[petsc-dev] [petsc-maint] Incident INC0122538 MKL on Cori/KNL
    Mark Adams
    mfadams at lbl.gov
    Tue Jul  3 05:36:39 CDT 2018
I built a 32 bit integer version and now it dies in PetscInit. Ugh.
==3965== Conditional jump or move depends on uninitialised value(s)
==3965==    at 0x27AFFD8F: _int_free (malloc.c:3945)
==3965==    by 0x20074F48: PetscOptionsSetValue (options.c:1152)
==3965==    by 0x20070450: PetscOptionsInsertArgs_Private (options.c:636)
==3965==    by 0x2007189F: PetscOptionsInsert (options.c:746)
==3965==    by 0x20093DB1: PetscInitialize (pinit.c:929)
==3965==    by 0x2000ABCE: main (ex19.c:106)
==3965==
vex amd64->IR: unhandled instruction bytes: 0x62 0xF1 0x7F 0x8 0x7B 0xC2
0xC5 0xFB 0x10 0xD
vex amd64->IR:   REX=0 REX.W=0 REX.R=0 REX.X=0 REX.B=0
vex amd64->IR:   VEX=0 VEX.L=0 VEX.nVVVV=0x0 ESC=NONE
vex amd64->IR:   PFX.66=0 PFX.F2=0 PFX.F3=0
==3965== valgrind: Unrecognised instruction at address 0x20104a53.
==3965==    at 0x20104A53: kh_resize_HTPrinted (viewreg.c:12)
==3965==    by 0x20104EE2: kh_put_HTPrinted (viewreg.c:12)
==3965==    by 0x201061EF: PetscOptionsHelpPrintedCheck (viewreg.c:89)
==3965==    by 0x2009AD61: PetscOptionsBegin_Private (aoptions.c:34)
==3965==    by 0x2008362E: PetscOptionsSetFromOptions (options.c:2646)
==3965==    by 0x20094689: PetscInitialize (pinit.c:967)
==3965== Your program just tried to execute an instruction that Valgrind
==3965== did not recognise.  There are two possible reasons for this.
==3965== 1. Your program has a bug and erroneously jumped to a non-code
==3965==    location.  If you are running Memcheck and you just saw a
==3965==    warning about a bad jump, it's probably your program's fault.
==3965== 2. The instruction is legitimate but Valgrind doesn't handle it,
==3965==    i.e. it's Valgrind's fault.  If you think this is the case or
==3965==    you are not sure, please let us know and we'll try to fix it.
==3965== Either way, Valgrind will now raise a SIGILL signal which will
==3965== probably kill your program.
[0]PETSC ERROR: ==3965== Conditional jump or move depends on uninitialised
value(s)
==3965==    at 0x27B18B48: strchrnul (strchr.S:106)
==3965==    by 0x27AE30C8: __find_specmb (printf-parse.h:108)
==3965==    by 0x27AE30C8: vfprintf (vfprintf.c:1311)
==3965==    by 0x27AFA045: vsnprintf (vsnprintf.c:119)
==3965==    by 0x20116802: PetscVSNPrintf (mprint.c:178)
==3965==    by 0x20117006: PetscVFPrintfDefault (mprint.c:294)
==3965==    by 0x20136BB2: PetscErrorPrintfDefault (errtrace.c:116)
==3965==    by 0x2013938C: PetscSignalHandlerDefault (signal.c:131)
==3965==    by 0x2013903B: PetscSignalHandler_Private (signal.c:43)
==3965==    by 0x2335D07F: ??? (in
/global/u2/m/madams/petsc_install/petsc/src/snes/examples/tutorials/ex19)
==3965==    by 0x20104A52: kh_resize_HTPrinted (viewreg.c:12)
==3965==
==3965==    at 0x27B08184: strlen (strlen.S:210)
==3965==    by 0x200B3A48: PetscStrlen (str.c:158)
==3965==    by 0x2011693D: PetscVSNPrintf (mprint.c:188)
==3965==
[0]PETSC ERROR: Caught signal number 4 Illegal instruction: Likely due to
memory corruption
On Mon, Jul 2, 2018 at 8:53 PM Mark Adams <mfadams at lbl.gov> wrote:
> Looping Treb and Baky back into the thread, and dropping PETSs.
> Great, thanks Barry for figuring this out.
> Treb and Baky need 64 bit indices, but in the mean time I can build a 32
> bit version to let them test.
> I am all set up to test a 64 bit version. If you can give me a branch I
> can test.
> Thanks,
> Mark
> On Mon, Jul 2, 2018 at 7:47 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>>    Progress has been made. These libraries do contain
>> mkl_set_num_threads() is found so ./configure knows that it is MKL
>> libraries (unlike before when it did not recognize that it was MKL
>> libraries).
>> Damn it, here is why:
>> --with-64-bit-indices=1
>> currently the MKL sparse stuff only works with 32 bit integers AND 32 bit
>> integer BLAS/LAPACK.
>> It will never work with 64 bit indices and 32 bit integer BLAS/LAPACK.
>> but maybe could be upgraded to work with 64 bit indices and 64 bit integer
>> BLAS/LAPACK   Richard?
>> Anyways the requirement in mkl_sparse.py is
>>     self.requires32bitint = 1
>> The problem is ./configure does not print enough information to make it
>> immediately clear it is rejecting the package because of this
>> incompatibility.
>>   Barry
>> > On Jul 2, 2018, at 5:57 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> > Same error:
>> > 15:53 nid02517 master *=
>> ~/petsc_install/petsc/src/snes/examples/tutorials$ make
>> PETSC_DIR=/global/homes/m/madams/petsc_install/petsc-cori-knl-dbg64-intel-omp
>> PETSC_ARCH="" ex19
>> > cc -o ex19.o -c -g -O0 -mkl -static-intel -fopenmp
>>  -I/global/homes/m/madams/petsc_install/petsc-cori-knl-dbg64-intel-omp/include
>> -I/global/homes/m/madams/tmp/hypre-2.14.0/include
>> -I/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/include
>>   `pwd`/ex19.c
>> > cc -g -O0 -mkl -static-intel -fopenmp  -o ex19 ex19.o
>> -L/global/homes/m/madams/petsc_install/petsc-cori-knl-dbg64-intel-omp/lib
>> -Wl,-rpath,/global/homes/m/madams/tmp/hypre-2.14.0/lib
>> -L/global/homes/m/madams/tmp/hypre-2.14.0/lib
>> -Wl,-rpath,/global/homes/m/madams/petsc_install/petsc-cori-knl-dbg64-intel-omp/lib
>> -L/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64
>> -lpetsc -lHYPRE -lparmetis -lmetis -lstdc++ -ldl -lmkl_intel_ilp64
>> -lmkl_intel_thread -lmkl_core -liomp5 -lpthread
>> /opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a(mkl_semaphore.o):
>> In function `mkl_serv_load_inspector':
>> > mkl_semaphore.c:(.text+0x123): warning: Using 'dlopen' in statically
>> linked applications requires at runtime the shared libraries from the glibc
>> version used for linking
>> /global/homes/m/madams/petsc_install/petsc-cori-knl-dbg64-intel-omp/lib/libpetsc.a(send.o):
>> In function `PetscOpenSocket':
>> /global/u2/m/madams/petsc_install/petsc/src/sys/classes/viewer/impls/socket/send.c:108:
>> warning: Using 'gethostbyname' in statically linked applications requires
>> at runtime the shared libraries from the glibc version used for linking
>> > rm ex19.o
>> > 15:54 nid02517 master *=
>> PETSC_ARCH="" runex19_gamg
>> > lid velocity = 0.0625, prandtl # = 1., grashof # = 1.
>> > [0]PETSC ERROR: --------------------- Error Message
>> > [1]PETSC ERROR: --------------------- Error Message
>> > [1]PETSC ERROR: Unknown type. Check for miss-spelling or missing
>> package:
>> http://www.mcs.anl.gov/petsc/documentation/installation.html#external
>> > [1]PETSC ERROR: Unknown Mat type given: aijmkl
>> > On Mon, Jul 2, 2018 at 6:43 PM Satish Balay <balay at mcs.anl.gov> wrote:
>> > Hm - I suspect its an issue with mkl includes - not the libraries.
>> > Satish
>> > On Mon, 2 Jul 2018, Smith, Barry F. wrote:
>> > >   Mark,
>> > >     This is not useful. We need the new configure log from when you
>> list all the libraries NERSE recommends (which may work).
>> > >     I already said what was wrong with this configuration.
>> > >     Barry
>> > > > On Jul 2, 2018, at 5:25 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> > > > On Mon, Jul 2, 2018 at 6:22 PM Satish Balay <balay at mcs.anl.gov>
>> wrote:
>> > > > I don't understand the problem here..
>> > > > > > > [0]PETSC ERROR: Unknown type. Check for miss-spelling or
>> missing package:
>> > > > > > > [0]PETSC ERROR: Unknown Mat type given: aijmkl
>> > > > If this is the problem - then we'll have to look at configure.log
>> to check why PETSC_HAVE_MKL_SPARSE flag is not set.
>> > > > <configure.log>
>> > <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180703/d6a566c3/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180703/d6a566c3/attachment-0001.obj>
