[petsc-dev] How to pass user data to a registered PC (PCRegister) ?
Jed Brown jed at jedbrown.org
Mon Jan 22 09:06:26 CST 2018
I used
  mkdir build; cd build
  PKG_CONFIG_PATH=$PETSC_DIR/$PETSC_ARCH/lib/pkgconfig:$SLEPC_DIR/$PETSC_ARCH/lib/pkgconfig cmake ..
and got a successful build.  Franck, you can have your CMakeLists.txt
add these paths to PKG_CONFIG_PATH before using pkgconfig.  It saves
time because it's the conventional way to specify PETSc libraries.
In general, when providing a test case, it's best to be precise and
complete.  It isn't a good use of Barry's time to expect him to browse
around your github repository and find your wiki.
Anyway, I have it built, but I don't know what the "dummy test case" is.
I tried tst/dummy/dummy.sh and got
  Error: check argument KO
Can you give the exact command to run and expected output?
"Smith, Barry F." <bsmith at mcs.anl.gov> writes:
>   I absolutely hate package configures that say they can't find something but give NO indication how to indicate the location of the missing thing.
> $ SLEPC_DIR=$SLEPC_DIR cmake .. -DBOOST_ROOT=/Users/barrysmith/Src/boost_1_66_0 -DSLEPC_DIR=$SLEPC_DIR
> CMake Warning at /usr/local/Cellar/cmake/3.9.5/share/cmake/Modules/FindBoost.cmake:786 (message):
>   New Boost version may have incorrect or missing dependencies and imported
>   targets
> Call Stack (most recent call first):
>   /usr/local/Cellar/cmake/3.9.5/share/cmake/Modules/FindBoost.cmake:892 (_Boost_COMPONENT_DEPENDENCIES)
>   /usr/local/Cellar/cmake/3.9.5/share/cmake/Modules/FindBoost.cmake:1523 (_Boost_MISSING_DEPENDENCIES)
>   CMakeLists.txt:38 (find_package)
>   targets
> -- Boost version: 1.66.0
> -- Found the following Boost libraries:
> --   mpi
> --   serialization
> -- Checking for module 'SLEPc>=3.8.1'
> --   No package 'SLEPc' found
> CMake Error at /usr/local/Cellar/cmake/3.9.5/share/cmake/Modules/FindPkgConfig.cmake:412 (message):
>   A required package was not found
>   /usr/local/Cellar/cmake/3.9.5/share/cmake/Modules/FindPkgConfig.cmake:588 (_pkg_check_modules_internal)
>   CMakeLists.txt:42 (pkg_check_modules)
> -- Configuring incomplete, errors occurred!
> See also "/Users/barrysmith/Src/geneo4PETSc/BUILD/CMakeFiles/CMakeOutput.log".
> ~/Src/geneo4PETSc/BUILD (master=) arch-franck
> Note at first it could not find BOOST but told me to set the directory with exact syntax. That's the way it should always do it.
> SLEPC_ROOT also did not work, nor did SLEPc_ROOT ;(
> So please tell me how to work through this dependency hell.
>    Barry
>> On Jan 21, 2018, at 11:06 AM, Franck Houssen <franck.houssen at inria.fr> wrote:
>> The last problem I had here was that, for now, I must use a bypass: calling  PetscOptionsBegin/End after/before PetscOptionsHead/Tail in the setup callback defined on PCRegister.
>> git-clone https://github.com/fghoussen/geneo4PETSc, the dummy test case should run. Then comment lines 2321 and 2464 in geneo.cpp (PetscOptionsBegin/End): the dummy test case should fail because as the option database "seems" to be empty, the default parameter are used and the name/version of the pc is not the expected one.
>> I believe (?) I use the correct PCRegister pattern (PCSetFromOptions between PCRegister and initGenEOPC). Either I'm wrong, or there is something behind...
>> Franck
>> PS: still trying to get osx to work... (don't know mac/clang enough, and, travis osx boxes are so slow to start and run - difficult to test). But if you used to it, you'll probably get this to work.
>> ----- Mail original -----
>>> De: "Franck Houssen" <franck.houssen at inria.fr>
>>> À: "Barry F. Smith" <bsmith at mcs.anl.gov>
>>> Cc: "For users of the development version of PETSc" <petsc-dev at mcs.anl.gov>
>>> Envoyé: Mardi 2 Janvier 2018 15:15:25
>>> Objet: Re: [petsc-dev] How to pass user data to a registered PC (PCRegister) ?
>>>> De: "Barry F. Smith" <bsmith at mcs.anl.gov>
>>>> À: "Franck Houssen" <franck.houssen at inria.fr>
>>>> Envoyé: Mardi 2 Janvier 2018 14:50:02
>>>> (PCRegister) ?
>>>>> On Jan 2, 2018, at 7:47 AM, Franck Houssen <franck.houssen at inria.fr>
>>>>> wrote:
>>>>> I'll try to fetch/pull the git clone: maybe there is a reg on the code
>>>>> level I am on.
>>>>  Unlikely.
>>>>   I'm afraid you need to use the debugger and slog through the call.
>>> OK, I'll do that ! For now, calling Begin/End is this only by-pass I have.
>>>> It    seems you are doing things ok so why this happens I cannot explain.
>>>> We
>>>>   use this paradigm everywhere with options in PETSc and it always works
>>>>   so
>>>>   I am totally lost as to why it fails for you.
>>>>   Barry
>>>>>> Envoyé: Mardi 2 Janvier 2018 13:22:16
>>>>>> (PCRegister) ?
>>>>>> static PetscErrorCode PCSetFromOptions_Jacobi(PetscOptionItems
>>>>>> *PetscOptionsObject,PC pc)
>>>>>> PC_Jacobi      *jac = (PC_Jacobi*)pc->data;
>>>>>> PetscErrorCode ierr;
>>>>>> PetscBool      flg;
>>>>>> PCJacobiType   deflt,type;
>>>>>> PetscFunctionBegin;
>>>>>> ierr = PCJacobiGetType(pc,&deflt);CHKERRQ(ierr);
>>>>>> ierr = PetscOptionsHead(PetscOptionsObject,"Jacobi
>>>>>> options");CHKERRQ(ierr);
>>>>>> ierr = PetscOptionsEnum("-pc_jacobi_type","How to construct diagonal
>>>>>> matrix","PCJacobiSetType",PCJacobiTypes,(PetscEnum)deflt,(PetscEnum*)&type,&flg);CHKERRQ(ierr);
>>>>>> if (flg) {
>>>>>>   ierr = PCJacobiSetType(pc,type);CHKERRQ(ierr);
>>>>>> ierr = PetscOptionsBool("-pc_jacobi_abs","Use absolute values of
>>>>>> diagaonal
>>>>>> entries","PCJacobiSetUseAbs",jac->useabs,&jac->useabs,NULL);CHKERRQ(ierr);
>>>>>> ierr = PetscOptionsTail();CHKERRQ(ierr);
>>>>>> PetscFunctionReturn(0);
>>>>>> Note how PetscOptionsHead() is called with the argument
>>>>>> PetscOptionsObject
>>>>> I do call PetscOptionsHead(PetscOptionsObject, ...);
>>>>>> which is passed in from above. My guess is that you don't
>>>>>> call it with this argument? You would get behavior you describe if you
>>>>>> don't.
>>>>>> Please send your REAL setupfromoptions_mypc() not just pseudo code.
>>>>> #define SETERRABT(msg)
>>>>> SETERRABORT(PETSC_COMM_WORLD,PETSC_ERR_ARG_NULL,msg)
>>>>> static PetscErrorCode setUpGenEOPCFromOptions(PetscOptionItems *
>>>>> PetscOptionsObject, PC pcPC) {
>>>>> // Get the context.
>>>>> if (!pcPC) SETERRABT("GenEO preconditioner is invalid");
>>>>> geneoContext * gCtx = (geneoContext *) pcPC->data;
>>>>> if (!gCtx) SETERRABT("GenEO preconditioner without context");
>>>>> // Check arguments.
>>>>> PetscErrorCode pcRC = PetscOptionsHead(PetscOptionsObject, "GenEO
>>>>> options");
>>>>> CHKERRQ(pcRC);
>>>>> pcRC = PetscOptionsBegin(PETSC_COMM_WORLD, NULL, "GenEO options", "GenEO
>>>>> options");
>>>>> CHKERRQ(pcRC);
>>>>> PetscBool pcHasOpt = PETSC_FALSE;
>>>>> PetscInt nbArgs = 2;
>>>>> char *args[2];
>>>>> pcRC = PetscOptionsStringArray("-geneo_lvl", "GenEO levels", "GenEO
>>>>> levels", args, &nbArgs, &pcHasOpt);
>>>>> CHKERRQ(pcRC);
>>>>> if (pcHasOpt) {
>>>>>> Barry
>>>>>>> On Jan 2, 2018, at 5:04 AM, Franck Houssen <franck.houssen at inria.fr>
>>>>>>>> Envoyé: Dimanche 31 Décembre 2017 23:41:42
>>>>>>>> (PCRegister) ?
>>>>>>>>> On Dec 31, 2017, at 8:40 AM, Franck Houssen <franck.houssen at inria.fr>
>>>>>>>>> wrote:
>>>>>>>>> Seems finally, I got it to work.
>>>>>>>>> To get the options to work I had to call PetscOptionsBegin/End
>>>>>>>>> after/before
>>>>>>>>> PetscOptionsHead/Tail which is not what is done in the jacobi
>>>>>>>>> example:
>>>>>>>>> is
>>>>>>>>> this the right way to go ?
>>>>>>>> Something is wrong.
>>>>>>> I felt there was something wrong !...
>>>>>>>> PetscOptionsBegin/end are called in PCSetFromOptions()
>>>>>>>> that is suppose to wrap YOUR PCSetFromOptions_mypc().
>>>>>>> OK, sounds logical, that's how I expected things to be done. That's why
>>>>>>> I
>>>>>>> was suspicious: what worked should not !...
>>>>>>> I believed maybe the problem was connected to the fact that I do NOT
>>>>>>> use
>>>>>>> compose function, but, according to Matt's explanation, I would say no:
>>>>>>> the use of PetscComposeFunction seems independent from the
>>>>>>> PCSetFromOptions_mypc problem.
>>>>>>> Note: in my case, I believe I do not really need PetscCompose, I just
>>>>>>> need
>>>>>>> one (regular) function to initialize specific stuffs needed in my_pc
>>>>>>> (at
>>>>>>> least for a start). I can go to PetscCompose later if it turns out to
>>>>>>> be
>>>>>>> relevant (that's how I understand this).
>>>>>>>> Perhaps you are
>>>>>>>> calling PCSetFromOptions_mypc directly which you should never do.
>>>>>>> No, I don't call PCSetFromOptions_mypc directly.
>>>>>>>> Your PCCreate_mypc() should stick the function pointer for
>>>>>>>> PCSetFromOptions_mypc into the ops table like it does PCApply_mypc
>>>>>>>> etc.
>>>>>>>> Then you just directly use PCSetFromOptions.
>>>>>>> create_mpc(PC pc) { // CB for PCRegister
>>>>>>> pcPC->ops->setfromoptions = setupfromoptions_mypc;
>>>>>>> static PetscErrorCode setupfromoptions_mypc(PetscOptionItems *
>>>>>>> PetscOptionsHead()
>>>>>>> PetscOptionsBegin()
>>>>>>> PetscOptionsStringArray("-mypc_opt", ..., flag)
>>>>>>> cout << "debug " << flag << endl;
>>>>>>> PetscOptionsEnd()
>>>>>>> PetscOptionsTail()
>>>>>>> I got called on setupfromoptions_mypc when I call PCSetUpFromOptions().
>>>>>>> If I let PetscOptionsBegin/End, it looks like I read in the "correct"
>>>>>>> option data base, I get (cout) : "debug 1" (-my_opt is read)
>>>>>>> If I comment PetscOptionsBegin/End, seems I read an incorrect (empty ?)
>>>>>>> option data base, I get (cout) : "debug 0"
>>>>>>> Looks weird even if it's not blocking for now (I know there is problem
>>>>>>> but
>>>>>>> I can by pass it)
>>>>>>>> Barry
>>>>>>>>> Franck
>>>>>>>>> PetscErrorCode PCSetFromOptions_mypc(PetscOptionItems *
>>>>>>>>> PetscOptionsObject,
>>>>>>>>> PC pcPC) {
>>>>>>>>> PetscOptionsHead
>>>>>>>>> PetscOptionsBegin
>>>>>>>>> ... // PetscOptionsStringArray
>>>>>>>>> PetscOptionsEnd
>>>>>>>>> PetscOptionsTail
>>>>>>>>>> Envoyé: Dimanche 31 Décembre 2017 15:01:43
>>>>>>>>>> (PCRegister) ?
>>>>>>>>>> Using PCSHELL means calling:
>>>>>>>>>> - PCShellSetSetUp, PCShellSetApply, PCShellSetDestroy to set
>>>>>>>>>> callbacks.
>>>>>>>>>> - PCShellSetContext/PCShellGetContext to get/set context in
>>>>>>>>>> callbacks.
>>>>>>>>>> To go from PCSHELL to PCRegister, one need to:
>>>>>>>>>> - #include <petsc/private/pcimpl.h> // Access to PC data/struct.
>>>>>>>>>> - Set callbacks with pc->ops->...
>>>>>>>>>> - NO more use ANY shell methods (context, name), but, use pc->data
>>>>>>>>>> instead.
>>>>>>>>>> - call PCRegister.
>>>>>>>>>> Correct ? Did I miss something ?
>>>>>>>>>> Seems I get things to work (without compose function).
>>>>>>>>>> The last problem I have is in the options: options are passed to
>>>>>>>>>> PetscInitialize but not found in the database (I mimic'ed the jacobi
>>>>>>>>>> example). Is there specific related to this ?
>>>>>>>>>>> Envoyé: Samedi 30 Décembre 2017 17:12:09
>>>>>>>>>>> (PCRegister) ?
>>>>>>>>>>> Don't get the link. I'll try first with independent function (no
>>>>>>>>>>> compose)
>>>>>>>>>>> and
>>>>>>>>>>> see if this can work at least for a start.
>>>>>>>>>>> Franck
>>>>>>>>>>>> Envoyé: Vendredi 29 Décembre 2017 17:55:30
>>>>>>>>>>>> (PCRegister) ?
>>>>>>>>>>>>> On Dec 29, 2017, at 9:03 AM, Franck Houssen
>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>> OK, on the highway now (bad ssh !), I'll try to check this out.
>>>>>>>>>>>>>> Envoyé: Jeudi 28 Décembre 2017 18:21:48
>>>>>>>>>>>>>> (PCRegister) ?
>>>>>>>>>>>>>>> On Dec 28, 2017, at 10:34 AM, Franck Houssen
>>>>>>>>>>>>>>>> Envoyé: Jeudi 28 Décembre 2017 16:43:16
>>>>>>>>>>>>>>>> PC
>>>>>>>>>>>>>>>> (PCRegister) ?
>>>>>>>>>>>>>>>> The register is for a new type of PC of which can have many
>>>>>>>>>>>>>>>> instantiations
>>>>>>>>>>>>>>>> at the same time.
>>>>>>>>>>>>>>> OK, I didn't get that that way ! I was looking for a way to
>>>>>>>>>>>>>>> plug
>>>>>>>>>>>>>>> "my"
>>>>>>>>>>>>>>> pc
>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>> the command line this way: -pc_type my_pc.
>>>>>>>>>>>>>>> I already call PCSetType(pc, PCSHELL) and PCShellSetName(pc,
>>>>>>>>>>>>>>> "my_pc"):
>>>>>>>>>>>>>>> maybe this already enables "-pc_type shell" or "-pc_type
>>>>>>>>>>>>>>> my_pc"...
>>>>>>>>>>>>>>> And
>>>>>>>>>>>>>>> I
>>>>>>>>>>>>>>> didn't know it ! :D I'll try that.
>>>>>>>>>>>>>>> I was looking for a way to integrate "my" (external) pc as any
>>>>>>>>>>>>>>> other
>>>>>>>>>>>>>>> regular/existing petsc pc (bjacobi, ...) like a kind of plugin
>>>>>>>>>>>>>>> but
>>>>>>>>>>>>>>> still
>>>>>>>>>>>>>>> integrated to the cmd line: I believed PCRegister was meant for
>>>>>>>>>>>>>>> that.
>>>>>>>>>>>>>> Indeed it is exactly what it is meant for.  Please try to follow
>>>>>>>>>>>>>> my
>>>>>>>>>>>>>> recipe
>>>>>>>>>>>>>> and let us know when you get stuck.
>>>>>>>>>>>>>>> Not sure if this is actually possible/enabled by the API.
>>>>>>>>>>>>>>>> For example
>>>>>>>>>>>>>>>> PCRegister("mypctype",mypc_create);
>>>>>>>>>>>>>>>> KSPCreate(&ksp1);
>>>>>>>>>>>>>>>> KSPCreate(&ksp2);
>>>>>>>>>>>>>>>> KSPGetPC(ksp1,&pc1);
>>>>>>>>>>>>>>>> KSPGetPC(ksp2,&pc2);
>>>>>>>>>>>>>>>> You don't want pc1 and pc2 to have the same dof
>>>>>>>>>>>>>>>> multiplicities,
>>>>>>>>>>>>>>>> domain
>>>>>>>>>>>>>>>> intersections etc since they are associated with completely
>>>>>>>>>>>>>>>> different
>>>>>>>>>>>>>>>> linear systems and presumably meshes etc.
>>>>>>>>>>>>>>>> Presumably you want each of pc1, pc2, to have their own
>>>>>>>>>>>>>>>> version
>>>>>>>>>>>>>>>> of
>>>>>>>>>>>>>>>> the
>>>>>>>>>>>>>>>> data so you need to stick it directly in the PC, for example
>>>>>>>>>>>>>>>> PCMypcSetDOFMultiplicities(pc1,stuff);
>>>>>>>>>>>>>>>> PCMypcSetDOFMultiplicities(pc2,otherstuff);
>>>>>>>>>>>>> OK, I must provide/implement PCMypcSetDOFMultiplicities (add data
>>>>>>>>>>>>> to
>>>>>>>>>>>>> pc
>>>>>>>>>>>>> context) besides mypc_create: sounds logical.
>>>>>>>>>>>>> Is this OK if PCMypcSetDOFMultiplicities is independent from
>>>>>>>>>>>>> mypc_create
>>>>>>>>>>>>> I guess yes.
>>>>>>>>>>>>> From what I remember/understand, I got lost here: from the jacobi
>>>>>>>>>>>>> example,
>>>>>>>>>>>>> mypc_create looks to be supposed (?) to call some kind of
>>>>>>>>>>>>> Petsc*ComposeFunction to associate PCMypcSetDOFMultiplicities to
>>>>>>>>>>>>> the
>>>>>>>>>>>>> pc
>>>>>>>>>>>>> (correct ?)... But, in the jacobi example,
>>>>>>>>>>>>> PCJacobiGetUseAbs_Jacobi
>>>>>>>>>>>>> is
>>>>>>>>>>>>> associated to PCJacobiGetUseAbs_C...
>>>>>>>>>>>> the _C name is a string name that is used by PETSc to "find" the
>>>>>>>>>>>> correct
>>>>>>>>>>>> function pointer which is PCJacobiGetUseAbs_Jacobi. There is no
>>>>>>>>>>>> _C function.
>>>>>>>>>>>>> Which turns out not to be implemented according to git grep ?!
>>>>>>>>>>>>> Got
>>>>>>>>>>>>> lost
>>>>>>>>>>>>> here (and looked for a way to pass user data directly to
>>>>>>>>>>>>> PCRegister):
>>>>>>>>>>>>> is
>>>>>>>>>>>>> PCMypcSetDOFMultiplicities supposed to be "attached/composed" or
>>>>>>>>>>>>> independent from the pc ?
>>>>>>>>>>>> composed.
>>>>>>>>>>>>>>> git grep PCJacobiGetUseAbs_C
>>>>>>>>>>>>> src/ksp/pc/impls/jacobi/jacobi.c:  ierr =
>>>>>>>>>>>>> PetscObjectComposeFunction((PetscObject)pc,"PCJacobiGetUseAbs_C",PCJacobiGetUseAbs_Jacobi);CHKERRQ(ierr);
>>>>>>>>>>>>> PetscUseMethod(pc,"PCJacobiGetUseAbs_C",(PC,PetscBool*),(pc,flg));CHKERRQ(ierr);
>>>>>>>>>>>>> Sorry, for the short answer. Hope I succeeded to be clear enough.
>>>>>>>>>>>> Just copy jacobi.c and start converting it over to your names and
>>>>>>>>>>>> needs
>>>>>>>>>>>> and you'll see it is actually really straightforward and not as
>>>>>>>>>>>> complicated as you think it is.
>>>>>>>>>>>> Barry
>>>>>>>>>>>>>>>> You write as many of these Set() functions as you need for
>>>>>>>>>>>>>>>> your
>>>>>>>>>>>>>>>> PCtype.
>>>>>>>>>>>>>>>> You
>>>>>>>>>>>>>>>> store the data inside the PC_Mypc data structure you create
>>>>>>>>>>>>>>>> with
>>>>>>>>>>>>>>>> mypc_create(). Look at PCCreate_Jacobi() and PCJacobiSetType
>>>>>>>>>>>>>>>> for
>>>>>>>>>>>>>>>> the
>>>>>>>>>>>>>>>> pattern.
>>>>>>>>>>>>>>>> Barry
>>>>>>>>>>>>>>>>> On Dec 28, 2017, at 9:34 AM, Franck Houssen
>>>>>>>>>>>>>>>>> At first, I expected the signature would be "PetscErrorCode
>>>>>>>>>>>>>>>>> PCRegister(const char sname[],PetscErrorCode (*function)(PC,
>>>>>>>>>>>>>>>>> void
>>>>>>>>>>>>>>>>> but
>>>>>>>>>>>>>>>>> it turns out to be "PetscErrorCode PCRegister(const char
>>>>>>>>>>>>>>>>> sname[],PetscErrorCode (*function)(PC))"
>>>>>>>>>>>>>>>>> I try to integrate a PC that needs A but also other
>>>>>>>>>>>>>>>>> informations
>>>>>>>>>>>>>>>>> (dof
>>>>>>>>>>>>>>>>> multiplicities, domain intersections that the user must
>>>>>>>>>>>>>>>>> provide).
>>>>>>>>>>>>>>>>> I
>>>>>>>>>>>>>>>>> guess
>>>>>>>>>>>>>>>>> I can get A with PCGetOperators in the setup callback of the
>>>>>>>>>>>>>>>>> PC.
>>>>>>>>>>>>>>>>> But
>>>>>>>>>>>>>>>>> still
>>>>>>>>>>>>>>>>> not sure how to pass the other informations if I get to use
>>>>>>>>>>>>>>>>> PCRegister.
>>>>>>>>>>>>>>>>> I
>>>>>>>>>>>>>>>>> looked a few examples in the bitbucket (jacobi:
>>>>>>>>>>>>>>>>> src/ksp/ksp/examples/tutorials/ex12.c and
>>>>>>>>>>>>>>>>> + SOR: src/ksp/pc/impls/sor/sor.c)... But didn't get any real
>>>>>>>>>>>>>>>>> relevant
>>>>>>>>>>>>>>>>> answer and feel a bit lost among the numerous pc !...
>>>>>>>>>>>>>>>>> The idea is: for now I use PCSetType(pc, PCSHELL) and
>>>>>>>>>>>>>>>>> PCShellSetContext
>>>>>>>>>>>>>>>>> with a context who knows the extra needed informations which
>>>>>>>>>>>>>>>>> is
>>>>>>>>>>>>>>>>> "not
>>>>>>>>>>>>>>>>> so
>>>>>>>>>>>>>>>>> handy" (that's OK as for now I am both the user and the PC
>>>>>>>>>>>>>>>>> provider).
>>>>>>>>>>>>>>>>> I'd
>>>>>>>>>>>>>>>>> like to package this in a more convenient way (a unique and
>>>>>>>>>>>>>>>>> "simple"
>>>>>>>>>>>>>>>>> call
>>>>>>>>>>>>>>>>> to PCRegister) to decouple the user from the PC machinery.
>>>>>>>>>>>>>>>>> Franck
