[petsc-dev] My configure is non-working again because of CMake
    Satish Balay
    balay at mcs.anl.gov
    Fri Jul  6 11:18:50 CDT 2018
On Fri, 6 Jul 2018, Satish Balay wrote:
> On Thu, 5 Jul 2018, Matthew Knepley wrote:
> > On Thu, Jul 5, 2018 at 5:45 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > > Can you try the following and see if it works for you
> > > ./configure PETSC_ARCH=arch-cmake-test --with-mpi=0 --with-sowing=0
> > > --with-fc=0 --download-cmake=
> > > https://cmake.org/files/v3.9/cmake-3.9.1.tar.gz
> > Yes, that worked. We can move back to that one if we want.
> Ok - I have the revert in balay/workarround-cmake-cxx11/maint
> Mark, Can you also confirm this work for you on titan?
Hm - I did'nt check this properly - there is also 3.9.6 - which should be preferable. Will update to that and check..
Satish
