[petsc-dev] Should we replace hypre PILUT with hypre Euclid?
    Fande Kong
    fdkong.jd at gmail.com
    Tue Jul 17 14:21:53 CDT 2018
On Tue, Jul 17, 2018 at 12:58 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Jul 17, 2018 at 2:55 PM Jed Brown <jed at jedbrown.org> wrote:
>> PETSc had a Euclid interface until Barry removed it.
>> https://bitbucket.org/petsc/petsc/commits/22b6d1ca80e4f79123036fb6afd7eb
>> 4463b3692a
>> See also
>> https://www.mail-archive.com/petsc-users@mcs.anl.gov/msg33196.html
> I would also add that it is considerate of Hypre to have such a terrible
> ILUT implementation
> because it reminds you that you should never ever ever use ILUT.
So in theory, can we have a much better implementation? From my
understanding, algorithm itself is not suitable for parallel computation,
and it might not be a implementation problem only.
Fande,
>   Matt
>> Fande Kong <fdkong.jd at gmail.com> writes:
>> > Hi Developers,
>> > The hypre user manual  has this statement (page 63):
>> > "Note: this code is no longer supported by the hypre team. We recommend
>> to
>> > use Euclid instead,
>> > which is more versatile and in general more efficient, especially when
>> used
>> > with many processors."
>> > https://computation.llnl.gov/sites/default/files/public/
>> hypre-2.11.2_usr_manual.pdf
>> > It may be a good idea to upgrade PETSc interface to use Euclid instead
>> of
>> > PILUT??
>> > Fande,
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180717/b79df735/attachment.html>
