[petsc-dev] How to pass user data to a registered PC (PCRegister) ?
Franck Houssen franck.houssen at inria.fr
Wed Jan 24 03:17:36 CST 2018
Oh man !.... You got it right ! My mistake. Thanks, Jed.
Franck
----- Mail original -----
> De: "Jed Brown" <jed at jedbrown.org>
> À: "Franck Houssen" <franck.houssen at inria.fr>
> Cc: "Barry F. Smith" <bsmith at mcs.anl.gov>, "For users of the development version of PETSc" <petsc-dev at mcs.anl.gov>
> Envoyé: Mercredi 24 Janvier 2018 06:41:44
> Objet: Re: [petsc-dev] How to pass user data to a registered PC (PCRegister) ?
> Franck, you set the prefix "igs_" so the option you're looking for is
> "-igs_geneo_lvl ASM,0".
> $ git diff
> diff --git i/src/geneo.cpp w/src/geneo.cpp
> index b4a4ea6..f09f97c 100644
> --- i/src/geneo.cpp
> +++ w/src/geneo.cpp
> @@ -2318,8 +2318,11 @@ static PetscErrorCode
> setUpGenEOPCFromOptions(PetscOptionItems * PetscOptionsObj
>    PetscErrorCode pcRC = PetscOptionsHead(PetscOptionsObject, "GenEO
>    options");
>    CHKERRQ(pcRC);
> +  //#define ORIGINAL
> +#ifdef ORIGINAL
>    pcRC = PetscOptionsBegin(PETSC_COMM_WORLD, NULL, "GenEO options", "GenEO
>    options");
>    CHKERRQ(pcRC);
> +#endif
>    PetscBool pcHasOpt = PETSC_FALSE;
>    PetscInt nbArgs = 2;
> @@ -2461,8 +2464,10 @@ static PetscErrorCode
>      gCtx->check = true;
> -  pcRC = PetscOptionsEnd();
> -  CHKERRQ(pcRC);
> +#ifdef ORIGINAL
> +    pcRC = PetscOptionsEnd();
> +    CHKERRQ(pcRC);
> +#endif
>    pcRC = PetscOptionsTail();
>    CHKERRQ(pcRC);
> $ ../../src/geneo4PETSc --inpFileA identity.inp --inpFileB B.inp -igs_pc_type
> geneo -igs_geneo_lvl ASM,0 --verbose 2 -geneo_chk log -geneo_dbg log,2
> --shortRes -igs_ksp_atol 1.e-12 -igs_ksp_rtol 1.e-12 -options_left no
> --metisDual | tail
> 4.
> 5.
> 6.
> 7.
> 8.
> INFO: nb DOFs 8, nb elements 7, nnz coefs 22, nb partitions 1, overlap 0,
> metis dual
> INFO: gmres ksp, eps rel 1.0e-12, eps abs 1.0e-12, max iterations 10000
> INFO: geneo0ASM pc, L1 mumps no-proj-fine-space
> INFO: solve - converged
> You can see the correct option by running with -help:
> --metisDual -help | grep geneo_lvl
>   -igs_geneo_lvl <string1,string2,...>: GenEO levels (GenEO levels)
> Also, if you hadn't gone out of your way to pass "-options_left no", you
> would have seen this output, which is actually not a joke:
> geneo -geneo_lvl ASM,0 --verbose 2 -geneo_chk log -geneo_dbg log,2
> --shortRes -igs_ksp_atol 1.e-12 -igs_ksp_rtol 1.e-12 --metisDual | tail -5
> WARNING! There are options you set that were not used!
> WARNING! could be spelling mistake, etc!
> Option left: name:-geneo_chk value: log
> Option left: name:-geneo_dbg value: log,2
> Option left: name:-geneo_lvl value: ASM,0
> Franck Houssen <franck.houssen at inria.fr> writes:
> > Forgot the logs !
> >> De: "Franck Houssen" <franck.houssen at inria.fr>
> >> À: "Jed Brown" <jed at jedbrown.org>
> >> Envoyé: Lundi 22 Janvier 2018 18:03:20
> >> (PCRegister) ?
> >> > Envoyé: Lundi 22 Janvier 2018 16:48:26
> >> > (PCRegister) ?
> >> > >> À: "Barry F. Smith" <bsmith at mcs.anl.gov>, "Franck Houssen"
> >> > >> Cc: "For users of the development version of PETSc"
> >> > >> Envoyé: Lundi 22 Janvier 2018 16:06:26
> >> > >> (PCRegister) ?
> >> > >> I used
> >> > >>   mkdir build; cd build
> >> > >>   PKG_CONFIG_PATH=$PETSC_DIR/$PETSC_ARCH/lib/pkgconfig:$SLEPC_DIR/$PETSC_ARCH/lib/pkgconfig
> >> > >>   cmake ..
> >> > >> and got a successful build.  Franck, you can have your CMakeLists.txt
> >> > >> add these paths to PKG_CONFIG_PATH before using pkgconfig.  It saves
> >> > >> time because it's the conventional way to specify PETSc libraries.
> >> > > You are right. I'll do that.
> >> > >> In general, when providing a test case, it's best to be precise and
> >> > >> complete.  It isn't a good use of Barry's time to expect him to
> >> > >> browse
> >> > >> around your github repository and find your wiki.
> >> > >> Anyway, I have it built, but I don't know what the "dummy test case"
> >> > >> is.
> >> > >> I tried tst/dummy/dummy.sh and got
> >> > > make all check
> >> > I'm on 'master' and getting usage errors along with
> >> >    Error: check argument KO
> >> > Am I supposed to ignore all these failures before modifying code in
> >> > search of a different error?
> >> In the dummy test case I added one line to run the app with --help: this
> >> is
> >> only for coverage purposes (this ends with "Error: check argument KO").
> >> ~/geneo4PETSc> head tst/dummy/dummy.sh
> >> #!/bin/bash
> >> @CMAKE_BINARY_DIR@/src/geneo4PETSc --help # Help for coverage.     <=====
> >> This is only for coverage
> >> echo "" # Add space for clarity.
> >> for f in "identity" "tridiag"                                      <======
> >> Here begins the test
> >> do
> >>   for p in "-igs_pc_type#bjacobi"                                  \
> >>   <====== OK
> >>                "-igs_pc_type#geneo#-geneo_lvl#ASM,0"               \
> >>                <====== Fails according to the diff
> >> Now run the dummy test case:
> >> ~/geneo4PETSc/BUILD> make all test ARGS="-V -R dummy" > OK.log (log
> >> attached)
> >> You see that, among others, this (sub) test has been ran OK (third solve):
> >> mpirun  -n 2  /tmp/BUILD/src/geneo4PETSc --inpFileA identity.inp
> >> --inpFileB
> >> B.inp -igs_pc_type geneo -geneo_lvl ASM,0 --verbose 2 -geneo_chk log
> >> -geneo_dbg log,2 --shortRes -igs_ksp_atol 1.e-12 -igs_ksp_rtol 1.e-12
> >> -options_left no --metisDual
> >> Now apply following modifications:
> >> >> git diff
> >> diff --git a/src/geneo.cpp b/src/geneo.cpp
> >> index b4a4ea6..3f9be0f 100644
> >> --- a/src/geneo.cpp
> >> +++ b/src/geneo.cpp
> >> @@ -2318,8 +2318,8 @@ static PetscErrorCode
> >>    options");
> >>    CHKERRQ(pcRC);
> >> -  pcRC = PetscOptionsBegin(PETSC_COMM_WORLD, NULL, "GenEO options",
> >> "GenEO
> >> options");
> >> -  CHKERRQ(pcRC);
> >> +  //pcRC = PetscOptionsBegin(PETSC_COMM_WORLD, NULL, "GenEO options",
> >> "GenEO
> >> options");
> >> +  //CHKERRQ(pcRC);
> >> @@ -2461,8 +2461,8 @@ static PetscErrorCode
> >>      gCtx->check = true;
> >> -  CHKERRQ(pcRC);
> >> +  //pcRC = PetscOptionsEnd();
> >> +  //CHKERRQ(pcRC);
> >>    CHKERRQ(pcRC);
> >> And rerun the dummy test:
> >> >> make all test ARGS="-V -R dummy" > KO.log
> >> Errors while running CTest
> >> make: *** [test] Error 8
> >> >> tail -n 20 KO.log
> >> 1:
> >> 1: mpirun  -n 2  /tmp/BUILD/src/geneo4PETSc --inpFileA identity.inp
> >> --inpFileB B.inp -igs_pc_type bjacobi --verbose 2 -geneo_chk log
> >> -geneo_dbg
> >> log,2 --shortRes -igs_ksp_atol 1.e-12 -igs_ksp_rtol 1.e-12 -options_left
> >> no
> >> --metisDual
> >> 1:
> >> -geneo_dbg
> >> no
> >> --metisNodal
> >> 1:
> >> --inpFileB B.inp -igs_pc_type geneo -geneo_lvl ASM,0 --verbose 2
> >> -geneo_chk
> >> log -geneo_dbg log,2 --shortRes -igs_ksp_atol 1.e-12 -igs_ksp_rtol 1.e-12
> >> 1:
> >> 1: 44c44
> >> 1: < INFO: geneo0ASM pc, L1 mumps no-proj-fine-space
> >> 1: ---
> >> 1: > INFO: geneo1ASM pc, L1 mumps no-proj-fine-space, tau 0.10, L2 arpack
> >> mumps
> >> 1/1 Test #1: dummy ............................***Failed    0.66 sec
> >> In tst/dummy, the same command line "mpirun  -n 2
> >> --inpFileA identity.inp --inpFileB B.inp -igs_pc_type geneo -geneo_lvl
> >> ASM,0
> >> --verbose 2 -geneo_chk log -geneo_dbg log,2 --shortRes -igs_ksp_atol
> >> 1.e-12
> >> -igs_ksp_rtol 1.e-12 -options_left no --metisDual" does not do the same
> >> thing with and without the modifications: this is because the options are
> >> not read correctly (seems the option database is empty)
> >> The correct behavior (no modif) is:
> >> >> -geneo_chk log -geneo_dbg log,2 --shortRes -igs_ksp_atol 1.e-12
> >> INFO: geneo0ASM pc, L1 mumps no-proj-fine-space  <===== you get geneo0ASM
> >> because you asked -geneo_lvl ASM,0
> >> The incorrect behavior (with modif) is:
> >> INFO: geneo1ASM pc, L1 mumps no-proj-fine-space, tau 0.10, L2 arpack mumps
> >> <======= you asked -geneo_lvl ASM,0 but you get the default
> >> parameter-geneo_lvl ASM,1 (=> geneo1ASM)
> >> Anyway, this is not so blocking as I have a bypass
> >> > > The diff of the firt test of the suite (called dummy) fails this way:
> >> > > 1: ---
> >> > > arpack
> >> > > mumps
> >> > >> Can you give the exact command to run and expected output?
> >> > >> "Smith, Barry F." <bsmith at mcs.anl.gov> writes:
> >> > >> >   I absolutely hate package configures that say they can't find
> >> > >> >   something
> >> > >> >   but give NO indication how to indicate the location of the
> >> > >> >   missing
> >> > >> >   thing.
> >> > >> > $ SLEPC_DIR=$SLEPC_DIR cmake ..
> >> > >> > -DBOOST_ROOT=/Users/barrysmith/Src/boost_1_66_0
> >> > >> > -DSLEPC_DIR=$SLEPC_DIR
> >> > >> > CMake Warning at
> >> > >> > /usr/local/Cellar/cmake/3.9.5/share/cmake/Modules/FindBoost.cmake:786
> >> > >> > (message):
> >> > >> >   New Boost version may have incorrect or missing dependencies and
> >> > >> >   imported
> >> > >> >   targets
> >> > >> > Call Stack (most recent call first):
> >> > >> >   /usr/local/Cellar/cmake/3.9.5/share/cmake/Modules/FindBoost.cmake:892
> >> > >> >   (_Boost_COMPONENT_DEPENDENCIES)
> >> > >> >   /usr/local/Cellar/cmake/3.9.5/share/cmake/Modules/FindBoost.cmake:1523
> >> > >> >   (_Boost_MISSING_DEPENDENCIES)
> >> > >> >   CMakeLists.txt:38 (find_package)
> >> > >> > CMake Warning at
> >> > >> > (message):
> >> > >> >   imported
> >> > >> >   targets
> >> > >> > -- Boost version: 1.66.0
> >> > >> > -- Found the following Boost libraries:
> >> > >> > --   mpi
> >> > >> > --   serialization
> >> > >> > -- Checking for module 'SLEPc>=3.8.1'
> >> > >> > --   No package 'SLEPc' found
> >> > >> > CMake Error at
> >> > >> > /usr/local/Cellar/cmake/3.9.5/share/cmake/Modules/FindPkgConfig.cmake:412
> >> > >> > (message):
> >> > >> >   A required package was not found
> >> > >> >   /usr/local/Cellar/cmake/3.9.5/share/cmake/Modules/FindPkgConfig.cmake:588
> >> > >> >   (_pkg_check_modules_internal)
> >> > >> >   CMakeLists.txt:42 (pkg_check_modules)
> >> > >> > -- Configuring incomplete, errors occurred!
> >> > >> > See also
> >> > >> > "/Users/barrysmith/Src/geneo4PETSc/BUILD/CMakeFiles/CMakeOutput.log".
> >> > >> > ~/Src/geneo4PETSc/BUILD (master=) arch-franck
> >> > >> > Note at first it could not find BOOST but told me to set the
> >> > >> > directory
> >> > >> > with
> >> > >> > exact syntax. That's the way it should always do it.
> >> > >> > SLEPC_ROOT also did not work, nor did SLEPc_ROOT ;(
> >> > >> > So please tell me how to work through this dependency hell.
> >> > >> >    Barry
> >> > >> >> On Jan 21, 2018, at 11:06 AM, Franck Houssen
> >> > >> >> wrote:
> >> > >> >> The last problem I had here was that, for now, I must use a
> >> > >> >> bypass:
> >> > >> >> calling  PetscOptionsBegin/End after/before PetscOptionsHead/Tail
> >> > >> >> in
> >> > >> >> the
> >> > >> >> setup callback defined on PCRegister.
> >> > >> >> git-clone https://github.com/fghoussen/geneo4PETSc, the dummy test
> >> > >> >> case
> >> > >> >> should run. Then comment lines 2321 and 2464 in geneo.cpp
> >> > >> >> (PetscOptionsBegin/End): the dummy test case should fail because
> >> > >> >> as
> >> > >> >> the
> >> > >> >> option database "seems" to be empty, the default parameter are
> >> > >> >> used
> >> > >> >> and
> >> > >> >> the name/version of the pc is not the expected one.
> >> > >> >> I believe (?) I use the correct PCRegister pattern
> >> > >> >> (PCSetFromOptions
> >> > >> >> between PCRegister and initGenEOPC). Either I'm wrong, or there is
> >> > >> >> something behind...
> >> > >> >> Franck
> >> > >> >> PS: still trying to get osx to work... (don't know mac/clang
> >> > >> >> enough,
> >> > >> >> and,
> >> > >> >> travis osx boxes are so slow to start and run - difficult to
> >> > >> >> test).
> >> > >> >> But
> >> > >> >> if you used to it, you'll probably get this to work.
> >> > >> >>> Envoyé: Mardi 2 Janvier 2018 15:15:25
> >> > >> >>> (PCRegister) ?
> >> > >> >>>> De: "Barry F. Smith" <bsmith at mcs.anl.gov>
> >> > >> >>>> Envoyé: Mardi 2 Janvier 2018 14:50:02
> >> > >> >>>> (PCRegister) ?
> >> > >> >>>>> On Jan 2, 2018, at 7:47 AM, Franck Houssen
> >> > >> >>>>> wrote:
> >> > >> >>>>> I'll try to fetch/pull the git clone: maybe there is a reg on
> >> > >> >>>>> the
> >> > >> >>>>> code
> >> > >> >>>>> level I am on.
> >> > >> >>>>  Unlikely.
> >> > >> >>>>   I'm afraid you need to use the debugger and slog through the
> >> > >> >>>>   call.
> >> > >> >>> OK, I'll do that ! For now, calling Begin/End is this only
> >> > >> >>> by-pass I
> >> > >> >>> have.
> >> > >> >>>> It    seems you are doing things ok so why this happens I cannot
> >> > >> >>>> explain.
> >> > >> >>>> We
> >> > >> >>>>   use this paradigm everywhere with options in PETSc and it
> >> > >> >>>>   always
> >> > >> >>>>   works
> >> > >> >>>>   so
> >> > >> >>>>   I am totally lost as to why it fails for you.
> >> > >> >>>>   Barry
> >> > >> >>>>>> Envoyé: Mardi 2 Janvier 2018 13:22:16
> >> > >> >>>>>> PC
> >> > >> >>>>>> (PCRegister) ?
> >> > >> >>>>>> static PetscErrorCode PCSetFromOptions_Jacobi(PetscOptionItems
> >> > >> >>>>>> *PetscOptionsObject,PC pc)
> >> > >> >>>>>> PC_Jacobi      *jac = (PC_Jacobi*)pc->data;
> >> > >> >>>>>> PetscErrorCode ierr;
> >> > >> >>>>>> PetscBool      flg;
> >> > >> >>>>>> PCJacobiType   deflt,type;
> >> > >> >>>>>> PetscFunctionBegin;
> >> > >> >>>>>> ierr = PCJacobiGetType(pc,&deflt);CHKERRQ(ierr);
> >> > >> >>>>>> ierr = PetscOptionsHead(PetscOptionsObject,"Jacobi
> >> > >> >>>>>> options");CHKERRQ(ierr);
> >> > >> >>>>>> ierr = PetscOptionsEnum("-pc_jacobi_type","How to construct
> >> > >> >>>>>> diagonal
> >> > >> >>>>>> matrix","PCJacobiSetType",PCJacobiTypes,(PetscEnum)deflt,(PetscEnum*)&type,&flg);CHKERRQ(ierr);
> >> > >> >>>>>> if (flg) {
> >> > >> >>>>>>   ierr = PCJacobiSetType(pc,type);CHKERRQ(ierr);
> >> > >> >>>>>> ierr = PetscOptionsBool("-pc_jacobi_abs","Use absolute values
> >> > >> >>>>>> of
> >> > >> >>>>>> diagaonal
> >> > >> >>>>>> entries","PCJacobiSetUseAbs",jac->useabs,&jac->useabs,NULL);CHKERRQ(ierr);
> >> > >> >>>>>> ierr = PetscOptionsTail();CHKERRQ(ierr);
> >> > >> >>>>>> PetscFunctionReturn(0);
> >> > >> >>>>>> Note how PetscOptionsHead() is called with the argument
> >> > >> >>>>>> PetscOptionsObject
> >> > >> >>>>> I do call PetscOptionsHead(PetscOptionsObject, ...);
> >> > >> >>>>>> which is passed in from above. My guess is that you don't
> >> > >> >>>>>> call it with this argument? You would get behavior you
> >> > >> >>>>>> describe
> >> > >> >>>>>> if
> >> > >> >>>>>> you
> >> > >> >>>>>> don't.
> >> > >> >>>>>> Please send your REAL setupfromoptions_mypc() not just pseudo
> >> > >> >>>>>> code.
> >> > >> >>>>> #define SETERRABT(msg)
> >> > >> >>>>> SETERRABORT(PETSC_COMM_WORLD,PETSC_ERR_ARG_NULL,msg)
> >> > >> >>>>> static PetscErrorCode setUpGenEOPCFromOptions(PetscOptionItems
> >> > >> >>>>> PetscOptionsObject, PC pcPC) {
> >> > >> >>>>> // Get the context.
> >> > >> >>>>> if (!pcPC) SETERRABT("GenEO preconditioner is invalid");
> >> > >> >>>>> geneoContext * gCtx = (geneoContext *) pcPC->data;
> >> > >> >>>>> if (!gCtx) SETERRABT("GenEO preconditioner without context");
> >> > >> >>>>> // Check arguments.
> >> > >> >>>>> "GenEO
> >> > >> >>>>> options");
> >> > >> >>>>> CHKERRQ(pcRC);
> >> > >> >>>>> options",
> >> > >> >>>>> "GenEO
> >> > >> >>>>> options");
> >> > >> >>>>> CHKERRQ(pcRC);
> >> > >> >>>>> char *args[2];
> >> > >> >>>>> pcRC = PetscOptionsStringArray("-geneo_lvl", "GenEO levels",
> >> > >> >>>>> "GenEO
> >> > >> >>>>> levels", args, &nbArgs, &pcHasOpt);
> >> > >> >>>>> CHKERRQ(pcRC);
> >> > >> >>>>> if (pcHasOpt) {
> >> > >> >>>>>> Barry
> >> > >> >>>>>>> On Jan 2, 2018, at 5:04 AM, Franck Houssen
> >> > >> >>>>>>>> Envoyé: Dimanche 31 Décembre 2017 23:41:42
> >> > >> >>>>>>>> PC
> >> > >> >>>>>>>> (PCRegister) ?
> >> > >> >>>>>>>>> On Dec 31, 2017, at 8:40 AM, Franck Houssen
> >> > >> >>>>>>>>> wrote:
> >> > >> >>>>>>>>> Seems finally, I got it to work.
> >> > >> >>>>>>>>> To get the options to work I had to call
> >> > >> >>>>>>>>> after/before
> >> > >> >>>>>>>>> PetscOptionsHead/Tail which is not what is done in the
> >> > >> >>>>>>>>> jacobi
> >> > >> >>>>>>>>> example:
> >> > >> >>>>>>>>> is
> >> > >> >>>>>>>>> this the right way to go ?
> >> > >> >>>>>>>> Something is wrong.
> >> > >> >>>>>>> I felt there was something wrong !...
> >> > >> >>>>>>>> PetscOptionsBegin/end are called in PCSetFromOptions()
> >> > >> >>>>>>>> that is suppose to wrap YOUR PCSetFromOptions_mypc().
> >> > >> >>>>>>> OK, sounds logical, that's how I expected things to be done.
> >> > >> >>>>>>> That's
> >> > >> >>>>>>> why
> >> > >> >>>>>>> I
> >> > >> >>>>>>> was suspicious: what worked should not !...
> >> > >> >>>>>>> I believed maybe the problem was connected to the fact that I
> >> > >> >>>>>>> do
> >> > >> >>>>>>> NOT
> >> > >> >>>>>>> use
> >> > >> >>>>>>> compose function, but, according to Matt's explanation, I
> >> > >> >>>>>>> would
> >> > >> >>>>>>> say
> >> > >> >>>>>>> no:
> >> > >> >>>>>>> the use of PetscComposeFunction seems independent from the
> >> > >> >>>>>>> PCSetFromOptions_mypc problem.
> >> > >> >>>>>>> Note: in my case, I believe I do not really need
> >> > >> >>>>>>> PetscCompose, I
> >> > >> >>>>>>> just
> >> > >> >>>>>>> need
> >> > >> >>>>>>> one (regular) function to initialize specific stuffs needed
> >> > >> >>>>>>> in
> >> > >> >>>>>>> my_pc
> >> > >> >>>>>>> (at
> >> > >> >>>>>>> least for a start). I can go to PetscCompose later if it
> >> > >> >>>>>>> turns
> >> > >> >>>>>>> out
> >> > >> >>>>>>> to
> >> > >> >>>>>>> be
> >> > >> >>>>>>> relevant (that's how I understand this).
> >> > >> >>>>>>>> Perhaps you are
> >> > >> >>>>>>>> calling PCSetFromOptions_mypc directly which you should
> >> > >> >>>>>>>> never
> >> > >> >>>>>>>> do.
> >> > >> >>>>>>> No, I don't call PCSetFromOptions_mypc directly.
> >> > >> >>>>>>>> Your PCCreate_mypc() should stick the function pointer for
> >> > >> >>>>>>>> PCSetFromOptions_mypc into the ops table like it does
> >> > >> >>>>>>>> PCApply_mypc
> >> > >> >>>>>>>> etc.
> >> > >> >>>>>>>> Then you just directly use PCSetFromOptions.
> >> > >> >>>>>>> create_mpc(PC pc) { // CB for PCRegister
> >> > >> >>>>>>> pcPC->ops->setfromoptions = setupfromoptions_mypc;
> >> > >> >>>>>>> static PetscErrorCode setupfromoptions_mypc(PetscOptionItems
> >> > >> >>>>>>> PetscOptionsHead()
> >> > >> >>>>>>> PetscOptionsBegin()
> >> > >> >>>>>>> PetscOptionsStringArray("-mypc_opt", ..., flag)
> >> > >> >>>>>>> cout << "debug " << flag << endl;
> >> > >> >>>>>>> PetscOptionsEnd()
> >> > >> >>>>>>> PetscOptionsTail()
> >> > >> >>>>>>> I got called on setupfromoptions_mypc when I call
> >> > >> >>>>>>> PCSetUpFromOptions().
> >> > >> >>>>>>> If I let PetscOptionsBegin/End, it looks like I read in the
> >> > >> >>>>>>> "correct"
> >> > >> >>>>>>> option data base, I get (cout) : "debug 1" (-my_opt is read)
> >> > >> >>>>>>> If I comment PetscOptionsBegin/End, seems I read an incorrect
> >> > >> >>>>>>> (empty
> >> > >> >>>>>>> option data base, I get (cout) : "debug 0"
> >> > >> >>>>>>> Looks weird even if it's not blocking for now (I know there
> >> > >> >>>>>>> is
> >> > >> >>>>>>> problem
> >> > >> >>>>>>> but
> >> > >> >>>>>>> I can by pass it)
> >> > >> >>>>>>>> Barry
> >> > >> >>>>>>>>> Franck
> >> > >> >>>>>>>>> PetscErrorCode PCSetFromOptions_mypc(PetscOptionItems *
> >> > >> >>>>>>>>> PetscOptionsObject,
> >> > >> >>>>>>>>> PC pcPC) {
> >> > >> >>>>>>>>> PetscOptionsHead
> >> > >> >>>>>>>>> PetscOptionsBegin
> >> > >> >>>>>>>>> ... // PetscOptionsStringArray
> >> > >> >>>>>>>>> PetscOptionsEnd
> >> > >> >>>>>>>>> PetscOptionsTail
> >> > >> >>>>>>>>>> Envoyé: Dimanche 31 Décembre 2017 15:01:43
> >> > >> >>>>>>>>>> registered
> >> > >> >>>>>>>>>> PC
> >> > >> >>>>>>>>>> (PCRegister) ?
> >> > >> >>>>>>>>>> Using PCSHELL means calling:
> >> > >> >>>>>>>>>> - PCShellSetSetUp, PCShellSetApply, PCShellSetDestroy to
> >> > >> >>>>>>>>>> set
> >> > >> >>>>>>>>>> callbacks.
> >> > >> >>>>>>>>>> - PCShellSetContext/PCShellGetContext to get/set context
> >> > >> >>>>>>>>>> in
> >> > >> >>>>>>>>>> callbacks.
> >> > >> >>>>>>>>>> To go from PCSHELL to PCRegister, one need to:
> >> > >> >>>>>>>>>> - #include <petsc/private/pcimpl.h> // Access to PC
> >> > >> >>>>>>>>>> data/struct.
> >> > >> >>>>>>>>>> - Set callbacks with pc->ops->...
> >> > >> >>>>>>>>>> - NO more use ANY shell methods (context, name), but, use
> >> > >> >>>>>>>>>> pc->data
> >> > >> >>>>>>>>>> instead.
> >> > >> >>>>>>>>>> - call PCRegister.
> >> > >> >>>>>>>>>> Correct ? Did I miss something ?
> >> > >> >>>>>>>>>> Seems I get things to work (without compose function).
> >> > >> >>>>>>>>>> The last problem I have is in the options: options are
> >> > >> >>>>>>>>>> passed
> >> > >> >>>>>>>>>> to
> >> > >> >>>>>>>>>> PetscInitialize but not found in the database (I mimic'ed
> >> > >> >>>>>>>>>> the
> >> > >> >>>>>>>>>> jacobi
> >> > >> >>>>>>>>>> example). Is there specific related to this ?
> >> > >> >>>>>>>>>>> Envoyé: Samedi 30 Décembre 2017 17:12:09
> >> > >> >>>>>>>>>>> registered
> >> > >> >>>>>>>>>>> PC
> >> > >> >>>>>>>>>>> (PCRegister) ?
> >> > >> >>>>>>>>>>> Don't get the link. I'll try first with independent
> >> > >> >>>>>>>>>>> function
> >> > >> >>>>>>>>>>> (no
> >> > >> >>>>>>>>>>> compose)
> >> > >> >>>>>>>>>>> and
> >> > >> >>>>>>>>>>> see if this can work at least for a start.
> >> > >> >>>>>>>>>>> Franck
> >> > >> >>>>>>>>>>>> Envoyé: Vendredi 29 Décembre 2017 17:55:30
> >> > >> >>>>>>>>>>>> registered
> >> > >> >>>>>>>>>>>> PC
> >> > >> >>>>>>>>>>>> (PCRegister) ?
> >> > >> >>>>>>>>>>>>> On Dec 29, 2017, at 9:03 AM, Franck Houssen
> >> > >> >>>>>>>>>>>>> wrote:
> >> > >> >>>>>>>>>>>>> OK, on the highway now (bad ssh !), I'll try to check
> >> > >> >>>>>>>>>>>>> this
> >> > >> >>>>>>>>>>>>> out.
> >> > >> >>>>>>>>>>>>>> Envoyé: Jeudi 28 Décembre 2017 18:21:48
> >> > >> >>>>>>>>>>>>>> registered
> >> > >> >>>>>>>>>>>>>> PC
> >> > >> >>>>>>>>>>>>>> (PCRegister) ?
> >> > >> >>>>>>>>>>>>>>> On Dec 28, 2017, at 10:34 AM, Franck Houssen
> >> > >> >>>>>>>>>>>>>>>> Envoyé: Jeudi 28 Décembre 2017 16:43:16
> >> > >> >>>>>>>>>>>>>>>> registered
> >> > >> >>>>>>>>>>>>>>>> PC
> >> > >> >>>>>>>>>>>>>>>> (PCRegister) ?
> >> > >> >>>>>>>>>>>>>>>> The register is for a new type of PC of which can
> >> > >> >>>>>>>>>>>>>>>> have
> >> > >> >>>>>>>>>>>>>>>> many
> >> > >> >>>>>>>>>>>>>>>> instantiations
> >> > >> >>>>>>>>>>>>>>>> at the same time.
> >> > >> >>>>>>>>>>>>>>> OK, I didn't get that that way ! I was looking for a
> >> > >> >>>>>>>>>>>>>>> way
> >> > >> >>>>>>>>>>>>>>> to
> >> > >> >>>>>>>>>>>>>>> plug
> >> > >> >>>>>>>>>>>>>>> "my"
> >> > >> >>>>>>>>>>>>>>> pc
> >> > >> >>>>>>>>>>>>>>> at
> >> > >> >>>>>>>>>>>>>>> the command line this way: -pc_type my_pc.
> >> > >> >>>>>>>>>>>>>>> I already call PCSetType(pc, PCSHELL) and
> >> > >> >>>>>>>>>>>>>>> PCShellSetName(pc,
> >> > >> >>>>>>>>>>>>>>> "my_pc"):
> >> > >> >>>>>>>>>>>>>>> maybe this already enables "-pc_type shell" or
> >> > >> >>>>>>>>>>>>>>> "-pc_type
> >> > >> >>>>>>>>>>>>>>> my_pc"...
> >> > >> >>>>>>>>>>>>>>> And
> >> > >> >>>>>>>>>>>>>>> I
> >> > >> >>>>>>>>>>>>>>> didn't know it ! :D I'll try that.
> >> > >> >>>>>>>>>>>>>>> I was looking for a way to integrate "my" (external)
> >> > >> >>>>>>>>>>>>>>> pc
> >> > >> >>>>>>>>>>>>>>> as
> >> > >> >>>>>>>>>>>>>>> any
> >> > >> >>>>>>>>>>>>>>> other
> >> > >> >>>>>>>>>>>>>>> regular/existing petsc pc (bjacobi, ...) like a kind
> >> > >> >>>>>>>>>>>>>>> of
> >> > >> >>>>>>>>>>>>>>> plugin
> >> > >> >>>>>>>>>>>>>>> but
> >> > >> >>>>>>>>>>>>>>> still
> >> > >> >>>>>>>>>>>>>>> integrated to the cmd line: I believed PCRegister was
> >> > >> >>>>>>>>>>>>>>> meant
> >> > >> >>>>>>>>>>>>>>> for
> >> > >> >>>>>>>>>>>>>>> that.
> >> > >> >>>>>>>>>>>>>> Indeed it is exactly what it is meant for.  Please try
> >> > >> >>>>>>>>>>>>>> to
> >> > >> >>>>>>>>>>>>>> follow
> >> > >> >>>>>>>>>>>>>> my
> >> > >> >>>>>>>>>>>>>> recipe
> >> > >> >>>>>>>>>>>>>> and let us know when you get stuck.
> >> > >> >>>>>>>>>>>>>>> Not sure if this is actually possible/enabled by the
> >> > >> >>>>>>>>>>>>>>> API.
> >> > >> >>>>>>>>>>>>>>>> For example
> >> > >> >>>>>>>>>>>>>>>> PCRegister("mypctype",mypc_create);
> >> > >> >>>>>>>>>>>>>>>> KSPCreate(&ksp1);
> >> > >> >>>>>>>>>>>>>>>> KSPCreate(&ksp2);
> >> > >> >>>>>>>>>>>>>>>> KSPGetPC(ksp1,&pc1);
> >> > >> >>>>>>>>>>>>>>>> KSPGetPC(ksp2,&pc2);
> >> > >> >>>>>>>>>>>>>>>> You don't want pc1 and pc2 to have the same dof
> >> > >> >>>>>>>>>>>>>>>> multiplicities,
> >> > >> >>>>>>>>>>>>>>>> domain
> >> > >> >>>>>>>>>>>>>>>> intersections etc since they are associated with
> >> > >> >>>>>>>>>>>>>>>> completely
> >> > >> >>>>>>>>>>>>>>>> different
> >> > >> >>>>>>>>>>>>>>>> linear systems and presumably meshes etc.
> >> > >> >>>>>>>>>>>>>>>> Presumably you want each of pc1, pc2, to have their
> >> > >> >>>>>>>>>>>>>>>> own
> >> > >> >>>>>>>>>>>>>>>> version
> >> > >> >>>>>>>>>>>>>>>> of
> >> > >> >>>>>>>>>>>>>>>> the
> >> > >> >>>>>>>>>>>>>>>> data so you need to stick it directly in the PC, for
> >> > >> >>>>>>>>>>>>>>>> example
> >> > >> >>>>>>>>>>>>>>>> PCMypcSetDOFMultiplicities(pc1,stuff);
> >> > >> >>>>>>>>>>>>>>>> PCMypcSetDOFMultiplicities(pc2,otherstuff);
> >> > >> >>>>>>>>>>>>> OK, I must provide/implement PCMypcSetDOFMultiplicities
> >> > >> >>>>>>>>>>>>> (add
> >> > >> >>>>>>>>>>>>> data
> >> > >> >>>>>>>>>>>>> to
> >> > >> >>>>>>>>>>>>> pc
> >> > >> >>>>>>>>>>>>> context) besides mypc_create: sounds logical.
> >> > >> >>>>>>>>>>>>> Is this OK if PCMypcSetDOFMultiplicities is independent
> >> > >> >>>>>>>>>>>>> from
> >> > >> >>>>>>>>>>>>> mypc_create
> >> > >> >>>>>>>>>>>>> I guess yes.
> >> > >> >>>>>>>>>>>>> From what I remember/understand, I got lost here: from
> >> > >> >>>>>>>>>>>>> the
> >> > >> >>>>>>>>>>>>> jacobi
> >> > >> >>>>>>>>>>>>> example,
> >> > >> >>>>>>>>>>>>> mypc_create looks to be supposed (?) to call some kind
> >> > >> >>>>>>>>>>>>> of
> >> > >> >>>>>>>>>>>>> Petsc*ComposeFunction to associate
> >> > >> >>>>>>>>>>>>> to
> >> > >> >>>>>>>>>>>>> the
> >> > >> >>>>>>>>>>>>> pc
> >> > >> >>>>>>>>>>>>> (correct ?)... But, in the jacobi example,
> >> > >> >>>>>>>>>>>>> PCJacobiGetUseAbs_Jacobi
> >> > >> >>>>>>>>>>>>> is
> >> > >> >>>>>>>>>>>>> associated to PCJacobiGetUseAbs_C...
> >> > >> >>>>>>>>>>>> the _C name is a string name that is used by PETSc to
> >> > >> >>>>>>>>>>>> "find"
> >> > >> >>>>>>>>>>>> the
> >> > >> >>>>>>>>>>>> correct
> >> > >> >>>>>>>>>>>> function pointer which is PCJacobiGetUseAbs_Jacobi.
> >> > >> >>>>>>>>>>>> There
> >> > >> >>>>>>>>>>>> is
> >> > >> >>>>>>>>>>>> no
> >> > >> >>>>>>>>>>>> _C function.
> >> > >> >>>>>>>>>>>>> Which turns out not to be implemented according to git
> >> > >> >>>>>>>>>>>>> grep
> >> > >> >>>>>>>>>>>>> Got
> >> > >> >>>>>>>>>>>>> lost
> >> > >> >>>>>>>>>>>>> here (and looked for a way to pass user data directly
> >> > >> >>>>>>>>>>>>> to
> >> > >> >>>>>>>>>>>>> PCRegister):
> >> > >> >>>>>>>>>>>>> is
> >> > >> >>>>>>>>>>>>> PCMypcSetDOFMultiplicities supposed to be
> >> > >> >>>>>>>>>>>>> "attached/composed"
> >> > >> >>>>>>>>>>>>> or
> >> > >> >>>>>>>>>>>>> independent from the pc ?
> >> > >> >>>>>>>>>>>> composed.
> >> > >> >>>>>>>>>>>>>>> git grep PCJacobiGetUseAbs_C
> >> > >> >>>>>>>>>>>>> src/ksp/pc/impls/jacobi/jacobi.c:  ierr =
> >> > >> >>>>>>>>>>>>> PetscObjectComposeFunction((PetscObject)pc,"PCJacobiGetUseAbs_C",PCJacobiGetUseAbs_Jacobi);CHKERRQ(ierr);
> >> > >> >>>>>>>>>>>>> PetscUseMethod(pc,"PCJacobiGetUseAbs_C",(PC,PetscBool*),(pc,flg));CHKERRQ(ierr);
> >> > >> >>>>>>>>>>>>> Sorry, for the short answer. Hope I succeeded to be
> >> > >> >>>>>>>>>>>>> clear
> >> > >> >>>>>>>>>>>>> enough.
> >> > >> >>>>>>>>>>>> Just copy jacobi.c and start converting it over to your
> >> > >> >>>>>>>>>>>> names
> >> > >> >>>>>>>>>>>> and
> >> > >> >>>>>>>>>>>> needs
> >> > >> >>>>>>>>>>>> and you'll see it is actually really straightforward and
> >> > >> >>>>>>>>>>>> not
> >> > >> >>>>>>>>>>>> as
> >> > >> >>>>>>>>>>>> complicated as you think it is.
> >> > >> >>>>>>>>>>>> Barry
> >> > >> >>>>>>>>>>>>>>>> You write as many of these Set() functions as you
> >> > >> >>>>>>>>>>>>>>>> need
> >> > >> >>>>>>>>>>>>>>>> for
> >> > >> >>>>>>>>>>>>>>>> your
> >> > >> >>>>>>>>>>>>>>>> PCtype.
> >> > >> >>>>>>>>>>>>>>>> You
> >> > >> >>>>>>>>>>>>>>>> store the data inside the PC_Mypc data structure you
> >> > >> >>>>>>>>>>>>>>>> create
> >> > >> >>>>>>>>>>>>>>>> with
> >> > >> >>>>>>>>>>>>>>>> mypc_create(). Look at PCCreate_Jacobi() and
> >> > >> >>>>>>>>>>>>>>>> PCJacobiSetType
> >> > >> >>>>>>>>>>>>>>>> for
> >> > >> >>>>>>>>>>>>>>>> the
> >> > >> >>>>>>>>>>>>>>>> pattern.
> >> > >> >>>>>>>>>>>>>>>> Barry
> >> > >> >>>>>>>>>>>>>>>>> On Dec 28, 2017, at 9:34 AM, Franck Houssen
> >> > >> >>>>>>>>>>>>>>>>> (PCRegister)
> >> > >> >>>>>>>>>>>>>>>>> At first, I expected the signature would be
> >> > >> >>>>>>>>>>>>>>>>> "PetscErrorCode
> >> > >> >>>>>>>>>>>>>>>>> PCRegister(const char sname[],PetscErrorCode
> >> > >> >>>>>>>>>>>>>>>>> (*function)(PC,
> >> > >> >>>>>>>>>>>>>>>>> void
> >> > >> >>>>>>>>>>>>>>>>> but
> >> > >> >>>>>>>>>>>>>>>>> it turns out to be "PetscErrorCode PCRegister(const
> >> > >> >>>>>>>>>>>>>>>>> char
> >> > >> >>>>>>>>>>>>>>>>> sname[],PetscErrorCode (*function)(PC))"
> >> > >> >>>>>>>>>>>>>>>>> I try to integrate a PC that needs A but also other
> >> > >> >>>>>>>>>>>>>>>>> informations
> >> > >> >>>>>>>>>>>>>>>>> (dof
> >> > >> >>>>>>>>>>>>>>>>> multiplicities, domain intersections that the user
> >> > >> >>>>>>>>>>>>>>>>> must
> >> > >> >>>>>>>>>>>>>>>>> provide).
> >> > >> >>>>>>>>>>>>>>>>> I
> >> > >> >>>>>>>>>>>>>>>>> guess
> >> > >> >>>>>>>>>>>>>>>>> I can get A with PCGetOperators in the setup
> >> > >> >>>>>>>>>>>>>>>>> callback
> >> > >> >>>>>>>>>>>>>>>>> of
> >> > >> >>>>>>>>>>>>>>>>> the
> >> > >> >>>>>>>>>>>>>>>>> PC.
> >> > >> >>>>>>>>>>>>>>>>> But
> >> > >> >>>>>>>>>>>>>>>>> still
> >> > >> >>>>>>>>>>>>>>>>> not sure how to pass the other informations if I
> >> > >> >>>>>>>>>>>>>>>>> get
> >> > >> >>>>>>>>>>>>>>>>> to
> >> > >> >>>>>>>>>>>>>>>>> use
> >> > >> >>>>>>>>>>>>>>>>> PCRegister.
> >> > >> >>>>>>>>>>>>>>>>> I
> >> > >> >>>>>>>>>>>>>>>>> looked a few examples in the bitbucket (jacobi:
> >> > >> >>>>>>>>>>>>>>>>> src/ksp/ksp/examples/tutorials/ex12.c and
> >> > >> >>>>>>>>>>>>>>>>> + SOR: src/ksp/pc/impls/sor/sor.c)... But didn't
> >> > >> >>>>>>>>>>>>>>>>> get
> >> > >> >>>>>>>>>>>>>>>>> any
> >> > >> >>>>>>>>>>>>>>>>> real
> >> > >> >>>>>>>>>>>>>>>>> relevant
> >> > >> >>>>>>>>>>>>>>>>> answer and feel a bit lost among the numerous pc
> >> > >> >>>>>>>>>>>>>>>>> The idea is: for now I use PCSetType(pc, PCSHELL)
> >> > >> >>>>>>>>>>>>>>>>> and
> >> > >> >>>>>>>>>>>>>>>>> PCShellSetContext
> >> > >> >>>>>>>>>>>>>>>>> with a context who knows the extra needed
> >> > >> >>>>>>>>>>>>>>>>> informations
> >> > >> >>>>>>>>>>>>>>>>> which
> >> > >> >>>>>>>>>>>>>>>>> is
> >> > >> >>>>>>>>>>>>>>>>> "not
> >> > >> >>>>>>>>>>>>>>>>> so
> >> > >> >>>>>>>>>>>>>>>>> handy" (that's OK as for now I am both the user and
> >> > >> >>>>>>>>>>>>>>>>> the
> >> > >> >>>>>>>>>>>>>>>>> PC
> >> > >> >>>>>>>>>>>>>>>>> provider).
> >> > >> >>>>>>>>>>>>>>>>> I'd
> >> > >> >>>>>>>>>>>>>>>>> like to package this in a more convenient way (a
> >> > >> >>>>>>>>>>>>>>>>> unique
> >> > >> >>>>>>>>>>>>>>>>> and
> >> > >> >>>>>>>>>>>>>>>>> "simple"
> >> > >> >>>>>>>>>>>>>>>>> call
> >> > >> >>>>>>>>>>>>>>>>> to PCRegister) to decouple the user from the PC
> >> > >> >>>>>>>>>>>>>>>>> machinery.
> >> > >> >>>>>>>>>>>>>>>>> Franck
> > [ 25%] Built target geneoLib
> > [ 50%] Built target geneo4PETSc
> > [ 75%] Built target genlaplacian
> > [100%] Built target gengraph
> > Running tests...
> > UpdateCTestConfiguration  from :/tmp/BUILD/DartConfiguration.tcl
> > Parse Config file:/tmp/BUILD/DartConfiguration.tcl
> > Test project /tmp/BUILD
> > Constructing a list of tests
> > Done constructing a list of tests
> > Updating test list for fixtures
> > Added 0 tests to meet fixture requirements
> > Checking test dependency graph...
> > Checking test dependency graph end
> > test 1
> >     Start 1: dummy
> > 1: Test command: /tmp/BUILD/tst/dummy/dummy.sh
> > 1: Test timeout computed to be: 1500
> > 1:
> > 1: usage: geneo4PETSc is an implementation of the GenEO preconditioner with
> > PETSc and SLEPc
> > 1:
> > 1:   -phelp,         print help related to PETSc
> > 1:   -shelp,         print help related to SLEPc
> > 1:   --help,         print help related to geneo4PETSc
> > 1:   --inpFileA F,   input file F describing the A matrix (mandatory)
> > 1:                   - a unique ID (number) is attributed to each degree of
> > freedom of the problem (described by A)
> > 1:                   - each line of the input file stands for one element
> > described like:
> > 1:                     - a list of n degrees of freedom (mandatory)
> > 1:                     - a "-" followed by a dense row ordered nxn matrix
> > (optional)
> > 1:                       note: if the dense matrix is not specified, a
> > default one is built with --inpEps
> > 1:                   you can pass arguments to the A matrix at the command
> > line using prefix -A_
> > 1:   --inpEps E,     epsilon used to tune the elementary matrix (defaults
> > to 0.0001)
> > 1:                   the default nDOF x nDOF elementary matrix is:
> > 1:                   | 1.+eps,  alpha,  alpha,  alpha, ... |
> > 1:                   |  alpha, 1.+eps,  alpha,  alpha, ... |
> > 1:                   |  alpha,  alpha, 1.+eps,  alpha, ... | where alpha =
> > -1./(nDOF-1)
> > 1:                   |  alpha,  alpha,  alpha, 1.+eps, ... |
> > 1:                   |    ...,    ...,    ...,    ..., ... |
> > 1:   --inpLibA L A,  input file describing the A matrix provided as a
> > library (.so)
> > 1:                   L: path to the library /path/to/libinput.so
> > 1:                   A: arguments to pass to the library (string)
> > 1:                      for geneo4PETSc, A must be one token, but for L, A
> > may be a list of (sub) tokens
> > 1:                      the geneo4PETSc token will be the concatenation of
> > all L sub tokens with #
> > 1:                      example: --inpLibA /path/to/lib
> > --param1=1#--param2=2#--param3=3
> > 1:                   the library must provide and implement the following
> > function
> > 1:                     /*
> > 1:                      * getInput: provide inputs (elements and associated
> > matrices) for domain decomposition
> > 1:                      *           each element is considered to be a set
> > of n DOFs
> > 1:                      * input parameter:
> > 1:                      *   - args: command line arguments passed to L
> > needed to create inputs (if any)
> > 1:                      * output parameters:
> > 1:                      *   - nbElem: number of elements
> > 1:                      *   - nbNode: number of nodes
> > 1:                      *   - elemPtr: list of element pointers (CSR
> > format)
> > 1:                      *   - elemIdx: list of element indices (CSR format)
> > 1:                      *   - elemSubMat: list of matrice associated to
> > each element
> > 1:                      *                 each matrice is a dense row
> > ordered nxn matrix (std::vector<double>)
> > 1:                      * return:
> > 1:                      *   - integer as return code (0 if OK, error code
> > otherwise)
> > 1:                      * linking:
> > 1:                      *   - use extern "C" to get a C style decoration of
> > symbols
> > 1:                      */
> > 1:                     int getInput(std::string const & args,
> > 1:                                  unsigned int & nbElem, unsigned int &
> > nbNode,
> > 1:                                  std::vector<unsigned int> & elemPtr,
> > std::vector<unsigned int> & elemIdx,
> > 1:                                  std::vector<std::vector<double>> &
> > elemSubMat)
> > 1:   --inpFileB F,   input file F describing the B vector
> > 1:                   - each line of the input file stands for one degree of
> > freedom described like:
> > 1:                     - one degree of freedom (mandatory)
> > 1:                     - one value (optional)
> > 1:                       note: if the value is not specified, the default
> > one is 1.
> > 1:                   you can pass arguments to the B vector at the command
> > line using prefix -B_
> > 1:   --metisDual,    use dual approach to partition input data with metis
> > (partition according to elements)
> > 1:                   each element belongs to one partition only
> > 1:   --metisNodal,   use nodal approach to partition input data with metis
> > (partition according to nodes)
> > 1:                   each element belongs to a partition if one of its
> > nodes does
> > 1:                   each element can belong to several partitions
> > 1:   --addOverlap L, add L layers of overlap at each domain borders
> > 1:   --debug F,      create debug files for steps before and after solve
> > (metis, A, B, X)
> > 1:                   F = log (ASCII file), bin (binary file) or mat (matlab
> > file)
> > 1:   --verbose V,    dump A, B and X
> > 1:                   V = 1: dumps X
> > 1:                   V = 2: dumps A, B and X
> > 1:   --timing,       print timing
> > 1:   --shortRes,     print short result status (makes output stable for
> > test suite checks)
> > 1:   --cmdLine,      print command line at the end of the log
> > 1:
> > 1: usage: implementation of GenEO (Domain Decomposition Method) with PETSc
> > and SLEPc
> > 1:
> > 1:   -geneo_lvl L1,L2 preconditioner with 2 levels L1 and L2
> > 1:                    L1 =   ASM = Additive Schwarz Method
> > 1:                    L1 =   RAS = Restricted Additive Schwarz method
> > 1:                    L1 =  SRAS = Symmetrized Restricted Additive Schwarz
> > method
> > 1:                    L1 =  ORAS = Optimized Restricted Additive Schwarz
> > method
> > 1:                    L1 = SORAS = Symmetrized Optimized Restricted
> > 1:                    L2 =     0 = do not use GenEO (enables to compare
> > 1-level with 2-levels methods)
> > 1:                    L2 =     1 =                  GenEO-1 (1st level
> > +  2d level [coarse space])
> > 1:                    L2 =    H1 =           hybrid GenEO-1 (1st level
> > [proj. fine space] +  2d level [coarse space])
> > 1:                    L2 =    E1 = efficient hybrid GenEO-1 (initial guess
> > [coarse space] + 1st level [proj. fine space])
> > 1:                    L2 =     2 =                  GenEO-2 (1st level
> > 1:                    L2 =    H2 =           hybrid GenEO-2 (1st level
> > 1:                    L2 =    E2 = efficient hybrid GenEO-2 (initial guess
> > 1:                    you can pass arguments to PETSc / SLEPc solvers at
> > the command line using prefix:
> > 1:                      -igs_  for iterative   global solve:
> > -igs_ksp_atol 1.e-06 -igs_ksp_rtol 1.e-06
> > 1:                      -dls1_ for      direct  local solve (level 1):
> > -dls1_pc_factor_mat_solver_package mumps
> > 1:                      -syl2_ for   sylvester  local solve (level 2):
> > -syl2_ksp_view
> > 1:                      -els2_ for       eigen  local solve (level 2):
> > -els2_eps_max_it 100 -els2_eps_type arnoldi
> > 1:                      -dcs2_ for      direct coarse solve (level 2):
> > -dcs2_pc_factor_mat_solver_package mumps
> > 1:                      -ubl2_ for upper bound  local solve (level 2):
> > -ubl2_eps_max_it 100
> > 1:                      -chks_ for customizing EPS solver used to check for
> > SPD (--check)
> > 1:                      -chkr_ for customizing basis vector used to check
> > for rank (--check)
> > 1:                    in case a solver diverges (for instance dcs2_), you
> > may add to the command line:
> > 1:                      -dcs2_ksp_view:        to see informations related
> > to the solve
> > 1:                      -mat_mumps_icntl_33 1: to ask mumps to compute the
> > determinant (if mumps is used)
> > 1:   -geneo_optim A   if an optimized method (ORAS, SORAS) is used as level
> > 1, a robin condition is used
> > 1:                    to modify the dirichlet matrix. robin = dirichlet +
> > optim * neumann (optim defaults to 0.)
> > 1:   -geneo_tau T     tau threshold (needed for GenEO - defaults to 0.1)
> > 1:   -geneo_gamma G   gamma threshold (needed for GenEO - defaults to 10.)
> > 1:   -geneo_cst       when using SORAS2 (or HSORAS) with GenEO2, do not
> > allow local variations of tau and gamma
> > 1:   -geneo_cut C     maximum number of local eigen vectors used to build Z
> > (defaults to false)
> > 1:   -geneo_no_syl    do not use Sylvester's law (inertia) to estimate the
> > number of eigen values used to build Z
> > 1:                    in case the eigen solver handles this estimation
> > (krylovschur), you don't need to do it
> > 1:   -geneo_offload   offload Z and E at master side (gather inputs, local
> > solve, scatter outputs)
> > 1:   -geneo_dbg F,D   create debug files
> > (matlab file)
> > 1:                    D = 1: timing and residual
> > 1:                    D = 2: global and local informations (timings may not
> > be relevant because of dumps)
> > 1:   -geneo_chk F     perform additional checks
> > 1:                      - check partition of unity
> > 1:                      - check matrices are SPD (with solvers prefixed
> > chks_)
> > 1:                      - check R from Z=QR (with solvers prefixed chkr_)
> > (matlab file)
> > 1:
> > 1: Error: check argument KO
> > 1:
> > 1:
> > -options_left no --metisNodal
> > 1:
> > 1:
> > 1: 44c44
> > 1: ---
> > mumps
> > 0% tests passed, 1 tests failed out of 1
> > Total Test time (real) =   0.66 sec
> > The following tests FAILED:
> > 	  1 - dummy (Failed)
> > Makefile:72: recipe for target 'test' failed
> > Running tests...
> > test 1
> >     Start 1: dummy
> > 1:
> > PETSc and SLEPc
> > 1:
> > described like:
> > (optional)
> > to 0.0001)
> > -1./(nDOF-1)
> > library (.so)
> > function
> > 1:                     /*
> > of n DOFs
> > format)
> > each element
> > 1:                      * return:
> > otherwise)
> > 1:                      * linking:
> > symbols
> > 1:                      */
> > nbNode,
> > elemSubMat)
> > one is 1.
> > nodes does
> > (metis, A, B, X)
> > file)
> > 1:                   V = 1: dumps X
> > test suite checks)
> > 1:
> > and SLEPc
> > 1:
> > method
> > method
> > -syl2_ksp_view
> > SPD (--check)
> > for rank (--check)
> > to the solve
> > (defaults to false)
> > (matlab file)
> > chks_)
> > (matlab file)
> > 1:
> > 1:
> > 1:
> > 1:
> > 1:
> > -igs_ksp_rtol 1.e-12 -options_left no --metisNodal
> > 1:
> > --inpFileB B.inp -igs_pc_type geneo -geneo_lvl ASM,1 --verbose 2
> > 1:
> > 1:
> > --inpFileB B.inp -igs_pc_type geneo -geneo_lvl ASM,1  --addOverlap 1
> > 1.e-12 -igs_ksp_rtol 1.e-12 -options_left no --metisDual
> > 1:
> > 1.e-12 -igs_ksp_rtol 1.e-12 -options_left no --metisNodal
> > 1:
> > --inpFileB B.inp -igs_pc_type geneo -geneo_lvl ASM,1  -geneo_offload
> > 1:
> > 1:
> > --inpFileB B.inp -igs_pc_type geneo -geneo_lvl ASM,H1 --verbose 2
> > 1:
> > 1:
> > --inpFileB B.inp -igs_pc_type geneo -geneo_lvl ASM,H1 --addOverlap 1
> > 1:
> > 1:
> > --inpFileB B.inp -igs_pc_type geneo -geneo_lvl ASM,H1 -geneo_offload
> > 1:
> > 1:
> > --inpFileB B.inp -igs_pc_type geneo -geneo_lvl ASM,E1 --verbose 2
> > 1:
> > 1:
> > --inpFileB B.inp -igs_pc_type geneo -geneo_lvl ASM,E1 --addOverlap 1
> > 1:
> > 1:
> > --inpFileB B.inp -igs_pc_type geneo -geneo_lvl ASM,E1 -geneo_offload
> > 1:
> > 1:
> > --inpFileB B.inp -igs_pc_type geneo -geneo_lvl SORAS,0 --verbose 2
> > 1:
> > 1:
> > --inpFileB B.inp -igs_pc_type geneo -geneo_lvl SORAS,2 --verbose 2
> > 1:
> > 1:
> > --inpFileB B.inp -igs_pc_type geneo -geneo_lvl SORAS,2  --addOverlap 1
> > 1:
> > 1:
> > --inpFileB B.inp -igs_pc_type geneo -geneo_lvl SORAS,2  -geneo_offload
> > 1:
> > 1:
> > --inpFileB B.inp -igs_pc_type geneo -geneo_lvl SORAS,H2 --verbose 2
> > 1:
> > 1:
> > --inpFileB B.inp -igs_pc_type geneo -geneo_lvl SORAS,H2 --addOverlap 1
> > 1:
> > 1:
> > --inpFileB B.inp -igs_pc_type geneo -geneo_lvl SORAS,H2 -geneo_offload
> > 1:
> > 1:
> > --inpFileB B.inp -igs_pc_type geneo -geneo_lvl SORAS,E2 --verbose 2
> > 1:
> > 1:
> > --inpFileB B.inp -igs_pc_type geneo -geneo_lvl SORAS,E2 --addOverlap 1
> > 1:
> > 1:
> > --inpFileB B.inp -igs_pc_type geneo -geneo_lvl SORAS,E2 -geneo_offload
> > 1:
> > 1:
> > 1: mpirun  -n 2  /tmp/BUILD/src/geneo4PETSc --inpFileA tridiag.inp --inpEps
> > 1. -igs_pc_type bjacobi --verbose 2 -geneo_chk log -geneo_dbg log,2
> > --metisDual
> > 1:
> > --metisNodal
> > 1:
> > 1. -igs_pc_type geneo -geneo_lvl ASM,0 --verbose 2 -geneo_chk log
> > 1:
> > 1:
> > 1. -igs_pc_type geneo -geneo_lvl ASM,1 --verbose 2 -geneo_chk log
> > 1:
> > 1:
> > 1. -igs_pc_type geneo -geneo_lvl ASM,1  --addOverlap 1 --verbose 2
> > 1:
> > 1:
> > 1. -igs_pc_type geneo -geneo_lvl ASM,1  -geneo_offload --verbose 2
> > 1:
> > 1:
> > 1. -igs_pc_type geneo -geneo_lvl ASM,H1 --verbose 2 -geneo_chk log
> > 1:
> > 1:
> > 1. -igs_pc_type geneo -geneo_lvl ASM,H1 --addOverlap 1 --verbose 2
> > 1:
> > 1:
> > 1. -igs_pc_type geneo -geneo_lvl ASM,H1 -geneo_offload --verbose 2
> > 1:
> > 1:
> > 1. -igs_pc_type geneo -geneo_lvl ASM,E1 --verbose 2 -geneo_chk log
> > 1:
> > 1:
> > 1. -igs_pc_type geneo -geneo_lvl ASM,E1 --addOverlap 1 --verbose 2
> > 1:
> > 1:
> > 1. -igs_pc_type geneo -geneo_lvl ASM,E1 -geneo_offload --verbose 2
> > 1:
> > 1:
> > 1. -igs_pc_type geneo -geneo_lvl SORAS,0 --verbose 2 -geneo_chk log
> > 1:
> > 1:
> > 1. -igs_pc_type geneo -geneo_lvl SORAS,2 --verbose 2 -geneo_chk log
> > 1:
> > 1:
> > 1. -igs_pc_type geneo -geneo_lvl SORAS,2  --addOverlap 1 --verbose 2
> > 1:
> > 1:
> > 1. -igs_pc_type geneo -geneo_lvl SORAS,2  -geneo_offload --verbose 2
> > 1:
> > 1:
> > 1. -igs_pc_type geneo -geneo_lvl SORAS,H2 --verbose 2 -geneo_chk log
> > 1:
> > 1:
> > 1. -igs_pc_type geneo -geneo_lvl SORAS,H2 --addOverlap 1 --verbose 2
> > 1:
> > 1:
> > 1. -igs_pc_type geneo -geneo_lvl SORAS,H2 -geneo_offload --verbose 2
> > 1:
> > 1:
> > 1. -igs_pc_type geneo -geneo_lvl SORAS,E2 --verbose 2 -geneo_chk log
> > 1:
> > 1:
> > 1. -igs_pc_type geneo -geneo_lvl SORAS,E2 --addOverlap 1 --verbose 2
> > 1:
> > 1:
> > 1. -igs_pc_type geneo -geneo_lvl SORAS,E2 -geneo_offload --verbose 2
> > 1:
> > 1:
> > 1: OK
> > 1/1 Test #1: dummy ............................   Passed   22.71 sec
> > The following tests passed:
> > 	dummy
> > 100% tests passed, 0 tests failed out of 1
> > Total Test time (real) =  22.71 sec
