[petsc-dev] test errors
Mark Adams
mfadams at lbl.gov
Sat Jun 16 22:10:57 CDT 2018
FYI, I suspect this is fine but I get some errors in testing 'maint' on
Cori (NERSC) KNL:
19:57 nid02516 maint= ~/petsc_install/petsc$ make
PETSC_DIR=/global/homes/m/madams/petsc_install/petsc-cori-knl-opt64-intel-omp
PETSC_ARCH="" test
Running test examples to verify correct installation
Using
and PETSC_ARCH=
*******************Error detected during compile or link!*******************
See http://www.mcs.anl.gov/petsc/documentation/faq.html
/global/homes/m/madams/petsc_install/petsc/src/snes/examples/tutorials ex19
cc -o ex19.o -c -g -fp-model fast -hcpu=mic-knl -fopenmp
-I/global/homes/m/madams/petsc_install/petsc-cori-knl-opt64-intel-omp/include
`pwd`/ex19.c
cc -g -fp-model fast -hcpu=mic-knl -fopenmp -o ex19 ex19.o
-L/global/homes/m/madams/petsc_install/petsc-cori-knl-opt64-intel-omp/lib
-Wl,-rpath,/global/homes/m/madams/petsc_install/petsc-cori-knl-opt64-intel-omp/lib
-lpetsc -lHYPRE -lflapack -lfblas -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl
-lhdf5 -lparmetis -lmetis -lstdc++ -ldl
/global/homes/m/madams/petsc_install/petsc-cori-knl-opt64-intel-omp/lib/libpetsc.a(dlimpl.o):
In function `PetscDLOpen':
/global/u2/m/madams/petsc_install/petsc/src/sys/dll/dlimpl.c:108: warning:
Using 'dlopen' in statically linked applications requires at runtime the
shared libraries from the glibc version used for linking
/global/homes/m/madams/petsc_install/petsc-cori-knl-opt64-intel-omp/lib/libpetsc.a(send.o):
In function `PetscSocketEstablish':
/global/u2/m/madams/petsc_install/petsc/src/sys/classes/viewer/impls/socket/send.c:189:
warning: Using 'gethostbyname' in statically linked applications requires
at runtime the shared libraries from the glibc version used for linking
/usr/bin/rm -f ex19.o
C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1 MPI
process
C/C++ example src/snes/examples/tutorials/ex19 run successfully with 2 MPI
processes
3,4c3,6
< 1 SNES Function norm 4.12227e-06
< 2 SNES Function norm 6.098e-11
> OMP: Warning #239: KMP_AFFINITY: granularity=fine will be used.
> 1 SNES Function norm 6.24808e-06
> 2 SNES Function norm 6.777e-11
Possible problem with ex19_hypre, diffs above
/global/homes/m/madams/petsc_install/petsc/src/snes/examples/tutorials ex5f
ftn -c -g -fp-model fast -hcpu=mic-knl -fopenmp
-o ex5f.o ex5f.F90
ftn -g -fp-model fast -hcpu=mic-knl -fopenmp -o ex5f ex5f.o
/usr/bin/rm -f ex5f.o
Fortran example src/snes/examples/tutorials/ex5f run successfully with 1
MPI process
Completed test examples
20:01 nid02516 maint= ~/petsc_install/petsc$
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180616/cd85d361/attachment.html>
