[petsc-dev] [petsc-users] Poor weak scaling when solving successive linearsystems
Junchao Zhang
jczhang at mcs.anl.gov
Wed Jun 13 13:09:31 CDT 2018
Mark,
Yes, it is 7-point stencil. I tried your options,
-pc_gamg_square_graph 0 -pc_gamg_threshold
0.0 -pc_gamg_repartition, and found they increased the time. I did not try
hypre since I don't know how to set its options.
I also tried periodic boundary condition and ran it with -mat_view
::load_balance. It gives fewer KSP iterations and but PETSc still reports
load imbalance at coarse levels.
--Junchao Zhang
On Tue, Jun 12, 2018 at 3:17 PM, Mark Adams <mfadams at lbl.gov> wrote:
> This all looks reasonable to me. The VecScatters times are a little high
> but these are fast little solves (.2 seconds each).
> The RAP times are very low, suggesting we could optimize parameters a bit
> and reduce the iteration count. These are 7 point stencils as I recall. You
> could try -pc_gamg_square_graph 0 (instead of 1) and you probably want
> '-pc_gamg_threshold 0.0'. You could also test hypre.
> And you should be able to improve coarse grid load imbalance with
> -pc_gamg_repartition.
> Mark
> On Tue, Jun 12, 2018 at 12:32 PM, Junchao Zhang <jczhang at mcs.anl.gov>
> wrote:
>> Mark,
>> I tried "-pc_gamg_type agg ..." options you mentioned, and also
>> -ksp_type cg + PETSc's default PC bjacobi. In the latter case, to reduce
>> execution time I called KSPSolve 100 times instead of 1000, and also
>> used -ksp_max_it 100. In the 36x48=1728 ranks case, I also did a test with
>> -log_sync. From there you can see a lot of time is spent on VecNormBarrier,
>> which implies load imbalance. Note VecScatterBarrie time is misleading,
>> since it barriers ALL ranks, but in reality VecScatter sort of syncs in
>> a small neighborhood.
>> Barry suggested trying periodic boundary condition so that the nonzeros
>> are perfectly balanced across processes. I will try that to see what
>> happens.
>> --Junchao Zhang
>> On Mon, Jun 11, 2018 at 8:09 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>> On Mon, Jun 11, 2018 at 12:46 AM, Junchao Zhang <jczhang at mcs.anl.gov>
>>> wrote:
>>>> I used an LCRC machine named Bebop. I tested on its Intel Broadwell
>>>> nodes. Each nodes has 2 CPUs and 36 cores in total. I collected data using
>>>> 36 cores in a node or 18 cores in a node. As you can see, 18 cores/node
>>>> gave much better performance, which is reasonable as routines like MatSOR,
>>>> MatMult, MatMultAdd are all bandwidth bound.
>>>> The code uses a DMDA 3D grid, 7-point stencil, and defines
>>>> nodes(vertices) at the surface or second to the surface as boundary nodes.
>>>> Boundary nodes only have a diagonal one in their row in the matrix.
>>>> Interior nodes have 7 nonzeros in their row. Boundary processors in the
>>>> processor grid has less nonzero. This is one source of load-imbalance. Will
>>>> load-imbalance get severer at coarser grids of an MG level?
>>> Yes.
>>> You can use a simple Jacobi solver to see the basic performance of your
>>> operator and machine. Do you see as much time spent in Vec Scatters?
>>> VecAXPY? etc.
>>>> I attach a trace view figure that show activity of each ranks along the
>>>> time axis in one KSPSove. White color means MPI wait. You can see
>>>> white takes a large space.
>>>> I don't have a good explanation why at large scale (1728 cores),
>>>> processors wait longer time, as the communication pattern is still 7-point
>>>> stencil in a cubic processor gird.
>>>> --Junchao Zhang
>>>> On Sat, Jun 9, 2018 at 11:32 AM, Smith, Barry F. <bsmith at mcs.anl.gov>
>>>> wrote:
>>>>> Junchao,
>>>>> Thanks, the load balance of matrix entries is remarkably similar
>>>>> for the two runs so it can't be a matter of worse work load imbalance for
>>>>> SOR for the larger case explaining why the SOR takes more time.
>>>>> Here is my guess (and I know no way to confirm it). In the
>>>>> smaller case the overlap of different processes on the same node running
>>>>> SOR at the same time is lower than the larger case hence the larger case is
>>>>> slower because there are more SOR processes fighting over the same memory
>>>>> bandwidth at the same time than in the smaller case. Ahh, here is
>>>>> something you can try, lets undersubscribe the memory bandwidth needs, run
>>>>> on say 16 processes per node with 8 nodes and 16 processes per node with 64
>>>>> nodes and send the two -log_view output files. I assume this is an LCRC
>>>>> machine and NOT a KNL system?
>>>>> Thanks
>>>>> Barry
>>>>> > On Jun 9, 2018, at 8:29 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>> > -pc_gamg_type classical
>>>>> > FYI, we only support smoothed aggregation "agg" (the default). (This
>>>>> thread started by saying you were using GAMG.)
>>>>> > It is not clear how much this will make a difference for you, but
>>>>> you don't want to use classical because we do not support it. It is meant
>>>>> as a reference implementation for developers.
>>>>> > First, how did you get the idea to use classical? If the
>>>>> documentation lead you to believe this was a good thing to do then we need
>>>>> to fix that!
>>>>> > Anyway, here is a generic input for GAMG:
>>>>> > -pc_type gamg
>>>>> > -pc_gamg_type agg
>>>>> > -pc_gamg_agg_nsmooths 1
>>>>> > -pc_gamg_coarse_eq_limit 1000
>>>>> > -pc_gamg_reuse_interpolation true
>>>>> > -pc_gamg_square_graph 1
>>>>> > -pc_gamg_threshold 0.05
>>>>> > -pc_gamg_threshold_scale .0
>>>>> > On Thu, Jun 7, 2018 at 6:52 PM, Junchao Zhang <jczhang at mcs.anl.gov>
>>>>> wrote:
>>>>> > OK, I have thought that space was a typo. btw, this option does not
>>>>> show up in -h.
>>>>> > I changed number of ranks to use all cores on each node to avoid
>>>>> misleading ratio in -log_view. Since one node has 36 cores, I ran with
>>>>> 6^3=216 ranks, and 12^3=1728 ranks. I also found call counts of MatSOR etc
>>>>> in the two tests were different. So they are not strict weak scaling tests.
>>>>> I tried to add -ksp_max_it 6 -pc_mg_levels 6, but still could not make the
>>>>> two have the same MatSOR count. Anyway, I attached the load balance output.
>>>>> > I find PCApply_MG calls PCMGMCycle_Private, which is recursive and
>>>>> indirectly calls MatSOR_MPIAIJ. I believe the following code in
>>>>> MatSOR_MPIAIJ practically syncs {MatSOR, MatMultAdd}_SeqAIJ between
>>>>> processors through VecScatter at each MG level. If SOR and MatMultAdd are
>>>>> imbalanced, the cost is accumulated along MG levels and shows up as large
>>>>> VecScatter cost.
>>>>> > 1460: while
>>>>> > (its--) {
>>>>> > 1461: VecScatterBegin(mat->Mvctx,xx
>>>>> ,mat->lvec,INSERT_VALUES,SCATTER_FORWARD
>>>>> > 1462: VecScatterEnd(mat->Mvctx,xx,m
>>>>> > 1464: /* update rhs: bb1 = bb - B*x */
>>>>> > 1465: VecScale
>>>>> > (mat->lvec,-1.0);
>>>>> > 1466: (*mat->B->ops->multadd)(mat->
>>>>> > B,mat->lvec,bb,bb1);
>>>>> > 1468: /* local sweep */
>>>>> > 1469: (*mat->A->ops->sor)(mat->A,bb
>>>>> 1,omega,SOR_SYMMETRIC_SWEEP,
>>>>> > fshift,lits,1,xx);
>>>>> > 1470: }
>>>>> > --Junchao Zhang
>>>>> > On Thu, Jun 7, 2018 at 3:11 PM, Smith, Barry F. <bsmith at mcs.anl.gov>
>>>>> wrote:
>>>>> > > On Jun 7, 2018, at 12:27 PM, Zhang, Junchao <jczhang at mcs.anl.gov>
>>>>> wrote:
>>>>> > > Searched but could not find this option, -mat_view::load_balance
>>>>> > There is a space between the view and the : load_balance is a
>>>>> particular viewer format that causes the printing of load balance
>>>>> information about number of nonzeros in the matrix.
>>>>> > Barry
>>>>> > > --Junchao Zhang
>>>>> > > On Thu, Jun 7, 2018 at 10:46 AM, Smith, Barry F. <
>>>>> bsmith at mcs.anl.gov> wrote:
>>>>> > > So the only surprise in the results is the SOR. It is
>>>>> embarrassingly parallel and normally one would not see a jump.
>>>>> > > The load balance for SOR time 1.5 is better at 1000 processes
>>>>> than for 125 processes of 2.1 not worse so this number doesn't easily
>>>>> explain it.
>>>>> > > Could you run the 125 and 1000 with -mat_view ::load_balance and
>>>>> see what you get out?
>>>>> > > Thanks
>>>>> > > Barry
>>>>> > > Notice that the MatSOR time jumps a lot about 5 secs when the
>>>>> -log_sync is on. My only guess is that the MatSOR is sharing memory
>>>>> bandwidth (or some other resource? cores?) with the VecScatter and for some
>>>>> reason this is worse for 1000 cores but I don't know why.
>>>>> > > > On Jun 6, 2018, at 9:13 PM, Junchao Zhang <jczhang at mcs.anl.gov>
>>>>> wrote:
>>>>> > > > Hi, PETSc developers,
>>>>> > > > I tested Michael Becker's code. The code calls the same
>>>>> KSPSolve 1000 times in the second stage and needs cubic number of
>>>>> processors to run. I ran with 125 ranks and 1000 ranks, with or without
>>>>> -log_sync option. I attach the log view output files and a scaling loss
>>>>> excel file.
>>>>> > > > I profiled the code with 125 processors. It looks {MatSOR,
>>>>> MatMult, MatMultAdd, MatMultTranspose, MatMultTransposeAdd}_SeqAIJ in aij.c
>>>>> took ~50% of the time, The other half time was spent on waiting in MPI.
>>>>> MatSOR_SeqAIJ took 30%, mostly in PetscSparseDenseMinusDot().
>>>>> > > > I tested it on a 36 cores/node machine. I found 32 ranks/node
>>>>> gave better performance (about 10%) than 36 ranks/node in the 125 ranks
>>>>> testing. I guess it is because processors in the former had more balanced
>>>>> memory bandwidth. I collected PAPI_DP_OPS (double precision operations) and
>>>>> PAPI_TOT_CYC (total cycles) of the 125 ranks case (see the attached files).
>>>>> It looks ranks at the two ends have less DP_OPS and TOT_CYC.
>>>>> > > > Does anyone familiar with the algorithm have quick explanations?
>>>>> > > > --Junchao Zhang
>>>>> > > > On Mon, Jun 4, 2018 at 11:59 AM, Michael Becker <
>>>>> Michael.Becker at physik.uni-giessen.de> wrote:
>>>>> > > > Hello again,
>>>>> > > > this took me longer than I anticipated, but here we go.
>>>>> > > > I did reruns of the cases where only half the processes per node
>>>>> were used (without -log_sync):
>>>>> > > > 125 procs,1st 125 procs,2nd
>>>>> 1000 procs,1st 1000 procs,2nd
>>>>> > > > Max Ratio Max Ratio
>>>>> Max Ratio Max Ratio
>>>>> > > > KSPSolve 1.203E+02 1.0 1.210E+02 1.0
>>>>> 1.399E+02 1.1 1.365E+02 1.0
>>>>> > > > VecTDot 6.376E+00 3.7 6.551E+00 4.0
>>>>> 7.885E+00 2.9 7.175E+00 3.4
>>>>> > > > VecNorm 4.579E+00 7.1 5.803E+00 10.2
>>>>> 8.534E+00 6.9 6.026E+00 4.9
>>>>> > > > VecScale 1.070E-01 2.1 1.129E-01 2.2
>>>>> 1.301E-01 2.5 1.270E-01 2.4
>>>>> > > > VecCopy 1.123E-01 1.3 1.149E-01 1.3
>>>>> 1.301E-01 1.6 1.359E-01 1.6
>>>>> > > > VecSet 7.063E-01 1.7 6.968E-01 1.7
>>>>> 7.432E-01 1.8 7.425E-01 1.8
>>>>> > > > VecAXPY 1.166E+00 1.4 1.167E+00 1.4
>>>>> 1.221E+00 1.5 1.279E+00 1.6
>>>>> > > > VecAYPX 1.317E+00 1.6 1.290E+00 1.6
>>>>> 1.536E+00 1.9 1.499E+00 2.0
>>>>> > > > VecScatterBegin 6.142E+00 3.2 5.974E+00 2.8
>>>>> 6.448E+00 3.0 6.472E+00 2.9
>>>>> > > > VecScatterEnd 3.606E+01 4.2 3.551E+01 4.0
>>>>> 5.244E+01 2.7 4.995E+01 2.7
>>>>> > > > MatMult 3.561E+01 1.6 3.403E+01 1.5
>>>>> 3.435E+01 1.4 3.332E+01 1.4
>>>>> > > > MatMultAdd 1.124E+01 2.0 1.130E+01 2.1
>>>>> 2.093E+01 2.9 1.995E+01 2.7
>>>>> > > > MatMultTranspose 1.372E+01 2.5 1.388E+01 2.6
>>>>> 1.477E+01 2.2 1.381E+01 2.1
>>>>> > > > MatSolve 1.949E-02 0.0 1.653E-02 0.0
>>>>> 4.789E-02 0.0 4.466E-02 0.0
>>>>> > > > MatSOR 6.610E+01 1.3 6.673E+01 1.3
>>>>> 7.111E+01 1.3 7.105E+01 1.3
>>>>> > > > MatResidual 2.647E+01 1.7 2.667E+01 1.7
>>>>> 2.446E+01 1.4 2.467E+01 1.5
>>>>> > > > PCSetUpOnBlocks 5.266E-03 1.4 5.295E-03 1.4
>>>>> 5.427E-03 1.5 5.289E-03 1.4
>>>>> > > > PCApply 1.031E+02 1.0 1.035E+02 1.0
>>>>> 1.180E+02 1.0 1.164E+02 1.0
>>>>> > > > I also slimmed down my code and basically wrote a simple weak
>>>>> scaling test (source files attached) so you can profile it yourself. I
>>>>> appreciate the offer Junchao, thank you.
>>>>> > > > You can adjust the system size per processor at runtime via
>>>>> "-nodes_per_proc 30" and the number of repeated calls to the function
>>>>> containing KSPsolve() via "-iterations 1000". The physical problem is
>>>>> simply calculating the electric potential from a homogeneous charge
>>>>> distribution, done multiple times to accumulate time in KSPsolve().
>>>>> > > > A job would be started using something like
>>>>> > > > mpirun -n 125 ~/petsc_ws/ws_test -nodes_per_proc 30 -mesh_size
>>>>> 1E-4 -iterations 1000 \\
>>>>> > > > -ksp_rtol 1E-6 \
>>>>> > > > -log_view -log_sync\
>>>>> > > > -pc_type gamg -pc_gamg_type classical\
>>>>> > > > -ksp_type cg \
>>>>> > > > -ksp_norm_type unpreconditioned \
>>>>> > > > -mg_levels_ksp_type richardson \
>>>>> > > > -mg_levels_ksp_norm_type none \
>>>>> > > > -mg_levels_pc_type sor \
>>>>> > > > -mg_levels_ksp_max_it 1 \
>>>>> > > > -mg_levels_pc_sor_its 1 \
>>>>> > > > -mg_levels_esteig_ksp_type cg \
>>>>> > > > -mg_levels_esteig_ksp_max_it 10 \
>>>>> > > > -gamg_est_ksp_type cg
>>>>> > > > , ideally started on a cube number of processes for a cubical
>>>>> process grid.
>>>>> > > > Using 125 processes and 10.000 iterations I get the output in
>>>>> "log_view_125_new.txt", which shows the same imbalance for me.
>>>>> > > > Michael
>>>>> > > > Am 02.06.2018 um 13:40 schrieb Mark Adams:
>>>>> > > >> On Fri, Jun 1, 2018 at 11:20 PM, Junchao Zhang <
>>>>> jczhang at mcs.anl.gov> wrote:
>>>>> > > >> Hi,Michael,
>>>>> > > >> You can add -log_sync besides -log_view, which adds barriers
>>>>> to certain events but measures barrier time separately from the events. I
>>>>> find this option makes it easier to interpret log_view output.
>>>>> > > >> That is great (good to know).
>>>>> > > >> This should give us a better idea if your large VecScatter
>>>>> costs are from slow communication or if it catching some sort of load
>>>>> imbalance.
>>>>> > > >> --Junchao Zhang
>>>>> > > >> On Wed, May 30, 2018 at 3:27 AM, Michael Becker <
>>>>> > > >> Barry: On its way. Could take a couple days again.
>>>>> > > >> Junchao: I unfortunately don't have access to a cluster with a
>>>>> faster network. This one has a mixed 4X QDR-FDR InfiniBand 2:1 blocking
>>>>> fat-tree network, which I realize causes parallel slowdown if the nodes are
>>>>> not connected to the same switch. Each node has 24 processors (2x12/socket)
>>>>> and four NUMA domains (two for each socket).
>>>>> > > >> The ranks are usually not distributed perfectly even, i.e. for
>>>>> 125 processes, of the six required nodes, five would use 21 cores and one
>>>>> 20.
>>>>> > > >> Would using another CPU type make a difference
>>>>> communication-wise? I could switch to faster ones (on the same network),
>>>>> but I always assumed this would only improve performance of the stuff that
>>>>> is unrelated to communication.
>>>>> > > >> Michael
>>>>> > > >>> The log files have something like "Average time for zero size
>>>>> MPI_Send(): 1.84231e-05". It looks you ran on a cluster with a very slow
>>>>> network. A typical machine should give less than 1/10 of the latency you
>>>>> have. An easy way to try is just running the code on a machine with a
>>>>> faster network and see what happens.
>>>>> > > >>> Also, how many cores & numa domains does a compute node have?
>>>>> I could not figure out how you distributed the 125 MPI ranks evenly.
>>>>> > > >>> --Junchao Zhang
>>>>> > > >>> On Tue, May 29, 2018 at 6:18 AM, Michael Becker <
>>>>> > > >>> Hello again,
>>>>> > > >>> here are the updated log_view files for 125 and 1000
>>>>> processors. I ran both problems twice, the first time with all processors
>>>>> per node allocated ("-1.txt"), the second with only half on twice the
>>>>> number of nodes ("-2.txt").
>>>>> > > >>>>> On May 24, 2018, at 12:24 AM, Michael Becker <
>>>>> > > >>>>> wrote:
>>>>> > > >>>>> I noticed that for every individual KSP iteration, six
>>>>> vector objects are created and destroyed (with CG, more with e.g. GMRES).
>>>>> > > >>>> Hmm, it is certainly not intended at vectors be created and
>>>>> destroyed within each KSPSolve() could you please point us to the code that
>>>>> makes you think they are being created and destroyed? We create all the
>>>>> work vectors at KSPSetUp() and destroy them in KSPReset() not during the
>>>>> solve. Not that this would be a measurable distance.
>>>>> > > >>> I mean this, right in the log_view output:
>>>>> > > >>>> Memory usage is given in bytes:
>>>>> > > >>>> Object Type Creations Destructions Memory Descendants' Mem.
>>>>> > > >>>> Reports information only for process 0.
>>>>> > > >>>> --- Event Stage 0: Main Stage
>>>>> > > >>>> --- Event Stage 1: First Solve
>>>>> > > >>>> --- Event Stage 2: Remaining Solves
>>>>> > > >>>> Vector 23904 23904 1295501184 0.
>>>>> > > >>> I logged the exact number of KSP iterations over the 999
>>>>> timesteps and its exactly 23904/6 = 3984.
>>>>> > > >>> Michael
>>>>> > > >>> Am 24.05.2018 um 19:50 schrieb Smith, Barry F.:
>>>>> > > >>>> Please send the log file for 1000 with cg as the solver.
>>>>> > > >>>> You should make a bar chart of each event for the two cases
>>>>> to see which ones are taking more time and which are taking less (we cannot
>>>>> tell with the two logs you sent us since they are for different solvers.)
>>>>> > > >>>>> This seems kind of wasteful, is this supposed to be like
>>>>> this? Is this even the reason for my problems? Apart from that, everything
>>>>> seems quite normal to me (but I'm not the expert here).
>>>>> > > >>>>> Thanks in advance.
>>>>> > > >>>>> Michael
>>>>> > > >>>>> <log_view_125procs.txt><log_vi
>>>>> > > >>>>> ew_1000procs.txt>
>>>>> > > > <o-wstest-125.txt><Scaling-loss.png><o-wstest-1000.txt><o-ws
>>>>> ><PAPI_TOT_CYC.png><PAPI_DP_OPS.png>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180613/f1c70936/attachment-0001.html>
using 216 of 216 processes
30^3 unknowns per processor
total system size: 180^3
mesh size: 0.0001
Mat Object: 216 MPI processes
type: mpiaij
Load Balance - Nonzeros: Min 189000 avg 189000 max 189000
type: mpiaij
type: mpiaij
type: mpiaij
type: mpiaij
Load Balance - Nonzeros: Min 94500 avg 96739 max 106784
type: mpiaij
Load Balance - Nonzeros: Min 94500 avg 95898 max 102716
type: mpiaij
Load Balance - Nonzeros: Min 248220 avg 259246 max 273660
type: mpiaij
Load Balance - Nonzeros: Min 246056 avg 259040 max 273525
type: mpiaij
Load Balance - Nonzeros: Min 111528 avg 117225 max 133209
type: mpiaij
Load Balance - Nonzeros: Min 58106 avg 66984 max 69685
type: mpiaij
Load Balance - Nonzeros: Min 89708 avg 116072 max 137752
type: mpiaij
Load Balance - Nonzeros: Min 87894 avg 115602 max 136661
type: mpiaij
Load Balance - Nonzeros: Min 20878 avg 27301 max 37274
type: mpiaij
Load Balance - Nonzeros: Min 5809 avg 7404 max 9417
type: mpiaij
Load Balance - Nonzeros: Min 3833 avg 5850 max 13508
type: mpiaij
Load Balance - Nonzeros: Min 3106 avg 5439 max 11996
type: mpiaij
Load Balance - Nonzeros: Min 1079 avg 1677 max 3439
type: mpiaij
Load Balance - Nonzeros: Min 232 avg 426 max 977
type: mpiaij
Load Balance - Nonzeros: Min 0 avg 487 max 2786
type: mpiaij
Load Balance - Nonzeros: Min 0 avg 487 max 15513
type: mpiaij
type: mpiaij
Load Balance - Nonzeros: Min 0 avg 391 max 12579
type: mpiaij
Load Balance - Nonzeros: Min 0 avg 51 max 1471
type: mpiaij
Load Balance - Nonzeros: Min 0 avg 19 max 574
type: mpiaij
Load Balance - Nonzeros: Min 0 avg 1 max 171
type: mpiaij
Load Balance - Nonzeros: Min 0 avg 1 max 361
type: mpiaij
initsolve: 2 iterations
solve 1: 2 iterations
solve 2: 2 iterations
solve 3: 2 iterations
solve 4: 2 iterations
solve 5: 2 iterations
solve 6: 2 iterations
solve 7: 2 iterations
solve 8: 2 iterations
solve 9: 2 iterations
solve 10: 2 iterations
solve 20: 2 iterations
solve 30: 2 iterations
solve 40: 2 iterations
solve 50: 2 iterations
solve 60: 2 iterations
solve 70: 2 iterations
solve 80: 2 iterations
solve 90: 2 iterations
solve 100: 2 iterations
solve 200: 2 iterations
solve 300: 2 iterations
solve 400: 2 iterations
solve 500: 2 iterations
solve 600: 2 iterations
solve 700: 2 iterations
solve 800: 2 iterations
solve 900: 2 iterations
solve 1000: 2 iterations
Time in solve(): 35.8368 s
Time in KSPSolve(): 35.5561 s (99.2166%)
Number of KSP iterations (total): 2000
Number of solve iterations (total): 1000 (ratio: 2.00)
*** WIDEN YOUR WINDOW TO 120 CHARACTERS. Use 'enscript -r -fCourier9' to print this document ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./wstest on a intel-bdw-opt named bdw-0088 with 216 processors, by jczhang Tue Jun 12 23:17:27 2018
Using Petsc Development GIT revision: v3.9.2-570-g68f20b90 GIT Date: 2018-06-04 15:39:16 +0200
Max Max/Min Avg Total
Time (sec): 1.461e+02 1.00000 1.461e+02
Objects: 1.042e+04 1.00010 1.042e+04
Flop: 1.076e+10 1.12766 1.020e+10 2.203e+12
Flop/sec: 7.364e+07 1.12766 6.981e+07 1.508e+10
MPI Messages: 8.832e+05 1.87220 5.444e+05 1.176e+08
MPI Message Lengths: 7.040e+08 1.10023 1.209e+03 1.422e+11
MPI Reductions: 1.055e+04 1.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
e.g., VecAXPY() for real vectors of length N --> 2N flop
and VecAXPY() for complex vectors of length N --> 8N flop
Summary of Stages: ----- Time ------ ----- Flop ----- --- Messages --- -- Message Lengths -- -- Reductions --
Avg %Total Avg %Total counts %Total Avg %Total counts %Total
0: Main Stage: 9.1544e-02 0.1% 0.0000e+00 0.0% 2.592e+03 0.0% 1.802e+03 0.0% 1.700e+01 0.2%
1: First Solve: 1.1015e+02 75.4% 4.6662e+09 0.2% 8.968e+05 0.8% 4.494e+03 2.8% 5.250e+02 5.0%
2: Remaining Solves: 3.5853e+01 24.5% 2.1983e+12 99.8% 1.167e+08 99.2% 1.184e+03 97.2% 1.000e+04 94.8%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
Count: number of times phase was executed
Time and Flop: Max - maximum over all processors
Ratio - ratio of maximum to minimum over all processors
Mess: number of messages sent
Avg. len: average message length (bytes)
Reduct: number of global reductions
Global: entire computation
Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
%T - percent time in this phase %F - percent flop in this phase
%M - percent messages in this phase %L - percent message lengths in this phase
%R - percent reductions in this phase
Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over all processors)
Event Count Time (sec) Flop --- Global --- --- Stage --- Total
Max Ratio Max Ratio Max Ratio Mess Avg len Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
VecSet 2 1.0 8.6784e-05 3.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
BuildTwoSided 10 1.0 3.1507e-03 1.3 0.00e+00 0.0 2.4e+04 4.0e+00 0.0e+00 0 0 0 0 0 0 0 3 0 0 0
BuildTwoSidedF 27 1.0 6.3965e+00 2.6 0.00e+00 0.0 2.1e+04 1.1e+04 0.0e+00 3 0 0 0 0 4 0 2 6 0 0
KSPSetUp 8 1.0 3.2792e-03 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 1.6e+01 0 0 0 0 0 0 0 0 0 3 0
KSPSolve 1 1.0 1.1015e+02 1.0 2.33e+07 1.1 9.0e+05 4.5e+03 5.2e+02 75 0 1 3 5 100100100100100 42
VecTDot 3 1.0 9.1021e-0334.9 1.62e+05 1.0 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 0 1 0 0 1 3844
VecNorm 3 1.0 6.0630e-04 2.5 1.62e+05 1.0 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 0 1 0 0 1 57714
VecScale 10 1.0 1.1373e-04 2.9 2.97e+04 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 52201
VecCopy 1 1.0 1.3185e-04 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 64 1.0 7.6294e-04 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAXPY 2 1.0 1.5998e-04 1.5 1.08e+05 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 145819
VecAYPX 11 1.0 3.8528e-04 1.7 1.12e+05 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 1 0 0 0 61860
VecAssemblyBegin 2 1.0 4.5776e-0548.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAssemblyEnd 2 1.0 5.2214e-0554.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecScatterBegin 44 1.0 2.4009e-03 1.6 0.00e+00 0.0 1.2e+05 1.2e+03 0.0e+00 0 0 0 0 0 0 0 13 3 0 0
VecScatterEnd 44 1.0 1.5850e-02 3.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatMult 12 1.0 9.0702e-03 1.6 3.07e+06 1.1 3.8e+04 1.8e+03 0.0e+00 0 0 0 0 0 0 13 4 2 0 69092
MatMultAdd 10 1.0 3.8619e-03 1.9 6.98e+05 1.0 2.2e+04 5.6e+02 0.0e+00 0 0 0 0 0 0 3 2 0 0 38197
MatMultTranspose 10 1.0 5.2512e-03 2.0 6.98e+05 1.0 2.2e+04 5.6e+02 0.0e+00 0 0 0 0 0 0 3 2 0 0 28092
MatSolve 2 0.0 1.0014e-05 0.0 1.41e+03 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 140
MatSOR 20 1.0 2.4410e-02 1.6 5.77e+06 1.2 3.5e+04 1.4e+03 4.0e+00 0 0 0 0 0 0 25 4 1 1 47866
MatLUFactorSym 1 1.0 1.7500e-0413.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatLUFactorNum 1 1.0 6.8903e-0518.1 4.40e+03 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 64
MatResidual 10 1.0 7.2005e-03 1.8 2.45e+06 1.1 3.5e+04 1.4e+03 0.0e+00 0 0 0 0 0 0 11 4 1 0 68474
MatAssemblyBegin 82 1.0 6.4096e+00 2.6 0.00e+00 0.0 2.1e+04 1.1e+04 0.0e+00 3 0 0 0 0 4 0 2 6 0 0
MatAssemblyEnd 82 1.0 1.1275e-01 1.2 0.00e+00 0.0 1.8e+05 4.3e+02 2.1e+02 0 0 0 0 2 0 0 20 2 40 0
MatGetRow 3346824 1.1 5.1589e+01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 34 0 0 0 0 46 0 0 0 0 0
MatGetRowIJ 1 0.0 8.1062e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatCreateSubMats 5 1.0 2.2660e-01 1.8 0.00e+00 0.0 1.6e+05 1.7e+04 1.0e+01 0 0 0 2 0 0 0 18 65 2 0
MatCreateSubMat 5 1.0 3.0296e-01 1.0 0.00e+00 0.0 3.7e+04 1.5e+04 8.4e+01 0 0 0 0 1 0 0 4 14 16 0
MatGetOrdering 1 0.0 5.6982e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatIncreaseOvrlp 5 1.0 3.2210e-02 1.1 0.00e+00 0.0 7.0e+04 9.6e+02 1.0e+01 0 0 0 0 0 0 0 8 2 2 0
MatCoarsen 5 1.0 2.0194e-02 1.1 0.00e+00 0.0 1.5e+05 5.5e+02 2.9e+01 0 0 0 0 0 0 0 16 2 6 0
MatZeroEntries 5 1.0 1.0461e-0210.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatView 26 1.0 6.0523e-01 1.0 0.00e+00 0.0 3.3e+04 1.7e+04 5.1e+01 0 0 0 0 0 1 0 4 14 10 0
MatPtAP 5 1.0 2.0556e-01 1.0 1.25e+07 1.1 1.9e+05 2.5e+03 8.2e+01 0 0 0 0 1 0 53 21 12 16 11962
MatPtAPSymbolic 5 1.0 1.1618e-01 1.0 0.00e+00 0.0 9.4e+04 2.5e+03 3.5e+01 0 0 0 0 0 0 0 10 6 7 0
MatPtAPNumeric 5 1.0 8.9715e-02 1.0 1.25e+07 1.1 9.2e+04 2.5e+03 4.5e+01 0 0 0 0 0 0 53 10 6 9 27408
MatGetLocalMat 5 1.0 2.8648e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetBrAoCol 5 1.0 1.3785e-02 3.5 0.00e+00 0.0 5.3e+04 3.3e+03 0.0e+00 0 0 0 0 0 0 0 6 4 0 0
SFSetGraph 10 1.0 1.0729e-04 4.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
SFSetUp 10 1.0 6.7554e-03 1.1 0.00e+00 0.0 7.3e+04 5.4e+02 0.0e+00 0 0 0 0 0 0 0 8 1 0 0
SFBcastBegin 39 1.0 1.5974e-03 1.3 0.00e+00 0.0 1.5e+05 6.4e+02 0.0e+00 0 0 0 0 0 0 0 17 2 0 0
SFBcastEnd 39 1.0 1.0992e-02 7.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
GAMG: createProl 5 1.0 1.0922e+02 1.0 0.00e+00 0.0 5.5e+05 5.1e+03 2.5e+02 75 0 0 2 2 99 0 62 71 48 0
GAMG: partLevel 5 1.0 2.1535e-01 1.0 1.25e+07 1.1 1.9e+05 2.5e+03 1.9e+02 0 0 0 0 2 0 53 21 12 36 11418
repartition 2 1.0 8.9693e-04 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01 0 0 0 0 0 0 0 0 0 2 0
Invert-Sort 2 1.0 9.0194e-04 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00 0 0 0 0 0 0 0 0 0 2 0
Move A 2 1.0 4.0240e-03 1.1 0.00e+00 0.0 1.3e+03 9.9e+02 3.6e+01 0 0 0 0 0 0 0 0 0 7 0
Move P 2 1.0 3.3162e-03 1.2 0.00e+00 0.0 2.3e+03 1.5e+01 3.6e+01 0 0 0 0 0 0 0 0 0 7 0
PCSetUp 2 1.0 1.0945e+02 1.0 1.25e+07 1.1 7.4e+05 4.5e+03 4.7e+02 75 0 1 2 4 99 53 83 82 90 22
PCSetUpOnBlocks 2 1.0 4.7374e-04 4.7 4.40e+03 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 9
PCApply 2 1.0 3.8466e-02 1.4 9.62e+06 1.1 1.1e+05 1.0e+03 4.0e+00 0 0 0 0 0 0 42 13 3 1 50864
KSPSolve 1000 1.0 3.5565e+01 1.0 1.07e+10 1.1 1.2e+08 1.2e+03 1.0e+04 24100 99 97 95 99100100100100 61811
VecTDot 3000 1.0 2.1074e+00 1.2 1.62e+08 1.0 0.0e+00 0.0e+00 3.0e+03 1 2 0 0 28 5 2 0 0 30 16604
VecNorm 3000 1.0 1.1686e+00 1.1 1.62e+08 1.0 0.0e+00 0.0e+00 3.0e+03 1 2 0 0 28 3 2 0 0 30 29945
VecScale 10000 1.0 6.4481e-02 1.6 2.97e+07 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 92068
VecCopy 1000 1.0 8.6886e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 36000 1.0 4.7016e-01 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
VecAXPY 2000 1.0 1.6832e-01 1.5 1.08e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 1 0 0 0 0 1 0 0 0 138593
VecAYPX 11000 1.0 2.9297e-01 1.3 1.12e+08 1.1 0.0e+00 0.0e+00 0.0e+00 0 1 0 0 0 1 1 0 0 0 81352
VecScatterBegin 42000 1.0 2.1308e+00 1.6 0.00e+00 0.0 1.2e+08 1.2e+03 0.0e+00 1 0 99 97 0 4 0100100 0 0
VecScatterEnd 42000 1.0 9.5539e+00 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 5 0 0 0 0 22 0 0 0 0 0
MatMult 12000 1.0 7.7250e+00 1.2 3.07e+09 1.1 3.8e+07 1.8e+03 0.0e+00 5 28 32 47 0 19 29 32 48 0 81124
MatMultAdd 10000 1.0 4.8386e+00 1.6 6.98e+08 1.0 2.2e+07 5.6e+02 0.0e+00 3 7 19 9 0 11 7 19 9 0 30487
MatMultTranspose 10000 1.0 4.4888e+00 1.5 6.98e+08 1.0 2.2e+07 5.6e+02 0.0e+00 3 7 19 9 0 10 7 19 9 0 32863
MatSolve 2000 0.0 1.1715e-02 0.0 1.41e+06 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 120
MatSOR 20000 1.0 1.7121e+01 1.1 5.72e+09 1.2 3.5e+07 1.4e+03 4.0e+03 11 53 30 33 38 45 53 30 34 40 67719
MatResidual 10000 1.0 6.4821e+00 1.2 2.45e+09 1.1 3.5e+07 1.4e+03 0.0e+00 4 22 30 33 0 16 22 30 34 0 76062
PCSetUpOnBlocks 2000 1.0 2.6277e-02 3.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
PCApply 2000 1.0 3.0727e+01 1.0 9.57e+09 1.1 1.1e+08 1.0e+03 4.0e+03 21 88 97 84 38 85 89 98 86 40 63382
Krylov Solver 1 8 10120 0.
DMKSP interface 1 1 656 0.
Vector 4 45 2445008 0.
Matrix 0 59 15632384 0.
Distributed Mesh 1 1 5248 0.
Index Set 2 14 254340 0.
IS L to G Mapping 1 1 131728 0.
Star Forest Graph 2 2 1728 0.
Discrete System 1 1 932 0.
Vec Scatter 1 12 231168 0.
Preconditioner 1 8 8692 0.
Viewer 1 2 1680 0.
Application Order 0 1 46656664 0.
Krylov Solver 7 0 0 0.
Vector 112 71 2077080 0.
Matrix 124 65 40701300 0.
Matrix Coarsen 5 5 3180 0.
Index Set 104 92 24404092 0.
Star Forest Graph 10 10 8640 0.
Vec Scatter 28 17 21488 0.
Preconditioner 7 0 0 0.
Viewer 2 0 0 0.
Application Order 1 0 0 0.
Vector 10000 10000 645984000 0.
Average time to get PetscTime(): 6.19888e-07
Average time for MPI_Barrier(): 8.96454e-06
Average time for zero size MPI_Send(): 6.52781e-06
#PETSc Option Table entries:
-iterations 1000
-ksp_rtol 1E-6
-ksp_type cg
-log_view
-mesh_size 1E-4
-nodes_per_proc 30
-pc_type gamg
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --with-debugging=no --COPTFLAGS="-g -O3 -DPETSC_KERNEL_USE_UNROLL_4" --CXXOPTFLAGS="-g -O3 -DPETSC_KERNEL_USE_UNROLL_4" --FOPTFLAGS="-g -O3 -DPETSC_KERNEL_USE_UNROLL_4" --with-openmp=1 --download-sowing --download-fblaslapack=1 --download-scalapack=1 --download-metis=1 --download-parmetis=1 --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90 --PETSC_ARCH=intel-bdw-opt --PETSC_DIR=/home/jczhang/petsc
Libraries compiled on 2018-06-05 18:40:55 on beboplogin2
Machine characteristics: Linux-3.10.0-693.21.1.el7.x86_64-x86_64-with-centos-7.4.1708-Core
Using PETSc directory: /home/jczhang/petsc
Using PETSc arch: intel-bdw-opt
Using C compiler: mpicc -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O3 -DPETSC_KERNEL_USE_UNROLL_4 -fopenmp
Using Fortran compiler: mpif90 -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O3 -DPETSC_KERNEL_USE_UNROLL_4 -fopenmp
Using include paths: -I/home/jczhang/petsc/include -I/home/jczhang/petsc/intel-bdw-opt/include
Using C linker: mpicc
Using Fortran linker: mpif90
Using libraries: -Wl,-rpath,/home/jczhang/petsc/intel-bdw-opt/lib -L/home/jczhang/petsc/intel-bdw-opt/lib -lpetsc -Wl,-rpath,/home/jczhang/petsc/intel-bdw-opt/lib -L/home/jczhang/petsc/intel-bdw-opt/lib -Wl,-rpath,/blues/gpfs/home/jczhang/spack/opt/spack/linux-centos7-x86_64/gcc-4.8.5/intel-mpi-2018.0.128-afy57nutkjquvasoogql4bmgwdjdhtbi/compilers_and_libraries_2018.0.128/linux/mpi/intel64/lib/debug_mt -L/blues/gpfs/home/jczhang/spack/opt/spack/linux-centos7-x86_64/gcc-4.8.5/intel-mpi-2018.0.128-afy57nutkjquvasoogql4bmgwdjdhtbi/compilers_and_libraries_2018.0.128/linux/mpi/intel64/lib/debug_mt -Wl,-rpath,/blues/gpfs/home/jczhang/spack/opt/spack/linux-centos7-x86_64/gcc-4.8.5/intel-mpi-2018.0.128-afy57nutkjquvasoogql4bmgwdjdhtbi/compilers_and_libraries_2018.0.128/linux/mpi/intel64/lib -L/blues/gpfs/home/jczhang/spack/opt/spack/linux-centos7-x86_64/gcc-4.8.5/intel-mpi-2018.0.128-afy57nutkjquvasoogql4bmgwdjdhtbi/compilers_and_libraries_2018.0.128/linux/mpi/intel64/lib -Wl,-rpath,/blues/gpfs/home/software/bebop/craype-17.02-1-knl/opt/gcc/4.9.1/snos/lib/gcc/x86_64-suse-linux/4.9.1 -L/blues/gpfs/home/software/bebop/craype-17.02-1-knl/opt/gcc/4.9.1/snos/lib/gcc/x86_64-suse-linux/4.9.1 -Wl,-rpath,/blues/gpfs/home/software/bebop/craype-17.02-1-knl/opt/gcc/4.9.1/snos/lib/gcc -L/blues/gpfs/home/software/bebop/craype-17.02-1-knl/opt/gcc/4.9.1/snos/lib/gcc -Wl,-rpath,/blues/gpfs/home/software/bebop/craype-17.02-1-knl/opt/gcc/4.9.1/snos/lib64 -L/blues/gpfs/home/software/bebop/craype-17.02-1-knl/opt/gcc/4.9.1/snos/lib64 -Wl,-rpath,/blues/gpfs/home/jczhang/spack/opt/spack/linux-centos7-x86_64/gcc-4.8.5/hpctoolkit-2017.06-557cxm5zivsflxdq5sqgcx3j6z7ybn6n/lib -L/blues/gpfs/home/jczhang/spack/opt/spack/linux-centos7-x86_64/gcc-4.8.5/hpctoolkit-2017.06-557cxm5zivsflxdq5sqgcx3j6z7ybn6n/lib -Wl,-rpath,/blues/gpfs/home/software/spack-0.10.1/opt/spack/linux-centos7-x86_64/intel-17.0.4/intel-mkl-2017.3.196-v7uuj6zmthzln35n2hb7i5u5ybncv5ev/compilers_and_libraries_2017.4.196/linux/tbb/lib/intel64_lin/gcc4.7 -L/blues/gpfs/home/software/spack-0.10.1/opt/spack/linux-centos7-x86_64/intel-17.0.4/intel-mkl-2017.3.196-v7uuj6zmthzln35n2hb7i5u5ybncv5ev/compilers_and_libraries_2017.4.196/linux/tbb/lib/intel64_lin/gcc4.7 -Wl,-rpath,/blues/gpfs/home/software/spack-0.10.1/opt/spack/linux-centos7-x86_64/intel-17.0.4/intel-mkl-2017.3.196-v7uuj6zmthzln35n2hb7i5u5ybncv5ev/compilers_and_libraries_2017.4.196/linux/compiler/lib/intel64_lin -L/blues/gpfs/home/software/spack-0.10.1/opt/spack/linux-centos7-x86_64/intel-17.0.4/intel-mkl-2017.3.196-v7uuj6zmthzln35n2hb7i5u5ybncv5ev/compilers_and_libraries_2017.4.196/linux/compiler/lib/intel64_lin -Wl,-rpath,/blues/gpfs/home/software/spack-0.10.1/opt/spack/linux-centos7-x86_64/intel-17.0.4/intel-mkl-2017.3.196-v7uuj6zmthzln35n2hb7i5u5ybncv5ev/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64_lin -L/blues/gpfs/home/software/spack-0.10.1/opt/spack/linux-centos7-x86_64/intel-17.0.4/intel-mkl-2017.3.196-v7uuj6zmthzln35n2hb7i5u5ybncv5ev/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64_lin -Wl,-rpath,/blues/gpfs/home/software/spack-0.10.1/opt/spack/linux-centos7-x86_64/intel-17.0.4/intel-mkl-2017.3.196-v7uuj6zmthzln35n2hb7i5u5ybncv5ev/lib -L/blues/gpfs/home/software/spack-0.10.1/opt/spack/linux-centos7-x86_64/intel-17.0.4/intel-mkl-2017.3.196-v7uuj6zmthzln35n2hb7i5u5ybncv5ev/lib -Wl,-rpath,/blues/gpfs/home/software/spack-0.10.1/opt/spack/linux-centos7-x86_64/gcc-4.8.5/intel-17.0.4-74uvhjiulyqgvsmywifbbuo46v5n42xc/tbb/lib/intel64/gcc4.4 -L/blues/gpfs/home/software/spack-0.10.1/opt/spack/linux-centos7-x86_64/gcc-4.8.5/intel-17.0.4-74uvhjiulyqgvsmywifbbuo46v5n42xc/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/blues/gpfs/home/software/spack-0.10.1/opt/spack/linux-centos7-x86_64/gcc-4.8.5/intel-17.0.4-74uvhjiulyqgvsmywifbbuo46v5n42xc/lib/intel64 -L/blues/gpfs/home/software/spack-0.10.1/opt/spack/linux-centos7-x86_64/gcc-4.8.5/intel-17.0.4-74uvhjiulyqgvsmywifbbuo46v5n42xc/lib/intel64 -Wl,-rpath,/blues/gpfs/home/software/bebop/craype-17.02-1-knl/opt/gcc/4.9.1/snos/lib -L/blues/gpfs/home/software/bebop/craype-17.02-1-knl/opt/gcc/4.9.1/snos/lib -Wl,-rpath,/opt/intel/mpi-rt/2017.0.0/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/mpi-rt/2017.0.0/intel64/lib -lscalapack -lflapack -lfblas -lparmetis -lmetis -lm -lX11 -lstdc++ -ldl -lmpifort -lmpi -lmpigi -lrt -lpthread -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lstdc++ -ldl
mesh size: 0.0001
initsolve: 9 iterations
solve 1: 9 iterations
solve 2: 9 iterations
solve 3: 9 iterations
solve 4: 9 iterations
solve 5: 9 iterations
solve 6: 9 iterations
solve 7: 9 iterations
solve 8: 9 iterations
solve 9: 9 iterations
solve 10: 9 iterations
solve 20: 9 iterations
solve 30: 9 iterations
solve 40: 9 iterations
solve 50: 9 iterations
solve 60: 9 iterations
solve 70: 9 iterations
solve 80: 9 iterations
solve 90: 9 iterations
solve 100: 9 iterations
solve 200: 9 iterations
solve 300: 9 iterations
solve 400: 9 iterations
solve 500: 9 iterations
solve 600: 9 iterations
solve 700: 9 iterations
solve 800: 9 iterations
solve 900: 9 iterations
solve 1000: 9 iterations
Time in solve(): 157.375 s
Time in KSPSolve(): 157.136 s (99.8483%)
Number of KSP iterations (total): 9000
Number of solve iterations (total): 1000 (ratio: 9.00)
./wstest on a intel-bdw-opt named bdwd-0016 with 216 processors, by jczhang Tue Jun 12 15:33:46 2018
Time (sec): 1.636e+02 1.00001 1.636e+02
Objects: 3.650e+04 1.00003 3.650e+04
Flop: 5.496e+10 1.22075 5.177e+10 1.118e+13
Flop/sec: 3.359e+08 1.22075 3.164e+08 6.835e+10
MPI Messages: 2.993e+06 6.33817 1.352e+06 2.921e+08
MPI Message Lengths: 4.193e+09 2.87396 2.166e+03 6.326e+11
MPI Reductions: 4.771e+04 1.00006
0: Main Stage: 1.3931e-01 0.1% 0.0000e+00 0.0% 2.160e+03 0.0% 1.802e+03 0.0% 1.700e+01 0.0%
1: First Solve: 6.0653e+00 3.7% 2.1068e+10 0.2% 7.694e+05 0.3% 3.264e+03 0.4% 6.818e+02 1.4%
2: Remaining Solves: 1.5739e+02 96.2% 1.1160e+13 99.8% 2.913e+08 99.7% 2.163e+03 99.6% 4.700e+04 98.5%
Phase summary info:
VecSet 2 1.0 5.7220e-05 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
BuildTwoSided 4 1.0 1.1373e-02 9.3 0.00e+00 0.0 4.6e+03 4.0e+00 0.0e+00 0 0 0 0 0 0 0 1 0 0 0
BuildTwoSidedF 38 1.0 1.9472e-01 3.9 0.00e+00 0.0 2.0e+04 2.3e+04 0.0e+00 0 0 0 0 0 2 0 3 18 0 0
KSPSetUp 11 1.0 1.0682e-02 7.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.4e+01 0 0 0 0 0 0 0 0 0 2 0
KSPSolve 1 1.0 6.0648e+00 1.0 1.06e+08 1.3 7.7e+05 3.3e+03 6.8e+02 4 0 0 0 1 100100100100100 3474
VecTDot 102 1.0 2.2696e-02 2.4 2.48e+06 1.0 0.0e+00 0.0e+00 1.0e+02 0 0 0 0 0 0 3 0 0 15 23428
VecNorm 11 1.0 3.3295e-03 1.4 5.94e+05 1.0 0.0e+00 0.0e+00 1.1e+01 0 0 0 0 0 0 1 0 0 2 38535
VecScale 36 1.0 3.5572e-04 3.8 1.36e+05 2.3 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 61994
VecCopy 9 1.0 3.7885e-04 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 184 1.0 2.0907e-03 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAXPY 98 1.0 3.5741e-03 1.2 2.41e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 2 0 0 0 144490
VecAYPX 81 1.0 3.3052e-03 1.6 1.43e+06 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 1 0 0 0 92586
VecAssemblyBegin 12 1.0 1.3266e-03 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAssemblyEnd 12 1.0 2.3293e-04 2.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecPointwiseMult 44 1.0 1.3185e-03 1.3 3.95e+05 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 63923
VecScatterBegin 210 1.0 1.0943e-02 2.5 0.00e+00 0.0 4.1e+05 2.2e+03 0.0e+00 0 0 0 0 0 0 0 54 35 0 0
VecScatterEnd 210 1.0 6.8774e-02 2.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
VecSetRandom 4 1.0 1.3020e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatMult 86 1.0 6.3114e-02 1.4 2.88e+07 1.3 1.8e+05 2.4e+03 0.0e+00 0 0 0 0 0 1 27 24 18 0 91663
MatMultAdd 36 1.0 4.4785e-02 4.5 4.10e+06 1.3 5.8e+04 1.7e+03 0.0e+00 0 0 0 0 0 0 4 8 4 0 18261
MatMultTranspose 36 1.0 2.4255e-02 2.4 4.10e+06 1.3 5.8e+04 1.7e+03 0.0e+00 0 0 0 0 0 0 4 8 4 0 33718
MatSolve 9 0.0 1.1253e-04 0.0 8.89e+04 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 790
MatSOR 72 1.0 1.2917e-01 1.3 2.79e+07 1.2 8.2e+04 2.1e+03 1.8e+01 0 0 0 0 0 2 27 11 7 3 43962
MatLUFactorSym 1 1.0 1.4400e-0412.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatLUFactorNum 1 1.0 2.4796e-0461.2 2.28e+05 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 919
MatConvert 8 1.0 5.9213e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01 0 0 0 0 0 10 0 0 0 2 0
MatScale 12 1.0 5.9452e-03 1.6 1.82e+06 1.3 9.1e+03 2.1e+03 0.0e+00 0 0 0 0 0 0 2 1 1 0 61111
MatResidual 36 1.0 3.5977e-02 2.1 1.23e+07 1.3 8.2e+04 2.1e+03 0.0e+00 0 0 0 0 0 0 12 11 7 0 68156
MatAssemblyBegin 91 1.0 2.0844e-01 2.8 0.00e+00 0.0 2.0e+04 2.3e+04 0.0e+00 0 0 0 0 0 2 0 3 18 0 0
MatAssemblyEnd 91 1.0 2.1315e-01 2.0 0.00e+00 0.0 1.2e+05 3.0e+02 2.0e+02 0 0 0 0 0 2 0 15 1 29 0
MatGetRow 125604 1.1 2.0258e+00 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 32 0 0 0 0 0
MatGetRowIJ 1 0.0 2.6941e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatCreateSubMat 8 1.0 2.6344e-01 1.0 0.00e+00 0.0 4.8e+04 1.2e+04 1.3e+02 0 0 0 0 0 4 0 6 23 19 0
MatGetOrdering 1 0.0 7.4863e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatPartitioning 4 1.0 7.2333e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 8.8e+00 0 0 0 0 0 12 0 0 0 1 0
MatCoarsen 4 1.0 1.9829e-02 2.0 0.00e+00 0.0 9.8e+04 7.1e+02 2.7e+01 0 0 0 0 0 0 0 13 3 4 0
MatZeroEntries 4 1.0 2.1191e-03 3.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatAXPY 4 1.0 1.2023e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 20 0 0 0 0 0
MatMatMult 4 1.0 1.2128e-01 1.0 1.37e+06 1.3 5.7e+04 1.1e+03 5.0e+01 0 0 0 0 0 2 1 7 2 7 2206
MatMatMultSym 4 1.0 1.0835e-01 1.0 0.00e+00 0.0 4.8e+04 8.7e+02 4.8e+01 0 0 0 0 0 2 0 6 2 7 0
MatMatMultNum 4 1.0 9.3360e-03 1.0 1.37e+06 1.3 9.1e+03 2.1e+03 0.0e+00 0 0 0 0 0 0 1 1 1 0 28654
MatPtAP 4 1.0 3.1024e-01 1.0 3.11e+07 1.5 1.1e+05 7.7e+03 6.2e+01 0 0 0 0 0 5 27 15 35 9 18602
MatPtAPSymbolic 4 1.0 1.7289e-01 1.0 0.00e+00 0.0 5.8e+04 7.4e+03 2.8e+01 0 0 0 0 0 3 0 7 17 4 0
MatPtAPNumeric 4 1.0 1.3619e-01 1.0 3.11e+07 1.5 5.7e+04 8.1e+03 3.2e+01 0 0 0 0 0 2 27 7 18 5 42374
MatGetLocalMat 12 1.0 4.7843e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetBrAoCol 12 1.0 1.0638e-02 1.6 0.00e+00 0.0 6.4e+04 5.7e+03 0.0e+00 0 0 0 0 0 0 0 8 14 0 0
SFSetGraph 4 1.0 3.6716e-0538.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
SFSetUp 4 1.0 1.1905e-02 6.4 0.00e+00 0.0 1.4e+04 7.0e+02 0.0e+00 0 0 0 0 0 0 0 2 0 0 0
SFBcastBegin 35 1.0 1.3816e-03 2.8 0.00e+00 0.0 8.4e+04 7.1e+02 0.0e+00 0 0 0 0 0 0 0 11 2 0 0
SFBcastEnd 35 1.0 2.0089e-03 2.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
PCGAMGGraph_AGG 4 1.0 2.4202e+00 1.0 1.37e+06 1.3 2.7e+04 1.1e+03 4.8e+01 1 0 0 0 0 40 1 4 1 7 113
PCGAMGCoarse_AGG 4 1.0 2.1739e-02 1.1 0.00e+00 0.0 9.8e+04 7.1e+02 2.7e+01 0 0 0 0 0 0 0 13 3 4 0
PCGAMGProl_AGG 4 1.0 3.5299e-02 1.0 0.00e+00 0.0 2.9e+04 1.5e+03 6.4e+01 0 0 0 0 0 1 0 4 2 9 0
PCGAMGPOpt_AGG 4 1.0 1.3753e+00 1.0 1.91e+07 1.2 1.5e+05 1.7e+03 1.7e+02 1 0 0 0 0 23 18 19 10 24 2804
GAMG: createProl 4 1.0 3.8539e+00 1.0 2.05e+07 1.2 3.0e+05 1.3e+03 3.0e+02 2 0 0 0 1 64 20 39 16 45 1071
Graph 8 1.0 2.4189e+00 1.0 1.37e+06 1.3 2.7e+04 1.1e+03 4.8e+01 1 0 0 0 0 40 1 4 1 7 113
MIS/Agg 4 1.0 1.9926e-02 2.0 0.00e+00 0.0 9.8e+04 7.1e+02 2.7e+01 0 0 0 0 0 0 0 13 3 4 0
SA: col data 4 1.0 1.4641e-02 1.0 0.00e+00 0.0 1.8e+04 2.1e+03 1.6e+01 0 0 0 0 0 0 0 2 2 2 0
SA: frmProl0 4 1.0 1.9329e-02 1.0 0.00e+00 0.0 1.1e+04 4.1e+02 3.2e+01 0 0 0 0 0 0 0 1 0 5 0
SA: smooth 4 1.0 1.3270e+00 1.0 1.82e+06 1.3 5.7e+04 1.1e+03 5.8e+01 1 0 0 0 0 22 2 7 2 9 270
GAMG: partLevel 4 1.0 1.9283e+00 1.0 3.11e+07 1.5 1.7e+05 8.5e+03 2.9e+02 1 0 0 0 1 32 27 22 59 43 2993
repartition 4 1.0 1.3092e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 4.9e+01 1 0 0 0 0 22 0 0 0 7 0
Invert-Sort 4 1.0 3.9294e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.6e+01 0 0 0 0 0 1 0 0 0 2 0
Move A 4 1.0 1.5547e-01 1.1 0.00e+00 0.0 3.5e+04 1.7e+04 6.8e+01 0 0 0 0 0 2 0 5 23 10 0
Move P 4 1.0 1.1733e-01 1.0 0.00e+00 0.0 1.3e+04 4.3e+02 6.8e+01 0 0 0 0 0 2 0 2 0 10 0
PCSetUp 2 1.0 5.7918e+00 1.0 5.15e+07 1.4 4.8e+05 3.9e+03 6.2e+02 4 0 0 0 1 95 47 62 75 91 1709
PCSetUpOnBlocks 9 1.0 5.4765e-04 5.4 2.28e+05 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 416
PCApply 9 1.0 1.9558e-01 1.1 4.84e+07 1.3 2.8e+05 2.0e+03 1.8e+01 0 0 0 0 0 3 46 36 22 3 49938
KSPSolve 1000 1.0 1.5715e+02 1.0 5.49e+10 1.2 2.9e+08 2.2e+03 4.7e+04 96100100100 99 100100100100100 71017
VecTDot 18000 1.0 9.7654e+00 1.4 9.72e+08 1.0 0.0e+00 0.0e+00 1.8e+04 5 2 0 0 38 5 2 0 0 38 21499
VecNorm 11000 1.0 3.2415e+00 1.1 5.94e+08 1.0 0.0e+00 0.0e+00 1.1e+04 2 1 0 0 23 2 1 0 0 23 39582
VecScale 36000 1.0 1.9780e-01 1.9 1.36e+08 2.3 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 111486
VecCopy 1000 1.0 3.3195e-01 5.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 135000 1.0 1.5111e+00 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 1 0 0 0 0 0
VecAXPY 18000 1.0 1.2813e+00 1.3 9.72e+08 1.0 0.0e+00 0.0e+00 0.0e+00 1 2 0 0 0 1 2 0 0 0 163865
VecAYPX 45000 1.0 1.5992e+00 1.3 7.82e+08 1.0 0.0e+00 0.0e+00 0.0e+00 1 2 0 0 0 1 2 0 0 0 105117
VecScatterBegin 154000 1.0 7.6855e+00 2.7 0.00e+00 0.0 2.9e+08 2.2e+03 0.0e+00 3 0100100 0 3 0100100 0 0
VecScatterEnd 154000 1.0 4.1504e+01 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 19 0 0 0 0 20 0 0 0 0 0
MatMult 46000 1.0 3.4541e+01 1.4 1.55e+10 1.2 9.3e+07 2.7e+03 0.0e+00 17 28 32 40 0 18 28 32 40 0 90831
MatMultAdd 36000 1.0 2.6609e+01 2.3 4.10e+09 1.3 5.8e+07 1.7e+03 0.0e+00 12 7 20 16 0 12 7 20 16 0 30735
MatMultTranspose 36000 1.0 2.0506e+01 1.8 4.10e+09 1.3 5.8e+07 1.7e+03 0.0e+00 10 7 20 16 0 10 7 20 16 0 39881
MatSolve 9000 0.0 1.1517e-01 0.0 8.89e+07 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 772
MatSOR 72000 1.0 7.8436e+01 1.2 2.79e+10 1.2 8.2e+07 2.1e+03 1.8e+04 45 51 28 28 38 47 51 28 28 38 72300
MatResidual 36000 1.0 2.9426e+01 1.5 1.23e+10 1.3 8.2e+07 2.1e+03 0.0e+00 14 22 28 28 0 15 22 28 28 0 83328
PCSetUpOnBlocks 9000 1.0 1.2507e-0111.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
PCApply 9000 1.0 1.3756e+02 1.0 4.83e+10 1.3 2.8e+08 2.0e+03 1.8e+04 84 87 96 87 38 87 87 96 88 38 70939
Krylov Solver 1 7 8816 0.
Vector 4 38 2203656 0.
Matrix 0 36 21544876 0.
Index Set 2 14 14769980 0.
Vec Scatter 1 10 228640 0.
Preconditioner 1 7 7448 0.
Viewer 1 0 0 0.
Krylov Solver 10 4 6400 0.
Vector 172 138 6448200 0.
Matrix 141 105 37914116 0.
Matrix Partitioning 4 4 2624 0.
Matrix Coarsen 4 4 2544 0.
Index Set 102 90 14955164 0.
Star Forest Graph 4 4 3456 0.
Vec Scatter 33 24 77312 0.
Preconditioner 10 4 3424 0.
PetscRandom 8 8 5168 0.
Vector 36000 36000 2602584000 0.
Average time for MPI_Barrier(): 9.20296e-06
Average time for zero size MPI_Send(): 2.39677e-05
-iterations 1000
-ksp_rtol 1E-6
-ksp_type cg
-log_view
-mesh_size 1E-4
-nodes_per_proc 30
-pc_gamg_type agg
-pc_type gamg
