[petsc-dev] PETSc goes Jenkins
Patrick Sanan
patrick.sanan at gmail.com
Fri Jul 20 02:47:11 CDT 2018
This is super cool - thanks Alp and Karl!
Once tuning is complete, how is one intended to interpret the nice green
check marks? "The library compiles" or "All the tests passed"?
I ask because in the demo PR there is the reassuring check mark and "3 of 3
builds passed", even though failed tests are reported (timeouts).
2018-07-20 3:35 GMT+02:00 Karl Rupp <rupp at iue.tuwien.ac.at>:
> Hi all,
> we now have a first step towards full continuous integration via Jenkins
> completed. Thus, every new pull request that is (re-)based on a commit in
> master not older than today will be automatically tested with a subset of
> common tests that are intended to expose the most frequent issues. This, in
> particular, includes configurations with 64 bit integers as well as complex
> arithmetic.
> The integration of Jenkins into Bitbucket is smooth: You will notice on
> our demo pull request
> https://bitbucket.org/petsc/petsc/pull-requests/1039/jenkins
> file-for-build-pipelines-tied-to/diff
> that on the right it says "3 of 3 builds passed". If you click on the
> link, you will get further details on the individual builds and find
> further links to the test output stored on the Jenkins server.
> Implications on our development workflow: Currently 'next' gets (ab)used
> for all kinds of portability tests. As a consequence, every buggy merge
> clogs the whole integration pipeline, making it hard to integrate other
> PRs. With the Jenkins server in place, all pull requests will receive a
> good share of portability testing *before* they reach next. This reduces
> the burden on next, (hopefully) leading to faster code integration.
> Corollary: I strongly encourage all PETSc developers to use issue pull
> requests rather than merging to next directly (use your own judgment for
> exceptions!).
> Please note that we are still fine-tuning various aspects of the Jenkins
> infrastructure (location of the Jenkins server, which test nodes to use,
> which configurations to test, etc.). Most of these things are changes under
> the hood, though. If something still bubbles up and causes the testing to
> choke, please be considerate with us ;-)
> Finally, I'd like to explicitly thank Alp Dener for his help on getting
> Jenkins to run smoothly. Any credit should go to him.
> Best regards,
> Karli
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180720/bd775323/attachment.html>
