[petsc-dev] Bad scaling of GAMG in FieldSplit
Fande Kong
fdkong.jd at gmail.com
Thu Jul 26 11:15:37 CDT 2018
On Thu, Jul 26, 2018 at 9:51 AM, Junchao Zhang <jczhang at mcs.anl.gov> wrote:
> Hi, Pierre,
> From your log_view files, I see you did strong scaling. You used 4X more
> cores, but the execution time only dropped from 3.9143e+04 to 1.6910e+04.
> From my previous analysis of a GAMG weak scaling test, it looks
> communication is one of the reasons that caused poor scaling. In your
> case, VecScatterEnd time was doubled from 1.5575e+03 to 3.2413e+03. Its
> time percent jumped from 1% to 17%. This time can contribute to the big
> time ratio in MatMultAdd ant MatMultTranspose, misleading you guys thinking
> there was load-imbalance computation-wise.
> The reason is that I found in the interpolation and restriction phases
> of gamg, the communication pattern is very bad. Few processes communicate
> with hundreds of neighbors with message sizes of a few bytes.
We may need to truncate interpolation/restriction operators. Also do some
aggressive coarsening. Unfortunately, GAMG currently does not support.
Fande,
> If we can avoid this pattern algorithmically (which I don't know), or find
> ways with faster communication (which I am working), then we can get better
> scalability.
> --Junchao Zhang
> On Thu, Jul 26, 2018 at 10:02 AM, Pierre Jolivet <
> pierre.jolivet at enseeiht.fr> wrote:
>> > On 26 Jul 2018, at 4:24 PM, Karl Rupp <rupp at iue.tuwien.ac.at> wrote:
>> > Hi Pierre,
>> >> I’m using GAMG on a shifted Laplacian with these options:
>> >> -st_fieldsplit_pressure_ksp_type preonly
>> >> -st_fieldsplit_pressure_pc_composite_type additive
>> >> -st_fieldsplit_pressure_pc_type composite
>> >> -st_fieldsplit_pressure_sub_0_ksp_pc_type jacobi
>> >> -st_fieldsplit_pressure_sub_0_pc_type ksp
>> >> -st_fieldsplit_pressure_sub_1_ksp_pc_gamg_square_graph 10
>> >> -st_fieldsplit_pressure_sub_1_ksp_pc_type gamg
>> >> -st_fieldsplit_pressure_sub_1_pc_type ksp
>> >> and I end up with the following logs on 512 (top) and 2048 (bottom)
>> processes:
>> >> MatMult 1577790 1.0 3.1967e+03 1.2 4.48e+12 1.6 7.6e+09
>> 5.6e+03 0.0e+00 7 71 75 63 0 7 71 75 63 0 650501
>> >> MatMultAdd 204786 1.0 1.3412e+02 5.5 1.50e+10 1.7 5.5e+08
>> 2.7e+02 0.0e+00 0 0 5 0 0 0 0 5 0 0 50762
>> >> MatMultTranspose 204786 1.0 4.6790e+01 4.3 1.50e+10 1.7 5.5e+08
>> 2.7e+02 0.0e+00 0 0 5 0 0 0 0 5 0 0 145505
>> >> KSPSolve_FS_3 7286 1.0 7.5506e+02 1.0 9.14e+11 1.8 7.3e+09
>> 1.5e+03 2.6e+05 2 14 71 16 34 2 14 71 16 34 539009
>> >> MatMult 1778795 1.0 3.5511e+03 4.1 1.46e+12 1.9 4.0e+10
>> 2.4e+03 0.0e+00 7 66 75 61 0 7 66 75 61 0 728371
>> >> MatMultAdd 222360 1.0 2.5904e+0348.0 4.31e+09 1.9 2.4e+09
>> 1.3e+02 0.0e+00 14 0 4 0 0 14 0 4 0 0 2872
>> >> MatMultTranspose 222360 1.0 1.8736e+03421.8 4.31e+09 1.9 2.4e+09
>> 1.3e+02 0.0e+00 0 0 4 0 0 0 0 4 0 0 3970
>> >> KSPSolve_FS_3 7412 1.0 2.8939e+03 1.0 2.66e+11 2.1 3.5e+10
>> 6.1e+02 2.7e+05 17 11 67 14 28 17 11 67 14 28 148175
>> >> MatMultAdd and MatMultTranspose (performed by GAMG) somehow ruin the
>> scalability of the overall solver. The pressure space “only” has 3M
>> unknowns so I’m guessing that’s why GAMG is having a hard time strong
>> scaling.
>> > 3M unknowns divided by 512 processes implies less than 10k unknowns per
>> process. It is not unusual to see strong scaling roll off at this size.
>> Also note that the time per call(!) for "MatMult" is the same for both
>> cases, indicating that your run into a latency-limited regime.
>> > Also, have a look at the time ratios: With 2048 processes, MatMultAdd
>> and MatMultTranspose show a time ratio of 48 and 421, respectively. Maybe
>> one of your MPI ranks is getting a huge workload?
>> Maybe inside GAMG itself (how could I check this?), but since the timing
>> and ratio of the MatMult look OK and the distribution of the pressure space
>> is the same as the other three fields, I’m guessing this does not come from
>> my global Mat, but I may be wrong.
>> >> For the other fields, the matrix is somehow distributed nicely, i.e.,
>> I don’t want to change the overall distribution of the matrix.
>> >> Do you have any suggestion to improve the performance of GAMG in that
>> scenario? I had two ideas in mind but please correct me if I’m wrong or if
>> this is not doable:
>> >> 1) before setting up GAMG, first use a PCTELESCOPE to avoid having too
>> many processes work on this small problem
>> >> 2) have the sub_0_ and the sub_1_ work on two different nonoverlapping
>> communicators of size PETSC_COMM_WORLD/2, do the solve concurrently, and
>> then sum the solutions (only worth doing because of -pc_composite_type
>> additive). I have no idea if this easily doable with PETSc command line
>> arguments
>> > 1) is the more flexible approach, as you have better control over the
>> system sizes after 'telescoping’.
>> Right, but the advantage of 2) is that I wouldn't have one half or more
>> of processes idling and I could overlap the solves of both subpc in the
>> PCCOMPOSITE.
>> I’m attaching the -log_view for both runs (I trimmed some options).
>> Thanks for your help,
>> Pierre
>> > Best regards,
>> > Karli
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180726/028083ff/attachment.html>
