[petsc-dev] My configure is non-working again because of CMake
    Satish Balay
    balay at mcs.anl.gov
    Thu Jul  5 17:31:08 CDT 2018
Well - can you find the version between 3.7 and 3.11 that works on your box?
The previous update was done due to:
https://bitbucket.org/petsc/petsc/commits/e5b329dd4ac
No point in going back to having old issues..
Satish
On Thu, 5 Jul 2018, Matthew Knepley wrote:
> On Thu, Jul 5, 2018 at 5:18 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > Logs?
> I can send it, but its really straightforward. The clang++/g++ on my box
> (which I will not upgrade because the latest MacOS is crazy)
> does not have the <unorderedset> header, and thus is not compliant C++11.
> > And what version of cmake does not require C++11 compliant compiler? We
> > could downgrade to that..
> I reverted back to 3.7 which worked, so somewhere in between 3.7 and 3.11
> they made the change.
>   Thanks,
>     Matt
> > Satish
> > > Now we require a fully C++11 compliant compiler, or the CMake build dies.
> > > This is crazy.
> > >    Matt
