[petsc-dev] GAMG error with MKL
Jeff Hammond
jeff.science at gmail.com
Tue Jul 10 13:30:46 CDT 2018
On Tue, Jul 10, 2018 at 9:33 AM, Jed Brown <jed at jedbrown.org> wrote:
> Mark Adams <mfadams at lbl.gov> writes:
> > On Mon, Jul 9, 2018 at 7:19 PM Jeff Hammond <jeff.science at gmail.com>
> wrote:
> >> On Mon, Jul 9, 2018 at 7:38 AM, Mark Adams <mfadams at lbl.gov> wrote:
> >>> I agree with Matt's comment and let me add (somewhat redundantly)
> >>>> This isn't how you'd write MPI, is it? No, you'd figure out how to
> >>>> decompose your data properly to exploit locality and then implement an
> >>>> algorithm that minimizes communication and synchronization. Do that
> with
> >>>> OpenMP.
> >>> I have never seen a DOE app that does this correct, get you data model
> >>> figured out first, then implement.
> >> Chris Kerr's weather code (GFDL Hiram) has a single OpenMP parallel
> >> region. He was at the last NERSC workshop I attended. You should talk
> to
> >> him.
> > He is the last person I need to talk to :) but I wish my fusion
> colleagues
> > had walked down the road and talked with him 10 years ago.
> I don't know if Chris has ever lived there. And he's great, but GFDL is
> an application, not a library.
> Jeff, let us know when MKL can be called collectively from within an omp
> parallel region.
It can be called like that already, although I expect it to serialize by
default to avoid nested parallelism. You can always do something like the
following, which may benefit from KMP_HOT_TEAMS_MODE=1.
mkl_foo_wrapper(ARGS)
if (omp_in_parallel()) {
#pragma omp master
mkl_set_num_threads(omp_get_num_threads());
mkl_foo(ARGS);
} else {
mkl_foo(ARGS);
Of course, the right solution is for MKL to have entry points that don't
create a parallel region. We have discussed this but it's not clear how
important it is. What MKL functions would you like to support this
interface? "All of them" is not going to be productive for either of us.
Jeff
Jeff Hammond
http://jeffhammond.github.io/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180710/6b44f622/attachment.html>
