[petsc-dev] HDF5 download error
Satish Balay
balay at mcs.anl.gov
Wed Jun 20 06:24:34 CDT 2018
The fix for broken hdf5 url is in 'balay/update-hdf5-url/maint'.
Or you can do:
--download-hdf5=https://support.hdfgroup.org/ftp/HDF5/prev-releases/hdf5-1.8/hdf5-1.8.18/src/hdf5-1.8.18.tar.gz
Satish
On Wed, 20 Jun 2018, Karl Rupp wrote:
> Hi Mark,
> the FTP server at MCS is down today. It should come back up later today.
> Best regards,
> Karli
> On 06/20/2018 01:17 PM, Mark Adams wrote:
> > This looks like it is a problem with NERSC, this does not work:
> > 04:14 cori04 maint= ~/petsc_install/petsc$ ping ftp.mcs.anl.gov
> > <http://ftp.mcs.anl.gov>
> > PING ftp.mcs.anl.gov <http://ftp.mcs.anl.gov> (140.221.6.23) 56(84) bytes of
> > data.
> > On Wed, Jun 20, 2018 at 7:08 AM Mark Adams <mfadams at lbl.gov
> > <mailto:mfadams at lbl.gov>> wrote:
> > I get this error downloading HDF5 on Cori at NERSC and it has worked
> > before. This is on maint.
> > Trying to download
> > https://support.hdfgroup.org/ftp/HDF5/current18/src/hdf5-1.8.18.tar.gz
> > for HDF5
> > Trying to download
> > http://ftp.mcs.anl.gov/pub/petsc/externalpackages/hdf5-1.8.18.tar.gz
> > for HDF5
> > Trying to download
> > ftp://ftp.mcs.anl.gov/pub/petsc/externalpackages/hdf5-1.8.18.tar.gz for
> > HDF5
> > UNABLE to CONFIGURE with GIVEN OPTIONS (see
> > configure.log for details):
> > Error during download/extract/detection of HDF5:
> > file could not be opened successfully
> > Downloaded package HDF5 from:
> > is not a tarball.
> > [or installed python cannot process compressed files]
> > * If you are behind a firewall - please fix your proxy and rerun
> > ./configure
> > For example at LANL you may need to set the environmental
> > variable http_proxy (or HTTP_PROXY?) to http://proxyout.lanl.gov
> > * You can run with --with-packages-dir=/adirectory and ./configure
> > will instruct you what packages to download manually
> > * or you can download the above URL manually, to
> > /yourselectedlocation/hdf5-1.8.18.tar.gz
> > and use the configure option:
> > --download-hdf5=/yourselectedlocation/hdf5-1.8.18.tar.gz
> > Unable to download package HDF5 from:
> > * If URL specified manually - perhaps there is a typo?
> > * If your network is disconnected - please reconnect and rerun
> > ./configure
> > * Or perhaps you have a firewall blocking the download
> > ./configure
