[petsc-dev] Checkpoint-restart with DMPlex objects
Lawrence Mitchell
wence at gmx.li
Fri Jul 20 04:33:57 CDT 2018
Dear petsc-dev,
I'm once again revisiting doing "proper" checkpoint-restart cycles. I would like to leverage the existing PETSc stuff for this as much as possible, but I am a bit lost as to what is implemented, and what is missing.
I have:
- A (distributed) DMPlex defining the topology
- Some number of fields defined on this topology, each described by:
- a Section (with a point permutation set)
- a Vec of coefficients
- Some extra information that describes what the coefficients mean, but let's assume I know how to handle that.
(Aside, for Vecs with a block size > 1, I actually have a section that indexes the blocks, which probably means I need to unroll into an unblocked version first).
I would like:
- To be able to dump the DMPlex, and fields, on N processes
- To be able to load the DMPlex, and fields, on P processes. In the first instance, to get things going, I am happy if P=1.
For dumping, I think I can do DMView(dm) in PETSc "native" format, and that will write out the topology in a global numbering.
For the field coefficients, I can just VecView(vec). But there does not appear to be any way of saving the Section so that I can actually attach those coefficients to points in the mesh.
I can do PetscSectionCreateGlobalSection(section), so that I have a the global numbering for offsets, but presumably for the point numbering, I need to convert the local chart into global point numbers using DMPlexCreatePointNumbering?
For load, I can do DMLoad(dm), which only loads on rank-0 for now. Then VecLoad for the coefficients, and (presumably) a putative PetscSectionLoad so that I can associate coefficients to points in the topology.
So it feels like the crucial part of this is a native (HDF5) based viewing for PetscSection.
For each section (I'm ignoring fields, because those are just sections anyway), there are two explicit, and one implicit, pieces of information:
1. The number of dofs per point
2. The offset of the dof (this is the global numbering)
3 (implicit). The association of the local chart numbering to the global chart.
Saving the first two is easy, how best to save the last so that I can load easily. My thought is to, for each point in the section chart, save a three-tuple: (global-point-number, dofs-per-point, global-dof-number)
Then, I can easily read this data in and correctly map from the on-disk coefficients into any section I might have built on the newly loaded DM.
Does this all sound reasonable? Or have I missed either an existing implementation, or other issues?
Cheers,
Lawrence
