[petsc-dev] Github/TravisCI: caching petsc fails - is there a workaround ?
    Satish Balay
    balay at mcs.anl.gov
    Tue Jan 23 11:52:47 CST 2018
BTW: - if you are doing some caching - you might be able to cache
prebuilt externalpackage includes/libraries - and avoid
--download-package option.
i.e use --with-package-include --with-package-lib options [or
--with-package-dir option - if autodetection works]
Satish
On Tue, 23 Jan 2018, Satish Balay wrote:
> Not sure I understand the issue here.
> But If you are looking for a way to force PETSc configure to always rebuild externalpackages - you can:
> rm -f PETSC_ARCH/lib/conf/pkg.*
> Satish
> On Tue, 23 Jan 2018, Franck Houssen wrote:
> > Hello,
> > On Github/TravisCI, caching petsc fails: is there a possible workaround ?
> > Let's emphasize this: as I suspect this could have deep impacts, I am not asking for a fix. I just would like to know if there's a (known ?) trick to workaround this.
> > Go here https://github.com/fghoussen/geneo4PETSc on branch "caching" (note that caching is OK for openmpi and boost).
> > Commit 611ee54 creates the cache (to be re-used by future commits).
> > Commit 0cffa91 try to reuse the cache but fails with " Downloaded metis could not be used. " line 2615 in the travis log (see also line 3255).
> > Commits cfa36ff and bf33c3b try to remove external packages (partially/totally) but unfortunately this does not help.
> > And... I am left with no more idea / solution.
> > Is there some kind of trick like "removing CMakeCache.txt when using cmake" to "screw" the configure and let him think he has to restart everything even if "everything" (compilation objects) are already there ? (save compilation time)
> > I would totally understand you don't want to invest time on this. But if there is a know solution, this will be helpful.
> > Franck
> > Note: if you are not familiar with TravisCI, here is how its works. You have a 49 minutes time slot to go. If you go linux, you get a trusty (= ubuntu-2014-LTS...) what is more than 30 minutes long to upgrade (upgrade OS + compile openmpi boost petsc slepc which are outdated even after upgrade). If you go osx, both starting and running a job are VERY slow (5 to 10 h to start, slow build and no time to do what you would have done with linux - got no idea why ?!...). So all this to say that the time you have left for testing is significantly reduced. At this point caching is really critical...
