs
MatSOR_MPIAIJ: on rank 138 mat has 69 rows, 4637 nonzeros, send 238 to 11 nbrs,recv 251 from 11 nbrs
MatSOR_MPIAIJ: on rank 139 mat has 71 rows, 5583 nonzeros, send 350 to 17 nbrs,recv 326 from 17 nbrs
MatSOR_MPIAIJ: on rank 140 mat has 71 rows, 5529 nonzeros, send 346 to 17 nbrs,recv 331 from 17 nbrs
MatSOR_MPIAIJ: on rank 141 mat has 71 rows, 5529 nonzeros, send 346 to 17 nbrs,recv 331 from 17 nbrs
MatSOR_MPIAIJ: on rank 142 mat has 72 rows, 5588 nonzeros, send 350 to 17 nbrs,recv 328 from 17 nbrs
MatSOR_MPIAIJ: on rank 143 mat has 82 rows, 5660 nonzeros, send 283 to 11 nbrs,recv 267 from 11 nbrs
MatSOR_MPIAIJ: on rank 144 mat has 62 rows, 4265 nonzeros, send 241 to 11 nbrs,recv 244 from 11 nbrs
MatSOR_MPIAIJ: on rank 145 mat has 62 rows, 4815 nonzeros, send 318 to 17 nbrs,recv 327 from 17 nbrs
MatSOR_MPIAIJ: on rank 146 mat has 61 rows, 4696 nonzeros, send 317 to 17 nbrs,recv 326 from 17 nbrs
MatSOR_MPIAIJ: on rank 147 mat has 61 rows, 4696 nonzeros, send 317 to 17 nbrs,recv 326 from 17 nbrs
MatSOR_MPIAIJ: on rank 148 mat has 61 rows, 4721 nonzeros, send 321 to 17 nbrs,recv 327 from 17 nbrs
MatSOR_MPIAIJ: on rank 149 mat has 71 rows, 4828 nonzeros, send 254 to 11 nbrs,recv 241 from 11 nbrs
MatSOR_MPIAIJ: on rank 150 mat has 61 rows, 4706 nonzeros, send 305 to 17 nbrs,recv 327 from 17 nbrs
MatSOR_MPIAIJ: on rank 151 mat has 66 rows, 5853 nonzeros, send 431 to 26 nbrs,recv 447 from 26 nbrs
MatSOR_MPIAIJ: on rank 152 mat has 66 rows, 5888 nonzeros, send 434 to 26 nbrs,recv 446 from 26 nbrs
MatSOR_MPIAIJ: on rank 153 mat has 66 rows, 5888 nonzeros, send 434 to 26 nbrs,recv 446 from 26 nbrs
MatSOR_MPIAIJ: on rank 154 mat has 67 rows, 5946 nonzeros, send 440 to 26 nbrs,recv 445 from 26 nbrs
MatSOR_MPIAIJ: on rank 155 mat has 70 rows, 5344 nonzeros, send 332 to 17 nbrs,recv 340 from 17 nbrs
MatSOR_MPIAIJ: on rank 156 mat has 62 rows, 4734 nonzeros, send 306 to 17 nbrs,recv 328 from 17 nbrs
MatSOR_MPIAIJ: on rank 157 mat has 65 rows, 5783 nonzeros, send 445 to 26 nbrs,recv 429 from 26 nbrs
MatSOR_MPIAIJ: on rank 158 mat has 65 rows, 5727 nonzeros, send 433 to 26 nbrs,recv 433 from 26 nbrs
MatSOR_MPIAIJ: on rank 159 mat has 65 rows, 5727 nonzeros, send 433 to 26 nbrs,recv 433 from 26 nbrs
MatSOR_MPIAIJ: on rank 160 mat has 66 rows, 5787 nonzeros, send 438 to 26 nbrs,recv 435 from 26 nbrs
MatSOR_MPIAIJ: on rank 161 mat has 71 rows, 5433 nonzeros, send 342 to 17 nbrs,recv 339 from 17 nbrs
MatSOR_MPIAIJ: on rank 162 mat has 62 rows, 4734 nonzeros, send 306 to 17 nbrs,recv 328 from 17 nbrs
MatSOR_MPIAIJ: on rank 163 mat has 65 rows, 5783 nonzeros, send 445 to 26 nbrs,recv 429 from 26 nbrs
MatSOR_MPIAIJ: on rank 164 mat has 65 rows, 5727 nonzeros, send 433 to 26 nbrs,recv 433 from 26 nbrs
MatSOR_MPIAIJ: on rank 165 mat has 65 rows, 5727 nonzeros, send 433 to 26 nbrs,recv 433 from 26 nbrs
MatSOR_MPIAIJ: on rank 166 mat has 66 rows, 5787 nonzeros, send 438 to 26 nbrs,recv 435 from 26 nbrs
MatSOR_MPIAIJ: on rank 167 mat has 71 rows, 5436 nonzeros, send 342 to 17 nbrs,recv 339 from 17 nbrs
MatSOR_MPIAIJ: on rank 168 mat has 62 rows, 4724 nonzeros, send 306 to 17 nbrs,recv 326 from 17 nbrs
MatSOR_MPIAIJ: on rank 169 mat has 65 rows, 5770 nonzeros, send 445 to 26 nbrs,recv 424 from 26 nbrs
MatSOR_MPIAIJ: on rank 170 mat has 65 rows, 5714 nonzeros, send 433 to 26 nbrs,recv 427 from 26 nbrs
MatSOR_MPIAIJ: on rank 171 mat has 65 rows, 5714 nonzeros, send 433 to 26 nbrs,recv 427 from 26 nbrs
MatSOR_MPIAIJ: on rank 172 mat has 66 rows, 5780 nonzeros, send 438 to 26 nbrs,recv 433 from 26 nbrs
MatSOR_MPIAIJ: on rank 173 mat has 71 rows, 5438 nonzeros, send 342 to 17 nbrs,recv 340 from 17 nbrs
MatSOR_MPIAIJ: on rank 174 mat has 69 rows, 4637 nonzeros, send 238 to 11 nbrs,recv 251 from 11 nbrs
MatSOR_MPIAIJ: on rank 175 mat has 71 rows, 5583 nonzeros, send 350 to 17 nbrs,recv 326 from 17 nbrs
MatSOR_MPIAIJ: on rank 176 mat has 71 rows, 5529 nonzeros, send 346 to 17 nbrs,recv 331 from 17 nbrs
MatSOR_MPIAIJ: on rank 177 mat has 71 rows, 5529 nonzeros, send 346 to 17 nbrs,recv 331 from 17 nbrs
MatSOR_MPIAIJ: on rank 178 mat has 72 rows, 5588 nonzeros, send 350 to 17 nbrs,recv 328 from 17 nbrs
MatSOR_MPIAIJ: on rank 179 mat has 82 rows, 5660 nonzeros, send 283 to 11 nbrs,recv 267 from 11 nbrs
MatSOR_MPIAIJ: on rank 180 mat has 62 rows, 3751 nonzeros, send 167 to 7 nbrs,recv 168 from 7 nbrs
MatSOR_MPIAIJ: on rank 181 mat has 66 rows, 4558 nonzeros, send 238 to 11 nbrs,recv 230 from 11 nbrs
MatSOR_MPIAIJ: on rank 182 mat has 64 rows, 4330 nonzeros, send 234 to 11 nbrs,recv 226 from 11 nbrs
MatSOR_MPIAIJ: on rank 183 mat has 64 rows, 4330 nonzeros, send 234 to 11 nbrs,recv 226 from 11 nbrs
MatSOR_MPIAIJ: on rank 184 mat has 65 rows, 4397 nonzeros, send 242 to 11 nbrs,recv 229 from 11 nbrs
MatSOR_MPIAIJ: on rank 185 mat has 75 rows, 4523 nonzeros, send 184 to 7 nbrs,recv 166 from 7 nbrs
MatSOR_MPIAIJ: on rank 186 mat has 68 rows, 4606 nonzeros, send 240 to 11 nbrs,recv 241 from 11 nbrs
MatSOR_MPIAIJ: on rank 187 mat has 74 rows, 5871 nonzeros, send 348 to 17 nbrs,recv 350 from 17 nbrs
MatSOR_MPIAIJ: on rank 188 mat has 74 rows, 5896 nonzeros, send 354 to 17 nbrs,recv 351 from 17 nbrs
MatSOR_MPIAIJ: on rank 189 mat has 74 rows, 5896 nonzeros, send 354 to 17 nbrs,recv 351 from 17 nbrs
MatSOR_MPIAIJ: on rank 190 mat has 72 rows, 5743 nonzeros, send 343 to 17 nbrs,recv 346 from 17 nbrs
MatSOR_MPIAIJ: on rank 191 mat has 84 rows, 5850 nonzeros, send 283 to 11 nbrs,recv 259 from 11 nbrs
MatSOR_MPIAIJ: on rank 192 mat has 68 rows, 4561 nonzeros, send 245 to 11 nbrs,recv 234 from 11 nbrs
MatSOR_MPIAIJ: on rank 193 mat has 73 rows, 5817 nonzeros, send 364 to 17 nbrs,recv 334 from 17 nbrs
MatSOR_MPIAIJ: on rank 194 mat has 73 rows, 5820 nonzeros, send 359 to 17 nbrs,recv 344 from 17 nbrs
MatSOR_MPIAIJ: on rank 195 mat has 73 rows, 5820 nonzeros, send 359 to 17 nbrs,recv 344 from 17 nbrs
MatSOR_MPIAIJ: on rank 196 mat has 71 rows, 5670 nonzeros, send 347 to 17 nbrs,recv 342 from 17 nbrs
MatSOR_MPIAIJ: on rank 197 mat has 80 rows, 5609 nonzeros, send 282 to 11 nbrs,recv 263 from 11 nbrs
MatSOR_MPIAIJ: on rank 198 mat has 68 rows, 4561 nonzeros, send 245 to 11 nbrs,recv 234 from 11 nbrs
MatSOR_MPIAIJ: on rank 199 mat has 73 rows, 5817 nonzeros, send 364 to 17 nbrs,recv 334 from 17 nbrs
MatSOR_MPIAIJ: on rank 200 mat has 73 rows, 5820 nonzeros, send 359 to 17 nbrs,recv 344 from 17 nbrs
MatSOR_MPIAIJ: on rank 201 mat has 73 rows, 5820 nonzeros, send 359 to 17 nbrs,recv 344 from 17 nbrs
MatSOR_MPIAIJ: on rank 202 mat has 71 rows, 5670 nonzeros, send 347 to 17 nbrs,recv 342 from 17 nbrs
MatSOR_MPIAIJ: on rank 203 mat has 80 rows, 5603 nonzeros, send 282 to 11 nbrs,recv 261 from 11 nbrs
MatSOR_MPIAIJ: on rank 204 mat has 68 rows, 4553 nonzeros, send 245 to 11 nbrs,recv 233 from 11 nbrs
MatSOR_MPIAIJ: on rank 205 mat has 73 rows, 5821 nonzeros, send 364 to 17 nbrs,recv 329 from 17 nbrs
MatSOR_MPIAIJ: on rank 206 mat has 73 rows, 5824 nonzeros, send 359 to 17 nbrs,recv 339 from 17 nbrs
MatSOR_MPIAIJ: on rank 207 mat has 73 rows, 5824 nonzeros, send 359 to 17 nbrs,recv 339 from 17 nbrs
MatSOR_MPIAIJ: on rank 208 mat has 71 rows, 5688 nonzeros, send 347 to 17 nbrs,recv 344 from 17 nbrs
MatSOR_MPIAIJ: on rank 209 mat has 80 rows, 5610 nonzeros, send 283 to 11 nbrs,recv 264 from 11 nbrs
MatSOR_MPIAIJ: on rank 210 mat has 78 rows, 4706 nonzeros, send 177 to 7 nbrs,recv 167 from 7 nbrs
MatSOR_MPIAIJ: on rank 211 mat has 79 rows, 5695 nonzeros, send 289 to 11 nbrs,recv 261 from 11 nbrs
MatSOR_MPIAIJ: on rank 212 mat has 79 rows, 5631 nonzeros, send 282 to 11 nbrs,recv 265 from 11 nbrs
MatSOR_MPIAIJ: on rank 213 mat has 79 rows, 5631 nonzeros, send 282 to 11 nbrs,recv 265 from 11 nbrs
MatSOR_MPIAIJ: on rank 214 mat has 81 rows, 5770 nonzeros, send 285 to 11 nbrs,recv 268 from 11 nbrs
MatSOR_MPIAIJ: on rank 215 mat has 94 rows, 5994 nonzeros, send 229 to 7 nbrs,recv 197 from 7 nbrs
Leaving MG level 3
MatSOR_MPIAIJ: on rank 0 mat has 1301 rows, 84970 nonzeros, send 851 to 7 nbrs,recv 889 from 7 nbrs
MatSOR_MPIAIJ: on rank 1 mat has 1386 rows, 93842 nonzeros, send 1150 to 11 nbrs,recv 1178 from 11 nbrs
MatSOR_MPIAIJ: on rank 2 mat has 1386 rows, 93653 nonzeros, send 1142 to 11 nbrs,recv 1158 from 11 nbrs
MatSOR_MPIAIJ: on rank 3 mat has 1386 rows, 93653 nonzeros, send 1142 to 11 nbrs,recv 1158 from 11 nbrs
MatSOR_MPIAIJ: on rank 4 mat has 1386 rows, 93653 nonzeros, send 1142 to 11 nbrs,recv 1158 from 11 nbrs
MatSOR_MPIAIJ: on rank 5 mat has 1372 rows, 89740 nonzeros, send 820 to 7 nbrs,recv 820 from 7 nbrs
MatSOR_MPIAIJ: on rank 6 mat has 1387 rows, 93939 nonzeros, send 1144 to 11 nbrs,recv 1163 from 11 nbrs
MatSOR_MPIAIJ: on rank 7 mat has 1490 rows, 104725 nonzeros, send 1557 to 17 nbrs,recv 1530 from 17 nbrs
MatSOR_MPIAIJ: on rank 8 mat has 1490 rows, 104752 nonzeros, send 1535 to 17 nbrs,recv 1533 from 17 nbrs
MatSOR_MPIAIJ: on rank 9 mat has 1490 rows, 104752 nonzeros, send 1535 to 17 nbrs,recv 1533 from 17 nbrs
MatSOR_MPIAIJ: on rank 10 mat has 1490 rows, 104751 nonzeros, send 1535 to 17 nbrs,recv 1533 from 17 nbrs
MatSOR_MPIAIJ: on rank 11 mat has 1470 rows, 100147 nonzeros, send 1156 to 11 nbrs,recv 1150 from 11 nbrs
MatSOR_MPIAIJ: on rank 12 mat has 1387 rows, 93912 nonzeros, send 1140 to 11 nbrs,recv 1158 from 11 nbrs
MatSOR_MPIAIJ: on rank 13 mat has 1490 rows, 104627 nonzeros, send 1523 to 17 nbrs,recv 1520 from 17 nbrs
MatSOR_MPIAIJ: on rank 14 mat has 1490 rows, 104714 nonzeros, send 1532 to 17 nbrs,recv 1530 from 17 nbrs
MatSOR_MPIAIJ: on rank 15 mat has 1490 rows, 104714 nonzeros, send 1532 to 17 nbrs,recv 1530 from 17 nbrs
MatSOR_MPIAIJ: on rank 16 mat has 1490 rows, 104713 nonzeros, send 1532 to 17 nbrs,recv 1530 from 17 nbrs
MatSOR_MPIAIJ: on rank 17 mat has 1470 rows, 100074 nonzeros, send 1159 to 11 nbrs,recv 1145 from 11 nbrs
MatSOR_MPIAIJ: on rank 18 mat has 1387 rows, 93912 nonzeros, send 1140 to 11 nbrs,recv 1158 from 11 nbrs
MatSOR_MPIAIJ: on rank 19 mat has 1490 rows, 104627 nonzeros, send 1523 to 17 nbrs,recv 1520 from 17 nbrs
MatSOR_MPIAIJ: on rank 20 mat has 1490 rows, 104714 nonzeros, send 1532 to 17 nbrs,recv 1530 from 17 nbrs
MatSOR_MPIAIJ: on rank 21 mat has 1490 rows, 104714 nonzeros, send 1532 to 17 nbrs,recv 1530 from 17 nbrs
MatSOR_MPIAIJ: on rank 22 mat has 1490 rows, 104713 nonzeros, send 1532 to 17 nbrs,recv 1530 from 17 nbrs
MatSOR_MPIAIJ: on rank 23 mat has 1470 rows, 100074 nonzeros, send 1159 to 11 nbrs,recv 1145 from 11 nbrs
MatSOR_MPIAIJ: on rank 24 mat has 1387 rows, 93912 nonzeros, send 1140 to 11 nbrs,recv 1158 from 11 nbrs
MatSOR_MPIAIJ: on rank 25 mat has 1490 rows, 104627 nonzeros, send 1523 to 17 nbrs,recv 1520 from 17 nbrs
MatSOR_MPIAIJ: on rank 26 mat has 1490 rows, 104714 nonzeros, send 1532 to 17 nbrs,recv 1530 from 17 nbrs
MatSOR_MPIAIJ: on rank 27 mat has 1490 rows, 104714 nonzeros, send 1532 to 17 nbrs,recv 1530 from 17 nbrs
MatSOR_MPIAIJ: on rank 28 mat has 1490 rows, 104713 nonzeros, send 1532 to 17 nbrs,recv 1530 from 17 nbrs
MatSOR_MPIAIJ: on rank 29 mat has 1470 rows, 100074 nonzeros, send 1159 to 11 nbrs,recv 1145 from 11 nbrs
MatSOR_MPIAIJ: on rank 30 mat has 1366 rows, 89582 nonzeros, send 821 to 7 nbrs,recv 827 from 7 nbrs
MatSOR_MPIAIJ: on rank 31 mat has 1470 rows, 100041 nonzeros, send 1157 to 11 nbrs,recv 1147 from 11 nbrs
MatSOR_MPIAIJ: on rank 32 mat has 1470 rows, 100066 nonzeros, send 1171 to 11 nbrs,recv 1151 from 11 nbrs
MatSOR_MPIAIJ: on rank 33 mat has 1470 rows, 100066 nonzeros, send 1171 to 11 nbrs,recv 1151 from 11 nbrs
MatSOR_MPIAIJ: on rank 34 mat has 1470 rows, 100067 nonzeros, send 1171 to 11 nbrs,recv 1151 from 11 nbrs
MatSOR_MPIAIJ: on rank 35 mat has 1470 rows, 97042 nonzeros, send 890 to 7 nbrs,recv 850 from 7 nbrs
MatSOR_MPIAIJ: on rank 36 mat has 1392 rows, 94953 nonzeros, send 1209 to 11 nbrs,recv 1261 from 11 nbrs
MatSOR_MPIAIJ: on rank 37 mat has 1497 rows, 105726 nonzeros, send 1647 to 17 nbrs,recv 1659 from 17 nbrs
MatSOR_MPIAIJ: on rank 38 mat has 1497 rows, 105644 nonzeros, send 1626 to 17 nbrs,recv 1649 from 17 nbrs
MatSOR_MPIAIJ: on rank 39 mat has 1497 rows, 105644 nonzeros, send 1626 to 17 nbrs,recv 1649 from 17 nbrs
MatSOR_MPIAIJ: on rank 40 mat has 1497 rows, 105644 nonzeros, send 1626 to 17 nbrs,recv 1649 from 17 nbrs
MatSOR_MPIAIJ: on rank 41 mat has 1477 rows, 101022 nonzeros, send 1265 to 11 nbrs,recv 1243 from 11 nbrs
MatSOR_MPIAIJ: on rank 42 mat has 1490 rows, 105099 nonzeros, send 1610 to 17 nbrs,recv 1624 from 17 nbrs
MatSOR_MPIAIJ: on rank 43 mat has 1603 rows, 117555 nonzeros, send 2138 to 26 nbrs,recv 2094 from 26 nbrs
MatSOR_MPIAIJ: on rank 44 mat has 1603 rows, 117614 nonzeros, send 2122 to 26 nbrs,recv 2093 from 26 nbrs
MatSOR_MPIAIJ: on rank 45 mat has 1603 rows, 117614 nonzeros, send 2122 to 26 nbrs,recv 2093 from 26 nbrs
MatSOR_MPIAIJ: on rank 46 mat has 1603 rows, 117613 nonzeros, send 2122 to 26 nbrs,recv 2092 from 26 nbrs
MatSOR_MPIAIJ: on rank 47 mat has 1575 rows, 112042 nonzeros, send 1659 to 17 nbrs,recv 1629 from 17 nbrs
MatSOR_MPIAIJ: on rank 48 mat has 1490 rows, 105092 nonzeros, send 1613 to 17 nbrs,recv 1616 from 17 nbrs
MatSOR_MPIAIJ: on rank 49 mat has 1603 rows, 117501 nonzeros, send 2112 to 26 nbrs,recv 2081 from 26 nbrs
MatSOR_MPIAIJ: on rank 50 mat has 1603 rows, 117611 nonzeros, send 2127 to 26 nbrs,recv 2088 from 26 nbrs
MatSOR_MPIAIJ: on rank 51 mat has 1603 rows, 117611 nonzeros, send 2127 to 26 nbrs,recv 2088 from 26 nbrs
MatSOR_MPIAIJ: on rank 52 mat has 1603 rows, 117610 nonzeros, send 2127 to 26 nbrs,recv 2087 from 26 nbrs
MatSOR_MPIAIJ: on rank 53 mat has 1575 rows, 111983 nonzeros, send 1670 to 17 nbrs,recv 1625 from 17 nbrs
MatSOR_MPIAIJ: on rank 54 mat has 1490 rows, 105092 nonzeros, send 1613 to 17 nbrs,recv 1616 from 17 nbrs
MatSOR_MPIAIJ: on rank 55 mat has 1603 rows, 117501 nonzeros, send 2112 to 26 nbrs,recv 2081 from 26 nbrs
MatSOR_MPIAIJ: on rank 56 mat has 1603 rows, 117611 nonzeros, send 2127 to 26 nbrs,recv 2088 from 26 nbrs
MatSOR_MPIAIJ: on rank 57 mat has 1603 rows, 117611 nonzeros, send 2127 to 26 nbrs,recv 2088 from 26 nbrs
MatSOR_MPIAIJ: on rank 58 mat has 1603 rows, 117610 nonzeros, send 2127 to 26 nbrs,recv 2087 from 26 nbrs
MatSOR_MPIAIJ: on rank 59 mat has 1575 rows, 111983 nonzeros, send 1670 to 17 nbrs,recv 1625 from 17 nbrs
MatSOR_MPIAIJ: on rank 60 mat has 1490 rows, 105092 nonzeros, send 1613 to 17 nbrs,recv 1616 from 17 nbrs
MatSOR_MPIAIJ: on rank 61 mat has 1603 rows, 117501 nonzeros, send 2112 to 26 nbrs,recv 2081 from 26 nbrs
MatSOR_MPIAIJ: on rank 62 mat has 1603 rows, 117611 nonzeros, send 2127 to 26 nbrs,recv 2088 from 26 nbrs
MatSOR_MPIAIJ: on rank 63 mat has 1603 rows, 117611 nonzeros, send 2127 to 26 nbrs,recv 2088 from 26 nbrs
MatSOR_MPIAIJ: on rank 64 mat has 1603 rows, 117610 nonzeros, send 2127 to 26 nbrs,recv 2087 from 26 nbrs
MatSOR_MPIAIJ: on rank 65 mat has 1575 rows, 111983 nonzeros, send 1670 to 17 nbrs,recv 1625 from 17 nbrs
MatSOR_MPIAIJ: on rank 66 mat has 1465 rows, 100012 nonzeros, send 1235 to 11 nbrs,recv 1226 from 11 nbrs
MatSOR_MPIAIJ: on rank 67 mat has 1575 rows, 111864 nonzeros, send 1648 to 17 nbrs,recv 1627 from 17 nbrs
MatSOR_MPIAIJ: on rank 68 mat has 1575 rows, 111919 nonzeros, send 1670 to 17 nbrs,recv 1630 from 17 nbrs
MatSOR_MPIAIJ: on rank 69 mat has 1575 rows, 111919 nonzeros, send 1670 to 17 nbrs,recv 1630 from 17 nbrs
MatSOR_MPIAIJ: on rank 70 mat has 1575 rows, 111920 nonzeros, send 1670 to 17 nbrs,recv 1631 from 17 nbrs
MatSOR_MPIAIJ: on rank 71 mat has 1561 rows, 107589 nonzeros, send 1307 to 11 nbrs,recv 1268 from 11 nbrs
MatSOR_MPIAIJ: on rank 72 mat has 1392 rows, 94852 nonzeros, send 1197 to 11 nbrs,recv 1264 from 11 nbrs
MatSOR_MPIAIJ: on rank 73 mat has 1497 rows, 105863 nonzeros, send 1620 to 17 nbrs,recv 1661 from 17 nbrs
MatSOR_MPIAIJ: on rank 74 mat has 1497 rows, 105834 nonzeros, send 1621 to 17 nbrs,recv 1652 from 17 nbrs
MatSOR_MPIAIJ: on rank 75 mat has 1497 rows, 105834 nonzeros, send 1621 to 17 nbrs,recv 1652 from 17 nbrs
MatSOR_MPIAIJ: on rank 76 mat has 1497 rows, 105834 nonzeros, send 1621 to 17 nbrs,recv 1652 from 17 nbrs
MatSOR_MPIAIJ: on rank 77 mat has 1477 rows, 101066 nonzeros, send 1263 to 11 nbrs,recv 1237 from 11 nbrs
MatSOR_MPIAIJ: on rank 78 mat has 1490 rows, 105062 nonzeros, send 1584 to 17 nbrs,recv 1616 from 17 nbrs
MatSOR_MPIAIJ: on rank 79 mat has 1603 rows, 117684 nonzeros, send 2112 to 26 nbrs,recv 2093 from 26 nbrs
MatSOR_MPIAIJ: on rank 80 mat has 1603 rows, 117713 nonzeros, send 2099 to 26 nbrs,recv 2099 from 26 nbrs
MatSOR_MPIAIJ: on rank 81 mat has 1603 rows, 117713 nonzeros, send 2099 to 26 nbrs,recv 2099 from 26 nbrs
MatSOR_MPIAIJ: on rank 82 mat has 1603 rows, 117713 nonzeros, send 2099 to 26 nbrs,recv 2099 from 26 nbrs
MatSOR_MPIAIJ: on rank 83 mat has 1575 rows, 112043 nonzeros, send 1656 to 17 nbrs,recv 1629 from 17 nbrs
MatSOR_MPIAIJ: on rank 84 mat has 1490 rows, 105011 nonzeros, send 1585 to 17 nbrs,recv 1619 from 17 nbrs
MatSOR_MPIAIJ: on rank 85 mat has 1603 rows, 117581 nonzeros, send 2086 to 26 nbrs,recv 2083 from 26 nbrs
MatSOR_MPIAIJ: on rank 86 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 87 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 88 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 89 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 90 mat has 1490 rows, 105011 nonzeros, send 1585 to 17 nbrs,recv 1619 from 17 nbrs
MatSOR_MPIAIJ: on rank 91 mat has 1603 rows, 117581 nonzeros, send 2086 to 26 nbrs,recv 2083 from 26 nbrs
MatSOR_MPIAIJ: on rank 92 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 93 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 94 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 95 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 96 mat has 1490 rows, 105011 nonzeros, send 1585 to 17 nbrs,recv 1619 from 17 nbrs
MatSOR_MPIAIJ: on rank 97 mat has 1603 rows, 117581 nonzeros, send 2086 to 26 nbrs,recv 2083 from 26 nbrs
MatSOR_MPIAIJ: on rank 98 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 99 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 100 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 101 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 102 mat has 1465 rows, 99937 nonzeros, send 1219 to 11 nbrs,recv 1224 from 11 nbrs
MatSOR_MPIAIJ: on rank 103 mat has 1575 rows, 111930 nonzeros, send 1641 to 17 nbrs,recv 1623 from 17 nbrs
MatSOR_MPIAIJ: on rank 104 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 105 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 106 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 107 mat has 1561 rows, 107458 nonzeros, send 1319 to 11 nbrs,recv 1264 from 11 nbrs
MatSOR_MPIAIJ: on rank 108 mat has 1392 rows, 94852 nonzeros, send 1197 to 11 nbrs,recv 1264 from 11 nbrs
MatSOR_MPIAIJ: on rank 109 mat has 1497 rows, 105863 nonzeros, send 1620 to 17 nbrs,recv 1661 from 17 nbrs
MatSOR_MPIAIJ: on rank 110 mat has 1497 rows, 105834 nonzeros, send 1621 to 17 nbrs,recv 1652 from 17 nbrs
MatSOR_MPIAIJ: on rank 111 mat has 1497 rows, 105834 nonzeros, send 1621 to 17 nbrs,recv 1652 from 17 nbrs
MatSOR_MPIAIJ: on rank 112 mat has 1497 rows, 105834 nonzeros, send 1621 to 17 nbrs,recv 1652 from 17 nbrs
MatSOR_MPIAIJ: on rank 113 mat has 1477 rows, 101066 nonzeros, send 1263 to 11 nbrs,recv 1237 from 11 nbrs
MatSOR_MPIAIJ: on rank 114 mat has 1490 rows, 105062 nonzeros, send 1584 to 17 nbrs,recv 1616 from 17 nbrs
MatSOR_MPIAIJ: on rank 115 mat has 1603 rows, 117684 nonzeros, send 2112 to 26 nbrs,recv 2093 from 26 nbrs
MatSOR_MPIAIJ: on rank 116 mat has 1603 rows, 117713 nonzeros, send 2099 to 26 nbrs,recv 2099 from 26 nbrs
MatSOR_MPIAIJ: on rank 117 mat has 1603 rows, 117713 nonzeros, send 2099 to 26 nbrs,recv 2099 from 26 nbrs
MatSOR_MPIAIJ: on rank 118 mat has 1603 rows, 117713 nonzeros, send 2099 to 26 nbrs,recv 2099 from 26 nbrs
MatSOR_MPIAIJ: on rank 119 mat has 1575 rows, 112043 nonzeros, send 1656 to 17 nbrs,recv 1629 from 17 nbrs
MatSOR_MPIAIJ: on rank 120 mat has 1490 rows, 105011 nonzeros, send 1585 to 17 nbrs,recv 1619 from 17 nbrs
MatSOR_MPIAIJ: on rank 121 mat has 1603 rows, 117581 nonzeros, send 2086 to 26 nbrs,recv 2083 from 26 nbrs
MatSOR_MPIAIJ: on rank 122 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 123 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 124 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 125 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 126 mat has 1490 rows, 105011 nonzeros, send 1585 to 17 nbrs,recv 1619 from 17 nbrs
MatSOR_MPIAIJ: on rank 127 mat has 1603 rows, 117581 nonzeros, send 2086 to 26 nbrs,recv 2083 from 26 nbrs
MatSOR_MPIAIJ: on rank 128 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 129 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 130 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 131 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 132 mat has 1490 rows, 105011 nonzeros, send 1585 to 17 nbrs,recv 1619 from 17 nbrs
MatSOR_MPIAIJ: on rank 133 mat has 1603 rows, 117581 nonzeros, send 2086 to 26 nbrs,recv 2083 from 26 nbrs
MatSOR_MPIAIJ: on rank 134 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 135 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 136 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 137 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 138 mat has 1465 rows, 99937 nonzeros, send 1219 to 11 nbrs,recv 1224 from 11 nbrs
MatSOR_MPIAIJ: on rank 139 mat has 1575 rows, 111930 nonzeros, send 1641 to 17 nbrs,recv 1623 from 17 nbrs
MatSOR_MPIAIJ: on rank 140 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 141 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 142 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 143 mat has 1561 rows, 107458 nonzeros, send 1319 to 11 nbrs,recv 1264 from 11 nbrs
MatSOR_MPIAIJ: on rank 144 mat has 1392 rows, 94852 nonzeros, send 1197 to 11 nbrs,recv 1264 from 11 nbrs
MatSOR_MPIAIJ: on rank 145 mat has 1497 rows, 105863 nonzeros, send 1620 to 17 nbrs,recv 1661 from 17 nbrs
MatSOR_MPIAIJ: on rank 146 mat has 1497 rows, 105834 nonzeros, send 1621 to 17 nbrs,recv 1652 from 17 nbrs
MatSOR_MPIAIJ: on rank 147 mat has 1497 rows, 105834 nonzeros, send 1621 to 17 nbrs,recv 1652 from 17 nbrs
MatSOR_MPIAIJ: on rank 148 mat has 1497 rows, 105834 nonzeros, send 1621 to 17 nbrs,recv 1652 from 17 nbrs
MatSOR_MPIAIJ: on rank 149 mat has 1477 rows, 101066 nonzeros, send 1263 to 11 nbrs,recv 1237 from 11 nbrs
MatSOR_MPIAIJ: on rank 150 mat has 1490 rows, 105062 nonzeros, send 1584 to 17 nbrs,recv 1616 from 17 nbrs
MatSOR_MPIAIJ: on rank 151 mat has 1603 rows, 117684 nonzeros, send 2112 to 26 nbrs,recv 2093 from 26 nbrs
MatSOR_MPIAIJ: on rank 152 mat has 1603 rows, 117713 nonzeros, send 2099 to 26 nbrs,recv 2099 from 26 nbrs
MatSOR_MPIAIJ: on rank 153 mat has 1603 rows, 117713 nonzeros, send 2099 to 26 nbrs,recv 2099 from 26 nbrs
MatSOR_MPIAIJ: on rank 154 mat has 1603 rows, 117713 nonzeros, send 2099 to 26 nbrs,recv 2099 from 26 nbrs
MatSOR_MPIAIJ: on rank 155 mat has 1575 rows, 112043 nonzeros, send 1656 to 17 nbrs,recv 1629 from 17 nbrs
MatSOR_MPIAIJ: on rank 156 mat has 1490 rows, 105011 nonzeros, send 1585 to 17 nbrs,recv 1619 from 17 nbrs
MatSOR_MPIAIJ: on rank 157 mat has 1603 rows, 117581 nonzeros, send 2086 to 26 nbrs,recv 2083 from 26 nbrs
MatSOR_MPIAIJ: on rank 158 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 159 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 160 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 161 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 162 mat has 1490 rows, 105011 nonzeros, send 1585 to 17 nbrs,recv 1619 from 17 nbrs
MatSOR_MPIAIJ: on rank 163 mat has 1603 rows, 117581 nonzeros, send 2086 to 26 nbrs,recv 2083 from 26 nbrs
MatSOR_MPIAIJ: on rank 164 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 165 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 166 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 167 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 168 mat has 1490 rows, 105011 nonzeros, send 1585 to 17 nbrs,recv 1619 from 17 nbrs
MatSOR_MPIAIJ: on rank 169 mat has 1603 rows, 117581 nonzeros, send 2086 to 26 nbrs,recv 2083 from 26 nbrs
MatSOR_MPIAIJ: on rank 170 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 171 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 172 mat has 1603 rows, 117683 nonzeros, send 2104 to 26 nbrs,recv 2104 from 26 nbrs
MatSOR_MPIAIJ: on rank 173 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 174 mat has 1465 rows, 99937 nonzeros, send 1219 to 11 nbrs,recv 1224 from 11 nbrs
MatSOR_MPIAIJ: on rank 175 mat has 1575 rows, 111930 nonzeros, send 1641 to 17 nbrs,recv 1623 from 17 nbrs
MatSOR_MPIAIJ: on rank 176 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 177 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 178 mat has 1575 rows, 111976 nonzeros, send 1666 to 17 nbrs,recv 1635 from 17 nbrs
MatSOR_MPIAIJ: on rank 179 mat has 1561 rows, 107458 nonzeros, send 1319 to 11 nbrs,recv 1264 from 11 nbrs
MatSOR_MPIAIJ: on rank 180 mat has 1300 rows, 84688 nonzeros, send 792 to 7 nbrs,recv 862 from 7 nbrs
MatSOR_MPIAIJ: on rank 181 mat has 1392 rows, 94335 nonzeros, send 1130 to 11 nbrs,recv 1168 from 11 nbrs
MatSOR_MPIAIJ: on rank 182 mat has 1392 rows, 94219 nonzeros, send 1134 to 11 nbrs,recv 1159 from 11 nbrs
MatSOR_MPIAIJ: on rank 183 mat has 1392 rows, 94219 nonzeros, send 1134 to 11 nbrs,recv 1159 from 11 nbrs
MatSOR_MPIAIJ: on rank 184 mat has 1392 rows, 94219 nonzeros, send 1134 to 11 nbrs,recv 1159 from 11 nbrs
MatSOR_MPIAIJ: on rank 185 mat has 1386 rows, 90713 nonzeros, send 864 to 7 nbrs,recv 827 from 7 nbrs
MatSOR_MPIAIJ: on rank 186 mat has 1398 rows, 94373 nonzeros, send 1094 to 11 nbrs,recv 1138 from 11 nbrs
MatSOR_MPIAIJ: on rank 187 mat has 1497 rows, 105206 nonzeros, send 1525 to 17 nbrs,recv 1540 from 17 nbrs
MatSOR_MPIAIJ: on rank 188 mat has 1497 rows, 105249 nonzeros, send 1516 to 17 nbrs,recv 1545 from 17 nbrs
MatSOR_MPIAIJ: on rank 189 mat has 1497 rows, 105249 nonzeros, send 1516 to 17 nbrs,recv 1545 from 17 nbrs
MatSOR_MPIAIJ: on rank 190 mat has 1497 rows, 105249 nonzeros, send 1516 to 17 nbrs,recv 1545 from 17 nbrs
MatSOR_MPIAIJ: on rank 191 mat has 1477 rows, 100737 nonzeros, send 1176 to 11 nbrs,recv 1155 from 11 nbrs
MatSOR_MPIAIJ: on rank 192 mat has 1398 rows, 94314 nonzeros, send 1091 to 11 nbrs,recv 1143 from 11 nbrs
MatSOR_MPIAIJ: on rank 193 mat has 1497 rows, 105090 nonzeros, send 1496 to 17 nbrs,recv 1531 from 17 nbrs
MatSOR_MPIAIJ: on rank 194 mat has 1497 rows, 105199 nonzeros, send 1509 to 17 nbrs,recv 1550 from 17 nbrs
MatSOR_MPIAIJ: on rank 195 mat has 1497 rows, 105199 nonzeros, send 1509 to 17 nbrs,recv 1550 from 17 nbrs
MatSOR_MPIAIJ: on rank 196 mat has 1497 rows, 105199 nonzeros, send 1509 to 17 nbrs,recv 1550 from 17 nbrs
MatSOR_MPIAIJ: on rank 197 mat has 1477 rows, 100652 nonzeros, send 1174 to 11 nbrs,recv 1160 from 11 nbrs
MatSOR_MPIAIJ: on rank 198 mat has 1398 rows, 94314 nonzeros, send 1091 to 11 nbrs,recv 1143 from 11 nbrs
MatSOR_MPIAIJ: on rank 199 mat has 1497 rows, 105090 nonzeros, send 1496 to 17 nbrs,recv 1531 from 17 nbrs
MatSOR_MPIAIJ: on rank 200 mat has 1497 rows, 105199 nonzeros, send 1509 to 17 nbrs,recv 1550 from 17 nbrs
MatSOR_MPIAIJ: on rank 201 mat has 1497 rows, 105199 nonzeros, send 1509 to 17 nbrs,recv 1550 from 17 nbrs
MatSOR_MPIAIJ: on rank 202 mat has 1497 rows, 105199 nonzeros, send 1509 to 17 nbrs,recv 1550 from 17 nbrs
MatSOR_MPIAIJ: on rank 203 mat has 1477 rows, 100652 nonzeros, send 1174 to 11 nbrs,recv 1160 from 11 nbrs
MatSOR_MPIAIJ: on rank 204 mat has 1398 rows, 94314 nonzeros, send 1091 to 11 nbrs,recv 1143 from 11 nbrs
MatSOR_MPIAIJ: on rank 205 mat has 1497 rows, 105090 nonzeros, send 1496 to 17 nbrs,recv 1531 from 17 nbrs
MatSOR_MPIAIJ: on rank 206 mat has 1497 rows, 105199 nonzeros, send 1509 to 17 nbrs,recv 1550 from 17 nbrs
MatSOR_MPIAIJ: on rank 207 mat has 1497 rows, 105199 nonzeros, send 1509 to 17 nbrs,recv 1550 from 17 nbrs
MatSOR_MPIAIJ: on rank 208 mat has 1497 rows, 105199 nonzeros, send 1509 to 17 nbrs,recv 1550 from 17 nbrs
MatSOR_MPIAIJ: on rank 209 mat has 1477 rows, 100652 nonzeros, send 1174 to 11 nbrs,recv 1160 from 11 nbrs
MatSOR_MPIAIJ: on rank 210 mat has 1380 rows, 90224 nonzeros, send 813 to 7 nbrs,recv 820 from 7 nbrs
MatSOR_MPIAIJ: on rank 211 mat has 1477 rows, 100583 nonzeros, send 1153 to 11 nbrs,recv 1159 from 11 nbrs
MatSOR_MPIAIJ: on rank 212 mat has 1477 rows, 100633 nonzeros, send 1172 to 11 nbrs,recv 1170 from 11 nbrs
MatSOR_MPIAIJ: on rank 213 mat has 1477 rows, 100633 nonzeros, send 1172 to 11 nbrs,recv 1170 from 11 nbrs
MatSOR_MPIAIJ: on rank 214 mat has 1477 rows, 100633 nonzeros, send 1172 to 11 nbrs,recv 1170 from 11 nbrs
MatSOR_MPIAIJ: on rank 215 mat has 1470 rows, 97109 nonzeros, send 906 to 7 nbrs,recv 863 from 7 nbrs
Leaving MG level 4
doing MatInterpolateAdd
MatSOR_MPIAIJ: on rank 0 mat has 10976 rows, 201530 nonzeros, send 2394 to 6 nbrs,recv 2394 from 6 nbrs
MatSOR_MPIAIJ: on rank 1 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 2 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 3 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 4 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 5 mat has 10976 rows, 201530 nonzeros, send 2394 to 6 nbrs,recv 2394 from 6 nbrs
MatSOR_MPIAIJ: on rank 6 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 7 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 8 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 9 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 10 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 11 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 12 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 13 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 14 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 15 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 16 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 17 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 18 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 19 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 20 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 21 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 22 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 23 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 24 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 25 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 26 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 27 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 28 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 29 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 30 mat has 10976 rows, 201530 nonzeros, send 2394 to 6 nbrs,recv 2394 from 6 nbrs
MatSOR_MPIAIJ: on rank 31 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 32 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 33 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 34 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 35 mat has 10976 rows, 201530 nonzeros, send 2394 to 6 nbrs,recv 2394 from 6 nbrs
MatSOR_MPIAIJ: on rank 36 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 37 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 38 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 39 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 40 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 41 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 42 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 43 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 44 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 45 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 46 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 47 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 48 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 49 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 50 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 51 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 52 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 53 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 54 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 55 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 56 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 57 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 58 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 59 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 60 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 61 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 62 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 63 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 64 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 65 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 66 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 67 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 68 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 69 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 70 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 71 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 72 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 73 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 74 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 75 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 76 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 77 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 78 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 79 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 80 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 81 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 82 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 83 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 84 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 85 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 86 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 87 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 88 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 89 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 90 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 91 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 92 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 93 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 94 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 95 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 96 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 97 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 98 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 99 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 100 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 101 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 102 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 103 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 104 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 105 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 106 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 107 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 108 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 109 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 110 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 111 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 112 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 113 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 114 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 115 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 116 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 117 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 118 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 119 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 120 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 121 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 122 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 123 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 124 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 125 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 126 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 127 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 128 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 129 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 130 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 131 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 132 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 133 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 134 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 135 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 136 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 137 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 138 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 139 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 140 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 141 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 142 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 143 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 144 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 145 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 146 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 147 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 148 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 149 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 150 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 151 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 152 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 153 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 154 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 155 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 156 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 157 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 158 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 159 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 160 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 161 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 162 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 163 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 164 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 165 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 166 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 167 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 168 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 169 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 170 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 171 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 172 mat has 13500 rows, 256500 nonzeros, send 5580 to 18 nbrs,recv 5580 from 18 nbrs
MatSOR_MPIAIJ: on rank 173 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 174 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 175 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 176 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 177 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 178 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 179 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 180 mat has 10976 rows, 201530 nonzeros, send 2394 to 6 nbrs,recv 2394 from 6 nbrs
MatSOR_MPIAIJ: on rank 181 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 182 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 183 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 184 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 185 mat has 10976 rows, 201530 nonzeros, send 2394 to 6 nbrs,recv 2394 from 6 nbrs
MatSOR_MPIAIJ: on rank 186 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 187 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 188 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 189 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 190 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 191 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 192 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 193 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 194 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 195 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 196 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 197 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 198 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 199 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 200 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 201 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 202 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 203 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 204 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 205 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 206 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 207 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 208 mat has 12600 rows, 236700 nonzeros, send 4376 to 13 nbrs,recv 4376 from 13 nbrs
MatSOR_MPIAIJ: on rank 209 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 210 mat has 10976 rows, 201530 nonzeros, send 2394 to 6 nbrs,recv 2394 from 6 nbrs
MatSOR_MPIAIJ: on rank 211 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 212 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 213 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 214 mat has 11760 rows, 218415 nonzeros, send 3319 to 9 nbrs,recv 3319 from 9 nbrs
MatSOR_MPIAIJ: on rank 215 mat has 10976 rows, 201530 nonzeros, send 2394 to 6 nbrs,recv 2394 from 6 nbrs
Leaving MG level 5
MatSOR_MPIAIJ: on rank 0 mat has 27000 rows, 186300 nonzeros, send 2700 to 3 nbrs,recv 2700 from 3 nbrs
MatSOR_MPIAIJ: on rank 1 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 2 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 3 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 4 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 5 mat has 27000 rows, 186300 nonzeros, send 2700 to 3 nbrs,recv 2700 from 3 nbrs
MatSOR_MPIAIJ: on rank 6 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 7 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 8 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 9 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 10 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 11 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 12 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 13 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 14 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 15 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 16 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 17 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 18 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 19 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 20 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 21 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 22 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 23 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 24 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 25 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 26 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 27 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 28 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 29 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 30 mat has 27000 rows, 186300 nonzeros, send 2700 to 3 nbrs,recv 2700 from 3 nbrs
MatSOR_MPIAIJ: on rank 31 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 32 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 33 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 34 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 35 mat has 27000 rows, 186300 nonzeros, send 2700 to 3 nbrs,recv 2700 from 3 nbrs
MatSOR_MPIAIJ: on rank 36 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 37 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 38 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 39 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 40 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 41 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 42 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 43 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 44 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 45 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 46 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 47 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 48 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 49 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 50 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 51 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 52 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 53 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 54 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 55 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 56 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 57 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 58 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 59 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 60 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 61 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 62 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 63 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 64 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 65 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 66 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 67 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 68 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 69 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 70 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 71 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 72 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 73 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 74 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 75 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 76 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 77 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 78 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 79 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 80 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 81 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 82 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 83 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 84 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 85 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 86 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 87 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 88 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 89 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 90 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 91 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 92 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 93 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 94 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 95 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 96 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 97 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 98 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 99 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 100 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 101 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 102 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 103 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 104 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 105 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 106 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 107 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 108 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 109 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 110 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 111 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 112 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 113 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 114 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 115 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 116 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 117 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 118 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 119 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 120 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 121 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 122 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 123 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 124 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 125 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 126 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 127 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 128 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 129 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 130 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 131 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 132 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 133 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 134 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 135 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 136 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 137 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 138 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 139 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 140 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 141 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 142 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 143 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 144 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 145 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 146 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 147 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 148 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 149 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 150 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 151 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 152 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 153 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 154 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 155 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 156 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 157 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 158 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 159 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 160 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 161 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 162 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 163 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 164 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 165 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 166 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 167 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 168 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 169 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 170 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 171 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 172 mat has 27000 rows, 189000 nonzeros, send 5400 to 6 nbrs,recv 5400 from 6 nbrs
MatSOR_MPIAIJ: on rank 173 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 174 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 175 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 176 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 177 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 178 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 179 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 180 mat has 27000 rows, 186300 nonzeros, send 2700 to 3 nbrs,recv 2700 from 3 nbrs
MatSOR_MPIAIJ: on rank 181 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 182 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 183 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 184 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 185 mat has 27000 rows, 186300 nonzeros, send 2700 to 3 nbrs,recv 2700 from 3 nbrs
MatSOR_MPIAIJ: on rank 186 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 187 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 188 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 189 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 190 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 191 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 192 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 193 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 194 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 195 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 196 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 197 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 198 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 199 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 200 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 201 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 202 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 203 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 204 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 205 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 206 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 207 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 208 mat has 27000 rows, 188100 nonzeros, send 4500 to 5 nbrs,recv 4500 from 5 nbrs
MatSOR_MPIAIJ: on rank 209 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 210 mat has 27000 rows, 186300 nonzeros, send 2700 to 3 nbrs,recv 2700 from 3 nbrs
MatSOR_MPIAIJ: on rank 211 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 212 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 213 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 214 mat has 27000 rows, 187200 nonzeros, send 3600 to 4 nbrs,recv 3600 from 4 nbrs
MatSOR_MPIAIJ: on rank 215 mat has 27000 rows, 186300 nonzeros, send 2700 to 3 nbrs,recv 2700 from 3 nbrs
Leaving MG level 6
