[petsc-dev] GAMG error with MKL
Richard Tran Mills rtmills at anl.gov
Tue Jul 10 13:27:32 CDT 2018
On Mon, Jul 9, 2018 at 10:04 AM, Jed Brown <jed at jedbrown.org> wrote:
> Jeff Hammond <jeff.science at gmail.com> writes:
> > This is the textbook Wrong Way to write OpenMP and the reason that the
> > thread-scalability of DOE applications using MPI+OpenMP sucks.  It leads
> to
> > codes that do fork-join far too often and suffer from death by Amdahl,
> > unless you do a second pass where you fuse all the OpenMP regions and
> > replace the serial regions between them with critical sections or
> similar.
> > This isn't how you'd write MPI, is it?  No, you'd figure out how to
> > decompose your data properly to exploit locality and then implement an
> > algorithm that minimizes communication and synchronization.  Do that with
> > OpenMP.
> The applications that would call PETSc do not do this decomposition and
> the OpenMP programming model does not provide a "communicator" or
> similar abstraction to associate the work done by the various threads.
> It's all implicit.
This is perhaps the biggest single reason that I hate OpenMP.
--Richard
The idea with PETSc's threadcomm was to provide an
> object for this, but nobody wanted to call PETSc that way.  It's clear
> that applications using OpenMP are almost exclusively interested in its
> incrementalism, not in doing it right.  It's also pretty clear that the
> OpenMP forum agrees, otherwise they would be providing abstractions for
> performing collective operations across module boundaries within a
> parallel region.
> So the practical solution is to use OpenMP the way everyone else does,
> even if the performance is not good, because at least it works with the
> programming model the application has chosen.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180710/372a1d55/attachment.html>
