[petsc-dev] Remove legacy tests?
Thu Jul 5 18:12:58 CDT 2018
On Thu, Jul 5, 2018 at 6:07 PM Satish Balay <balay at mcs.anl.gov> wrote:
> Ok - there is some confusion here.
> The test harness does not use targets in
> examples/[tests,tutorials]/makefile.
> However we want to keep the functionality of us/users compiling
> individual examples manually - without going through the test harness.
> i.e the following should continue to work:
> cd src/ksp/ksp/examples/tutorials
> make ex2
I believe that only relies on
  a) Having compile targets, or a generic example compile target
  b) the compile rules in the toplevel makefiles
I do not think Jed objects to either.
   Matt
> On Thu, 5 Jul 2018, Jed Brown wrote:
> > Satish Balay <balay at mcs.anl.gov> writes:
> > >> When can we delete the legacy test system?  Are we currently using it
> > >> anywhere?
> > > [Don't know exactly which parts we would delete] - but the new targets
> > > cover ex*[f,f90] type examples - and not anything else.
> > Which targets are you referring to?  I don't see any build targets in
> > the source directories.
> ex%f90: etc targets in lib/petsc/conf/test
> >  There are a few run targets that I don't
> > understand.  We could delete lib/petsc/conf/test and any top-level
> > legacy targets.
> well lib/petsc/conf/test enables the above feature of 'make ex2'
> > > So all other examples that don't fit this string format still use the
> > > old targets.
> > Where are those?  They evidently aren't part of the nightly tests, thus
> > need to be updated.
> [With the above context] - I was refering to - say
> spectraladjointassimilation, burgers_spectral etc targes in
> src/tao/unconstrained/examples/tutorials/makefile
> Sure - this is not part of the test harness and nightlybilds.
> > > Also they are still useful to users [to create their own makefiles] -
> > > as we don't have an equivalent simiple replacement yet..
> > I don't mind makefiles sitting in source directories.  They're basically
> > just includes and a list of source files right now, and we can remove
> > the lists of source files.
> They also list dependencies compile dependencies [for the above purpose]
> Satish
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180705/8523a47d/attachment-0001.html>
