[petsc-dev] building with MKL
Mark Adams mfadams at lbl.gov
Sun Jul 1 17:21:30 CDT 2018
On Sun, Jul 1, 2018 at 6:14 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>    Can you please do
> nm -o
> /opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/*.* |
> grep mkl_blas_dtrsm
> > On Jul 1, 2018, at 3:14 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > Sorry, I've sent several today.
> > On Sun, Jul 1, 2018 at 2:59 PM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> >    Mark,
> >     You need to send the full configure.log (it if doesn't fit for
> petsc-dev, better to send it to petsc-maint that doesn't mind big
> attachments.
> >    Barry
> > > On Jul 1, 2018, at 1:49 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > > On Sun, Jul 1, 2018 at 1:43 PM Victor Eijkhout <
> eijkhout at tacc.utexas.edu> wrote:
> > >> On Jul 1, 2018, at 12:30 PM, Jeff Hammond <jeff.science at gmail.com>
> wrote:
> > >> If you really want to do this, then replace COMMON with CORE to
> specialize for SKX. There’s not point to using COMMON if you’ve got the MIC
> path already.
> > > We advocate CORE on our userguides, but the Intel compiler crashes
> reliably with that in certain cases. I think in particular Intel has never
> figured out how complex numbers work. If the compiler crashes it’s always
> on the petsc complex mode. I think I have submitted tickets about that, so
> maybe it’s fixed in update 3.
> > > I have also seen cases where CORE gives numerical problems and
> replacing by COMMON fixed them. Sorry, that was a user ticket and having
> solved it I didn’t bother to submit an Intel support ticket.
> > > I have unconfirmed reports of numerical problems. I will try your
> flags if I can reproduce them. Any other tricks that you used to get
> MKL/PETSc to work?
> > > Also, PETSc is having problems finding libs. I get this error that it
> can not find -blas and I see that there is a libmkl_blas95_ilp64.a and
> libmkl_blas95_lp64.a, but no libblas.a.
> > > I'm stuck, any help would be appreciated,
> > > Thanks,
> > > Mark
> > > Executing: cc  -o /tmp/petsc-WPf2VB/config.libraries/conftest     -g
> -O0 -hcpu=mic-knl -qopenmp-simd -fopenmp
> /tmp/petsc-WPf2VB/config.libraries/conftest.o
> -Wl,-rpath,/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64
> -L/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64
> -lblas -lstdc++ -ldl
> > > Possible ERROR while running linker: exit code 256
> > > stderr:
> /usr/lib64/gcc/x86_64-suse-linux/4.8/../../../../x86_64-suse-linux/bin/ld:
> cannot find -lblas
> > >                     Popping language C
> > >               Unknown name mangling in BLAS/LAPACK
> > > **** Configure header /tmp/petsc-WPf2VB/confdefs.h ****
> > > #if !defined(INCLUDED_UNKNOWN)
> > > The support website is a nightmare anyway, so I’m not overly motivated
> to submit support tickets in the first place.
> > > Victor.
> > <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180701/92cbbf67/attachment-0001.html>
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_ao_worker.so:00000000037ce7c4 b ___kmpv_zeromkl_blas_dtrsm_omp_driver_v1_0
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_ao_worker.so:00000000037ce7c8 b ___kmpv_zeromkl_blas_dtrsm_omp_driver_v1_1
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_ao_worker.so:00000000005d5750 T mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_ao_worker.so:0000000000457140 T mkl_blas_dtrsm_ao_worker
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_ao_worker.so:00000000005de070 T mkl_blas_dtrsm_omp_driver_v1
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:lbprim.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:blkslvs1_ooc.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:blkslv1_unsym_ooc.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:blkslv1_ooc.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:blklu_unsym_ooc.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:blklu_ooc.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:blkl_ooc.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:blkldlslvs1_ooc.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:blkldl_ooc.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:dgetrinp.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:dsygv_2stage.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:dsytrs_3.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:dsytrs_aa.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:dgetrf2.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:dpotrf2.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:xdtptrs.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:xdtbtrs.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:xdpptrs.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:xdpptrf.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:xdpbtrs.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:xdgetrfnpi.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:xdgbtrs.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:xdgbtrf.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:dtrtrs.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:dtrtri.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:dtfsm.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:dsygvx.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:dsygvd.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:dsygv.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:dsygst.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:dpotrs.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:dpotrf_local.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:dpftrf.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:dpbtrf.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:dgetrs.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:dgetri.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:dgetrf_local.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:dgelsy.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:dgelsx.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:dgejsv.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:dsytrs2.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.a:dgetrf_local_team.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_core.so:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gf_ilp64.a:_dtrsm_direct.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gf_ilp64.a:_dtrsm_compact.o:                 U mkl_blas_dtrsm_compact
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gf_ilp64.a:_dtrsm.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gf_ilp64.a:_dtrsm_batch.o:                 U mkl_blas_dtrsm_batch
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gf_ilp64.so:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gf_ilp64.so:                 U mkl_blas_dtrsm_batch
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gf_ilp64.so:                 U mkl_blas_dtrsm_compact
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gf_lp64.a:_dtrsm_direct_lp64.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gf_lp64.a:_dtrsm_compact_lp64.o:                 U mkl_blas_dtrsm_compact
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gf_lp64.a:_dtrsm_lp64.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gf_lp64.a:_dtrsm_batch_lp64.o:                 U mkl_blas_dtrsm_batch
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gf_lp64.so:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gf_lp64.so:                 U mkl_blas_dtrsm_batch
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gf_lp64.so:                 U mkl_blas_dtrsm_compact
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:blkslv_unsym_ooc_omp.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:blkslvs_ooc_omp.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:blkslv_ooc_omp.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:blklu_unsym_ooc_omp.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:blklu_ooc_omp.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:blkl_ooc_omp.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:blkldlslvs_ooc_omp.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:blkldl_ooc_omp.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:_mkl_blas_lp64_dtrsm.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:dgetrfnpi_offload_par.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:dpotrf_offload_par.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:dgetrf_offload_par.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:dpotrf_par.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:dgetrf_par.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:dgetrf_ib_par.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:dpptrs_par.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:dpptrf_par.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:dgbtrf_par.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:dgetrf_int_par.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:dgetrfnpi_par.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:d__trsm_omp_v1_drv.o:0000000000000490 T mkl_blas_dtrsm_omp_driver_v1
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:d__trsm_omp_v1_drv.o:0000000000000000 t mkl_blas_dtrsm_omp_driver_v1.omp_fn.0
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:d__trsm_omp_v1_drv.o:00000000000001c0 t mkl_blas_dtrsm_omp_driver_v1.omp_fn.1
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:d__trsm_offload_drv.o:0000000000004500 T mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:d__trsm_offload_drv.o:00000000000022f0 t mkl_blas_dtrsm.omp_fn.0
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:d__trsm_offload_drv.o:                 U mkl_blas_dtrsm_host
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:d__trsm_direct_drv.o:0000000000000000 T mkl_blas_dtrsm_direct
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:d__trsm_compact_drv.o:0000000000000170 T mkl_blas_dtrsm_compact
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:d__trsm_compact_drv.o:0000000000000000 t mkl_blas_dtrsm_compact.omp_fn.0
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:d__trsm_drv.o:0000000000005540 T mkl_blas_dtrsm_host
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:d__trsm_drv.o:                 U mkl_blas_dtrsm_omp_driver_v1
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:d__trsm_batch_drv.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.a:d__trsm_batch_drv.o:0000000000002110 T mkl_blas_dtrsm_batch
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.so:0000000000245ae0 T mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.so:00000000002438d0 t mkl_blas_dtrsm.omp_fn.0
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.so:000000000021d530 T mkl_blas_dtrsm_batch
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.so:0000000000225350 T mkl_blas_dtrsm_compact
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.so:00000000002251e0 t mkl_blas_dtrsm_compact.omp_fn.0
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.so:0000000000225670 T mkl_blas_dtrsm_direct
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.so:0000000000222b10 T mkl_blas_dtrsm_host
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.so:0000000000246510 T mkl_blas_dtrsm_omp_driver_v1
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.so:0000000000246080 t mkl_blas_dtrsm_omp_driver_v1.omp_fn.0
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_gnu_thread.so:0000000000246240 t mkl_blas_dtrsm_omp_driver_v1.omp_fn.1
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_ilp64.a:_dtrsm_direct.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_ilp64.a:_dtrsm_compact.o:                 U mkl_blas_dtrsm_compact
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_ilp64.a:_dtrsm.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_ilp64.a:_dtrsm_batch.o:                 U mkl_blas_dtrsm_batch
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_ilp64.so:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_ilp64.so:                 U mkl_blas_dtrsm_batch
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_ilp64.so:                 U mkl_blas_dtrsm_compact
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_lp64.a:_dtrsm_direct_lp64.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_lp64.a:_dtrsm_compact_lp64.o:                 U mkl_blas_dtrsm_compact
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_lp64.a:_dtrsm_lp64.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_lp64.a:_dtrsm_batch_lp64.o:                 U mkl_blas_dtrsm_batch
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_lp64.so:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_lp64.so:                 U mkl_blas_dtrsm_batch
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_lp64.so:                 U mkl_blas_dtrsm_compact
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:blkslv_unsym_ooc_omp.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:blkslvs_ooc_omp.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:blkslv_ooc_omp.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:blklu_unsym_ooc_omp.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:blklu_ooc_omp.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:blkl_ooc_omp.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:blkldlslvs_ooc_omp.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:blkldl_ooc_omp.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:_mkl_blas_lp64_dtrsm.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:dgetrfnpi_offload_par.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:dpotrf_offload_par.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:dgetrf_offload_par.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:dpotrf_par.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:dgetrf_par.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:dgetrf_ib_par.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:dpptrs_par.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:dpptrf_par.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:dgbtrf_par.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:dgetrf_int_par.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:dgetrfnpi_par.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:d__trsm_omp_v1_drv.o:0000000000000000 b ___kmpv_zeromkl_blas_dtrsm_omp_driver_v1_0
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:d__trsm_omp_v1_drv.o:0000000000000004 b ___kmpv_zeromkl_blas_dtrsm_omp_driver_v1_1
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:d__trsm_omp_v1_drv.o:0000000000000000 T mkl_blas_dtrsm_omp_driver_v1
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:d__trsm_offload_drv.o:0000000000000000 b ___kmpv_zeromkl_blas_dtrsm_0
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:d__trsm_offload_drv.o:0000000000000210 T mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:d__trsm_offload_drv.o:                 U mkl_blas_dtrsm_host
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:d__trsm_direct_drv.o:0000000000000000 T mkl_blas_dtrsm_direct
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:d__trsm_compact_drv.o:0000000000000004 b ___kmpv_zeromkl_blas_dtrsm_compact_0
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:d__trsm_compact_drv.o:0000000000000000 T mkl_blas_dtrsm_compact
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:d__trsm_drv.o:0000000000007c10 T mkl_blas_dtrsm_host
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:d__trsm_drv.o:                 U mkl_blas_dtrsm_omp_driver_v1
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:d__trsm_batch_drv.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a:d__trsm_batch_drv.o:0000000000000000 T mkl_blas_dtrsm_batch
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.so:000000000226ca34 b ___kmpv_zeromkl_blas_dtrsm_0
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.so:000000000226c9d0 b ___kmpv_zeromkl_blas_dtrsm_compact_0
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.so:000000000226ca38 b ___kmpv_zeromkl_blas_dtrsm_omp_driver_v1_0
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.so:000000000226ca3c b ___kmpv_zeromkl_blas_dtrsm_omp_driver_v1_1
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.so:0000000000316140 T mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.so:00000000002ed8d0 T mkl_blas_dtrsm_batch
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.so:00000000002f97b0 T mkl_blas_dtrsm_compact
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.so:00000000002f9f80 T mkl_blas_dtrsm_direct
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.so:00000000002f88a0 T mkl_blas_dtrsm_host
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.so:000000000031a6b0 T mkl_blas_dtrsm_omp_driver_v1
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_sequential.a:blkslv_unsym_ooc_omp_no.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_sequential.a:blkslvs_ooc_omp_no.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_sequential.a:blkslv_ooc_omp_no.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_sequential.a:blklu_unsym_ooc_omp_no.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_sequential.a:blklu_ooc_omp_no.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_sequential.a:blkl_ooc_omp_no.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_sequential.a:blkldlslvs_ooc_omp_no.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_sequential.a:blkldl_ooc_omp_no.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_sequential.a:_mkl_blas_lp64_dtrsm.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_sequential.a:dgetrfnpi_offload_seq.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_sequential.a:dpotrf_seq.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_sequential.a:dgetrf_ib_seq.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_sequential.a:dgbtrf_seq.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_sequential.a:d__trsm_direct_seq.o:0000000000000000 T mkl_blas_dtrsm_direct
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_sequential.a:d__trsm_compact_seq.o:0000000000000000 T mkl_blas_dtrsm_compact
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_sequential.a:d__trsm_seq.o:0000000000000000 T mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_sequential.a:d__trsm_batch_seq.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_sequential.a:d__trsm_batch_seq.o:0000000000000000 T mkl_blas_dtrsm_batch
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_sequential.so:0000000000152a40 T mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_sequential.so:0000000000152580 T mkl_blas_dtrsm_batch
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_sequential.so:0000000000152a90 T mkl_blas_dtrsm_compact
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_sequential.so:0000000000152b30 T mkl_blas_dtrsm_direct
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_tbb_thread.a:blkslv_unsym_ooc_omp_tbb.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_tbb_thread.a:blkslvs_ooc_omp_tbb.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_tbb_thread.a:blkslv_ooc_omp_tbb.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_tbb_thread.a:blklu_unsym_ooc_omp_tbb.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_tbb_thread.a:blklu_ooc_omp_tbb.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_tbb_thread.a:blkl_ooc_omp_tbb.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_tbb_thread.a:blkldlslvs_ooc_omp_tbb.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_tbb_thread.a:blkldl_ooc_omp_tbb.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_tbb_thread.a:_mkl_blas_lp64_dtrsm.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_tbb_thread.a:dgetrfnpi_offload_seq.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_tbb_thread.a:dgetrf_ib_seq.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_tbb_thread.a:dgbtrf_seq.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_tbb_thread.a:d__trsm_drv.o:0000000000000160 T mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_tbb_thread.a:d__trsm_direct_seq.o:0000000000000000 T mkl_blas_dtrsm_direct
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_tbb_thread.a:d__trsm_compact_seq.o:0000000000000000 T mkl_blas_dtrsm_compact
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_tbb_thread.a:d__trsm_batch_seq.o:                 U mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_tbb_thread.a:d__trsm_batch_seq.o:0000000000000000 T mkl_blas_dtrsm_batch
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_tbb_thread.so:0000000000203b10 T mkl_blas_dtrsm
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_tbb_thread.so:00000000001d5480 T mkl_blas_dtrsm_batch
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_tbb_thread.so:00000000001d5940 T mkl_blas_dtrsm_compact
/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_tbb_thread.so:00000000001d59e0 T mkl_blas_dtrsm_direct
