[petsc-dev] titan
    Mark Adams
    mfadams at lbl.gov
    Fri Jul  6 18:19:18 CDT 2018
Todd, I've been building PETSc on Titan and SUMMIT for users. cray-petsc
has been hosed for a while. I put my most recent configure file in:
/ccs/proj/env003/arch-titan-opt64idx-pgi.py
This is a public space. My builds are here also. You run with, for instance,
make PETSC_DIR=/ccs/proj/env003/petscv3.9-opt64-pgi PETSC_ARCH=""
There are several other builds in there that you can use. I now see that I
don't have the machine name in the directory name, yuck. But this and a
v3.7 version are recent and work (on Titan).
On Fri, Jul 6, 2018 at 6:47 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>    I know Mark Adams has tried recently; without limited success.
>    As always the big problem is facilities removing accounts, such as
> Satish's, so testing gets difficult.
>    But yes, we want to support Titan so have users send
> configure.log/make.log to petsc-maint at mcs.anl.gov
>    Barry
> > On Jul 6, 2018, at 12:45 PM, Munson, Todd <tmunson at mcs.anl.gov> wrote:
> > Barry,
> > Have you tested petsc compilation on titan?  Is there a config example
> > for that machine?
> > Apparently titan died and when they brought it back up, the petsc install
> > was fracked, so some ORNL users are trying to compile petsc locally
> > rather than wait for the facilities people.
> > Thanks, Todd
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180706/1157975c/attachment.html>
