[petsc-dev] How to pass user data to a registered PC (PCRegister) ?
Franck Houssen
franck.houssen at inria.fr
Mon Jan 22 11:04:29 CST 2018
Forgot the logs !
----- Mail original -----
> De: "Franck Houssen" <franck.houssen at inria.fr>
> À: "Jed Brown" <jed at jedbrown.org>
> Cc: "Barry F. Smith" <bsmith at mcs.anl.gov>, "For users of the development version of PETSc" <petsc-dev at mcs.anl.gov>
> Envoyé: Lundi 22 Janvier 2018 18:03:20
> Objet: Re: [petsc-dev] How to pass user data to a registered PC (PCRegister) ?
> > De: "Jed Brown" <jed at jedbrown.org>
> > À: "Franck Houssen" <franck.houssen at inria.fr>
> > Envoyé: Lundi 22 Janvier 2018 16:48:26
> > (PCRegister) ?
> > Franck Houssen <franck.houssen at inria.fr> writes:
> > >> À: "Barry F. Smith" <bsmith at mcs.anl.gov>, "Franck Houssen"
> > >> Cc: "For users of the development version of PETSc"
> > >> Envoyé: Lundi 22 Janvier 2018 16:06:26
> > >> (PCRegister) ?
> > >> I used
> > >> mkdir build; cd build
> > >> PKG_CONFIG_PATH=$PETSC_DIR/$PETSC_ARCH/lib/pkgconfig:$SLEPC_DIR/$PETSC_ARCH/lib/pkgconfig
> > >> cmake ..
> > >> and got a successful build. Franck, you can have your CMakeLists.txt
> > >> add these paths to PKG_CONFIG_PATH before using pkgconfig. It saves
> > >> time because it's the conventional way to specify PETSc libraries.
> > > You are right. I'll do that.
> > >> In general, when providing a test case, it's best to be precise and
> > >> complete. It isn't a good use of Barry's time to expect him to browse
> > >> around your github repository and find your wiki.
> > >> Anyway, I have it built, but I don't know what the "dummy test case" is.
> > >> I tried tst/dummy/dummy.sh and got
> > > make all check
> > I'm on 'master' and getting usage errors along with
> > Error: check argument KO
> > Am I supposed to ignore all these failures before modifying code in
> > search of a different error?
> In the dummy test case I added one line to run the app with --help: this is
> only for coverage purposes (this ends with "Error: check argument KO").
> ~/geneo4PETSc> head tst/dummy/dummy.sh
> #!/bin/bash
> @CMAKE_BINARY_DIR@/src/geneo4PETSc --help # Help for coverage. <=====
> This is only for coverage
> echo "" # Add space for clarity.
> for f in "identity" "tridiag" <======
> Here begins the test
> do
> for p in "-igs_pc_type#bjacobi" \
> <====== OK
> "-igs_pc_type#geneo#-geneo_lvl#ASM,0" \
> <====== Fails according to the diff
> Now run the dummy test case:
> ~/geneo4PETSc/BUILD> make all test ARGS="-V -R dummy" > OK.log (log attached)
> You see that, among others, this (sub) test has been ran OK (third solve):
> mpirun -n 2 /tmp/BUILD/src/geneo4PETSc --inpFileA identity.inp --inpFileB
> B.inp -igs_pc_type geneo -geneo_lvl ASM,0 --verbose 2 -geneo_chk log
> -geneo_dbg log,2 --shortRes -igs_ksp_atol 1.e-12 -igs_ksp_rtol 1.e-12
> -options_left no --metisDual
> Now apply following modifications:
> >> git diff
> diff --git a/src/geneo.cpp b/src/geneo.cpp
> index b4a4ea6..3f9be0f 100644
> --- a/src/geneo.cpp
> +++ b/src/geneo.cpp
> @@ -2318,8 +2318,8 @@ static PetscErrorCode
> setUpGenEOPCFromOptions(PetscOptionItems * PetscOptionsObj
> PetscErrorCode pcRC = PetscOptionsHead(PetscOptionsObject, "GenEO
> options");
> CHKERRQ(pcRC);
> - pcRC = PetscOptionsBegin(PETSC_COMM_WORLD, NULL, "GenEO options", "GenEO
> options");
> - CHKERRQ(pcRC);
> + //pcRC = PetscOptionsBegin(PETSC_COMM_WORLD, NULL, "GenEO options", "GenEO
> options");
> + //CHKERRQ(pcRC);
> PetscBool pcHasOpt = PETSC_FALSE;
> PetscInt nbArgs = 2;
> @@ -2461,8 +2461,8 @@ static PetscErrorCode
> gCtx->check = true;
> - pcRC = PetscOptionsEnd();
> - CHKERRQ(pcRC);
> + //pcRC = PetscOptionsEnd();
> + //CHKERRQ(pcRC);
> pcRC = PetscOptionsTail();
> CHKERRQ(pcRC);
> And rerun the dummy test:
> >> make all test ARGS="-V -R dummy" > KO.log
> Errors while running CTest
> make: *** [test] Error 8
> >> tail -n 20 KO.log
> 1:
> 1: mpirun -n 2 /tmp/BUILD/src/geneo4PETSc --inpFileA identity.inp
> --inpFileB B.inp -igs_pc_type bjacobi --verbose 2 -geneo_chk log -geneo_dbg
> log,2 --shortRes -igs_ksp_atol 1.e-12 -igs_ksp_rtol 1.e-12 -options_left no
> --metisDual
> 1:
> --metisNodal
> 1:
> --inpFileB B.inp -igs_pc_type geneo -geneo_lvl ASM,0 --verbose 2 -geneo_chk
> log -geneo_dbg log,2 --shortRes -igs_ksp_atol 1.e-12 -igs_ksp_rtol 1.e-12
> 1:
> 1: 44c44
> 1: < INFO: geneo0ASM pc, L1 mumps no-proj-fine-space
> 1: ---
> 1: > INFO: geneo1ASM pc, L1 mumps no-proj-fine-space, tau 0.10, L2 arpack
> mumps
> 1/1 Test #1: dummy ............................***Failed 0.66 sec
> In tst/dummy, the same command line "mpirun -n 2 /tmp/BUILD/src/geneo4PETSc
> --inpFileA identity.inp --inpFileB B.inp -igs_pc_type geneo -geneo_lvl ASM,0
> --verbose 2 -geneo_chk log -geneo_dbg log,2 --shortRes -igs_ksp_atol 1.e-12
> -igs_ksp_rtol 1.e-12 -options_left no --metisDual" does not do the same
> thing with and without the modifications: this is because the options are
> not read correctly (seems the option database is empty)
> The correct behavior (no modif) is:
> INFO: geneo0ASM pc, L1 mumps no-proj-fine-space <===== you get geneo0ASM
> because you asked -geneo_lvl ASM,0
> The incorrect behavior (with modif) is:
> INFO: geneo1ASM pc, L1 mumps no-proj-fine-space, tau 0.10, L2 arpack mumps
> <======= you asked -geneo_lvl ASM,0 but you get the default
> parameter-geneo_lvl ASM,1 (=> geneo1ASM)
> Anyway, this is not so blocking as I have a bypass
> > > The diff of the firt test of the suite (called dummy) fails this way:
> > > 1: ---
> > > mumps
> > >> Can you give the exact command to run and expected output?
> > >> "Smith, Barry F." <bsmith at mcs.anl.gov> writes:
> > >> > I absolutely hate package configures that say they can't find
> > >> > something
> > >> > but give NO indication how to indicate the location of the missing
> > >> > thing.
> > >> > $ SLEPC_DIR=$SLEPC_DIR cmake ..
> > >> > -DBOOST_ROOT=/Users/barrysmith/Src/boost_1_66_0 -DSLEPC_DIR=$SLEPC_DIR
> > >> > CMake Warning at
> > >> > /usr/local/Cellar/cmake/3.9.5/share/cmake/Modules/FindBoost.cmake:786
> > >> > (message):
> > >> > New Boost version may have incorrect or missing dependencies and
> > >> > imported
> > >> > targets
> > >> > Call Stack (most recent call first):
> > >> > /usr/local/Cellar/cmake/3.9.5/share/cmake/Modules/FindBoost.cmake:892
> > >> > (_Boost_COMPONENT_DEPENDENCIES)
> > >> > /usr/local/Cellar/cmake/3.9.5/share/cmake/Modules/FindBoost.cmake:1523
> > >> > (_Boost_MISSING_DEPENDENCIES)
> > >> > CMakeLists.txt:38 (find_package)
> > >> > CMake Warning at
> > >> > (message):
> > >> > imported
> > >> > targets
> > >> > -- Boost version: 1.66.0
> > >> > -- Found the following Boost libraries:
> > >> > -- mpi
> > >> > -- serialization
> > >> > -- Checking for module 'SLEPc>=3.8.1'
> > >> > -- No package 'SLEPc' found
> > >> > CMake Error at
> > >> > /usr/local/Cellar/cmake/3.9.5/share/cmake/Modules/FindPkgConfig.cmake:412
> > >> > (message):
> > >> > A required package was not found
> > >> > /usr/local/Cellar/cmake/3.9.5/share/cmake/Modules/FindPkgConfig.cmake:588
> > >> > (_pkg_check_modules_internal)
> > >> > CMakeLists.txt:42 (pkg_check_modules)
> > >> > -- Configuring incomplete, errors occurred!
> > >> > See also
> > >> > "/Users/barrysmith/Src/geneo4PETSc/BUILD/CMakeFiles/CMakeOutput.log".
> > >> > ~/Src/geneo4PETSc/BUILD (master=) arch-franck
> > >> > Note at first it could not find BOOST but told me to set the directory
> > >> > with
> > >> > exact syntax. That's the way it should always do it.
> > >> > SLEPC_ROOT also did not work, nor did SLEPc_ROOT ;(
> > >> > So please tell me how to work through this dependency hell.
> > >> > Barry
> > >> >> On Jan 21, 2018, at 11:06 AM, Franck Houssen
> > >> >> wrote:
> > >> >> The last problem I had here was that, for now, I must use a bypass:
> > >> >> calling PetscOptionsBegin/End after/before PetscOptionsHead/Tail in
> > >> >> the
> > >> >> setup callback defined on PCRegister.
> > >> >> git-clone https://github.com/fghoussen/geneo4PETSc, the dummy test
> > >> >> case
> > >> >> should run. Then comment lines 2321 and 2464 in geneo.cpp
> > >> >> (PetscOptionsBegin/End): the dummy test case should fail because as
> > >> >> the
> > >> >> option database "seems" to be empty, the default parameter are used
> > >> >> and
> > >> >> the name/version of the pc is not the expected one.
> > >> >> I believe (?) I use the correct PCRegister pattern (PCSetFromOptions
> > >> >> between PCRegister and initGenEOPC). Either I'm wrong, or there is
> > >> >> something behind...
> > >> >> Franck
> > >> >> PS: still trying to get osx to work... (don't know mac/clang enough,
> > >> >> and,
> > >> >> travis osx boxes are so slow to start and run - difficult to test).
> > >> >> But
> > >> >> if you used to it, you'll probably get this to work.
> > >> >>> Envoyé: Mardi 2 Janvier 2018 15:15:25
> > >> >>> (PCRegister) ?
> > >> >>>> De: "Barry F. Smith" <bsmith at mcs.anl.gov>
> > >> >>>> Envoyé: Mardi 2 Janvier 2018 14:50:02
> > >> >>>> (PCRegister) ?
> > >> >>>>> On Jan 2, 2018, at 7:47 AM, Franck Houssen
> > >> >>>>> wrote:
> > >> >>>>> I'll try to fetch/pull the git clone: maybe there is a reg on the
> > >> >>>>> code
> > >> >>>>> level I am on.
> > >> >>>> Unlikely.
> > >> >>>> I'm afraid you need to use the debugger and slog through the
> > >> >>>> call.
> > >> >>> OK, I'll do that ! For now, calling Begin/End is this only by-pass I
> > >> >>> have.
> > >> >>>> It seems you are doing things ok so why this happens I cannot
> > >> >>>> explain.
> > >> >>>> We
> > >> >>>> use this paradigm everywhere with options in PETSc and it always
> > >> >>>> works
> > >> >>>> so
> > >> >>>> I am totally lost as to why it fails for you.
> > >> >>>> Barry
> > >> >>>>>> Envoyé: Mardi 2 Janvier 2018 13:22:16
> > >> >>>>>> (PCRegister) ?
> > >> >>>>>> static PetscErrorCode PCSetFromOptions_Jacobi(PetscOptionItems
> > >> >>>>>> *PetscOptionsObject,PC pc)
> > >> >>>>>> PC_Jacobi *jac = (PC_Jacobi*)pc->data;
> > >> >>>>>> PetscErrorCode ierr;
> > >> >>>>>> PetscBool flg;
> > >> >>>>>> PCJacobiType deflt,type;
> > >> >>>>>> PetscFunctionBegin;
> > >> >>>>>> ierr = PCJacobiGetType(pc,&deflt);CHKERRQ(ierr);
> > >> >>>>>> ierr = PetscOptionsHead(PetscOptionsObject,"Jacobi
> > >> >>>>>> options");CHKERRQ(ierr);
> > >> >>>>>> ierr = PetscOptionsEnum("-pc_jacobi_type","How to construct
> > >> >>>>>> diagonal
> > >> >>>>>> matrix","PCJacobiSetType",PCJacobiTypes,(PetscEnum)deflt,(PetscEnum*)&type,&flg);CHKERRQ(ierr);
> > >> >>>>>> if (flg) {
> > >> >>>>>> ierr = PCJacobiSetType(pc,type);CHKERRQ(ierr);
> > >> >>>>>> ierr = PetscOptionsBool("-pc_jacobi_abs","Use absolute values of
> > >> >>>>>> diagaonal
> > >> >>>>>> entries","PCJacobiSetUseAbs",jac->useabs,&jac->useabs,NULL);CHKERRQ(ierr);
> > >> >>>>>> ierr = PetscOptionsTail();CHKERRQ(ierr);
> > >> >>>>>> PetscFunctionReturn(0);
> > >> >>>>>> Note how PetscOptionsHead() is called with the argument
> > >> >>>>>> PetscOptionsObject
> > >> >>>>> I do call PetscOptionsHead(PetscOptionsObject, ...);
> > >> >>>>>> which is passed in from above. My guess is that you don't
> > >> >>>>>> call it with this argument? You would get behavior you describe
> > >> >>>>>> if
> > >> >>>>>> you
> > >> >>>>>> don't.
> > >> >>>>>> Please send your REAL setupfromoptions_mypc() not just pseudo
> > >> >>>>>> code.
> > >> >>>>> #define SETERRABT(msg)
> > >> >>>>> SETERRABORT(PETSC_COMM_WORLD,PETSC_ERR_ARG_NULL,msg)
> > >> >>>>> static PetscErrorCode setUpGenEOPCFromOptions(PetscOptionItems *
> > >> >>>>> PetscOptionsObject, PC pcPC) {
> > >> >>>>> // Get the context.
> > >> >>>>> if (!pcPC) SETERRABT("GenEO preconditioner is invalid");
> > >> >>>>> geneoContext * gCtx = (geneoContext *) pcPC->data;
> > >> >>>>> if (!gCtx) SETERRABT("GenEO preconditioner without context");
> > >> >>>>> // Check arguments.
> > >> >>>>> options");
> > >> >>>>> CHKERRQ(pcRC);
> > >> >>>>> "GenEO
> > >> >>>>> options");
> > >> >>>>> CHKERRQ(pcRC);
> > >> >>>>> char *args[2];
> > >> >>>>> pcRC = PetscOptionsStringArray("-geneo_lvl", "GenEO levels",
> > >> >>>>> "GenEO
> > >> >>>>> levels", args, &nbArgs, &pcHasOpt);
> > >> >>>>> CHKERRQ(pcRC);
> > >> >>>>> if (pcHasOpt) {
> > >> >>>>>> Barry
> > >> >>>>>>> On Jan 2, 2018, at 5:04 AM, Franck Houssen
> > >> >>>>>>>> Envoyé: Dimanche 31 Décembre 2017 23:41:42
> > >> >>>>>>>> (PCRegister) ?
> > >> >>>>>>>>> On Dec 31, 2017, at 8:40 AM, Franck Houssen
> > >> >>>>>>>>> wrote:
> > >> >>>>>>>>> Seems finally, I got it to work.
> > >> >>>>>>>>> To get the options to work I had to call PetscOptionsBegin/End
> > >> >>>>>>>>> after/before
> > >> >>>>>>>>> PetscOptionsHead/Tail which is not what is done in the jacobi
> > >> >>>>>>>>> example:
> > >> >>>>>>>>> is
> > >> >>>>>>>>> this the right way to go ?
> > >> >>>>>>>> Something is wrong.
> > >> >>>>>>> I felt there was something wrong !...
> > >> >>>>>>>> PetscOptionsBegin/end are called in PCSetFromOptions()
> > >> >>>>>>>> that is suppose to wrap YOUR PCSetFromOptions_mypc().
> > >> >>>>>>> OK, sounds logical, that's how I expected things to be done.
> > >> >>>>>>> That's
> > >> >>>>>>> why
> > >> >>>>>>> I
> > >> >>>>>>> was suspicious: what worked should not !...
> > >> >>>>>>> I believed maybe the problem was connected to the fact that I do
> > >> >>>>>>> NOT
> > >> >>>>>>> use
> > >> >>>>>>> compose function, but, according to Matt's explanation, I would
> > >> >>>>>>> say
> > >> >>>>>>> no:
> > >> >>>>>>> the use of PetscComposeFunction seems independent from the
> > >> >>>>>>> PCSetFromOptions_mypc problem.
> > >> >>>>>>> Note: in my case, I believe I do not really need PetscCompose, I
> > >> >>>>>>> just
> > >> >>>>>>> need
> > >> >>>>>>> one (regular) function to initialize specific stuffs needed in
> > >> >>>>>>> my_pc
> > >> >>>>>>> (at
> > >> >>>>>>> least for a start). I can go to PetscCompose later if it turns
> > >> >>>>>>> out
> > >> >>>>>>> to
> > >> >>>>>>> be
> > >> >>>>>>> relevant (that's how I understand this).
> > >> >>>>>>>> Perhaps you are
> > >> >>>>>>>> calling PCSetFromOptions_mypc directly which you should never
> > >> >>>>>>>> do.
> > >> >>>>>>> No, I don't call PCSetFromOptions_mypc directly.
> > >> >>>>>>>> Your PCCreate_mypc() should stick the function pointer for
> > >> >>>>>>>> PCSetFromOptions_mypc into the ops table like it does
> > >> >>>>>>>> PCApply_mypc
> > >> >>>>>>>> etc.
> > >> >>>>>>>> Then you just directly use PCSetFromOptions.
> > >> >>>>>>> create_mpc(PC pc) { // CB for PCRegister
> > >> >>>>>>> pcPC->ops->setfromoptions = setupfromoptions_mypc;
> > >> >>>>>>> static PetscErrorCode setupfromoptions_mypc(PetscOptionItems *
> > >> >>>>>>> PetscOptionsHead()
> > >> >>>>>>> PetscOptionsBegin()
> > >> >>>>>>> PetscOptionsStringArray("-mypc_opt", ..., flag)
> > >> >>>>>>> cout << "debug " << flag << endl;
> > >> >>>>>>> PetscOptionsEnd()
> > >> >>>>>>> PetscOptionsTail()
> > >> >>>>>>> I got called on setupfromoptions_mypc when I call
> > >> >>>>>>> PCSetUpFromOptions().
> > >> >>>>>>> If I let PetscOptionsBegin/End, it looks like I read in the
> > >> >>>>>>> "correct"
> > >> >>>>>>> option data base, I get (cout) : "debug 1" (-my_opt is read)
> > >> >>>>>>> If I comment PetscOptionsBegin/End, seems I read an incorrect
> > >> >>>>>>> (empty
> > >> >>>>>>> option data base, I get (cout) : "debug 0"
> > >> >>>>>>> Looks weird even if it's not blocking for now (I know there is
> > >> >>>>>>> problem
> > >> >>>>>>> but
> > >> >>>>>>> I can by pass it)
> > >> >>>>>>>> Barry
> > >> >>>>>>>>> Franck
> > >> >>>>>>>>> PetscErrorCode PCSetFromOptions_mypc(PetscOptionItems *
> > >> >>>>>>>>> PetscOptionsObject,
> > >> >>>>>>>>> PC pcPC) {
> > >> >>>>>>>>> PetscOptionsHead
> > >> >>>>>>>>> PetscOptionsBegin
> > >> >>>>>>>>> ... // PetscOptionsStringArray
> > >> >>>>>>>>> PetscOptionsEnd
> > >> >>>>>>>>> PetscOptionsTail
> > >> >>>>>>>>>> Envoyé: Dimanche 31 Décembre 2017 15:01:43
> > >> >>>>>>>>>> PC
> > >> >>>>>>>>>> (PCRegister) ?
> > >> >>>>>>>>>> Using PCSHELL means calling:
> > >> >>>>>>>>>> - PCShellSetSetUp, PCShellSetApply, PCShellSetDestroy to set
> > >> >>>>>>>>>> callbacks.
> > >> >>>>>>>>>> - PCShellSetContext/PCShellGetContext to get/set context in
> > >> >>>>>>>>>> callbacks.
> > >> >>>>>>>>>> To go from PCSHELL to PCRegister, one need to:
> > >> >>>>>>>>>> - #include <petsc/private/pcimpl.h> // Access to PC
> > >> >>>>>>>>>> data/struct.
> > >> >>>>>>>>>> - Set callbacks with pc->ops->...
> > >> >>>>>>>>>> - NO more use ANY shell methods (context, name), but, use
> > >> >>>>>>>>>> pc->data
> > >> >>>>>>>>>> instead.
> > >> >>>>>>>>>> - call PCRegister.
> > >> >>>>>>>>>> Correct ? Did I miss something ?
> > >> >>>>>>>>>> Seems I get things to work (without compose function).
> > >> >>>>>>>>>> The last problem I have is in the options: options are passed
> > >> >>>>>>>>>> to
> > >> >>>>>>>>>> PetscInitialize but not found in the database (I mimic'ed the
> > >> >>>>>>>>>> jacobi
> > >> >>>>>>>>>> example). Is there specific related to this ?
> > >> >>>>>>>>>>> Envoyé: Samedi 30 Décembre 2017 17:12:09
> > >> >>>>>>>>>>> PC
> > >> >>>>>>>>>>> (PCRegister) ?
> > >> >>>>>>>>>>> Don't get the link. I'll try first with independent function
> > >> >>>>>>>>>>> (no
> > >> >>>>>>>>>>> compose)
> > >> >>>>>>>>>>> and
> > >> >>>>>>>>>>> see if this can work at least for a start.
> > >> >>>>>>>>>>> Franck
> > >> >>>>>>>>>>>> Envoyé: Vendredi 29 Décembre 2017 17:55:30
> > >> >>>>>>>>>>>> registered
> > >> >>>>>>>>>>>> PC
> > >> >>>>>>>>>>>> (PCRegister) ?
> > >> >>>>>>>>>>>>> On Dec 29, 2017, at 9:03 AM, Franck Houssen
> > >> >>>>>>>>>>>>> wrote:
> > >> >>>>>>>>>>>>> OK, on the highway now (bad ssh !), I'll try to check this
> > >> >>>>>>>>>>>>> out.
> > >> >>>>>>>>>>>>>> Envoyé: Jeudi 28 Décembre 2017 18:21:48
> > >> >>>>>>>>>>>>>> registered
> > >> >>>>>>>>>>>>>> PC
> > >> >>>>>>>>>>>>>> (PCRegister) ?
> > >> >>>>>>>>>>>>>>> On Dec 28, 2017, at 10:34 AM, Franck Houssen
> > >> >>>>>>>>>>>>>>>> Envoyé: Jeudi 28 Décembre 2017 16:43:16
> > >> >>>>>>>>>>>>>>>> registered
> > >> >>>>>>>>>>>>>>>> PC
> > >> >>>>>>>>>>>>>>>> (PCRegister) ?
> > >> >>>>>>>>>>>>>>>> The register is for a new type of PC of which can have
> > >> >>>>>>>>>>>>>>>> many
> > >> >>>>>>>>>>>>>>>> instantiations
> > >> >>>>>>>>>>>>>>>> at the same time.
> > >> >>>>>>>>>>>>>>> OK, I didn't get that that way ! I was looking for a way
> > >> >>>>>>>>>>>>>>> to
> > >> >>>>>>>>>>>>>>> plug
> > >> >>>>>>>>>>>>>>> "my"
> > >> >>>>>>>>>>>>>>> pc
> > >> >>>>>>>>>>>>>>> at
> > >> >>>>>>>>>>>>>>> the command line this way: -pc_type my_pc.
> > >> >>>>>>>>>>>>>>> I already call PCSetType(pc, PCSHELL) and
> > >> >>>>>>>>>>>>>>> PCShellSetName(pc,
> > >> >>>>>>>>>>>>>>> "my_pc"):
> > >> >>>>>>>>>>>>>>> maybe this already enables "-pc_type shell" or "-pc_type
> > >> >>>>>>>>>>>>>>> my_pc"...
> > >> >>>>>>>>>>>>>>> And
> > >> >>>>>>>>>>>>>>> I
> > >> >>>>>>>>>>>>>>> didn't know it ! :D I'll try that.
> > >> >>>>>>>>>>>>>>> I was looking for a way to integrate "my" (external) pc
> > >> >>>>>>>>>>>>>>> as
> > >> >>>>>>>>>>>>>>> any
> > >> >>>>>>>>>>>>>>> other
> > >> >>>>>>>>>>>>>>> regular/existing petsc pc (bjacobi, ...) like a kind of
> > >> >>>>>>>>>>>>>>> plugin
> > >> >>>>>>>>>>>>>>> but
> > >> >>>>>>>>>>>>>>> still
> > >> >>>>>>>>>>>>>>> integrated to the cmd line: I believed PCRegister was
> > >> >>>>>>>>>>>>>>> meant
> > >> >>>>>>>>>>>>>>> for
> > >> >>>>>>>>>>>>>>> that.
> > >> >>>>>>>>>>>>>> Indeed it is exactly what it is meant for. Please try to
> > >> >>>>>>>>>>>>>> follow
> > >> >>>>>>>>>>>>>> my
> > >> >>>>>>>>>>>>>> recipe
> > >> >>>>>>>>>>>>>> and let us know when you get stuck.
> > >> >>>>>>>>>>>>>>> Not sure if this is actually possible/enabled by the
> > >> >>>>>>>>>>>>>>> API.
> > >> >>>>>>>>>>>>>>>> For example
> > >> >>>>>>>>>>>>>>>> PCRegister("mypctype",mypc_create);
> > >> >>>>>>>>>>>>>>>> KSPCreate(&ksp1);
> > >> >>>>>>>>>>>>>>>> KSPCreate(&ksp2);
> > >> >>>>>>>>>>>>>>>> KSPGetPC(ksp1,&pc1);
> > >> >>>>>>>>>>>>>>>> KSPGetPC(ksp2,&pc2);
> > >> >>>>>>>>>>>>>>>> You don't want pc1 and pc2 to have the same dof
> > >> >>>>>>>>>>>>>>>> multiplicities,
> > >> >>>>>>>>>>>>>>>> domain
> > >> >>>>>>>>>>>>>>>> intersections etc since they are associated with
> > >> >>>>>>>>>>>>>>>> completely
> > >> >>>>>>>>>>>>>>>> different
> > >> >>>>>>>>>>>>>>>> linear systems and presumably meshes etc.
> > >> >>>>>>>>>>>>>>>> Presumably you want each of pc1, pc2, to have their own
> > >> >>>>>>>>>>>>>>>> version
> > >> >>>>>>>>>>>>>>>> of
> > >> >>>>>>>>>>>>>>>> the
> > >> >>>>>>>>>>>>>>>> data so you need to stick it directly in the PC, for
> > >> >>>>>>>>>>>>>>>> example
> > >> >>>>>>>>>>>>>>>> PCMypcSetDOFMultiplicities(pc1,stuff);
> > >> >>>>>>>>>>>>>>>> PCMypcSetDOFMultiplicities(pc2,otherstuff);
> > >> >>>>>>>>>>>>> OK, I must provide/implement PCMypcSetDOFMultiplicities
> > >> >>>>>>>>>>>>> (add
> > >> >>>>>>>>>>>>> data
> > >> >>>>>>>>>>>>> to
> > >> >>>>>>>>>>>>> pc
> > >> >>>>>>>>>>>>> context) besides mypc_create: sounds logical.
> > >> >>>>>>>>>>>>> Is this OK if PCMypcSetDOFMultiplicities is independent
> > >> >>>>>>>>>>>>> from
> > >> >>>>>>>>>>>>> mypc_create
> > >> >>>>>>>>>>>>> I guess yes.
> > >> >>>>>>>>>>>>> From what I remember/understand, I got lost here: from the
> > >> >>>>>>>>>>>>> jacobi
> > >> >>>>>>>>>>>>> example,
> > >> >>>>>>>>>>>>> mypc_create looks to be supposed (?) to call some kind of
> > >> >>>>>>>>>>>>> Petsc*ComposeFunction to associate
> > >> >>>>>>>>>>>>> to
> > >> >>>>>>>>>>>>> the
> > >> >>>>>>>>>>>>> pc
> > >> >>>>>>>>>>>>> (correct ?)... But, in the jacobi example,
> > >> >>>>>>>>>>>>> PCJacobiGetUseAbs_Jacobi
> > >> >>>>>>>>>>>>> is
> > >> >>>>>>>>>>>>> associated to PCJacobiGetUseAbs_C...
> > >> >>>>>>>>>>>> the _C name is a string name that is used by PETSc to
> > >> >>>>>>>>>>>> "find"
> > >> >>>>>>>>>>>> the
> > >> >>>>>>>>>>>> correct
> > >> >>>>>>>>>>>> function pointer which is PCJacobiGetUseAbs_Jacobi. There
> > >> >>>>>>>>>>>> is
> > >> >>>>>>>>>>>> no
> > >> >>>>>>>>>>>> _C function.
> > >> >>>>>>>>>>>>> Which turns out not to be implemented according to git
> > >> >>>>>>>>>>>>> grep
> > >> >>>>>>>>>>>>> Got
> > >> >>>>>>>>>>>>> lost
> > >> >>>>>>>>>>>>> here (and looked for a way to pass user data directly to
> > >> >>>>>>>>>>>>> PCRegister):
> > >> >>>>>>>>>>>>> is
> > >> >>>>>>>>>>>>> PCMypcSetDOFMultiplicities supposed to be
> > >> >>>>>>>>>>>>> "attached/composed"
> > >> >>>>>>>>>>>>> or
> > >> >>>>>>>>>>>>> independent from the pc ?
> > >> >>>>>>>>>>>> composed.
> > >> >>>>>>>>>>>>>>> git grep PCJacobiGetUseAbs_C
> > >> >>>>>>>>>>>>> src/ksp/pc/impls/jacobi/jacobi.c: ierr =
> > >> >>>>>>>>>>>>> PetscObjectComposeFunction((PetscObject)pc,"PCJacobiGetUseAbs_C",PCJacobiGetUseAbs_Jacobi);CHKERRQ(ierr);
> > >> >>>>>>>>>>>>> PetscUseMethod(pc,"PCJacobiGetUseAbs_C",(PC,PetscBool*),(pc,flg));CHKERRQ(ierr);
> > >> >>>>>>>>>>>>> Sorry, for the short answer. Hope I succeeded to be clear
> > >> >>>>>>>>>>>>> enough.
> > >> >>>>>>>>>>>> Just copy jacobi.c and start converting it over to your
> > >> >>>>>>>>>>>> names
> > >> >>>>>>>>>>>> and
> > >> >>>>>>>>>>>> needs
> > >> >>>>>>>>>>>> and you'll see it is actually really straightforward and
> > >> >>>>>>>>>>>> not
> > >> >>>>>>>>>>>> as
> > >> >>>>>>>>>>>> complicated as you think it is.
> > >> >>>>>>>>>>>> Barry
> > >> >>>>>>>>>>>>>>>> You write as many of these Set() functions as you need
> > >> >>>>>>>>>>>>>>>> for
> > >> >>>>>>>>>>>>>>>> your
> > >> >>>>>>>>>>>>>>>> PCtype.
> > >> >>>>>>>>>>>>>>>> You
> > >> >>>>>>>>>>>>>>>> store the data inside the PC_Mypc data structure you
> > >> >>>>>>>>>>>>>>>> create
> > >> >>>>>>>>>>>>>>>> with
> > >> >>>>>>>>>>>>>>>> mypc_create(). Look at PCCreate_Jacobi() and
> > >> >>>>>>>>>>>>>>>> PCJacobiSetType
> > >> >>>>>>>>>>>>>>>> for
> > >> >>>>>>>>>>>>>>>> the
> > >> >>>>>>>>>>>>>>>> pattern.
> > >> >>>>>>>>>>>>>>>> Barry
> > >> >>>>>>>>>>>>>>>>> On Dec 28, 2017, at 9:34 AM, Franck Houssen
> > >> >>>>>>>>>>>>>>>>> At first, I expected the signature would be
> > >> >>>>>>>>>>>>>>>>> "PetscErrorCode
> > >> >>>>>>>>>>>>>>>>> PCRegister(const char sname[],PetscErrorCode
> > >> >>>>>>>>>>>>>>>>> (*function)(PC,
> > >> >>>>>>>>>>>>>>>>> void
> > >> >>>>>>>>>>>>>>>>> but
> > >> >>>>>>>>>>>>>>>>> it turns out to be "PetscErrorCode PCRegister(const
> > >> >>>>>>>>>>>>>>>>> char
> > >> >>>>>>>>>>>>>>>>> sname[],PetscErrorCode (*function)(PC))"
> > >> >>>>>>>>>>>>>>>>> I try to integrate a PC that needs A but also other
> > >> >>>>>>>>>>>>>>>>> informations
> > >> >>>>>>>>>>>>>>>>> (dof
> > >> >>>>>>>>>>>>>>>>> multiplicities, domain intersections that the user
> > >> >>>>>>>>>>>>>>>>> must
> > >> >>>>>>>>>>>>>>>>> provide).
> > >> >>>>>>>>>>>>>>>>> I
> > >> >>>>>>>>>>>>>>>>> guess
> > >> >>>>>>>>>>>>>>>>> I can get A with PCGetOperators in the setup callback
> > >> >>>>>>>>>>>>>>>>> of
> > >> >>>>>>>>>>>>>>>>> the
> > >> >>>>>>>>>>>>>>>>> PC.
> > >> >>>>>>>>>>>>>>>>> But
> > >> >>>>>>>>>>>>>>>>> still
> > >> >>>>>>>>>>>>>>>>> not sure how to pass the other informations if I get
> > >> >>>>>>>>>>>>>>>>> to
> > >> >>>>>>>>>>>>>>>>> use
> > >> >>>>>>>>>>>>>>>>> PCRegister.
> > >> >>>>>>>>>>>>>>>>> I
> > >> >>>>>>>>>>>>>>>>> looked a few examples in the bitbucket (jacobi:
> > >> >>>>>>>>>>>>>>>>> src/ksp/ksp/examples/tutorials/ex12.c and
> > >> >>>>>>>>>>>>>>>>> + SOR: src/ksp/pc/impls/sor/sor.c)... But didn't get
> > >> >>>>>>>>>>>>>>>>> any
> > >> >>>>>>>>>>>>>>>>> real
> > >> >>>>>>>>>>>>>>>>> relevant
> > >> >>>>>>>>>>>>>>>>> answer and feel a bit lost among the numerous pc !...
> > >> >>>>>>>>>>>>>>>>> The idea is: for now I use PCSetType(pc, PCSHELL) and
> > >> >>>>>>>>>>>>>>>>> PCShellSetContext
> > >> >>>>>>>>>>>>>>>>> with a context who knows the extra needed informations
> > >> >>>>>>>>>>>>>>>>> which
> > >> >>>>>>>>>>>>>>>>> is
> > >> >>>>>>>>>>>>>>>>> "not
> > >> >>>>>>>>>>>>>>>>> so
> > >> >>>>>>>>>>>>>>>>> handy" (that's OK as for now I am both the user and
> > >> >>>>>>>>>>>>>>>>> the
> > >> >>>>>>>>>>>>>>>>> PC
> > >> >>>>>>>>>>>>>>>>> provider).
> > >> >>>>>>>>>>>>>>>>> I'd
> > >> >>>>>>>>>>>>>>>>> like to package this in a more convenient way (a
> > >> >>>>>>>>>>>>>>>>> unique
> > >> >>>>>>>>>>>>>>>>> and
> > >> >>>>>>>>>>>>>>>>> "simple"
> > >> >>>>>>>>>>>>>>>>> call
> > >> >>>>>>>>>>>>>>>>> to PCRegister) to decouple the user from the PC
> > >> >>>>>>>>>>>>>>>>> machinery.
> > >> >>>>>>>>>>>>>>>>> Franck
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180122/0dd98a82/attachment-0002.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180122/0dd98a82/attachment-0003.bin>
