[petsc-dev] Expensive VecDuplicate_MPI_DA
Jed Brown
jed at jedbrown.org
Tue Jun 19 22:35:39 CDT 2018
"Smith, Barry F." <bsmith at mcs.anl.gov> writes:
> Jed,
> You added these two lines. Any idea why they are needed?
That was just replacing the old interface
https://bitbucket.org/petsc/petsc/commits/077aedaf8cb5b060ad5dab7a12035daf9d64dd75#Lsrc/dm/impls/da/dadist.cF19
that you added here
https://bitbucket.org/petsc/petsc/commits/5ead1ec26b293130cbc6f8fa84f0a9ffce38a0bf
> Thanks
> Barry
> 3e08d2bebf99 src/dm/impls/da/dadist.c (Barry Smith 2012-09-18 14) PetscFunctionBegin;
> c688c0463f6c src/dm/impls/da/dadist.c (Matthew Knepley 2012-11-11 15) ierr = VecGetDM(g, &da);CHKERRQ(ierr);
> 2dcb2ebcaafe src/dm/impls/da/dadist.c (Barry Smith 2010-10-31 16) ierr = DMCreateGlobalVector(da,gg);CHKERRQ(ierr);
> 077aedaf8cb5 src/dm/impls/da/dadist.c (Jed Brown 2013-02-11 17) ierr = VecGetLayout(g,&map);CHKERRQ(ierr);
> 077aedaf8cb5 src/dm/impls/da/dadist.c (Jed Brown 2013-02-11 18) ierr = VecSetLayout(*gg,map);CHKERRQ(ierr);
> 2dcb2ebcaafe src/dm/impls/da/dadist.c (Barry Smith 2010-10-31 19) PetscFunctionReturn(0)
> If we were a bit more clever we could probably avoid all communication in VecDuplicate() but is it worth bothering unless we know it is problematic
>> On Jun 19, 2018, at 4:30 PM, Junchao Zhang <jczhang at mcs.anl.gov> wrote:
>> I met an expensive VecDuplicate. See the attached call stack. VecDuplicate_MPI_DA indirectly calls MPI_Allreduce/Allgather to build the vector's layout, but it then immediately destroys it with VecGetLayout & VecSetLayout. Is it wrong?
>> PetscErrorCode VecDuplicate_MPI_DA(Vec g,Vec *gg)
>> PetscErrorCode ierr;
>> DM da;
>> PetscLayout map;
>> PetscFunctionBegin;
>> PetscFunctionReturn(0);
>> --Junchao Zhang
>> <VecDup.png>
