[petsc-dev] SETERRQ in fortran
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Wed Jan 31 15:04:40 CST 2018
  No, that is CHKERRQ()
> On Jan 31, 2018, at 2:02 PM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> Maybe I'm missing something, but maybe this define is all what you need?
> #define SETERRQ(ierr) if (ierr/=0) call PetscError(comm,ierr,0,"message")
> program main
>  integer ierr,comm
>  call something(ierr); SETERRQ(ierr)
> end program main
> On 6 January 2018 at 02:33, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>>> On Jan 5, 2018, at 5:00 PM, Jed Brown <jed at jedbrown.org> wrote:
>>> "Smith, Barry F." <bsmith at mcs.anl.gov> writes:
>>>>>>>>> On Jan 4, 2018, at 5:10 PM, Blaise A Bourdin <bourdin at lsu.edu> wrote:
>>>>>>>>>> On Jan 4, 2018, at 3:16 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>>>>>>>>>> It's changed a bit.  It is better but you need to understand how the new one works, so take a few minutes to see how it works before converting.
>>>>>>>>> Got it.
>>>>>>>>> An example or a link to the fortran macro definition from the man page would be nice
>>>>>>>>> I am confused about the rationale for putting the endif in the macro, though.
>>>>>>>> It matches the C paradigm
>>>>>>> Hardly.
>>>>>> It matches the paradigm as close as can be reasonable done.
>>>>>> I debated putting the then into the macros also.
>>>>>>> #define SETERRQ(c,ierr,s)  then ;call PetscError(c,ierr,0,s);return;endif
>>>>>> So usage would be
>>>>>>    if (bad) SETERRQ();
>>>>>> would that be better.
>>>>> No, Fortran isn't C.
>>>>> if (bad) then
>>>>>    SETERRQ(...)
>>>>> endif
>>>>> It doesn't get used so much from Fortran that we need to conceal the
>>>>> language constructs.
>>>>  It will, eventually I want all Fortran examples/tests to have checks on every call (like with have in C).
>>> CHKERRQ does the if internally, so it also has the endif.
>>  What is the relevance of this statement.
>>> SETERRA/SETERRQ is used a total of 34 times in 17 Fortran files.
>>> SETERRQ is used a median of zero times and an average of less than 1 in
>>> the C examples.
>>   I am not sure why you are saying this. My resistance to change has nothing to do with how often it is used.
>>   I am leaning to changing it but don't want to until all the test harness branches etc get into master. So it will be a few days.
>>>>>>> This Fortran:
>>>>>>> #define SETERRQ(c,ierr,s)  ;call PetscError(c,ierr,0,s);return;endif
>>>>>>> This would be like writing this C
>>>>>>> #define SETERRQ(c,ierr,s) return PetscError(...); }
>>>>>>> to be used like
>>>>>>> if (BAD) { SETERRQ(comm, ierr, "why")
>>>>>>> which is just bananas and still not as gross as the Fortran.  You might
>>>>>>> not have noticed this because SETERRQ is not called from any of PETSc's
>>>>>>> Fortran examples.
>>>>>>  But SETERRA() is and has the same pattern.
>>>>> It isn't syntactically correct when !defined(PETSC_USE_ERRORCHECKING).
>>>>> The endif isn't going to kill anyone and pulling it out of the macro
>>>>> will make it easier to understand and avoid the circus antics when used
>>>>> in any context other than a positive conditional with no else clause.
>>>>  I'll take this under advisement. Of course in our examples the endif will ALWAYS be on the same line as the rest. Using three lines for a SETERRQ() is ugly.
>>>>>>>>> Beside not having unmatched if / end if in my code, in a select case construct, I have to write something as ugly as
>>>>>>>>> select case (i)
>>>>>>>>>        case(1)
>>>>>>>>>                !do something
>>>>>>>>>        case(2)
>>>>>>>>>                !do something else
>>>>>>>>>        case default
>>>>>>>>>                if (0 == 0) then
>>>>>>>>>                        SETERRQ(PETSC_COMM_WORLD,PETSC_ERR_ARG_OUTOFRANG,”invalid value”)
>>>>>>>>> end select
>>>>>>>> What is ugly about this ? except that you put the SETERRQ on a new line which you did not need to do.
>>>>>>> Reread the above code.  Requiring the dummy opening if statement is nuts.
>>>>>> Agreed. He should not use SETERRQ() in this case, should call the error functions directly)
>>>>>>>> How do you want to write it so it is prettier?
>>>>>>> SETERRQ should not include that endif.  CHKERRQ has the opening if and
>>>>>>> thus needs the closing too (so it's as intended).  Also note that your
>>>>>>> first reply to Blaise was talking about CHKERRQ when he was asking about
>>>>>>> SETERRQ.
>>>>>>  Hmm, I'm not sure about. Oh well, it doesn't matter. You have convinced me of anything.
> Lisandro Dalcin
> Research Scientist
> Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
> Extreme Computing Research Center (ECRC)
> King Abdullah University of Science and Technology (KAUST)
> http://ecrc.kaust.edu.sa/
> 4700 King Abdullah University of Science and Technology
> al-Khawarizmi Bldg (Bldg 1), Office # 0109
> Thuwal 23955-6900, Kingdom of Saudi Arabia
> http://www.kaust.edu.sa
> Office Phone: +966 12 808-0459
