[petsc-dev] PetscSF and/or VecScatter with device pointers
Jed Brown jed at jedbrown.org
Thu Jul 12 16:08:28 CDT 2018
Matthew Knepley <knepley at gmail.com> writes:
> On Thu, Jul 12, 2018 at 6:47 AM Lawrence Mitchell <
> lawrence.mitchell at imperial.ac.uk> wrote:
>> Dear petsc-dev,
>> we're starting to explore (with Andreas cc'd) residual assembly on
>> GPUs.  The question naturally arises: how to do GlobalToLocal and
>> LocalToGlobal.
> There is not a lot of Mem Band difference between a GPU and a Skylake, but
> I assume this is
> to use hardware already purchased by some center.
Skylake Xeon is around 100 GB/s per socket, versus a V100 at about 750
GB/s.  That's nothing to sneeze at, but moving the entire vector to the
host just to pack messages is a much bigger hit for large subdomains
because the entire volume needs to move over PCI-Express.
>> I have:
>> A PetscSF describing the communication pattern.
>> A Vec holding the data to communicate.  This will have an up-to-date
>> device pointer.
>> I would like:
>> PetscSFBcastBegin/End (and ReduceBegin/End, etc...) to (optionally)
>> work with raw device pointers.  I am led to believe that modern MPIs
>> can plug directly into device memory, so I would like to avoid copying
>> data to the host, doing the communication there, and then going back
>> up to the device.
>> Given that I think that the window implementation (which just
>> delegates the MPI for all the packing) is not considered prime time
>> (mostly due to MPI implementation bugs, I think), I think this means
>> implementing a version of PetscSF_Basic that can handle the
>> pack/unpack directly on the device, and then just hands off to MPI.
> I think that is the case.
I doubt GPU Direct can give high performance for the derived data types
that the SF Window implementation uses (if it works at all).
>> The next thing is how to put a higher-level interface on top of this.
>> What, if any, suggestions are there for doing something where the
>> top-level API is agnostic to whether the data are on the host or the
>> device.
>> We had thought something like:
>> - Make PetscSF handle device pointers (possibly with new implementation?)
>> - Make VecScatter use SF.
> Yep, this is what I would do.
Agreed.
>> Calling VecScatterBegin/End on a Vec with up-to-date device pointers
>> just uses the SF directly.
>> Have there been any thoughts about how you want to do multi-GPU
>> interaction?
With MPI-parallel code, I don't see a compelling reason to support
multiple devices per MPI process.
> I don't think so, but Karl could reply if there has been.
> How are you doing local assembly?
>    Matt
>> Cheers,
>> Lawrence
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
