[petsc-dev] [petsc-users] Poor weak scaling when solving successive linearsystems
    Junchao Zhang
    jczhang at mcs.anl.gov
    Tue Jun 12 11:32:28 CDT 2018
Mark,
  I tried "-pc_gamg_type agg ..." options you mentioned, and also -ksp_type
cg + PETSc's default PC bjacobi. In the latter case, to reduce execution
time I called KSPSolve 100 times instead of 1000, and also used -ksp_max_it
100. In the 36x48=1728 ranks case, I also did a test with -log_sync. From
there you can see a lot of time is spent on VecNormBarrier, which implies
load imbalance. Note VecScatterBarrie time is misleading, since it barriers
ALL ranks, but in reality VecScatter sort of syncs in a small neighborhood.
  Barry suggested trying periodic boundary condition so that the nonzeros
are perfectly balanced across processes. I will try that to see what
happens.
--Junchao Zhang
On Mon, Jun 11, 2018 at 8:09 AM, Mark Adams <mfadams at lbl.gov> wrote:
> On Mon, Jun 11, 2018 at 12:46 AM, Junchao Zhang <jczhang at mcs.anl.gov>
> wrote:
>> I used an LCRC machine named Bebop. I tested on its Intel Broadwell
>> nodes. Each nodes has 2 CPUs and 36 cores in total. I collected data using
>> 36 cores in a node or 18 cores in a node.  As you can see, 18 cores/node
>> gave much better performance, which is reasonable as routines like MatSOR,
>> MatMult, MatMultAdd are all bandwidth bound.
>> The code uses a DMDA 3D grid, 7-point stencil, and defines
>> nodes(vertices) at the surface or second to the surface as boundary nodes.
>> Boundary nodes only have a diagonal one in their row in the matrix.
>> Interior nodes have 7 nonzeros in their row. Boundary processors in the
>> processor grid has less nonzero. This is one source of load-imbalance. Will
>> load-imbalance get severer at coarser grids of an MG level?
> Yes.
> You can use a simple Jacobi solver to see the basic performance of your
> operator and machine. Do you see as much time spent in Vec Scatters?
> VecAXPY? etc.
>> I attach a trace view figure that show activity of each ranks along the
>> time axis in one KSPSove. White color means MPI wait. You can see white
>> takes a large space.
>> I don't have a good explanation why at large scale (1728 cores),
>> processors wait longer time, as the communication pattern is still 7-point
>> stencil in a cubic processor gird.
>> --Junchao Zhang
>> On Sat, Jun 9, 2018 at 11:32 AM, Smith, Barry F. <bsmith at mcs.anl.gov>
>> wrote:
>>>   Junchao,
>>>       Thanks, the load balance of matrix entries is remarkably similar
>>> for the two runs so it can't be a matter of worse work load imbalance for
>>> SOR for the larger case explaining why the SOR takes more time.
>>>       Here is my guess (and I know no way to confirm it). In the smaller
>>> case the overlap of different processes on the same node running SOR at the
>>> same time is lower than the larger case hence the larger case is slower
>>> because there are more SOR processes fighting over the same memory
>>> bandwidth at the same time than in the smaller case.   Ahh, here is
>>> something you can try, lets undersubscribe the memory bandwidth needs, run
>>> on say 16 processes per node with 8 nodes and 16 processes per node with 64
>>> nodes and send the two -log_view output files. I assume this is an LCRC
>>> machine and NOT a KNL system?
>>>    Thanks
>>>    Barry
>>> > On Jun 9, 2018, at 8:29 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>> > -pc_gamg_type classical
>>> > FYI, we only support smoothed aggregation "agg" (the default). (This
>>> thread started by saying you were using GAMG.)
>>> > It is not clear how much this will make a difference for you, but you
>>> don't want to use classical because we do not support it. It is meant as a
>>> reference implementation for developers.
>>> > First, how did you get the idea to use classical? If the documentation
>>> lead you to believe this was a good thing to do then we need to fix that!
>>> > Anyway, here is a generic input for GAMG:
>>> > -pc_type gamg
>>> > -pc_gamg_type agg
>>> > -pc_gamg_agg_nsmooths 1
>>> > -pc_gamg_coarse_eq_limit 1000
>>> > -pc_gamg_reuse_interpolation true
>>> > -pc_gamg_square_graph 1
>>> > -pc_gamg_threshold 0.05
>>> > -pc_gamg_threshold_scale .0
>>> > On Thu, Jun 7, 2018 at 6:52 PM, Junchao Zhang <jczhang at mcs.anl.gov>
>>> wrote:
>>> > OK, I have thought that space was a typo. btw, this option does not
>>> show up in -h.
>>> > I changed number of ranks to use all cores on each node to avoid
>>> misleading ratio in -log_view. Since one node has 36 cores, I ran with
>>> 6^3=216 ranks, and 12^3=1728 ranks. I also found call counts of MatSOR etc
>>> in the two tests were different. So they are not strict weak scaling tests.
>>> I tried to add -ksp_max_it 6 -pc_mg_levels 6, but still could not make the
>>> two have the same MatSOR count. Anyway, I attached the load balance output.
>>> > I find PCApply_MG calls PCMGMCycle_Private, which is recursive and
>>> indirectly calls MatSOR_MPIAIJ. I believe the following code in
>>> MatSOR_MPIAIJ practically syncs {MatSOR, MatMultAdd}_SeqAIJ  between
>>> processors through VecScatter at each MG level. If SOR and MatMultAdd are
>>> imbalanced, the cost is accumulated along MG levels and shows up as large
>>> VecScatter cost.
>>> > 1460:     while
>>> >  (its--) {
>>> > 1461:       VecScatterBegin(mat->Mvctx,xx
>>> ,mat->lvec,INSERT_VALUES,SCATTER_FORWARD
>>> > 1462:       VecScatterEnd(mat->Mvctx,xx,m
>>> > 1464:       /* update rhs: bb1 = bb - B*x */
>>> > 1465:       VecScale
>>> > (mat->lvec,-1.0);
>>> > 1466:       (*mat->B->ops->multadd)(mat->
>>> > B,mat->lvec,bb,bb1);
>>> > 1468:       /* local sweep */
>>> > 1469:       (*mat->A->ops->sor)(mat->A,bb1,omega,SOR_SYMMETRIC_SWEEP,
>>> > fshift,lits,1,xx);
>>> > 1470:     }
>>> > --Junchao Zhang
>>> > On Thu, Jun 7, 2018 at 3:11 PM, Smith, Barry F. <bsmith at mcs.anl.gov>
>>> wrote:
>>> > > On Jun 7, 2018, at 12:27 PM, Zhang, Junchao <jczhang at mcs.anl.gov>
>>> wrote:
>>> > > Searched but could not find this option, -mat_view::load_balance
>>> >    There is a space between the view and the :   load_balance is a
>>> particular viewer format that causes the printing of load balance
>>> information about number of nonzeros in the matrix.
>>> >    Barry
>>> > > --Junchao Zhang
>>> > > On Thu, Jun 7, 2018 at 10:46 AM, Smith, Barry F. <bsmith at mcs.anl.gov>
>>> wrote:
>>> > >  So the only surprise in the results is the SOR. It is
>>> embarrassingly parallel and normally one would not see a jump.
>>> > >  The load balance for SOR time 1.5 is better at 1000 processes than
>>> for 125 processes of 2.1  not worse so this number doesn't easily explain
>>> it.
>>> > >  Could you run the 125 and 1000 with -mat_view ::load_balance and
>>> see what you get out?
>>> > >    Thanks
>>> > >      Barry
>>> > >  Notice that the MatSOR time jumps a lot about 5 secs when the
>>> -log_sync is on. My only guess is that the MatSOR is sharing memory
>>> bandwidth (or some other resource? cores?) with the VecScatter and for some
>>> reason this is worse for 1000 cores but I don't know why.
>>> > > > On Jun 6, 2018, at 9:13 PM, Junchao Zhang <jczhang at mcs.anl.gov>
>>> wrote:
>>> > > > Hi, PETSc developers,
>>> > > >  I tested Michael Becker's code. The code calls the same KSPSolve
>>> 1000 times in the second stage and needs cubic number of processors to run.
>>> I ran with 125 ranks and 1000 ranks, with or without -log_sync option. I
>>> attach the log view output files and a scaling loss excel file.
>>> > > >  I profiled the code with 125 processors. It looks {MatSOR,
>>> MatMult, MatMultAdd, MatMultTranspose, MatMultTransposeAdd}_SeqAIJ in aij.c
>>> took ~50% of the time,  The other half time was spent on waiting in MPI.
>>> MatSOR_SeqAIJ took 30%, mostly in PetscSparseDenseMinusDot().
>>> > > >  I tested it on a 36 cores/node machine. I found 32 ranks/node
>>> gave better performance (about 10%) than 36 ranks/node in the 125 ranks
>>> testing.  I guess it is because processors in the former had more balanced
>>> memory bandwidth. I collected PAPI_DP_OPS (double precision operations) and
>>> PAPI_TOT_CYC (total cycles) of the 125 ranks case (see the attached files).
>>> It looks ranks at the two ends have less DP_OPS and TOT_CYC.
>>> > > >  Does anyone familiar with the algorithm have quick explanations?
>>> > > > --Junchao Zhang
>>> > > > On Mon, Jun 4, 2018 at 11:59 AM, Michael Becker <
>>> Michael.Becker at physik.uni-giessen.de> wrote:
>>> > > > Hello again,
>>> > > > this took me longer than I anticipated, but here we go.
>>> > > > I did reruns of the cases where only half the processes per node
>>> were used (without -log_sync):
>>> > > >                     125 procs,1st           125 procs,2nd
>>> 1000 procs,1st          1000 procs,2nd
>>> > > >                   Max        Ratio        Max        Ratio
>>> Max        Ratio        Max        Ratio
>>> > > > KSPSolve           1.203E+02    1.0        1.210E+02    1.0
>>> 1.399E+02    1.1        1.365E+02    1.0
>>> > > > VecTDot            6.376E+00    3.7        6.551E+00    4.0
>>> 7.885E+00    2.9        7.175E+00    3.4
>>> > > > VecNorm            4.579E+00    7.1        5.803E+00   10.2
>>> 8.534E+00    6.9        6.026E+00    4.9
>>> > > > VecScale           1.070E-01    2.1        1.129E-01    2.2
>>> 1.301E-01    2.5        1.270E-01    2.4
>>> > > > VecCopy            1.123E-01    1.3        1.149E-01    1.3
>>> 1.301E-01    1.6        1.359E-01    1.6
>>> > > > VecSet             7.063E-01    1.7        6.968E-01    1.7
>>> 7.432E-01    1.8        7.425E-01    1.8
>>> > > > VecAXPY            1.166E+00    1.4        1.167E+00    1.4
>>> 1.221E+00    1.5        1.279E+00    1.6
>>> > > > VecAYPX            1.317E+00    1.6        1.290E+00    1.6
>>> 1.536E+00    1.9        1.499E+00    2.0
>>> > > > VecScatterBegin    6.142E+00    3.2        5.974E+00    2.8
>>> 6.448E+00    3.0        6.472E+00    2.9
>>> > > > VecScatterEnd      3.606E+01    4.2        3.551E+01    4.0
>>> 5.244E+01    2.7        4.995E+01    2.7
>>> > > > MatMult            3.561E+01    1.6        3.403E+01    1.5
>>> 3.435E+01    1.4        3.332E+01    1.4
>>> > > > MatMultAdd         1.124E+01    2.0        1.130E+01    2.1
>>> 2.093E+01    2.9        1.995E+01    2.7
>>> > > > MatMultTranspose   1.372E+01    2.5        1.388E+01    2.6
>>> 1.477E+01    2.2        1.381E+01    2.1
>>> > > > MatSolve           1.949E-02    0.0        1.653E-02    0.0
>>> 4.789E-02    0.0        4.466E-02    0.0
>>> > > > MatSOR             6.610E+01    1.3        6.673E+01    1.3
>>> 7.111E+01    1.3        7.105E+01    1.3
>>> > > > MatResidual        2.647E+01    1.7        2.667E+01    1.7
>>> 2.446E+01    1.4        2.467E+01    1.5
>>> > > > PCSetUpOnBlocks    5.266E-03    1.4        5.295E-03    1.4
>>> 5.427E-03    1.5        5.289E-03    1.4
>>> > > > PCApply            1.031E+02    1.0        1.035E+02    1.0
>>> 1.180E+02    1.0        1.164E+02    1.0
>>> > > > I also slimmed down my code and basically wrote a simple weak
>>> scaling test (source files attached) so you can profile it yourself. I
>>> appreciate the offer Junchao, thank you.
>>> > > > You can adjust the system size per processor at runtime via
>>> "-nodes_per_proc 30" and the number of repeated calls to the function
>>> containing KSPsolve() via "-iterations 1000". The physical problem is
>>> simply calculating the electric potential from a homogeneous charge
>>> distribution, done multiple times to accumulate time in KSPsolve().
>>> > > > A job would be started using something like
>>> > > > mpirun -n 125 ~/petsc_ws/ws_test -nodes_per_proc 30 -mesh_size
>>> 1E-4 -iterations 1000 \\
>>> > > > -ksp_rtol 1E-6 \
>>> > > > -log_view -log_sync\
>>> > > > -pc_type gamg -pc_gamg_type classical\
>>> > > > -ksp_type cg \
>>> > > > -ksp_norm_type unpreconditioned \
>>> > > > -mg_levels_ksp_type richardson \
>>> > > > -mg_levels_ksp_norm_type none \
>>> > > > -mg_levels_pc_type sor \
>>> > > > -mg_levels_ksp_max_it 1 \
>>> > > > -mg_levels_pc_sor_its 1 \
>>> > > > -mg_levels_esteig_ksp_type cg \
>>> > > > -mg_levels_esteig_ksp_max_it 10 \
>>> > > > -gamg_est_ksp_type cg
>>> > > > , ideally started on a cube number of processes for a cubical
>>> process grid.
>>> > > > Using 125 processes and 10.000 iterations I get the output in
>>> "log_view_125_new.txt", which shows the same imbalance for me.
>>> > > > Michael
>>> > > > Am 02.06.2018 um 13:40 schrieb Mark Adams:
>>> > > >> On Fri, Jun 1, 2018 at 11:20 PM, Junchao Zhang <
>>> jczhang at mcs.anl.gov> wrote:
>>> > > >> Hi,Michael,
>>> > > >>  You can add -log_sync besides -log_view, which adds barriers to
>>> certain events but measures barrier time separately from the events. I find
>>> this option makes it easier to interpret log_view output.
>>> > > >> That is great (good to know).
>>> > > >> This should give us a better idea if your large VecScatter costs
>>> are from slow communication or if it catching some sort of load imbalance.
>>> > > >> --Junchao Zhang
>>> > > >> On Wed, May 30, 2018 at 3:27 AM, Michael Becker <
>>> > > >> Barry: On its way. Could take a couple days again.
>>> > > >> Junchao: I unfortunately don't have access to a cluster with a
>>> faster network. This one has a mixed 4X QDR-FDR InfiniBand 2:1 blocking
>>> fat-tree network, which I realize causes parallel slowdown if the nodes are
>>> not connected to the same switch. Each node has 24 processors (2x12/socket)
>>> and four NUMA domains (two for each socket).
>>> > > >> The ranks are usually not distributed perfectly even, i.e. for
>>> 125 processes, of the six required nodes, five would use 21 cores and one
>>> 20.
>>> > > >> Would using another CPU type make a difference
>>> communication-wise? I could switch to faster ones (on the same network),
>>> but I always assumed this would only improve performance of the stuff that
>>> is unrelated to communication.
>>> > > >> Michael
>>> > > >>> The log files have something like "Average time for zero size
>>> MPI_Send(): 1.84231e-05". It looks you ran on a cluster with a very slow
>>> network. A typical machine should give less than 1/10 of the latency you
>>> have. An easy way to try is just running the code on a machine with a
>>> faster network and see what happens.
>>> > > >>> Also, how many cores & numa domains does a compute node have? I
>>> could not figure out how you distributed the 125 MPI ranks evenly.
>>> > > >>> --Junchao Zhang
>>> > > >>> On Tue, May 29, 2018 at 6:18 AM, Michael Becker <
>>> > > >>> Hello again,
>>> > > >>> here are the updated log_view files for 125 and 1000 processors.
>>> I ran both problems twice, the first time with all processors per node
>>> allocated ("-1.txt"), the second with only half on twice the number of
>>> nodes ("-2.txt").
>>> > > >>>>> On May 24, 2018, at 12:24 AM, Michael Becker <
>>> > > >>>>> wrote:
>>> > > >>>>> I noticed that for every individual KSP iteration, six vector
>>> objects are created and destroyed (with CG, more with e.g. GMRES).
>>> > > >>>>   Hmm, it is certainly not intended at vectors be created and
>>> destroyed within each KSPSolve() could you please point us to the code that
>>> makes you think they are being created and destroyed?   We create all the
>>> work vectors at KSPSetUp() and destroy them in KSPReset() not during the
>>> solve. Not that this would be a measurable distance.
>>> > > >>> I mean this, right in the log_view output:
>>> > > >>>> Memory usage is given in bytes:
>>> > > >>>> Object Type Creations Destructions Memory Descendants' Mem.
>>> > > >>>> Reports information only for process 0.
>>> > > >>>> --- Event Stage 0: Main Stage
>>> > > >>>> --- Event Stage 1: First Solve
>>> > > >>>> --- Event Stage 2: Remaining Solves
>>> > > >>>> Vector 23904 23904 1295501184 0.
>>> > > >>> I logged the exact number of KSP iterations over the 999
>>> timesteps and its exactly 23904/6 = 3984.
>>> > > >>> Michael
>>> > > >>> Am 24.05.2018 um 19:50 schrieb Smith, Barry F.:
>>> > > >>>>  Please send the log file for 1000 with cg as the solver.
>>> > > >>>>   You should make a bar chart of each event for the two cases
>>> to see which ones are taking more time and which are taking less (we cannot
>>> tell with the two logs you sent us since they are for different solvers.)
>>> > > >>>>> This seems kind of wasteful, is this supposed to be like this?
>>> Is this even the reason for my problems? Apart from that, everything seems
>>> quite normal to me (but I'm not the expert here).
>>> > > >>>>> Thanks in advance.
>>> > > >>>>> Michael
>>> > > >>>>> <log_view_125procs.txt><log_vi
>>> > > >>>>> ew_1000procs.txt>
>>> > > > <o-wstest-125.txt><Scaling-loss.png><o-wstest-1000.txt><o-ws
>>> ><PAPI_TOT_CYC.png><PAPI_DP_OPS.png>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180612/cf768443/attachment-0001.html>
using 216 of 216 processes
30^3 unknowns per processor
total system size: 180^3
mesh size: 0.0001
initsolve: 10 iterations
solve 1: 10 iterations
solve 2: 10 iterations
solve 3: 10 iterations
solve 4: 10 iterations
solve 5: 10 iterations
solve 6: 10 iterations
solve 7: 10 iterations
solve 8: 10 iterations
solve 9: 10 iterations
solve 10: 10 iterations
solve 20: 10 iterations
solve 30: 10 iterations
solve 40: 10 iterations
solve 50: 10 iterations
solve 60: 10 iterations
solve 70: 10 iterations
solve 80: 10 iterations
solve 90: 10 iterations
solve 100: 10 iterations
solve 200: 10 iterations
solve 300: 10 iterations
solve 400: 10 iterations
solve 500: 10 iterations
solve 600: 10 iterations
solve 700: 10 iterations
solve 800: 10 iterations
solve 900: 10 iterations
solve 1000: 10 iterations
Time in solve():      109.012 s
Time in KSPSolve():   108.771 s (99.7789%)
Number of   KSP iterations (total): 10000
Number of solve iterations (total): 1000 (ratio: 10.00)
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./wstest on a intel-bdw-opt named bdwd-0003 with 216 processors, by jczhang Sun Jun 10 23:54:41 2018
Using Petsc Development GIT revision: v3.9.2-570-g68f20b90  GIT Date: 2018-06-04 15:39:16 +0200
                         Max       Max/Min        Avg      Total
Time (sec):           1.126e+02      1.00002   1.126e+02
Objects:              4.045e+04      1.00002   4.045e+04
Flop:                 3.198e+10      1.10193   3.098e+10  6.691e+12
Flop/sec:            2.839e+08      1.10195   2.751e+08  5.941e+10
MPI Messages:         2.571e+06      4.18338   1.529e+06  3.302e+08
MPI Message Lengths:  2.182e+09      2.17075   1.164e+03  3.844e+11
MPI Reductions:       5.260e+04      1.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flop
                            and VecAXPY() for complex vectors of length N --> 8N flop
Summary of Stages:   ----- Time ------  ----- Flop -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 1.7742e-01   0.2%  0.0000e+00   0.0%  2.160e+03   0.0%  1.802e+03        0.0%  1.700e+01   0.0%
 1:     First Solve: 3.4111e+00   3.0%  1.0911e+10   0.2%  7.694e+05   0.2%  1.496e+03        0.3%  5.760e+02   1.1%
 2: Remaining Solves: 1.0903e+02  96.8%  6.6798e+12  99.8%  3.294e+08  99.8%  1.163e+03       99.7%  5.200e+04  98.9%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flop: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flop in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flop                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
VecSet                 2 1.0 7.1764e-05 2.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided          4 1.0 2.3761e-03 2.9 0.00e+00 0.0 5.1e+03 4.0e+00 0.0e+00  0  0  0  0  0   0  0  1  0  0     0
BuildTwoSidedF        40 1.0 7.3972e-02 2.2 0.00e+00 0.0 2.2e+04 6.4e+03 0.0e+00  0  0  0  0  0   2  0  3 12  0     0
KSPSetUp              11 1.0 1.9271e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 1.4e+01  0  0  0  0  0   0  0  0  0  2     0
KSPSolve               1 1.0 3.4107e+00 1.0 5.31e+07 1.2 7.7e+05 1.5e+03 5.8e+02  3  0  0  0  1 100100100100100  3199
VecTDot              104 1.0 1.0672e-02 1.7 2.32e+06 1.0 0.0e+00 0.0e+00 1.0e+02  0  0  0  0  0   0  5  0  0 18 46901
VecNorm               12 1.0 1.6296e-03 1.8 6.48e+05 1.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  0   0  1  0  0  2 85891
VecScale              40 1.0 3.9005e-04 4.7 9.01e+04 2.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 40510
VecCopy                9 1.0 3.4094e-04 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               197 1.0 2.0678e-03 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY              100 1.0 3.4885e-03 1.2 2.26e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  4  0  0  0 139836
VecAYPX               86 1.0 2.7862e-03 1.3 1.34e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  3  0  0  0 103723
VecAssemblyBegin      14 1.0 2.4695e-03 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd        14 1.0 2.8300e-04 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult      44 1.0 1.2159e-03 1.3 3.26e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 57569
VecScatterBegin      230 1.0 7.8228e-03 2.3 0.00e+00 0.0 4.6e+05 1.4e+03 0.0e+00  0  0  0  0  0   0  0 59 55  0     0
VecScatterEnd        230 1.0 2.2854e-02 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSetRandom           4 1.0 1.1837e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMult               91 1.0 3.2917e-02 1.2 1.52e+07 1.1 1.8e+05 1.9e+03 0.0e+00  0  0  0  0  0   1 29 24 29  0 96787
MatMultAdd            40 1.0 1.4560e-02 2.1 2.38e+06 1.3 7.4e+04 3.0e+02 0.0e+00  0  0  0  0  0   0  4 10  2  0 32696
MatMultTranspose      40 1.0 1.3394e-02 1.7 2.38e+06 1.3 7.4e+04 3.0e+02 0.0e+00  0  0  0  0  0   0  4 10  2  0 35544
MatSolve              10 0.0 6.1989e-05 0.0 1.22e+04 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   198
MatSOR                80 1.0 4.1121e-02 1.1 1.40e+07 1.1 8.5e+04 1.5e+03 2.0e+01  0  0  0  0  0   1 27 11 11  3 71623
MatLUFactorSym         1 1.0 7.9155e-05 6.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         1 1.0 7.7009e-0519.0 1.01e+04 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   131
MatConvert             4 1.0 4.0369e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale              12 1.0 2.5949e-03 1.7 8.36e+05 1.2 8.5e+03 1.5e+03 0.0e+00  0  0  0  0  0   0  2  1  1  0 66198
MatResidual           40 1.0 1.5780e-02 1.5 5.98e+06 1.1 8.5e+04 1.5e+03 0.0e+00  0  0  0  0  0   0 11 11 11  0 78689
MatAssemblyBegin      83 1.0 7.5437e-02 2.0 0.00e+00 0.0 2.2e+04 6.4e+03 0.0e+00  0  0  0  0  0   2  0  3 12  0     0
MatAssemblyEnd        83 1.0 7.3102e-02 1.3 0.00e+00 0.0 1.0e+05 2.2e+02 1.8e+02  0  0  0  0  0   2  0 13  2 31     0
MatGetRow          88851 1.0 1.4340e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0  42  0  0  0  0     0
MatGetRowIJ            1 0.0 1.8120e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCreateSubMat        4 1.0 1.1639e-02 1.9 0.00e+00 0.0 4.5e+03 5.5e+02 6.4e+01  0  0  0  0  0   0  0  1  0 11     0
MatGetOrdering         1 0.0 9.7036e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             4 1.0 9.6412e-03 1.1 0.00e+00 0.0 9.4e+04 8.0e+02 2.5e+01  0  0  0  0  0   0  0 12  6  4     0
MatZeroEntries         4 1.0 4.4084e-04 3.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                4 1.0 9.6810e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0  28  0  0  0  0     0
MatMatMult             4 1.0 4.4704e-02 1.0 5.98e+05 1.3 5.4e+04 7.0e+02 4.9e+01  0  0  0  0  0   1  1  7  3  9  2667
MatMatMultSym          4 1.0 3.8034e-02 1.0 0.00e+00 0.0 4.6e+04 5.6e+02 4.8e+01  0  0  0  0  0   1  0  6  2  8     0
MatMatMultNum          4 1.0 6.2041e-03 1.0 5.98e+05 1.3 8.5e+03 1.5e+03 0.0e+00  0  0  0  0  0   0  1  1  1  0 19219
MatPtAP                4 1.0 1.0061e-01 1.0 8.06e+06 1.5 1.2e+05 2.5e+03 6.1e+01  0  0  0  0  0   3 14 15 26 11 14973
MatPtAPSymbolic        4 1.0 6.1238e-02 1.0 0.00e+00 0.0 5.6e+04 2.8e+03 2.8e+01  0  0  0  0  0   2  0  7 14  5     0
MatPtAPNumeric         4 1.0 3.9100e-02 1.0 8.06e+06 1.5 6.1e+04 2.2e+03 3.2e+01  0  0  0  0  0   1 14  8 12  6 38528
MatTrnMatMult          1 1.0 8.1200e-02 1.0 2.72e+06 1.3 1.0e+04 9.2e+03 1.6e+01  0  0  0  0  0   2  5  1  8  3  6689
MatTrnMatMultSym       1 1.0 5.5003e-02 1.0 0.00e+00 0.0 9.0e+03 4.6e+03 1.6e+01  0  0  0  0  0   2  0  1  4  3     0
MatTrnMatMultNum       1 1.0 2.6250e-02 1.0 2.72e+06 1.3 1.1e+03 4.8e+04 0.0e+00  0  0  0  0  0   1  5  0  5  0 20693
MatGetLocalMat        14 1.0 7.8259e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol         12 1.0 5.9967e-03 1.5 0.00e+00 0.0 5.9e+04 2.7e+03 0.0e+00  0  0  0  0  0   0  0  8 14  0     0
SFSetGraph             4 1.0 3.9816e-0510.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetUp                4 1.0 2.9175e-03 1.8 0.00e+00 0.0 1.5e+04 6.6e+02 0.0e+00  0  0  0  0  0   0  0  2  1  0     0
SFBcastBegin          33 1.0 1.0576e-03 2.5 0.00e+00 0.0 7.8e+04 8.2e+02 0.0e+00  0  0  0  0  0   0  0 10  6  0     0
SFBcastEnd            33 1.0 1.6055e-03 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCGAMGGraph_AGG        4 1.0 1.9680e+00 1.0 5.98e+05 1.1 2.5e+04 7.4e+02 4.8e+01  2  0  0  0  0  58  1  3  2  8    63
PCGAMGCoarse_AGG       4 1.0 1.0160e-01 1.0 2.72e+06 1.3 1.2e+05 2.0e+03 4.5e+01  0  0  0  0  0   3  5 15 21  8  5346
PCGAMGProl_AGG         4 1.0 2.3153e-02 1.1 0.00e+00 0.0 3.5e+04 1.3e+03 6.4e+01  0  0  0  0  0   1  0  5  4 11     0
PCGAMGPOpt_AGG         4 1.0 1.0441e+00 1.0 9.81e+06 1.1 1.4e+05 1.2e+03 1.6e+02  1  0  0  0  0  31 19 18 14 29  1965
GAMG: createProl       4 1.0 3.1363e+00 1.0 1.31e+07 1.1 3.2e+05 1.5e+03 3.2e+02  3  0  0  0  1  92 25 41 40 56   867
  Graph                8 1.0 1.9667e+00 1.0 5.98e+05 1.1 2.5e+04 7.4e+02 4.8e+01  2  0  0  0  0  58  1  3  2  8    63
  MIS/Agg              4 1.0 9.7492e-03 1.1 0.00e+00 0.0 9.4e+04 8.0e+02 2.5e+01  0  0  0  0  0   0  0 12  6  4     0
  SA: col data         4 1.0 5.0085e-03 1.1 0.00e+00 0.0 2.1e+04 2.0e+03 1.6e+01  0  0  0  0  0   0  0  3  4  3     0
  SA: frmProl0         4 1.0 1.5262e-02 1.0 0.00e+00 0.0 1.4e+04 3.7e+02 3.2e+01  0  0  0  0  0   0  0  2  0  6     0
  SA: smooth           4 1.0 1.0149e+00 1.0 8.36e+05 1.3 5.4e+04 7.0e+02 5.7e+01  1  0  0  0  0  30  2  7  3 10   164
GAMG: partLevel        4 1.0 1.1628e-01 1.0 8.06e+06 1.5 1.2e+05 2.4e+03 1.6e+02  0  0  0  0  0   3 14 16 26 28 12956
  repartition          2 1.0 8.7881e-04 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  0   0  0  0  0  2     0
  Invert-Sort          2 1.0 1.3301e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  0   0  0  0  0  1     0
  Move A               2 1.0 9.6662e-03 2.4 0.00e+00 0.0 1.9e+03 1.3e+03 3.4e+01  0  0  0  0  0   0  0  0  0  6     0
  Move P               2 1.0 8.2741e-03 3.1 0.00e+00 0.0 2.6e+03 2.1e+01 3.4e+01  0  0  0  0  0   0  0  0  0  6     0
PCSetUp                2 1.0 3.2645e+00 1.0 2.12e+07 1.3 4.4e+05 1.7e+03 5.1e+02  3  0  0  0  1  96 39 57 66 88  1294
PCSetUpOnBlocks       10 1.0 4.4870e-04 3.5 1.01e+04 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    23
PCApply               10 1.0 7.8002e-02 1.0 2.48e+07 1.1 3.2e+05 9.4e+02 2.0e+01  0  0  0  0  0   2 47 41 26  3 65884
KSPSolve            1000 1.0 1.0878e+02 1.0 3.19e+10 1.1 3.3e+08 1.2e+03 5.2e+04 97100100100 99 100100100100100 61407
VecTDot            20000 1.0 7.9760e+00 1.4 1.08e+09 1.0 0.0e+00 0.0e+00 2.0e+04  6  3  0  0 38   6  3  0  0 38 29247
VecNorm            12000 1.0 2.9418e+00 1.1 6.48e+08 1.0 0.0e+00 0.0e+00 1.2e+04  3  2  0  0 23   3  2  0  0 23 47579
VecScale           40000 1.0 2.1746e-01 1.7 9.01e+07 2.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 72661
VecCopy             1000 1.0 8.4139e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet            150000 1.0 1.4097e+00 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
VecAXPY            20000 1.0 1.3505e+00 1.1 1.08e+09 1.0 0.0e+00 0.0e+00 0.0e+00  1  3  0  0  0   1  3  0  0  0 172735
VecAYPX            50000 1.0 1.6715e+00 1.3 8.09e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  3  0  0  0   1  3  0  0  0 104366
VecScatterBegin   171000 1.0 5.6701e+00 2.4 0.00e+00 0.0 3.3e+08 1.2e+03 0.0e+00  4  0100100  0   4  0100100  0     0
VecScatterEnd     171000 1.0 2.8652e+01 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 21  0  0  0  0  21  0  0  0  0     0
MatMult            51000 1.0 2.2225e+01 1.2 9.55e+09 1.1 9.7e+07 2.2e+03 0.0e+00 17 30 29 55  0  18 30 29 55  0 90340
MatMultAdd         40000 1.0 1.9086e+01 2.1 2.38e+09 1.3 7.4e+07 3.0e+02 0.0e+00 13  7 22  6  0  13  7 22  6  0 24944
MatMultTranspose   40000 1.0 1.5344e+01 1.8 2.38e+09 1.3 7.4e+07 3.0e+02 0.0e+00 10  7 22  6  0  11  7 22  6  0 31027
MatSolve           10000 0.0 5.1090e-02 0.0 1.22e+07 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   240
MatSOR             80000 1.0 4.7799e+01 1.2 1.40e+10 1.1 8.5e+07 1.5e+03 2.0e+04 40 44 26 33 38  41 44 26 33 38 61484
MatResidual        40000 1.0 1.6702e+01 1.4 5.98e+09 1.1 8.5e+07 1.5e+03 0.0e+00 13 19 26 33  0  13 19 26 33  0 74349
PCSetUpOnBlocks    10000 1.0 1.4676e-01 4.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCApply            10000 1.0 9.0367e+01 1.0 2.47e+10 1.1 3.2e+08 9.4e+02 2.0e+04 80 77 96 77 38  82 77 96 78 38 56799
       Krylov Solver     1              7         8816     0.
     DMKSP interface     1              1          656     0.
              Vector     4             38      1915568     0.
              Matrix     0             50      9208336     0.
    Distributed Mesh     1              1         5248     0.
           Index Set     2             12       137820     0.
   IS L to G Mapping     1              1       131728     0.
   Star Forest Graph     2              2         1728     0.
     Discrete System     1              1          932     0.
         Vec Scatter     1             10       228640     0.
      Preconditioner     1              7         7448     0.
              Viewer     1              0            0     0.
       Krylov Solver    10              4         6400     0.
              Vector   171            137      6010696     0.
              Matrix   122             72     21592712     0.
      Matrix Coarsen     4              4         2544     0.
           Index Set    76             66       118624     0.
   Star Forest Graph     4              4         3456     0.
         Vec Scatter    28             19        24048     0.
      Preconditioner    10              4         3424     0.
         PetscRandom     8              8         5168     0.
              Vector 40000          40000   2398240000     0.
Average time to get PetscTime(): 5.96046e-07
Average time for MPI_Barrier(): 8.96454e-06
Average time for zero size MPI_Send(): 1.3921e-05
#PETSc Option Table entries:
-iterations 1000
-ksp_rtol 1E-6
-ksp_type cg
-log_view
-mesh_size 1E-4
-nodes_per_proc 30
-pc_gamg_type agg
-pc_type gamg
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --with-debugging=no --COPTFLAGS="-g -O3 -DPETSC_KERNEL_USE_UNROLL_4" --CXXOPTFLAGS="-g -O3 -DPETSC_KERNEL_USE_UNROLL_4" --FOPTFLAGS="-g -O3 -DPETSC_KERNEL_USE_UNROLL_4" --with-openmp=1 --download-sowing --download-fblaslapack=1 --download-scalapack=1 --download-metis=1 --download-parmetis=1 --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90 --PETSC_ARCH=intel-bdw-opt --PETSC_DIR=/home/jczhang/petsc
Libraries compiled on 2018-06-05 18:40:55 on beboplogin2
Machine characteristics: Linux-3.10.0-693.21.1.el7.x86_64-x86_64-with-centos-7.4.1708-Core
Using PETSc directory: /home/jczhang/petsc
Using PETSc arch: intel-bdw-opt
Using C compiler: mpicc  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O3 -DPETSC_KERNEL_USE_UNROLL_4 -fopenmp
Using Fortran compiler: mpif90  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O3 -DPETSC_KERNEL_USE_UNROLL_4  -fopenmp
Using include paths: -I/home/jczhang/petsc/include -I/home/jczhang/petsc/intel-bdw-opt/include
Using C linker: mpicc
Using Fortran linker: mpif90
Using libraries: -Wl,-rpath,/home/jczhang/petsc/intel-bdw-opt/lib -L/home/jczhang/petsc/intel-bdw-opt/lib -lpetsc -Wl,-rpath,/home/jczhang/petsc/intel-bdw-opt/lib -L/home/jczhang/petsc/intel-bdw-opt/lib -Wl,-rpath,/blues/gpfs/home/jczhang/spack/opt/spack/linux-centos7-x86_64/gcc-4.8.5/intel-mpi-2018.0.128-afy57nutkjquvasoogql4bmgwdjdhtbi/compilers_and_libraries_2018.0.128/linux/mpi/intel64/lib/debug_mt -L/blues/gpfs/home/jczhang/spack/opt/spack/linux-centos7-x86_64/gcc-4.8.5/intel-mpi-2018.0.128-afy57nutkjquvasoogql4bmgwdjdhtbi/compilers_and_libraries_2018.0.128/linux/mpi/intel64/lib/debug_mt -Wl,-rpath,/blues/gpfs/home/jczhang/spack/opt/spack/linux-centos7-x86_64/gcc-4.8.5/intel-mpi-2018.0.128-afy57nutkjquvasoogql4bmgwdjdhtbi/compilers_and_libraries_2018.0.128/linux/mpi/intel64/lib -L/blues/gpfs/home/jczhang/spack/opt/spack/linux-centos7-x86_64/gcc-4.8.5/intel-mpi-2018.0.128-afy57nutkjquvasoogql4bmgwdjdhtbi/compilers_and_libraries_2018.0.128/linux/mpi/intel64/lib -Wl,-rpath,/blues/gpfs/home/software/bebop/craype-17.02-1-knl/opt/gcc/4.9.1/snos/lib/gcc/x86_64-suse-linux/4.9.1 -L/blues/gpfs/home/software/bebop/craype-17.02-1-knl/opt/gcc/4.9.1/snos/lib/gcc/x86_64-suse-linux/4.9.1 -Wl,-rpath,/blues/gpfs/home/software/bebop/craype-17.02-1-knl/opt/gcc/4.9.1/snos/lib/gcc -L/blues/gpfs/home/software/bebop/craype-17.02-1-knl/opt/gcc/4.9.1/snos/lib/gcc -Wl,-rpath,/blues/gpfs/home/software/bebop/craype-17.02-1-knl/opt/gcc/4.9.1/snos/lib64 -L/blues/gpfs/home/software/bebop/craype-17.02-1-knl/opt/gcc/4.9.1/snos/lib64 -Wl,-rpath,/blues/gpfs/home/jczhang/spack/opt/spack/linux-centos7-x86_64/gcc-4.8.5/hpctoolkit-2017.06-557cxm5zivsflxdq5sqgcx3j6z7ybn6n/lib -L/blues/gpfs/home/jczhang/spack/opt/spack/linux-centos7-x86_64/gcc-4.8.5/hpctoolkit-2017.06-557cxm5zivsflxdq5sqgcx3j6z7ybn6n/lib -Wl,-rpath,/blues/gpfs/home/software/spack-0.10.1/opt/spack/linux-centos7-x86_64/intel-17.0.4/intel-mkl-2017.3.196-v7uuj6zmthzln35n2hb7i5u5ybncv5ev/compilers_and_libraries_2017.4.196/linux/tbb/lib/intel64_lin/gcc4.7 -L/blues/gpfs/home/software/spack-0.10.1/opt/spack/linux-centos7-x86_64/intel-17.0.4/intel-mkl-2017.3.196-v7uuj6zmthzln35n2hb7i5u5ybncv5ev/compilers_and_libraries_2017.4.196/linux/tbb/lib/intel64_lin/gcc4.7 -Wl,-rpath,/blues/gpfs/home/software/spack-0.10.1/opt/spack/linux-centos7-x86_64/intel-17.0.4/intel-mkl-2017.3.196-v7uuj6zmthzln35n2hb7i5u5ybncv5ev/compilers_and_libraries_2017.4.196/linux/compiler/lib/intel64_lin -L/blues/gpfs/home/software/spack-0.10.1/opt/spack/linux-centos7-x86_64/intel-17.0.4/intel-mkl-2017.3.196-v7uuj6zmthzln35n2hb7i5u5ybncv5ev/compilers_and_libraries_2017.4.196/linux/compiler/lib/intel64_lin -Wl,-rpath,/blues/gpfs/home/software/spack-0.10.1/opt/spack/linux-centos7-x86_64/intel-17.0.4/intel-mkl-2017.3.196-v7uuj6zmthzln35n2hb7i5u5ybncv5ev/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64_lin -L/blues/gpfs/home/software/spack-0.10.1/opt/spack/linux-centos7-x86_64/intel-17.0.4/intel-mkl-2017.3.196-v7uuj6zmthzln35n2hb7i5u5ybncv5ev/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64_lin -Wl,-rpath,/blues/gpfs/home/software/spack-0.10.1/opt/spack/linux-centos7-x86_64/intel-17.0.4/intel-mkl-2017.3.196-v7uuj6zmthzln35n2hb7i5u5ybncv5ev/lib -L/blues/gpfs/home/software/spack-0.10.1/opt/spack/linux-centos7-x86_64/intel-17.0.4/intel-mkl-2017.3.196-v7uuj6zmthzln35n2hb7i5u5ybncv5ev/lib -Wl,-rpath,/blues/gpfs/home/software/spack-0.10.1/opt/spack/linux-centos7-x86_64/gcc-4.8.5/intel-17.0.4-74uvhjiulyqgvsmywifbbuo46v5n42xc/tbb/lib/intel64/gcc4.4 -L/blues/gpfs/home/software/spack-0.10.1/opt/spack/linux-centos7-x86_64/gcc-4.8.5/intel-17.0.4-74uvhjiulyqgvsmywifbbuo46v5n42xc/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/blues/gpfs/home/software/spack-0.10.1/opt/spack/linux-centos7-x86_64/gcc-4.8.5/intel-17.0.4-74uvhjiulyqgvsmywifbbuo46v5n42xc/lib/intel64 -L/blues/gpfs/home/software/spack-0.10.1/opt/spack/linux-centos7-x86_64/gcc-4.8.5/intel-17.0.4-74uvhjiulyqgvsmywifbbuo46v5n42xc/lib/intel64 -Wl,-rpath,/blues/gpfs/home/software/bebop/craype-17.02-1-knl/opt/gcc/4.9.1/snos/lib -L/blues/gpfs/home/software/bebop/craype-17.02-1-knl/opt/gcc/4.9.1/snos/lib -Wl,-rpath,/opt/intel/mpi-rt/2017.0.0/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/mpi-rt/2017.0.0/intel64/lib -lscalapack -lflapack -lfblas -lparmetis -lmetis -lm -lX11 -lstdc++ -ldl -lmpifort -lmpi -lmpigi -lrt -lpthread -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lstdc++ -ldl
srun: Warning: can't honor --ntasks-per-node set to 36 which doesn't match the requested tasks 48 with the number of requested nodes 48. Ignoring --ntasks-per-node.
using 1728 of 1728 processes
total system size: 360^3
mesh size: 0.0001
initsolve: 12 iterations
solve 1: 12 iterations
solve 2: 12 iterations
solve 3: 12 iterations
solve 4: 12 iterations
solve 5: 12 iterations
solve 6: 12 iterations
solve 7: 12 iterations
solve 8: 12 iterations
solve 9: 12 iterations
solve 10: 12 iterations
solve 20: 12 iterations
solve 30: 12 iterations
solve 40: 12 iterations
solve 50: 12 iterations
solve 60: 12 iterations
solve 70: 12 iterations
solve 80: 12 iterations
solve 90: 12 iterations
solve 100: 12 iterations
solve 200: 12 iterations
solve 300: 12 iterations
solve 400: 12 iterations
solve 500: 12 iterations
solve 600: 12 iterations
solve 700: 12 iterations
solve 800: 12 iterations
solve 900: 12 iterations
solve 1000: 12 iterations
Time in solve():      183.41 s
Time in KSPSolve():   183.154 s (99.8607%)
Number of   KSP iterations (total): 12000
Number of solve iterations (total): 1000 (ratio: 12.00)
./wstest on a intel-bdw-opt named bdw-0065 with 1728 processors, by jczhang Sun Jun 10 23:56:56 2018
Time (sec):           1.873e+02      1.00001   1.873e+02
Objects:              4.846e+04      1.00002   4.846e+04
Flop:                 3.894e+10      1.11735   3.767e+10  6.509e+13
Flop/sec:            2.080e+08      1.11735   2.012e+08  3.476e+11
MPI Messages:         4.708e+06      6.19009   2.297e+06  3.969e+09
MPI Message Lengths:  2.889e+09      2.40120   1.037e+03  4.115e+12
MPI Reductions:       6.264e+04      1.00000
 0:      Main Stage: 1.1424e-01   0.1%  0.0000e+00   0.0%  1.901e+04   0.0%  1.802e+03        0.0%  1.700e+01   0.0%
 1:     First Solve: 3.7160e+00   2.0%  1.0002e+11   0.2%  8.597e+06   0.2%  1.305e+03        0.3%  6.140e+02   1.0%
 2: Remaining Solves: 1.8343e+02  98.0%  6.4988e+13  99.8%  3.961e+09  99.8%  1.036e+03       99.7%  6.200e+04  99.0%
Phase summary info:
VecSet                 2 1.0 1.5020e-04 5.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided          4 1.0 2.8999e-03 2.2 0.00e+00 0.0 5.1e+04 4.0e+00 0.0e+00  0  0  0  0  0   0  0  1  0  0     0
BuildTwoSidedF        40 1.0 1.2657e-01 2.3 0.00e+00 0.0 2.1e+05 6.2e+03 0.0e+00  0  0  0  0  0   2  0  2 12  0     0
KSPSetUp              11 1.0 5.3284e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.4e+01  0  0  0  0  0   0  0  0  0  2     0
KSPSolve               1 1.0 3.7157e+00 1.0 6.06e+07 1.2 8.6e+06 1.3e+03 6.1e+02  2  0  0  0  1 100100100100100 26919
VecTDot              108 1.0 2.7509e-02 1.4 2.54e+06 1.0 0.0e+00 0.0e+00 1.1e+02  0  0  0  0  0   1  4  0  0 18 159329
VecNorm               14 1.0 2.2557e-03 1.7 7.56e+05 1.0 0.0e+00 0.0e+00 1.4e+01  0  0  0  0  0   0  1  0  0  2 579146
VecScale              48 1.0 4.7922e-04 3.6 1.24e+05 2.5 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 355623
VecCopy                9 1.0 4.0150e-04 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               227 1.0 2.5015e-03 2.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY              104 1.0 5.3051e-03 1.7 2.48e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  4  0  0  0 806970
VecAYPX               96 1.0 3.2096e-03 1.4 1.51e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  3  0  0  0 811392
VecAssemblyBegin      14 1.0 3.1312e-03 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd        14 1.0 3.3569e-04 2.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult      44 1.0 1.2739e-03 1.3 3.26e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 440721
VecScatterBegin      264 1.0 1.2353e-02 2.9 0.00e+00 0.0 5.2e+06 1.2e+03 0.0e+00  0  0  0  0  0   0  0 61 57  0     0
VecScatterEnd        264 1.0 6.0780e-02 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecSetRandom           4 1.0 1.1327e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMult              101 1.0 4.6448e-02 1.5 1.76e+07 1.1 2.0e+06 1.7e+03 0.0e+00  0  0  0  0  0   1 29 23 30  0 625296
MatMultAdd            48 1.0 5.0853e-02 4.2 2.86e+06 1.3 9.1e+05 2.7e+02 0.0e+00  0  0  0  0  0   1  5 11  2  0 93269
MatMultTranspose      48 1.0 3.3805e-02 3.4 2.86e+06 1.3 9.1e+05 2.7e+02 0.0e+00  0  0  0  0  0   0  5 11  2  0 140302
MatSolve              12 0.0 6.8688e-04 0.0 8.45e+05 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1230
MatSOR                96 1.0 5.9859e-02 1.2 1.72e+07 1.1 1.0e+06 1.4e+03 2.4e+01  0  0  0  0  0   1 29 12 12  4 478874
MatLUFactorSym         1 1.0 3.2248e-03294.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         1 1.0 2.8222e-03986.4 4.22e+06 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1494
MatConvert             4 1.0 1.2332e-02 3.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale              12 1.0 3.8207e-03 2.6 8.60e+05 1.2 8.4e+04 1.4e+03 0.0e+00  0  0  0  0  0   0  1  1  1  0 368774
MatResidual           48 1.0 2.7284e-02 2.0 7.46e+06 1.2 1.0e+06 1.4e+03 0.0e+00  0  0  0  0  0   0 12 12 12  0 445843
MatAssemblyBegin      83 1.0 1.2762e-01 2.1 0.00e+00 0.0 2.1e+05 6.2e+03 0.0e+00  0  0  0  0  0   2  0  2 12  0     0
MatAssemblyEnd        83 1.0 1.2948e-01 1.6 0.00e+00 0.0 1.1e+06 1.8e+02 1.8e+02  0  0  0  0  0   3  0 13  2 29     0
MatGetRow          89034 1.0 1.4585e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0  38  0  0  0  0     0
MatGetRowIJ            1 0.0 1.0991e-04 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCreateSubMat        4 1.0 2.8479e-02 1.3 0.00e+00 0.0 5.9e+04 4.9e+02 6.4e+01  0  0  0  0  0   1  0  1  0 10     0
MatGetOrdering         1 0.0 2.7084e-04 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             4 1.0 2.0675e-02 1.1 0.00e+00 0.0 1.1e+06 6.2e+02 5.1e+01  0  0  0  0  0   1  0 13  6  8     0
MatZeroEntries         4 1.0 3.2139e-04 3.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                4 1.0 9.9720e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0  27  0  0  0  0     0
MatMatMult             4 1.0 8.0693e-02 1.1 6.22e+05 1.3 5.4e+05 6.4e+02 5.0e+01  0  0  0  0  0   2  1  6  3  8 12315
MatMatMultSym          4 1.0 6.5204e-02 1.0 0.00e+00 0.0 4.6e+05 5.1e+02 4.8e+01  0  0  0  0  0   2  0  5  2  8     0
MatMatMultNum          4 1.0 9.7268e-03 1.0 6.22e+05 1.3 8.4e+04 1.3e+03 0.0e+00  0  0  0  0  0   0  1  1  1  0 102165
MatPtAP                4 1.0 1.7622e-01 1.0 8.31e+06 1.6 1.2e+06 2.3e+03 6.2e+01  0  0  0  0  0   5 13 14 25 10 72429
MatPtAPSymbolic        4 1.0 9.2023e-02 1.0 0.00e+00 0.0 5.6e+05 2.7e+03 2.8e+01  0  0  0  0  0   2  0  7 14  5     0
MatPtAPNumeric         4 1.0 8.2069e-02 1.0 8.31e+06 1.6 6.7e+05 1.9e+03 3.2e+01  0  0  0  0  0   2 13  8 12  5 155523
MatTrnMatMult          1 1.0 9.1041e-02 1.0 2.72e+06 1.3 9.2e+04 9.1e+03 1.6e+01  0  0  0  0  0   2  5  1  7  3 49668
MatTrnMatMultSym       1 1.0 6.3481e-02 1.0 0.00e+00 0.0 8.2e+04 4.5e+03 1.6e+01  0  0  0  0  0   2  0  1  3  3     0
MatTrnMatMultNum       1 1.0 2.7639e-02 1.0 2.72e+06 1.3 9.5e+03 4.9e+04 0.0e+00  0  0  0  0  0   1  5  0  4  0 163601
MatGetLocalMat        14 1.0 9.3658e-03 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol         12 1.0 9.1021e-03 2.3 0.00e+00 0.0 5.9e+05 2.6e+03 0.0e+00  0  0  0  0  0   0  0  7 14  0     0
SFSetGraph             4 1.0 7.6056e-0526.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetUp                4 1.0 3.6201e-03 1.7 0.00e+00 0.0 1.5e+05 6.0e+02 0.0e+00  0  0  0  0  0   0  0  2  1  0     0
SFBcastBegin          59 1.0 2.5663e-03 3.4 0.00e+00 0.0 9.8e+05 6.2e+02 0.0e+00  0  0  0  0  0   0  0 11  5  0     0
SFBcastEnd            59 1.0 7.1716e-03 7.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCGAMGGraph_AGG        4 1.0 2.0067e+00 1.0 6.22e+05 1.2 2.5e+05 6.7e+02 4.8e+01  1  0  0  0  0  54  1  3  2  8   505
PCGAMGCoarse_AGG       4 1.0 1.2379e-01 1.0 2.72e+06 1.3 1.3e+06 1.6e+03 7.1e+01  0  0  0  0  0   3  5 16 19 12 36527
PCGAMGProl_AGG         4 1.0 2.7567e-02 1.1 0.00e+00 0.0 3.3e+05 1.2e+03 6.4e+01  0  0  0  0  0   1  0  4  4 10     0
PCGAMGPOpt_AGG         4 1.0 1.1260e+00 1.0 1.01e+07 1.1 1.4e+06 1.1e+03 1.7e+02  1  0  0  0  0  30 17 16 13 27 14814
GAMG: createProl       4 1.0 3.2832e+00 1.0 1.34e+07 1.2 3.3e+06 1.3e+03 3.5e+02  2  0  0  0  1  88 22 39 38 57  6767
  Graph                8 1.0 2.0053e+00 1.0 6.22e+05 1.2 2.5e+05 6.7e+02 4.8e+01  1  0  0  0  0  54  1  3  2  8   506
  MIS/Agg              4 1.0 2.0879e-02 1.1 0.00e+00 0.0 1.1e+06 6.2e+02 5.1e+01  0  0  0  0  0   1  0 13  6  8     0
  SA: col data         4 1.0 5.9071e-03 1.1 0.00e+00 0.0 2.0e+05 1.8e+03 1.6e+01  0  0  0  0  0   0  0  2  3  3     0
  SA: frmProl0         4 1.0 1.8157e-02 1.0 0.00e+00 0.0 1.3e+05 3.7e+02 3.2e+01  0  0  0  0  0   0  0  2  0  5     0
  SA: smooth           4 1.0 1.0804e+00 1.0 8.60e+05 1.3 5.4e+05 6.4e+02 5.8e+01  1  0  0  0  0  29  1  6  3  9  1286
GAMG: partLevel        4 1.0 2.1361e-01 1.0 8.31e+06 1.6 1.3e+06 2.2e+03 1.6e+02  0  0  0  0  0   6 13 15 25 27 59752
  repartition          2 1.0 1.5340e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  0   0  0  0  0  2     0
  Invert-Sort          2 1.0 4.6380e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  0   0  0  0  0  1     0
  Move A               2 1.0 2.1691e-02 1.4 0.00e+00 0.0 2.4e+04 1.2e+03 3.4e+01  0  0  0  0  0   0  0  0  0  6     0
  Move P               2 1.0 1.3658e-02 1.8 0.00e+00 0.0 3.5e+04 1.7e+01 3.4e+01  0  0  0  0  0   0  0  0  0  6     0
PCSetUp                2 1.0 3.5135e+00 1.0 2.17e+07 1.3 4.6e+06 1.5e+03 5.4e+02  2  0  0  0  1  94 35 54 63 87  9957
PCSetUpOnBlocks       12 1.0 6.3727e-0342.4 4.22e+06 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   662
PCApply               12 1.0 1.3277e-01 1.0 3.14e+07 1.2 3.8e+06 8.4e+02 2.4e+01  0  0  0  0  0   4 50 45 29  4 379007
KSPSolve            1000 1.0 1.8317e+02 1.0 3.89e+10 1.1 4.0e+09 1.0e+03 6.2e+04 98100100100 99 100100100100100 354794
VecTDot            24000 1.0 2.3516e+01 1.2 1.30e+09 1.0 0.0e+00 0.0e+00 2.4e+04 11  3  0  0 38  12  3  0  0 39 95232
VecNorm            14000 1.0 6.8848e+00 1.1 7.56e+08 1.0 0.0e+00 0.0e+00 1.4e+04  4  2  0  0 22   4  2  0  0 23 189748
VecScale           48000 1.0 2.9046e-01 2.5 1.24e+08 2.5 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 586732
VecCopy             1000 1.0 8.8122e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet            180000 1.0 1.8199e+00 2.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
VecAXPY            24000 1.0 1.6535e+00 1.2 1.30e+09 1.0 0.0e+00 0.0e+00 0.0e+00  1  3  0  0  0   1  3  0  0  0 1354423
VecAYPX            60000 1.0 1.9924e+00 1.3 9.77e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  3  0  0  0   1  3  0  0  0 846000
VecScatterBegin   205000 1.0 9.1513e+00 3.1 0.00e+00 0.0 4.0e+09 1.0e+03 0.0e+00  3  0100100  0   3  0100100  0     0
VecScatterEnd     205000 1.0 5.6576e+01 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 26  0  0  0  0  27  0  0  0  0     0
MatMult            61000 1.0 3.2314e+01 1.5 1.17e+10 1.1 1.1e+09 2.0e+03 0.0e+00 13 30 29 55  0  14 30 29 55  0 600882
MatMultAdd         48000 1.0 4.4993e+01 2.9 2.86e+09 1.3 9.1e+08 2.7e+02 0.0e+00 20  7 23  6  0  20  7 23  6  0 105415
MatMultTranspose   48000 1.0 3.4573e+01 3.1 2.86e+09 1.3 9.1e+08 2.7e+02 0.0e+00  8  7 23  6  0   8  7 23  6  0 137187
MatSolve           12000 0.0 7.3331e-01 0.0 8.45e+08 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1152
MatSOR             96000 1.0 7.1605e+01 1.2 1.72e+10 1.1 1.0e+09 1.4e+03 2.4e+04 36 44 25 33 38  37 44 25 33 39 399609
MatResidual        48000 1.0 2.5073e+01 1.7 7.46e+09 1.2 1.0e+09 1.4e+03 0.0e+00 10 19 25 33  0  10 19 25 33  0 485156
PCSetUpOnBlocks    12000 1.0 1.7560e-0115.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCApply            12000 1.0 1.4437e+02 1.0 3.04e+10 1.2 3.8e+09 8.4e+02 2.4e+04 77 77 97 78 38  78 77 97 78 39 348175
              Vector     4             38      1919384     0.
              Matrix     0             50     10310768     0.
           Index Set     2             12       206536     0.
              Viewer     1              0            0     0.
              Vector   179            145      6496648     0.
              Matrix   122             72     21618064     0.
           Index Set    74             64       185744     0.
         Vec Scatter    28             19        24056     0.
              Vector 48000          48000   2878368000     0.
Average time to get PetscTime(): 5.00679e-07
Average time for MPI_Barrier(): 1.45912e-05
Average time for zero size MPI_Send(): 6.50518e-06
-iterations 1000
-ksp_rtol 1E-6
-ksp_type cg
-log_view
-mesh_size 1E-4
-nodes_per_proc 30
-pc_gamg_type agg
-pc_type gamg
mesh size: 0.0001
initsolve: 163 iterations
solve 1: 163 iterations
solve 2: 163 iterations
solve 3: 163 iterations
solve 4: 163 iterations
solve 5: 163 iterations
solve 6: 163 iterations
solve 7: 163 iterations
solve 8: 163 iterations
solve 9: 163 iterations
solve 10: 163 iterations
solve 20: 163 iterations
solve 30: 163 iterations
solve 40: 163 iterations
solve 50: 163 iterations
solve 60: 163 iterations
solve 70: 163 iterations
solve 80: 163 iterations
solve 90: 163 iterations
solve 100: 163 iterations
solve 200: 163 iterations
solve 300: 163 iterations
solve 400: 163 iterations
solve 500: 163 iterations
solve 600: 163 iterations
solve 700: 163 iterations
solve 800: 163 iterations
solve 900: 163 iterations
solve 1000: 163 iterations
Time in solve():      423.567 s
Time in KSPSolve():   423.327 s (99.9431%)
Number of   KSP iterations (total): 163000
Number of solve iterations (total): 1000 (ratio: 163.00)
./wstest on a intel-bdw-opt named bdw-0437 with 216 processors, by jczhang Tue Jun 12 02:09:30 2018
Time (sec):           4.243e+02      1.00000   4.243e+02
Objects:              3.500e+01      1.00000   3.500e+01
Flop:                 1.661e+11      1.00537   1.658e+11  3.581e+13
Flop/sec:            3.914e+08      1.00537   3.907e+08  8.439e+10
MPI Messages:         9.850e+05      2.00000   8.208e+05  1.773e+08
MPI Message Lengths:  7.092e+09      2.00000   7.200e+03  1.277e+12
MPI Reductions:       4.915e+05      1.00000
 0:      Main Stage: 1.0660e-01   0.0%  0.0000e+00   0.0%  2.160e+03   0.0%  1.802e+03        0.0%  1.700e+01   0.0%
 1:     First Solve: 6.4530e-01   0.2%  3.5887e+10   0.1%  1.793e+05   0.1%  7.135e+03        0.1%  5.070e+02   0.1%
 2: Remaining Solves: 4.2358e+02  99.8%  3.5773e+13  99.9%  1.771e+08  99.9%  7.200e+03       99.9%  4.910e+05  99.9%
Phase summary info:
VecSet                 2 1.0 6.1989e-05 2.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSidedF         2 1.0 6.4178e-03 8.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
KSPSetUp               2 1.0 9.5639e-0316.0 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  0   1  0  0  0  1     0
KSPSolve               1 1.0 6.5393e-01 1.0 1.66e+08 1.0 1.8e+05 7.1e+03 5.1e+02  0  0  0  0  0 100100100100100 54879
VecTDot              326 1.0 2.6734e-01 1.3 1.76e+07 1.0 0.0e+00 0.0e+00 3.3e+02  0  0  0  0  0  39 11  0  0 64 14223
VecNorm              165 1.0 4.5129e-02 1.5 8.91e+06 1.0 0.0e+00 0.0e+00 1.6e+02  0  0  0  0  0   6  5  0  0 33 42646
VecCopy                1 1.0 9.1076e-05 2.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               164 1.0 4.1964e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecAXPY              326 1.0 2.9594e-02 1.8 1.76e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   3 11  0  0  0 128488
VecAYPX              163 1.0 2.5827e-02 5.8 8.78e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  5  0  0  0 73387
VecScatterBegin      164 1.0 1.1089e-02 2.3 0.00e+00 0.0 1.8e+05 7.2e+03 0.0e+00  0  0  0  0  0   1  0 99100  0     0
VecScatterEnd        164 1.0 4.3868e-02 8.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
MatMult              164 1.0 1.7538e-01 1.4 5.76e+07 1.0 1.8e+05 7.2e+03 0.0e+00  0  0  0  0  0  22 34 99100  0 70534
MatSolve             163 1.0 1.2920e-01 1.2 5.55e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0  18 33  0  0  0 92709
MatLUFactorNum         1 1.0 6.4151e-03 3.9 5.65e+05 1.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 17867
MatILUFactorSym        1 1.0 2.3391e-03 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyBegin       2 1.0 1.4147e-0217.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatAssemblyEnd         2 1.0 4.0359e-03 1.1 0.00e+00 0.0 2.2e+03 1.8e+03 8.0e+00  0  0  0  0  0   1  0  1  0  2     0
MatGetRowIJ            1 1.0 5.1022e-0553.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         1 1.0 2.6393e-04 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCSetUp                2 1.0 1.3018e-02 3.1 5.65e+05 1.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0  8805
PCSetUpOnBlocks        1 1.0 8.4250e-03 2.6 5.65e+05 1.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0 13605
PCApply              163 1.0 1.3862e-01 1.2 5.55e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0  19 33  0  0  0 86409
KSPSolve            1000 1.0 4.2333e+02 1.0 1.66e+11 1.0 1.8e+08 7.2e+03 4.9e+05100100100100100 100100100100100 84502
VecTDot           326000 1.0 1.0805e+02 1.3 1.76e+10 1.0 0.0e+00 0.0e+00 3.3e+05 22 11  0  0 66  22 11  0  0 66 35191
VecNorm           165000 1.0 3.5069e+01 1.2 8.91e+09 1.0 0.0e+00 0.0e+00 1.6e+05  8  5  0  0 34   8  5  0  0 34 54879
VecCopy             1000 1.0 9.4171e-02 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet            163000 1.0 4.2720e+00 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
VecAXPY           326000 1.0 2.1878e+01 1.3 1.76e+10 1.0 0.0e+00 0.0e+00 0.0e+00  4 11  0  0  0   4 11  0  0  0 173800
VecAYPX           163000 1.0 1.0099e+01 2.1 8.78e+09 1.0 0.0e+00 0.0e+00 0.0e+00  2  5  0  0  0   2  5  0  0  0 187673
VecScatterBegin   164000 1.0 1.1169e+01 2.2 0.00e+00 0.0 1.8e+08 7.2e+03 0.0e+00  2  0100100  0   2  0100100  0     0
VecScatterEnd     164000 1.0 1.9032e+01 2.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   3  0  0  0  0     0
MatMult           164000 1.0 1.4498e+02 1.2 5.76e+10 1.0 1.8e+08 7.2e+03 0.0e+00 32 35100100  0  32 35100100  0 85325
MatSolve          163000 1.0 1.2030e+02 1.1 5.55e+10 1.0 0.0e+00 0.0e+00 0.0e+00 27 33  0  0  0  27 33  0  0  0 99564
PCSetUpOnBlocks     1000 1.0 2.3875e-02 7.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCApply           163000 1.0 1.3030e+02 1.1 5.55e+10 1.0 0.0e+00 0.0e+00 0.0e+00 29 33  0  0  0  29 33  0  0  0 91925
       Krylov Solver     1              2         2424     0.
              Vector     4             10      1117680     0.
              Matrix     0              4      5974172     0.
           Index Set     2              5       446760     0.
         Vec Scatter     1              2       218528     0.
      Preconditioner     1              2         1912     0.
              Viewer     1              0            0     0.
       Krylov Solver     1              0            0     0.
              Vector     7              1         1656     0.
              Matrix     4              0            0     0.
           Index Set     5              2        12384     0.
         Vec Scatter     1              0            0     0.
      Preconditioner     1              0            0     0.
Average time to get PetscTime(): 6.19888e-07
Average time for MPI_Barrier(): 2.01702e-05
Average time for zero size MPI_Send(): 5.63926e-06
-iterations 1000
-ksp_rtol 1E-6
-ksp_type cg
-log_view
-mesh_size 1E-4
-nodes_per_proc 30
mesh size: 0.0001
initsolve: 100 iterations
solve 1: 100 iterations
solve 2: 100 iterations
solve 3: 100 iterations
solve 4: 100 iterations
solve 5: 100 iterations
solve 6: 100 iterations
solve 7: 100 iterations
solve 8: 100 iterations
solve 9: 100 iterations
solve 10: 100 iterations
solve 20: 100 iterations
solve 30: 100 iterations
solve 40: 100 iterations
solve 50: 100 iterations
solve 60: 100 iterations
solve 70: 100 iterations
solve 80: 100 iterations
solve 90: 100 iterations
solve 100: 100 iterations
Time in solve():      29.0941 s
Time in KSPSolve():   29.0545 s (99.8639%)
Number of solve iterations (total): 100 (ratio: 100.00)
./wstest on a intel-bdw-opt named bdwd-0033 with 216 processors, by jczhang Tue Jun 12 09:57:11 2018
Time (sec):           2.961e+01      1.00008   2.961e+01
Flop:                 1.034e+10      1.00537   1.032e+10  2.229e+12
Flop/sec:            3.491e+08      1.00544   3.485e+08  7.528e+10
MPI Messages:         6.123e+04      2.00000   5.102e+04  1.102e+07
MPI Message Lengths:  4.407e+08      2.00000   7.198e+03  7.933e+10
MPI Reductions:       3.064e+04      1.00000
 0:      Main Stage: 8.8708e-02   0.3%  0.0000e+00   0.0%  2.160e+03   0.0%  1.802e+03        0.0%  1.700e+01   0.1%
 1:     First Solve: 4.2526e-01   1.4%  2.2182e+10   1.0%  1.112e+05   1.0%  7.095e+03        1.0%  3.190e+02   1.0%
 2: Remaining Solves: 2.9096e+01  98.3%  2.2067e+12  99.0%  1.091e+07  99.0%  7.200e+03       99.0%  3.030e+04  98.9%
Phase summary info:
VecSet                 2 1.0 1.9312e-04 6.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSidedF         2 1.0 1.1070e-0245.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
KSPSetUp               2 1.0 7.4315e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  0   0  0  0  0  2     0
KSPSolve               1 1.0 4.2496e-01 1.0 1.03e+08 1.0 1.1e+05 7.1e+03 3.2e+02  1  1  1  1  1 100100100100100 52198
VecTDot              201 1.0 1.3848e-01 1.3 1.09e+07 1.0 0.0e+00 0.0e+00 2.0e+02  0  0  0  0  1  29 11  0  0 63 16930
VecNorm              102 1.0 4.7182e-02 1.5 5.51e+06 1.0 0.0e+00 0.0e+00 1.0e+02  0  0  0  0  0  10  5  0  0 32 25216
VecCopy                1 1.0 7.5817e-05 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               102 1.0 2.6131e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecAXPY              200 1.0 1.2963e-02 1.3 1.08e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   3 11  0  0  0 179961
VecAYPX              100 1.0 5.0817e-03 1.6 5.37e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  5  0  0  0 228384
VecScatterBegin      101 1.0 6.9609e-03 2.7 0.00e+00 0.0 1.1e+05 7.2e+03 0.0e+00  0  0  1  1  0   1  0 98100  0     0
VecScatterEnd        101 1.0 2.8235e-02 7.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
MatMult              101 1.0 1.0444e-01 1.3 3.55e+07 1.0 1.1e+05 7.2e+03 0.0e+00  0  0  1  1  0  20 34 98100  0 72945
MatSolve             101 1.0 8.1540e-02 1.2 3.44e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0  17 33  0  0  0 91020
MatLUFactorNum         1 1.0 5.0550e-03 3.1 5.65e+05 1.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 22675
MatILUFactorSym        1 1.0 2.3129e-03 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyBegin       2 1.0 1.1154e-0236.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
MatAssemblyEnd         2 1.0 4.6539e-03 1.1 0.00e+00 0.0 2.2e+03 1.8e+03 8.0e+00  0  0  0  0  0   1  0  2  0  3     0
MatGetRowIJ            1 1.0 8.1062e-06 8.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         1 1.0 2.6512e-04 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCSetUp                2 1.0 1.2755e-02 3.3 5.65e+05 1.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  1  0  0  0  8986
PCSetUpOnBlocks        1 1.0 7.0622e-03 2.2 5.65e+05 1.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  1  0  0  0 16230
PCApply              101 1.0 9.0092e-02 1.2 3.44e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0  18 33  0  0  0 82380
KSPSolve             100 1.0 2.9067e+01 1.0 1.02e+10 1.0 1.1e+07 7.2e+03 3.0e+04 98 99 99 99 99 100100100100100 75919
VecTDot            20100 1.0 9.0870e+00 1.3 1.09e+09 1.0 0.0e+00 0.0e+00 2.0e+04 27 11  0  0 66  28 11  0  0 66 25800
VecNorm            10200 1.0 2.8064e+00 1.2 5.51e+08 1.0 0.0e+00 0.0e+00 1.0e+04  9  5  0  0 33   9  5  0  0 34 42393
VecCopy              100 1.0 1.1604e-02 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet             10100 1.0 2.5848e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
VecAXPY            20000 1.0 1.3038e+00 1.3 1.08e+09 1.0 0.0e+00 0.0e+00 0.0e+00  4 10  0  0  0   4 11  0  0  0 178922
VecAYPX            10000 1.0 5.1897e-01 1.6 5.37e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  5  0  0  0   1  5  0  0  0 223631
VecScatterBegin    10100 1.0 7.0715e-01 2.5 0.00e+00 0.0 1.1e+07 7.2e+03 0.0e+00  2  0 99 99  0   2  0100100  0     0
VecScatterEnd      10100 1.0 1.2401e+00 2.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   3  0  0  0  0     0
MatMult            10100 1.0 9.1593e+00 1.2 3.55e+09 1.0 1.1e+07 7.2e+03 0.0e+00 28 34 99 99  0  29 35100100  0 83174
MatSolve           10100 1.0 7.4668e+00 1.1 3.44e+09 1.0 0.0e+00 0.0e+00 0.0e+00 24 33  0  0  0  24 34  0  0  0 99398
PCSetUpOnBlocks      100 1.0 2.2914e-0312.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCApply            10100 1.0 8.0915e+00 1.1 3.44e+09 1.0 0.0e+00 0.0e+00 0.0e+00 26 33  0  0  0  26 34  0  0  0 91724
              Viewer     1              0            0     0.
              Vector     7              1         1656     0.
              Matrix     4              0            0     0.
Average time for MPI_Barrier(): 1.07765e-05
Average time for zero size MPI_Send(): 5.81035e-06
-iterations 100
-ksp_max_it 100
-ksp_rtol 1E-6
-ksp_type cg
-log_view
-mesh_size 1E-4
-nodes_per_proc 30
mesh size: 0.0001
Time in solve():      92.6599 s
Time in KSPSolve():   92.6245 s (99.9617%)
./wstest on a intel-bdw-opt named bdw-0255 with 1728 processors, by jczhang Tue Jun 12 10:32:54 2018
Time (sec):           9.433e+01      1.00008   9.433e+01
Flop:                 1.034e+10      1.00537   1.033e+10  1.785e+13
Flop/sec:            1.096e+08      1.00543   1.095e+08  1.892e+11
MPI Messages:         6.123e+04      2.00000   5.613e+04  9.699e+07
MPI Message Lengths:  4.407e+08      2.00000   7.198e+03  6.981e+11
 0:      Main Stage: 1.6240e-01   0.2%  0.0000e+00   0.0%  1.901e+04   0.0%  1.802e+03        0.0%  1.700e+01   0.1%
 1:     First Solve: 1.5073e+00   1.6%  1.7764e+11   1.0%  9.789e+05   1.0%  7.095e+03        1.0%  3.190e+02   1.0%
 2: Remaining Solves: 9.2661e+01  98.2%  1.7670e+13  99.0%  9.599e+07  99.0%  7.200e+03       99.0%  3.030e+04  98.9%
Phase summary info:
VecSet                 2 1.0 1.4305e-04 5.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSidedF         2 1.0 1.8184e-02 8.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
KSPSetUp               2 1.0 9.9397e-04 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  0   0  0  0  0  2     0
KSPSolve               1 1.0 1.5071e+00 1.0 1.03e+08 1.0 9.8e+05 7.1e+03 3.2e+02  2  1  1  1  1 100100100100100 117873
VecTDot              201 1.0 6.6377e-01 1.1 1.09e+07 1.0 0.0e+00 0.0e+00 2.0e+02  1  0  0  0  1  43 11  0  0 63 28256
VecNormBarrier       102 1.0 1.8365e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0  11  0  0  0  0     0
VecNorm              102 1.0 1.8855e-01 1.2 5.51e+06 1.0 0.0e+00 0.0e+00 1.0e+02  0  0  0  0  0  12  5  0  0 32 50480
VecCopy                1 1.0 8.1062e-05 2.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               102 1.0 2.6536e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY              200 1.0 2.1202e-02 2.2 1.08e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1 11  0  0  0 880215
VecAYPX              100 1.0 1.2952e-02 4.4 5.37e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  5  0  0  0 716824
VecScatterBarrie     101 1.0 2.4745e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0  16  0  0  0  0     0
VecScatterBegin      101 1.0 1.7003e-02 5.3 0.00e+00 0.0 9.6e+05 7.2e+03 0.0e+00  0  0  1  1  0   0  0 98100  0     0
VecScatterEnd        101 1.0 2.4191e-02 6.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatMult              101 1.0 3.4479e-01 1.1 3.55e+07 1.0 9.6e+05 7.2e+03 0.0e+00  0  0  1  1  0  21 34 98100  0 177214
MatSolve             101 1.0 8.3888e-02 1.3 3.44e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   5 33  0  0  0 707780
MatLUFactorNum         1 1.0 7.0050e-03 4.3 5.65e+05 1.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 135051
MatILUFactorSym        1 1.0 2.3711e-03 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyBegin       2 1.0 1.8245e-02 7.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatAssemblyEnd         2 1.0 2.4878e-02 1.3 0.00e+00 0.0 1.9e+04 1.8e+03 8.0e+00  0  0  0  0  0   2  0  2  0  3     0
MatGetRowIJ            1 1.0 3.0041e-0531.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         1 1.0 3.9482e-04 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCSetUp                2 1.0 1.4109e-02 3.7 5.65e+05 1.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  1  0  0  0 67051
PCSetUpOnBlocks        1 1.0 8.9779e-03 2.9 5.65e+05 1.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 105373
PCApply              101 1.0 9.6632e-02 1.3 3.44e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   5 33  0  0  0 614442
KSPSolve             100 1.0 9.2634e+01 1.0 1.02e+10 1.0 9.6e+07 7.2e+03 3.0e+04 98 99 99 99 99 100100100100100 190747
VecTDot            20100 1.0 4.2454e+01 1.1 1.09e+09 1.0 0.0e+00 0.0e+00 2.0e+04 44 11  0  0 66  45 11  0  0 66 44178
VecNormBarrier     10200 1.0 1.1839e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 12  0  0  0  0  12  0  0  0  0     0
VecNorm            10200 1.0 8.3957e+00 1.0 5.51e+08 1.0 0.0e+00 0.0e+00 1.0e+04  9  5  0  0 33   9  5  0  0 34 113365
VecCopy              100 1.0 1.9274e-02 3.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet             10100 1.0 2.6170e-01 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY            20000 1.0 1.3767e+00 1.5 1.08e+09 1.0 0.0e+00 0.0e+00 0.0e+00  1 10  0  0  0   1 11  0  0  0 1355593
VecAYPX            10000 1.0 7.4878e-01 2.5 5.37e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  5  0  0  0   0  5  0  0  0 1239961
VecScatterBarrie   10100 1.0 1.2403e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 13  0  0  0  0  13  0  0  0  0     0
VecScatterBegin    10100 1.0 8.7978e-01 2.8 0.00e+00 0.0 9.6e+07 7.2e+03 0.0e+00  1  0 99 99  0   1  0100100  0     0
VecScatterEnd      10100 1.0 1.5403e+00 3.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatMult            10100 1.0 2.1855e+01 1.1 3.55e+09 1.0 9.6e+07 7.2e+03 0.0e+00 22 34 99 99  0  23 35100100  0 279576
MatSolve           10100 1.0 7.6917e+00 1.2 3.44e+09 1.0 0.0e+00 0.0e+00 0.0e+00  8 33  0  0  0   8 34  0  0  0 771924
PCSetUpOnBlocks      100 1.0 5.4588e-02218.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCApply            10100 1.0 8.3117e+00 1.1 3.44e+09 1.0 0.0e+00 0.0e+00 0.0e+00  8 33  0  0  0   8 34  0  0  0 714350
              Viewer     1              0            0     0.
              Vector     7              1         1656     0.
              Matrix     4              0            0     0.
Average time for MPI_Barrier(): 1.4782e-05
Average time for zero size MPI_Send(): 5.14062e-06
-iterations 100
-ksp_max_it 100
-ksp_rtol 1E-6
-ksp_type cg
-log_sync
-log_view
-mesh_size 1E-4
-nodes_per_proc 30
mesh size: 0.0001
Time in solve():      87.3816 s
Time in KSPSolve():   87.3319 s (99.9432%)
./wstest on a intel-bdw-opt named bdw-0521 with 1728 processors, by jczhang Tue Jun 12 09:55:23 2018
Time (sec):           8.886e+01      1.00020   8.886e+01
Flop/sec:            1.164e+08      1.00556   1.162e+08  2.009e+11
 0:      Main Stage: 1.4006e-01   0.2%  0.0000e+00   0.0%  1.901e+04   0.0%  1.802e+03        0.0%  1.700e+01   0.1%
 1:     First Solve: 1.3361e+00   1.5%  1.7764e+11   1.0%  9.789e+05   1.0%  7.095e+03        1.0%  3.190e+02   1.0%
 2: Remaining Solves: 8.7382e+01  98.3%  1.7670e+13  99.0%  9.599e+07  99.0%  7.200e+03       99.0%  3.030e+04  98.9%
Phase summary info:
VecSet                 2 1.0 1.4186e-04 5.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSidedF         2 1.0 2.6349e-02 2.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
KSPSetUp               2 1.0 8.3871e-0311.0 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  0   1  0  0  0  2     0
KSPSolve               1 1.0 1.3359e+00 1.0 1.03e+08 1.0 9.8e+05 7.1e+03 3.2e+02  2  1  1  1  1 100100100100100 132978
VecTDot              201 1.0 8.2208e-01 1.1 1.09e+07 1.0 0.0e+00 0.0e+00 2.0e+02  1  0  0  0  1  60 11  0  0 63 22814
VecNorm              102 1.0 2.4688e-01 1.1 5.51e+06 1.0 0.0e+00 0.0e+00 1.0e+02  0  0  0  0  0  17  5  0  0 32 38552
VecCopy                1 1.0 1.8883e-04 5.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               102 1.0 2.9655e-03 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY              200 1.0 2.1235e-02 2.3 1.08e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1 11  0  0  0 878832
VecAYPX              100 1.0 2.1644e-02 7.5 5.37e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  5  0  0  0 428973
VecScatterBegin      101 1.0 1.7088e-02 6.0 0.00e+00 0.0 9.6e+05 7.2e+03 0.0e+00  0  0  1  1  0   0  0 98100  0     0
VecScatterEnd        101 1.0 3.3919e-02 7.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatMult              101 1.0 1.1378e-01 1.4 3.55e+07 1.0 9.6e+05 7.2e+03 0.0e+00  0  0  1  1  0   7 34 98100  0 537005
MatSolve             101 1.0 9.4168e-02 1.5 3.44e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   5 33  0  0  0 630513
MatLUFactorNum         1 1.0 7.2019e-03 4.5 5.65e+05 1.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 131358
MatILUFactorSym        1 1.0 2.3780e-03 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyBegin       2 1.0 2.6405e-02 2.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatAssemblyEnd         2 1.0 2.9236e-02 1.2 0.00e+00 0.0 1.9e+04 1.8e+03 8.0e+00  0  0  0  0  0   2  0  2  0  3     0
MatGetRowIJ            1 1.0 2.0981e-0522.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         1 1.0 2.5988e-04 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCSetUp                2 1.0 1.3383e-02 3.5 5.65e+05 1.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  1  0  0  0 70690
PCSetUpOnBlocks        1 1.0 8.7321e-03 2.8 5.65e+05 1.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 108340
PCApply              101 1.0 1.0021e-01 1.4 3.44e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   6 33  0  0  0 592485
KSPSolve             100 1.0 8.7357e+01 1.0 1.02e+10 1.0 9.6e+07 7.2e+03 3.0e+04 98 99 99 99 99 100100100100100 202269
VecTDot            20100 1.0 5.4682e+01 1.1 1.09e+09 1.0 0.0e+00 0.0e+00 2.0e+04 60 11  0  0 66  61 11  0  0 66 34299
VecNorm            10200 1.0 1.7258e+01 1.2 5.51e+08 1.0 0.0e+00 0.0e+00 1.0e+04 17  5  0  0 33  17  5  0  0 34 55150
VecCopy              100 1.0 1.1919e-02 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet             10100 1.0 4.0643e-01 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY            20000 1.0 1.4651e+00 1.6 1.08e+09 1.0 0.0e+00 0.0e+00 0.0e+00  1 10  0  0  0   1 11  0  0  0 1273800
VecAYPX            10000 1.0 5.7149e-01 1.9 5.37e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  5  0  0  0   0  5  0  0  0 1624624
VecScatterBegin    10100 1.0 8.3204e-01 2.8 0.00e+00 0.0 9.6e+07 7.2e+03 0.0e+00  1  0 99 99  0   1  0100100  0     0
VecScatterEnd      10100 1.0 2.8371e+00 5.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatMult            10100 1.0 1.0399e+01 1.3 3.55e+09 1.0 9.6e+07 7.2e+03 0.0e+00 10 34 99 99  0  10 35100100  0 587563
MatSolve           10100 1.0 7.7816e+00 1.2 3.44e+09 1.0 0.0e+00 0.0e+00 0.0e+00  8 33  0  0  0   8 34  0  0  0 763013
PCSetUpOnBlocks      100 1.0 2.7120e-0312.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCApply            10100 1.0 9.1625e+00 1.3 3.44e+09 1.0 0.0e+00 0.0e+00 0.0e+00  9 33  0  0  0   9 34  0  0  0 648014
              Viewer     1              0            0     0.
              Vector     7              1         1656     0.
              Matrix     4              0            0     0.
Average time for MPI_Barrier(): 1.92165e-05
Average time for zero size MPI_Send(): 7.10013e-06
-iterations 100
-ksp_max_it 100
-ksp_rtol 1E-6
-ksp_type cg
-log_view
-mesh_size 1E-4
-nodes_per_proc 30
