[petsc-dev] GAMG error with MKL
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Tue Jul  3 15:31:54 CDT 2018
  Mark,
   Just remove the error checking
  ierr = PetscObjectTypeCompare((PetscObject)A,MATMPIAIJ,&flg);CHKERRQ(ierr);
  if (!flg) SETERRQ(PetscObjectComm((PetscObject)A),PETSC_ERR_SUP,"This function requires a MATMPIAIJ matrix as input");
from
MatMPIAIJGetSeqAIJ()
this routine should be rewritten to use the PetscUseMethod macro and not check the type explicitly.
   Barry
> On Jul 3, 2018, at 8:28 AM, Mark Adams <mfadams at lbl.gov> wrote:
> GAMG drills into AIJ data structures and will need to be fixed up to work with MKL matrices, I guess, but it is failing now from a logic error.
> This example works with one processor but fails with 2 (appended). The code looks like this:
>     ierr = PetscObjectBaseTypeCompare((PetscObject)Amat,MATSEQAIJ,&isseqaij);CHKERRQ(ierr);
>     ierr = PetscObjectBaseTypeCompare((PetscObject)Amat,MATMPIAIJ,&ismpiaij);CHKERRQ(ierr);
>     if (isseqaij) {
>     } else if (ismpiaij) {
>       ierr = MatMPIAIJGetSeqAIJ(Amat,&Daij,&Oaij,&garray);CHKERRQ(ierr);
> The failure below is from this call to MatMPIAIJGetSeqAIJ, on this line:
> The difference is PetscObjectTypeCompare vs PetscObjectBaseTypeCompare. GAMG could use PetscObjectTypeCompare or MatMPIAIJGetSeqAIJ could use PetscObjectBaseTypeCompare ...
> Mark
> srun -n 2 ./ex19 -pc_type gamg -snes_monitor_short -ksp_monitor_short
> lid velocity = 0.0625, prandtl # = 1., grashof # = 1.
>   0 SNES Function norm 0.239155
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: No support for this operation for this object type
> [0]PETSC ERROR: This function requires a MATMPIAIJ matrix as input
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.9.2-825-g3a11c7608d  GIT Date: 2018-07-01 06:15:09 +0200
> [0]PETSC ERROR: /global/u2/m/madams/petsc_install/petsc/src/snes/examples/tutorials/./ex19 on a  named nid02516 by madams Tue Jul  3 04:58:13 2018
> [0]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=64 --known-level1-dcache-assoc=8 --known-sizeof-char=1 --known-sizeof-void-p=8 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=8 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=8 --known-bits-per-byte=8 --known-memcmp-ok=1 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --known-mpi-int64_t=1 --known-mpi-c-double-complex=1 --known-mklspblas-supports-zero-based=0 --known-has-attribute-aligned=1 --with-cc=cc --with-cxx=CC --with-fc=ftn COPTFLAGS="  -g -O1 -mkl -static-intel" CXXOPTFLAGS="-g -O1 -mkl -static-intel" FOPTFLAGS="  -g -O1 -mkl -static-intel" --download-metis=1 --with-hypre-dir=/global/homes/m/madams/tmp/hypre32-2.14.0 --download-parmetis=1 LIBS="-L/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64 -lmkl_intel_lp64 -lmkl_intel_thread -lmkl_core -liomp5 -lpthread" --with-blaslapack-include=/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/include --with-debugging=0 --with-mpiexec=srun --with-batch=1 --known-mpi-shared-libraries=1 --known-64-bit-blas-indices=0 --with-64-bit-indices=0 PETSC_ARCH=arch-cori-knl-opt-intel-omp --with-openmp=1 --download-p4est=0 --with-x=0 --prefix=/global/homes/m/madams/petsc_install/petsc-cori-knl-opt-intel-omp PETSC_DIR=/global/homes/m/madams/petsc_install/petsc
> [0]PETSC ERROR: #1 MatMPIAIJGetSeqAIJ() line 4328 in /global/u2/m/madams/petsc_install/petsc/src/mat/impls/aij/mpi/mpiaij.c
> [0]PETSC ERROR: #2 PCGAMGCreateGraph() line 118 in /global/u2/m/madams/petsc_install/petsc/src/ksp/pc/impls/gamg/util.c
> [0]PETSC ERROR: #3 PCGAMGGraph_AGG() line 832 in /global/u2/m/madams/petsc_install/petsc/src/ksp/pc/impls/gamg/agg.c
> [0]PETSC ERROR: #4 PCSetUp_GAMG() line 517 in /global/u2/m/madams/petsc_install/petsc/src/ksp/pc/impls/gamg/gamg.c
> [0]PETSC ERROR: #5 PCSetUp() line 932 in /global/u2/m/madams/petsc_install/petsc/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: #6 KSPSetUp() line 381 in /global/u2/m/madams/petsc_install/petsc/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #7 KSPSolve() line 612 in /global/u2/m/madams/petsc_install/petsc/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #8 SNESSolve_NEWTONLS() line 224 in /global/u2/m/madams/petsc_install/petsc/src/snes/impls/ls/ls.c
> [0]PETSC ERROR: #9 SNESSolve() line 4350 in /global/u2/m/madams/petsc_install/petsc/src/snes/interface/snes.c
> [0]PETSC ERROR: #10 main() line 161 in /global/homes/m/madams/petsc_install/petsc/src/snes/examples/tutorials/ex19.c
> [0]PETSC ERROR: PETSc Option Table entries:
> [0]PETSC ERROR: -ksp_monitor_short
> [0]PETSC ERROR: -mat_type aijmkl
> [0]PETSC ERROR: -options_left
> [0]PETSC ERROR: -pc_type gamg
> [0]PETSC ERROR: -snes_monitor_short
