[petsc-dev] trying to make MKL work with GAMG
    Mark Adams
    mfadams at lbl.gov
    Thu Jul  5 10:32:14 CDT 2018
On Wed, Jul 4, 2018 at 1:09 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> > On Jul 4, 2018, at 9:40 AM, Mark Adams <mfadams at lbl.gov> wrote:
> > "-mat_seqaij_type seqaijmkl" just worked.
>     Mark,
>       Please clarify. Does this mean you can use -mat_seqaij_type
> seqaijmkl to satisfy all your needs now without changing any code?
Apparently yes. I timed the code and it took much longer with
NUM_OMP_THREADS > 1 (not sure what that is about but not my problem now),
so that tells me that threads were activated.
I want to package up this simple approach and my branch that works
with -mat_type
aijmkl , and let the user analyze each. (So I am not worrying about
performance, I just want correctness).
>    Barry
> > On Wed, Jul 4, 2018 at 9:44 AM Mark Adams <mfadams at lbl.gov> wrote:
> > On Wed, Jul 4, 2018 at 3:01 AM Richard Tran Mills <rtmills at anl.gov>
> wrote:
> > Hi Mark,
> > I'd never looked at the code for MatCreateMPIAIJWithSeqAIJ(), but it
> looks like if you are using MPIAIJ matrices but you've set
> "-mat_seqaij_type seqaijmkl",
> > No, I am using -mat_type aijmkl
> > then the "diagonal" portion of the MPIAIJ matrix ends up as a SEQAIJMKL
> instance, but the off-diagonal portion ends up as a plain SEQAIJ when it is
> created with MatCreateSeqAIJWithArrays(). (I have not stepped through this
> with a debugger to verify that this is actually what happens.) So, if we
> want the off-diagonal matrix to also be a SEQAIJMKL, then we either need to
> add some logic after the MatCreateSeqAIJWithArrays() call to check to see
> if a different subtype of SEQAIJ is being used and then convert it to the
> correct type, or we need a variant of MatCreateSeqAIJWithArrays() that will
> honor the subtype of SEQAIJ that we are using. Barry, since you added the
> concept of subtyping for SEQAIJ, what do you prefer?
> > No preference.
> > I note that in some (most?) cases, I think we are OK or even better off
> with the off-diagonal matrix in the MPIAIJ not being a SEQAIJMKL one,
> because the PETSc routines can used the "compressed row" stuff to speed up
> handling the many zero rows that often end up in the off-diagonal, whereas
> the MKL routines cannot.
> > OK , I'll keep that in mind. I pushed a branch with fixes to get my gamg
> tests working (ksp ex56 primarily). I'm going to make a new branch and try
> "-mat_seqaij_type seqaijmkl".
> > Thanks,
> > Mark
> > --Richard
> > On Tue, Jul 3, 2018 at 4:31 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > I have having to fix AIJ methods that don't get the type from the args
> to set created matrix type, so as to keep the MKL typing.
> > I am not sure how to fix this because I don't know to say 'make MPI from
> SEQ' in this method
> > PetscErrorCode MatCreateMPIAIJWithSeqAIJ(MPI_Comm comm,Mat A,Mat B,const
> PetscInt garray[],Mat *mat)
> >   ierr = MatCreate(comm,mat);CHKERRQ(ierr);
> >   ierr = MatGetSize(A,&m,&n);CHKERRQ(ierr);
> >   ierr = MatSetSizes(*mat,m,n,PETSC_DECIDE,N);CHKERRQ(ierr);
> >   ierr = MatSetType(*mat,MATMPIAIJ);CHKERRQ(ierr);
> > How should I do this?  Other places in the code I get the type from
> input (MPI) args and set created matrix types accordingly. I could just put
> a switch with an error for any new types that might come along in the
> future ...
> > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180705/ae5a97b7/attachment.html>
