[petsc-dev] Remove legacy tests?
    Jose E. Roman
    jroman at dsic.upv.es
    Fri Jul  6 02:44:08 CDT 2018
Well, if you want to remove it, I can just insert ${PETSC_DIR}/lib/petsc/conf/test in SLEPc's repository, so not a big problem.
> El 6 jul 2018, a las 7:46, Jose E. Roman <jroman at dsic.upv.es> escribió:
> SLEPc still uses the legacy test system. I have not had time to move to the new test harness.
> Jose
>> El 6 jul 2018, a las 2:42, Smith, Barry F. <bsmith at mcs.anl.gov> escribió:
>>> On Jul 5, 2018, at 5:36 PM, Jed Brown <jed at jedbrown.org> wrote:
>>> When can we delete the legacy test system?  Are we currently using it
>>> anywhere?
>> Make test currently requires the test include file
>>  Barry
