[petsc-dev] Bad scaling of GAMG in FieldSplit
Jed Brown jed at jedbrown.org
Thu Jul 26 13:43:34 CDT 2018
Matthew Knepley <knepley at gmail.com> writes:
> On Thu, Jul 26, 2018 at 12:56 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>> On Thu, Jul 26, 2018 at 10:35 AM, Junchao Zhang <jczhang at mcs.anl.gov>
>> wrote:
>>> On Thu, Jul 26, 2018 at 11:15 AM, Fande Kong <fdkong.jd at gmail.com> wrote:
>>>> On Thu, Jul 26, 2018 at 9:51 AM, Junchao Zhang <jczhang at mcs.anl.gov>
>>>> wrote:
>>>>> Hi, Pierre,
>>>>>   From your log_view files, I see you did strong scaling. You used 4X
>>>>> more cores, but the execution time only dropped from 3.9143e+04
>>>>> to 1.6910e+04.
>>>>>   From my previous analysis of a GAMG weak scaling test, it looks
>>>>> communication is one of the reasons that caused poor scaling.  In your
>>>>> case,  VecScatterEnd time was doubled from 1.5575e+03 to 3.2413e+03. Its
>>>>> time percent jumped from 1% to 17%. This time can contribute to the big
>>>>> time ratio in MatMultAdd ant MatMultTranspose, misleading you guys thinking
>>>>> there was load-imbalance computation-wise.
>>>>>   The reason is that I found in the interpolation and restriction
>>>>> phases of gamg, the communication pattern is very bad. Few processes
>>>>> communicate with hundreds of neighbors with message sizes of a few bytes.
>>>> We may need to truncate interpolation/restriction operators. Also do
>>>> some aggressive coarsening.  Unfortunately, GAMG currently does not support.
>>>  Are these gamg options the truncation you thought?
>>> -pc_gamg_threshold[] <thresh,default=0> - Before aggregating the graph
>>> GAMG will remove small values from the graph on each level
>>> -pc_gamg_threshold_scale <scale,default=1> - Scaling of threshold on each
>>> coarser grid if not specified
>> Nope.  Totally different things.
> Well, you could use _threshold to do more aggressive coarsening, but not
> for thinning out
> the interpolation.
Increasing the threshold results in slower coarsening.
Note that square_graph 10 is very unusual.
> There are some simple filters we might be able to use (Luke Olson
> talked about it today), but Mark is the expert.
>    Matt
>> Fande
>>>> Fande,
>>>>> If we can avoid this pattern algorithmically (which I don't know), or
>>>>> find ways with faster communication (which I am working), then we can get
>>>>> better scalability.
>>>>> --Junchao Zhang
>>>>> On Thu, Jul 26, 2018 at 10:02 AM, Pierre Jolivet <
>>>>> pierre.jolivet at enseeiht.fr> wrote:
>>>>>> > On 26 Jul 2018, at 4:24 PM, Karl Rupp <rupp at iue.tuwien.ac.at> wrote:
>>>>>> > Hi Pierre,
>>>>>> >> I’m using GAMG on a shifted Laplacian with these options:
>>>>>> >> -st_fieldsplit_pressure_ksp_type preonly
>>>>>> >> -st_fieldsplit_pressure_pc_composite_type additive
>>>>>> >> -st_fieldsplit_pressure_pc_type composite
>>>>>> >> -st_fieldsplit_pressure_sub_0_ksp_pc_type jacobi
>>>>>> >> -st_fieldsplit_pressure_sub_0_pc_type ksp
>>>>>> >> -st_fieldsplit_pressure_sub_1_ksp_pc_gamg_square_graph 10
>>>>>> >> -st_fieldsplit_pressure_sub_1_ksp_pc_type gamg
>>>>>> >> -st_fieldsplit_pressure_sub_1_pc_type ksp
>>>>>> >> and I end up with the following logs on 512 (top) and 2048 (bottom)
>>>>>> processes:
>>>>>> >> MatMult          1577790 1.0 3.1967e+03 1.2 4.48e+12 1.6 7.6e+09
>>>>>> 5.6e+03 0.0e+00  7 71 75 63  0   7 71 75 63  0 650501
>>>>>> >> MatMultAdd        204786 1.0 1.3412e+02 5.5 1.50e+10 1.7 5.5e+08
>>>>>> 2.7e+02 0.0e+00  0  0  5  0  0   0  0  5  0  0 50762
>>>>>> >> MatMultTranspose  204786 1.0 4.6790e+01 4.3 1.50e+10 1.7 5.5e+08
>>>>>> 2.7e+02 0.0e+00  0  0  5  0  0   0  0  5  0  0 145505
>>>>>> >> KSPSolve_FS_3       7286 1.0 7.5506e+02 1.0 9.14e+11 1.8 7.3e+09
>>>>>> 1.5e+03 2.6e+05  2 14 71 16 34   2 14 71 16 34 539009
>>>>>> >> MatMult          1778795 1.0 3.5511e+03 4.1 1.46e+12 1.9 4.0e+10
>>>>>> 2.4e+03 0.0e+00  7 66 75 61  0   7 66 75 61  0 728371
>>>>>> >> MatMultAdd        222360 1.0 2.5904e+0348.0 4.31e+09 1.9 2.4e+09
>>>>>> 1.3e+02 0.0e+00 14  0  4  0  0  14  0  4  0  0  2872
>>>>>> >> MatMultTranspose  222360 1.0 1.8736e+03421.8 4.31e+09 1.9 2.4e+09
>>>>>> 1.3e+02 0.0e+00  0  0  4  0  0   0  0  4  0  0  3970
>>>>>> >> KSPSolve_FS_3       7412 1.0 2.8939e+03 1.0 2.66e+11 2.1 3.5e+10
>>>>>> 6.1e+02 2.7e+05 17 11 67 14 28  17 11 67 14 28 148175
>>>>>> >> MatMultAdd and MatMultTranspose (performed by GAMG) somehow ruin
>>>>>> the scalability of the overall solver. The pressure space “only” has 3M
>>>>>> unknowns so I’m guessing that’s why GAMG is having a hard time strong
>>>>>> scaling.
>>>>>> > 3M unknowns divided by 512 processes implies less than 10k unknowns
>>>>>> per process. It is not unusual to see strong scaling roll off at this size.
>>>>>> Also note that the time per call(!) for "MatMult" is the same for both
>>>>>> cases, indicating that your run into a latency-limited regime.
>>>>>> > Also, have a look at the time ratios: With 2048 processes,
>>>>>> MatMultAdd and MatMultTranspose show a time ratio of 48 and 421,
>>>>>> respectively. Maybe one of your MPI ranks is getting a huge workload?
>>>>>> Maybe inside GAMG itself (how could I check this?), but since the
>>>>>> timing and ratio of the MatMult look OK and the distribution of the
>>>>>> pressure space is the same as the other three fields, I’m guessing this
>>>>>> does not come from my global Mat, but I may be wrong.
>>>>>> >> For the other fields, the matrix is somehow distributed nicely,
>>>>>> i.e., I don’t want to change the overall distribution of the matrix.
>>>>>> >> Do you have any suggestion to improve the performance of GAMG in
>>>>>> that scenario? I had two ideas in mind but please correct me if I’m wrong
>>>>>> or if this is not doable:
>>>>>> >> 1) before setting up GAMG, first use a PCTELESCOPE to avoid having
>>>>>> too many processes work on this small problem
>>>>>> >> 2) have the sub_0_ and the sub_1_ work on two different
>>>>>> nonoverlapping communicators of size PETSC_COMM_WORLD/2, do the solve
>>>>>> concurrently, and then sum the solutions (only worth doing because of
>>>>>> -pc_composite_type additive). I have no idea if this easily doable with
>>>>>> PETSc command line arguments
>>>>>> > 1) is the more flexible approach, as you have better control over
>>>>>> the system sizes after 'telescoping’.
>>>>>> Right, but the advantage of 2) is that I wouldn't have one half or
>>>>>> more of processes idling and I could overlap the solves of both subpc in
>>>>>> the PCCOMPOSITE.
>>>>>> I’m attaching the -log_view for both runs (I trimmed some options).
>>>>>> Thanks for your help,
>>>>>> Pierre
>>>>>> > Best regards,
>>>>>> > Karli
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
