[petsc-dev] GAMG error with MKL
Smith, Barry F.
bsmith at mcs.anl.gov
Mon Jul 9 13:43:24 CDT 2018
> On Jul 9, 2018, at 12:04 PM, Jed Brown <jed at jedbrown.org> wrote:
> Jeff Hammond <jeff.science at gmail.com> writes:
>> This is the textbook Wrong Way to write OpenMP and the reason that the
>> thread-scalability of DOE applications using MPI+OpenMP sucks. It leads to
>> codes that do fork-join far too often and suffer from death by Amdahl,
>> unless you do a second pass where you fuse all the OpenMP regions and
>> replace the serial regions between them with critical sections or similar.
>> This isn't how you'd write MPI, is it? No, you'd figure out how to
>> decompose your data properly to exploit locality and then implement an
>> algorithm that minimizes communication and synchronization. Do that with
>> OpenMP.
> The applications that would call PETSc do not do this decomposition and
> the OpenMP programming model does not provide a "communicator" or
> similar abstraction to associate the work done by the various threads.
> It's all implicit. The idea with PETSc's threadcomm was to provide an
> object for this, but nobody wanted to call PETSc that way. It's clear
> that applications using OpenMP are almost exclusively interested in its
> incrementalism, not in doing it right. It's also pretty clear that the
> OpenMP forum agrees, otherwise they would be providing abstractions for
> performing collective operations across module boundaries within a
> parallel region.
> So the practical solution is to use OpenMP the way everyone else does,
> even if the performance is not good, because at least it works with the
> programming model the application has chosen.
Yes. Run the application using OpenMP with profiling and then chuck a few #pragma into the PETSc code where profiling indicates performance may be improved, note the improvement. Also be sure there is a way to configure or run the program with and without the OpenMP pragmas being turned on.
Barry
