[petsc-dev] GAMG and custom MatMults in smoothers
    Matthew Knepley
    knepley at gmail.com
    Mon Jul  2 09:38:19 CDT 2018
On Mon, Jul 2, 2018 at 9:33 AM Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>
wrote:
> 2. 7. 2018 v 15:50, Matthew Knepley <knepley at gmail.com>:
> On Mon, Jul 2, 2018 at 8:28 AM Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>
> wrote:
>> 2. 7. 2018 v 15:05, Matthew Knepley <knepley at gmail.com>:
>> On Mon, Jul 2, 2018 at 7:54 AM Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>
>> wrote:
>>> 2. 7. 2018 v 14:48, Matthew Knepley <knepley at gmail.com>:
>>> On Mon, Jul 2, 2018 at 3:48 AM Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>
>>> wrote:
>>>> Barry wrote:
>>>>   This could get ugly real fast, for example, for vector operations,
>>>> there may be dozens of named vectors and each one gets its own logging?
>>>> You'd have to make sure that only the objects you care about get named, is
>>>> that possible?
>>>>    I don't know if there is a good solution within the PETSc logging
>>>> infrastructure to get what you want but maybe what you propose is the best
>>>> possible.
>>>> As I suggest, this behavior would be only triggered by a specific
>>>> option.
>>>> I think there are actually 4 strings which could be used as an event
>>>> name suffix in log view:
>>>> 1) name
>>>> 2) prefix
>>>> 3) type
>>>> 4) custom string (set by something like PetscObjectSetLogViewSuffix)
>>>> I think the best would be to let user choose by offering
>>>> -log_view_by_{name,prefix,type,suffix}.
>>>> For example, with -log_view_by_prefix, you could readily distinguish
>>>> PCTelescope outer and inner apply, because you would see a separate
>>>> "PCApply (telescope_)" event.
>>>> With -log_view_by_type, you would see PCApply (telescope).
>>>> I think this would be useful because the current class-wide events like
>>>> MatMult or PCApply aggregate very different operations from which some are
>>>> for free and some form hotspots.
>>>> Stefano wrote:
>>>> The issue with this sort of “dynamic” logging is that now PETSc
>>>> requires PetscLogEvent created during the registration of the class, so
>>>> that all the ranks in PETSC_COMM_WORLD have the same events registered.
>>>> What you propose is not generally supported for this specific reason.
>>>> Your “log_name” may work if users register their own classes (with
>>>> their own LogEvents created properly), and currently we don’t have support
>>>> (maybe I’m wrong) to add an “InitializePackage” method for the users’
>>>> registered classes.
>>>> I don't agree. What I suggest is basically an ability to allow
>>>> automatically created object-wise events, so it _can't_ be managed during
>>>> the class registration. In presence of respective option, the event would
>>>> be created during PetscLogEventBegin by taking the class-wide event's name,
>>>> concatenating the suffix and registering a new event. The event id would be
>>>> stored in the PetscObject structure.
>>>> Matt wrote:
>>>> As people have pointed out, this would not work well for Events.
>>>> However, this is exactly what stages are for.
>>>> Use separate stages for the different types of MatMult. I did this, for
>>>> example, when looking at performance
>>>> on different MG levels.
>>>> Yes, performance on different MG levels is a nice use case. I don't
>>>> understand how you inject stages into MatMults. To me it's exactly the same
>>>> problem as with events - you have to define MatMult_custom where you take
>>>> the original mult and wrap into PetscStageLogPush/Pop and then use
>>>> MatSetOperation to redefine MatMult. Or do you mean something more elegant?
>>> You could do that, but usually I think of stages as being structural. I
>>> think for your example I would push/pop the stage
>>> inside your Mat operation wrapper (I don't see why you need another
>>> one), and this behavior could be controlled with
>>> another option so you could turn it off.
>>> I meant hierarchies of typically Mats or PCs, where you don't define any
>>> custom operations but compose together existing types (which should be
>>> promoted I believe). So no "my" wrapper. As I wrote below:
>>>  Think e.g. of having additive MATCOMPOSITE wrapping multiplicative
>>>> MATCOMPOSITE wrapping MATTRANSPOSE wrapping MATAIJ. You want to measure
>>>> this MATAIJ instance's MatMult separately but you surely don't want to
>>>> rewrite implementation of MatMult_Transpose or force yourself to use
>>>> MATSHELL just to hang the events on MatMult*.
>> Its not enough to make separate stages for additive MC, multiplicative
>> MC, and MT? If you want stages for every single
>> combination created dynamically, you can push another stage when each of
>> these combinations is created using GetTag()
>> or something like that. You could switch between these behaviors with an
>> option.
>> I'm not sure I understand. Do you mean registering and pushing/popping
>> these stages in the user's code? You can surely call PetscStageLogRegister
>> somewhere after PetscInitialize, but where do you place your
>> PetscStageLogPush/Pop calls?
> No. You would create a stage when the MATCOMPOSITE is created (or once
> when any MATCOMPOSITE is created), and push/pop
> on application.
> There's surely no problem with creating that stage. But still I don't see
> how can you push/pop on specific MatMult if it's aggregated together with
> another MatMults in a higher level MatMult without redefining the latter?
> And there can be arbitrary number of such levels. If you push/pop your
> stage in the code calling the top-level MatMult, you can't distinguish
> different MatMults occurring inside.
I do not understand what you mean. Each operation would happen in a
separate stage. Its time for a specific, simple example
where you think this would break. This could be coded in 10 minutes.
> And I don't understand what's in this context the advantage of using
> stages (which are typically registered by user and from his perspective
> they are generally spanning multiple different operations/function calls)
> against events which are precisely meant for single operations/function
> calls (at least I hope so based on thousands of use cases in PETSc itself).
Events are semantically associated with given operations. Stages are
semantically associated with the context of an operation.
So defining a bunch of events for MatMult does not make sense to me,
whereas defining a bunch of stages for different MatMults
definitely does.
> You want me to create a stage which is shorter than then the wrapping
> event which is I think much uglier than what I propose :-)
I don't. I think it follows exactly the toplevel design.
     Matt
> Vaclav
>   Matt
>> Thanks
>> Vaclav
>> The reason I think this is preferable is that we do not mess with any
>> logging infrastructure, we just use stages inside of other objects.
>>   Thanks,
>>      Matt
>>> Thanks
>>> Vaclav
>>>   Matt
>>>> Thanks
>>>> Vaclav
>>>> 29. 6. 2018 v 22:42, Smith, Barry F. <bsmith at mcs.anl.gov>:
>>>> On Jun 29, 2018, at 9:33 AM, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>
>>>> wrote:
>>>> 22. 6. 2018 v 17:47, Smith, Barry F. <bsmith at mcs.anl.gov>:
>>>> On Jun 22, 2018, at 5:43 AM, Pierre Jolivet <pierre.jolivet at enseeiht.fr>
>>>> wrote:
>>>> Hello,
>>>> I’m solving a system using a MATSHELL and PCGAMG.
>>>> The MPIAIJ Mat I’m giving to GAMG has a specific structure (inherited
>>>> from the MATSHELL) I’d like to exploit during the solution phase when the
>>>> smoother on the finest level is doing MatMults.
>>>> Is there some way to:
>>>> 1) decouple in -log_view the time spent in the MATSHELL MatMult and in
>>>> the smoothers MatMult
>>>> You can register a new event and then inside your MATSHELL MatMult()
>>>> call PetscLogEventBegin/End on your new event.
>>>>  Note that the MatMult() like will still contain the time for your
>>>> MatShell mult so you will need to subtract it off to get the time for your
>>>> non-shell matmults.
>>>> In PERMON, we sometimes have quite complicated hierarchy of wrapped
>>>> matrices and want to measure MatMult{,Transpose,Add,TransposeAdd}
>>>> separately for particular ones. Think e.g. of having additive MATCOMPOSITE
>>>> wrapping multiplicative MATCOMPOSITE wrapping MATTRANSPOSE wrapping MATAIJ.
>>>> You want to measure this MATAIJ instance's MatMult separately but you
>>>> surely don't want to rewrite implementation of MatMult_Transpose or force
>>>> yourself to use MATSHELL just to hang the events on MatMult*.
>>>> We had a special wrapper type just adding some prefix to the events for
>>>> the given object but this is not nice. What about adding a functionality to
>>>> PetscLogEventBegin/End that would distinguish based on the first
>>>> PetscObject's name or option prefix? Of course optionally not to break guys
>>>> relying on current behavior - e.g. under something like -log_view_by_name.
>>>> To me it's quite an elegant solution working for any PetscObject and any
>>>> event.
>>>> that possible?
>>>> possible.
>>>>   Barry
>>>> I can do that if I get some upvotes.
>>>> Vaclav
>>>> 2) hardwire a specific MatMult implementation for the smoother on the
>>>> finest level
>>>> In the latest release you do MatSetOperation() to override the normal
>>>> matrix vector product with anything else you want.
>>>> Thanks in advance,
>>>> Pierre
>>>> PS : here is what I have right now,
>>>> MatMult              118 1.0 1.0740e+02 1.6 1.04e+13 1.6 1.7e+06
>>>> 6.1e+05 0.0e+00 47100 90 98  0 47100 90 98  0 81953703
>>>> PCSetUp                2 1.0 8.6513e+00 1.0 1.01e+09 1.7 2.6e+05
>>>> 4.0e+05 1.8e+02  5  0 14 10 66   5  0 14 10 68 94598
>>>> PCApply               14 1.0 8.0373e+01 1.1 9.06e+12 1.6 1.3e+06
>>>> 6.0e+05 2.1e+01 45 87 72 78  8 45 87 72 78  8 95365211 // I’m guessing a
>>>> lot of time here is being wasted in doing inefficient MatMults on the
>>>> finest level but this is only speculation
>>>> Same code with -pc_type none -ksp_max_it 13,
>>>> MatMult               14 1.0 1.2936e+01 1.7 1.35e+12 1.6 2.0e+05
>>>> 6.1e+05 0.0e+00 15100 78 93  0 15100 78 93  0 88202079
>>>> The grid itself is rather simple (two levels, extremely aggressive
>>>> coarsening),
>>>> type is MULTIPLICATIVE, levels=2 cycles=v
>>>> KSP Object: (mg_coarse_) 1024 MPI processes
>>>> linear system matrix = precond matrix:
>>>>   Mat Object: 1024 MPI processes
>>>>     type: mpiaij
>>>>     rows=775, cols=775
>>>>     total: nonzeros=1793, allocated nonzeros=1793
>>>> linear system matrix followed by preconditioner matrix:
>>>> type: shell
>>>> rows=1369307136, cols=1369307136
>>>> type: mpiaij
>>>> total: nonzeros=19896719360, allocated nonzeros=19896719360
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180702/8cbf7627/attachment-0001.html>
