[petsc-dev] How to pass user data to a registered PC (PCRegister) ?
Franck Houssen
franck.houssen at inria.fr
Sun Jan 21 11:06:00 CST 2018
The last problem I had here was that, for now, I must use a bypass: calling PetscOptionsBegin/End after/before PetscOptionsHead/Tail in the setup callback defined on PCRegister.
git-clone https://github.com/fghoussen/geneo4PETSc, the dummy test case should run. Then comment lines 2321 and 2464 in geneo.cpp (PetscOptionsBegin/End): the dummy test case should fail because as the option database "seems" to be empty, the default parameter are used and the name/version of the pc is not the expected one.
I believe (?) I use the correct PCRegister pattern (PCSetFromOptions between PCRegister and initGenEOPC). Either I'm wrong, or there is something behind...
Franck
PS: still trying to get osx to work... (don't know mac/clang enough, and, travis osx boxes are so slow to start and run - difficult to test). But if you used to it, you'll probably get this to work.
----- Mail original -----
> De: "Franck Houssen" <franck.houssen at inria.fr>
> À: "Barry F. Smith" <bsmith at mcs.anl.gov>
> Cc: "For users of the development version of PETSc" <petsc-dev at mcs.anl.gov>
> Envoyé: Mardi 2 Janvier 2018 15:15:25
> Objet: Re: [petsc-dev] How to pass user data to a registered PC (PCRegister) ?
> > De: "Barry F. Smith" <bsmith at mcs.anl.gov>
> > À: "Franck Houssen" <franck.houssen at inria.fr>
> > Envoyé: Mardi 2 Janvier 2018 14:50:02
> > (PCRegister) ?
> > > On Jan 2, 2018, at 7:47 AM, Franck Houssen <franck.houssen at inria.fr>
> > > wrote:
> > > I'll try to fetch/pull the git clone: maybe there is a reg on the code
> > > level I am on.
> > Unlikely.
> > I'm afraid you need to use the debugger and slog through the call.
> OK, I'll do that ! For now, calling Begin/End is this only by-pass I have.
> > It seems you are doing things ok so why this happens I cannot explain.
> > We
> > use this paradigm everywhere with options in PETSc and it always works
> > so
> > I am totally lost as to why it fails for you.
> > Barry
> > >> Envoyé: Mardi 2 Janvier 2018 13:22:16
> > >> (PCRegister) ?
> > >> static PetscErrorCode PCSetFromOptions_Jacobi(PetscOptionItems
> > >> *PetscOptionsObject,PC pc)
> > >> PC_Jacobi *jac = (PC_Jacobi*)pc->data;
> > >> PetscErrorCode ierr;
> > >> PetscBool flg;
> > >> PCJacobiType deflt,type;
> > >> PetscFunctionBegin;
> > >> ierr = PCJacobiGetType(pc,&deflt);CHKERRQ(ierr);
> > >> ierr = PetscOptionsHead(PetscOptionsObject,"Jacobi
> > >> options");CHKERRQ(ierr);
> > >> ierr = PetscOptionsEnum("-pc_jacobi_type","How to construct diagonal
> > >> matrix","PCJacobiSetType",PCJacobiTypes,(PetscEnum)deflt,(PetscEnum*)&type,&flg);CHKERRQ(ierr);
> > >> if (flg) {
> > >> ierr = PCJacobiSetType(pc,type);CHKERRQ(ierr);
> > >> ierr = PetscOptionsBool("-pc_jacobi_abs","Use absolute values of
> > >> diagaonal
> > >> entries","PCJacobiSetUseAbs",jac->useabs,&jac->useabs,NULL);CHKERRQ(ierr);
> > >> ierr = PetscOptionsTail();CHKERRQ(ierr);
> > >> PetscFunctionReturn(0);
> > >> Note how PetscOptionsHead() is called with the argument
> > >> PetscOptionsObject
> > > I do call PetscOptionsHead(PetscOptionsObject, ...);
> > >> which is passed in from above. My guess is that you don't
> > >> call it with this argument? You would get behavior you describe if you
> > >> don't.
> > >> Please send your REAL setupfromoptions_mypc() not just pseudo code.
> > > #define SETERRABT(msg)
> > > SETERRABORT(PETSC_COMM_WORLD,PETSC_ERR_ARG_NULL,msg)
> > > static PetscErrorCode setUpGenEOPCFromOptions(PetscOptionItems *
> > > PetscOptionsObject, PC pcPC) {
> > > // Get the context.
> > > if (!pcPC) SETERRABT("GenEO preconditioner is invalid");
> > > geneoContext * gCtx = (geneoContext *) pcPC->data;
> > > if (!gCtx) SETERRABT("GenEO preconditioner without context");
> > > // Check arguments.
> > > PetscErrorCode pcRC = PetscOptionsHead(PetscOptionsObject, "GenEO
> > > options");
> > > CHKERRQ(pcRC);
> > > pcRC = PetscOptionsBegin(PETSC_COMM_WORLD, NULL, "GenEO options", "GenEO
> > > options");
> > > CHKERRQ(pcRC);
> > > PetscBool pcHasOpt = PETSC_FALSE;
> > > PetscInt nbArgs = 2;
> > > char *args[2];
> > > pcRC = PetscOptionsStringArray("-geneo_lvl", "GenEO levels", "GenEO
> > > levels", args, &nbArgs, &pcHasOpt);
> > > CHKERRQ(pcRC);
> > > if (pcHasOpt) {
> > >> Barry
> > >>> On Jan 2, 2018, at 5:04 AM, Franck Houssen <franck.houssen at inria.fr>
> > >>>> Envoyé: Dimanche 31 Décembre 2017 23:41:42
> > >>>> (PCRegister) ?
> > >>>>> On Dec 31, 2017, at 8:40 AM, Franck Houssen <franck.houssen at inria.fr>
> > >>>>> wrote:
> > >>>>> Seems finally, I got it to work.
> > >>>>> To get the options to work I had to call PetscOptionsBegin/End
> > >>>>> after/before
> > >>>>> PetscOptionsHead/Tail which is not what is done in the jacobi
> > >>>>> example:
> > >>>>> is
> > >>>>> this the right way to go ?
> > >>>> Something is wrong.
> > >>> I felt there was something wrong !...
> > >>>> PetscOptionsBegin/end are called in PCSetFromOptions()
> > >>>> that is suppose to wrap YOUR PCSetFromOptions_mypc().
> > >>> OK, sounds logical, that's how I expected things to be done. That's why
> > >>> I
> > >>> was suspicious: what worked should not !...
> > >>> I believed maybe the problem was connected to the fact that I do NOT
> > >>> use
> > >>> compose function, but, according to Matt's explanation, I would say no:
> > >>> the use of PetscComposeFunction seems independent from the
> > >>> PCSetFromOptions_mypc problem.
> > >>> Note: in my case, I believe I do not really need PetscCompose, I just
> > >>> need
> > >>> one (regular) function to initialize specific stuffs needed in my_pc
> > >>> (at
> > >>> least for a start). I can go to PetscCompose later if it turns out to
> > >>> be
> > >>> relevant (that's how I understand this).
> > >>>> Perhaps you are
> > >>>> calling PCSetFromOptions_mypc directly which you should never do.
> > >>> No, I don't call PCSetFromOptions_mypc directly.
> > >>>> Your PCCreate_mypc() should stick the function pointer for
> > >>>> PCSetFromOptions_mypc into the ops table like it does PCApply_mypc
> > >>>> etc.
> > >>>> Then you just directly use PCSetFromOptions.
> > >>> create_mpc(PC pc) { // CB for PCRegister
> > >>> pcPC->ops->setfromoptions = setupfromoptions_mypc;
> > >>> static PetscErrorCode setupfromoptions_mypc(PetscOptionItems *
> > >>> PetscOptionsHead()
> > >>> PetscOptionsBegin()
> > >>> PetscOptionsStringArray("-mypc_opt", ..., flag)
> > >>> cout << "debug " << flag << endl;
> > >>> PetscOptionsEnd()
> > >>> PetscOptionsTail()
> > >>> I got called on setupfromoptions_mypc when I call PCSetUpFromOptions().
> > >>> If I let PetscOptionsBegin/End, it looks like I read in the "correct"
> > >>> option data base, I get (cout) : "debug 1" (-my_opt is read)
> > >>> If I comment PetscOptionsBegin/End, seems I read an incorrect (empty ?)
> > >>> option data base, I get (cout) : "debug 0"
> > >>> Looks weird even if it's not blocking for now (I know there is problem
> > >>> but
> > >>> I can by pass it)
> > >>>> Barry
> > >>>>> Franck
> > >>>>> PetscErrorCode PCSetFromOptions_mypc(PetscOptionItems *
> > >>>>> PetscOptionsObject,
> > >>>>> PC pcPC) {
> > >>>>> PetscOptionsHead
> > >>>>> PetscOptionsBegin
> > >>>>> ... // PetscOptionsStringArray
> > >>>>> PetscOptionsEnd
> > >>>>> PetscOptionsTail
> > >>>>>> Envoyé: Dimanche 31 Décembre 2017 15:01:43
> > >>>>>> (PCRegister) ?
> > >>>>>> Using PCSHELL means calling:
> > >>>>>> - PCShellSetSetUp, PCShellSetApply, PCShellSetDestroy to set
> > >>>>>> callbacks.
> > >>>>>> - PCShellSetContext/PCShellGetContext to get/set context in
> > >>>>>> callbacks.
> > >>>>>> To go from PCSHELL to PCRegister, one need to:
> > >>>>>> - #include <petsc/private/pcimpl.h> // Access to PC data/struct.
> > >>>>>> - Set callbacks with pc->ops->...
> > >>>>>> - NO more use ANY shell methods (context, name), but, use pc->data
> > >>>>>> instead.
> > >>>>>> - call PCRegister.
> > >>>>>> Correct ? Did I miss something ?
> > >>>>>> Seems I get things to work (without compose function).
> > >>>>>> The last problem I have is in the options: options are passed to
> > >>>>>> PetscInitialize but not found in the database (I mimic'ed the jacobi
> > >>>>>> example). Is there specific related to this ?
> > >>>>>>> Envoyé: Samedi 30 Décembre 2017 17:12:09
> > >>>>>>> (PCRegister) ?
> > >>>>>>> Don't get the link. I'll try first with independent function (no
> > >>>>>>> compose)
> > >>>>>>> and
> > >>>>>>> see if this can work at least for a start.
> > >>>>>>> Franck
> > >>>>>>>> Envoyé: Vendredi 29 Décembre 2017 17:55:30
> > >>>>>>>> (PCRegister) ?
> > >>>>>>>>> On Dec 29, 2017, at 9:03 AM, Franck Houssen
> > >>>>>>>>> wrote:
> > >>>>>>>>> OK, on the highway now (bad ssh !), I'll try to check this out.
> > >>>>>>>>>> Envoyé: Jeudi 28 Décembre 2017 18:21:48
> > >>>>>>>>>> (PCRegister) ?
> > >>>>>>>>>>> On Dec 28, 2017, at 10:34 AM, Franck Houssen
> > >>>>>>>>>>>> Envoyé: Jeudi 28 Décembre 2017 16:43:16
> > >>>>>>>>>>>> PC
> > >>>>>>>>>>>> (PCRegister) ?
> > >>>>>>>>>>>> The register is for a new type of PC of which can have many
> > >>>>>>>>>>>> instantiations
> > >>>>>>>>>>>> at the same time.
> > >>>>>>>>>>> OK, I didn't get that that way ! I was looking for a way to
> > >>>>>>>>>>> plug
> > >>>>>>>>>>> "my"
> > >>>>>>>>>>> pc
> > >>>>>>>>>>> at
> > >>>>>>>>>>> the command line this way: -pc_type my_pc.
> > >>>>>>>>>>> I already call PCSetType(pc, PCSHELL) and PCShellSetName(pc,
> > >>>>>>>>>>> "my_pc"):
> > >>>>>>>>>>> maybe this already enables "-pc_type shell" or "-pc_type
> > >>>>>>>>>>> my_pc"...
> > >>>>>>>>>>> And
> > >>>>>>>>>>> I
> > >>>>>>>>>>> didn't know it ! :D I'll try that.
> > >>>>>>>>>>> I was looking for a way to integrate "my" (external) pc as any
> > >>>>>>>>>>> other
> > >>>>>>>>>>> regular/existing petsc pc (bjacobi, ...) like a kind of plugin
> > >>>>>>>>>>> but
> > >>>>>>>>>>> still
> > >>>>>>>>>>> integrated to the cmd line: I believed PCRegister was meant for
> > >>>>>>>>>>> that.
> > >>>>>>>>>> Indeed it is exactly what it is meant for. Please try to follow
> > >>>>>>>>>> my
> > >>>>>>>>>> recipe
> > >>>>>>>>>> and let us know when you get stuck.
> > >>>>>>>>>>> Not sure if this is actually possible/enabled by the API.
> > >>>>>>>>>>>> For example
> > >>>>>>>>>>>> PCRegister("mypctype",mypc_create);
> > >>>>>>>>>>>> KSPCreate(&ksp1);
> > >>>>>>>>>>>> KSPCreate(&ksp2);
> > >>>>>>>>>>>> KSPGetPC(ksp1,&pc1);
> > >>>>>>>>>>>> KSPGetPC(ksp2,&pc2);
> > >>>>>>>>>>>> You don't want pc1 and pc2 to have the same dof
> > >>>>>>>>>>>> multiplicities,
> > >>>>>>>>>>>> domain
> > >>>>>>>>>>>> intersections etc since they are associated with completely
> > >>>>>>>>>>>> different
> > >>>>>>>>>>>> linear systems and presumably meshes etc.
> > >>>>>>>>>>>> Presumably you want each of pc1, pc2, to have their own
> > >>>>>>>>>>>> version
> > >>>>>>>>>>>> of
> > >>>>>>>>>>>> the
> > >>>>>>>>>>>> data so you need to stick it directly in the PC, for example
> > >>>>>>>>>>>> PCMypcSetDOFMultiplicities(pc1,stuff);
> > >>>>>>>>>>>> PCMypcSetDOFMultiplicities(pc2,otherstuff);
> > >>>>>>>>> OK, I must provide/implement PCMypcSetDOFMultiplicities (add data
> > >>>>>>>>> to
> > >>>>>>>>> pc
> > >>>>>>>>> context) besides mypc_create: sounds logical.
> > >>>>>>>>> Is this OK if PCMypcSetDOFMultiplicities is independent from
> > >>>>>>>>> mypc_create
> > >>>>>>>>> I guess yes.
> > >>>>>>>>> From what I remember/understand, I got lost here: from the jacobi
> > >>>>>>>>> example,
> > >>>>>>>>> mypc_create looks to be supposed (?) to call some kind of
> > >>>>>>>>> Petsc*ComposeFunction to associate PCMypcSetDOFMultiplicities to
> > >>>>>>>>> the
> > >>>>>>>>> pc
> > >>>>>>>>> (correct ?)... But, in the jacobi example,
> > >>>>>>>>> PCJacobiGetUseAbs_Jacobi
> > >>>>>>>>> is
> > >>>>>>>>> associated to PCJacobiGetUseAbs_C...
> > >>>>>>>> the _C name is a string name that is used by PETSc to "find" the
> > >>>>>>>> correct
> > >>>>>>>> function pointer which is PCJacobiGetUseAbs_Jacobi. There is no
> > >>>>>>>> _C function.
> > >>>>>>>>> Which turns out not to be implemented according to git grep ?!
> > >>>>>>>>> Got
> > >>>>>>>>> lost
> > >>>>>>>>> here (and looked for a way to pass user data directly to
> > >>>>>>>>> PCRegister):
> > >>>>>>>>> is
> > >>>>>>>>> PCMypcSetDOFMultiplicities supposed to be "attached/composed" or
> > >>>>>>>>> independent from the pc ?
> > >>>>>>>> composed.
> > >>>>>>>>>>> git grep PCJacobiGetUseAbs_C
> > >>>>>>>>> src/ksp/pc/impls/jacobi/jacobi.c: ierr =
> > >>>>>>>>> PetscObjectComposeFunction((PetscObject)pc,"PCJacobiGetUseAbs_C",PCJacobiGetUseAbs_Jacobi);CHKERRQ(ierr);
> > >>>>>>>>> PetscUseMethod(pc,"PCJacobiGetUseAbs_C",(PC,PetscBool*),(pc,flg));CHKERRQ(ierr);
> > >>>>>>>>> Sorry, for the short answer. Hope I succeeded to be clear enough.
> > >>>>>>>> Just copy jacobi.c and start converting it over to your names and
> > >>>>>>>> needs
> > >>>>>>>> and you'll see it is actually really straightforward and not as
> > >>>>>>>> complicated as you think it is.
> > >>>>>>>> Barry
> > >>>>>>>>>>>> You write as many of these Set() functions as you need for
> > >>>>>>>>>>>> your
> > >>>>>>>>>>>> PCtype.
> > >>>>>>>>>>>> You
> > >>>>>>>>>>>> store the data inside the PC_Mypc data structure you create
> > >>>>>>>>>>>> with
> > >>>>>>>>>>>> mypc_create(). Look at PCCreate_Jacobi() and PCJacobiSetType
> > >>>>>>>>>>>> for
> > >>>>>>>>>>>> the
> > >>>>>>>>>>>> pattern.
> > >>>>>>>>>>>> Barry
> > >>>>>>>>>>>>> On Dec 28, 2017, at 9:34 AM, Franck Houssen
> > >>>>>>>>>>>>> At first, I expected the signature would be "PetscErrorCode
> > >>>>>>>>>>>>> PCRegister(const char sname[],PetscErrorCode (*function)(PC,
> > >>>>>>>>>>>>> void
> > >>>>>>>>>>>>> but
> > >>>>>>>>>>>>> it turns out to be "PetscErrorCode PCRegister(const char
> > >>>>>>>>>>>>> sname[],PetscErrorCode (*function)(PC))"
> > >>>>>>>>>>>>> I try to integrate a PC that needs A but also other
> > >>>>>>>>>>>>> informations
> > >>>>>>>>>>>>> (dof
> > >>>>>>>>>>>>> multiplicities, domain intersections that the user must
> > >>>>>>>>>>>>> provide).
> > >>>>>>>>>>>>> I
> > >>>>>>>>>>>>> guess
> > >>>>>>>>>>>>> I can get A with PCGetOperators in the setup callback of the
> > >>>>>>>>>>>>> PC.
> > >>>>>>>>>>>>> But
> > >>>>>>>>>>>>> still
> > >>>>>>>>>>>>> not sure how to pass the other informations if I get to use
> > >>>>>>>>>>>>> PCRegister.
> > >>>>>>>>>>>>> I
> > >>>>>>>>>>>>> looked a few examples in the bitbucket (jacobi:
> > >>>>>>>>>>>>> src/ksp/ksp/examples/tutorials/ex12.c and
> > >>>>>>>>>>>>> + SOR: src/ksp/pc/impls/sor/sor.c)... But didn't get any real
> > >>>>>>>>>>>>> relevant
> > >>>>>>>>>>>>> answer and feel a bit lost among the numerous pc !...
> > >>>>>>>>>>>>> The idea is: for now I use PCSetType(pc, PCSHELL) and
> > >>>>>>>>>>>>> PCShellSetContext
> > >>>>>>>>>>>>> with a context who knows the extra needed informations which
> > >>>>>>>>>>>>> is
> > >>>>>>>>>>>>> "not
> > >>>>>>>>>>>>> so
> > >>>>>>>>>>>>> handy" (that's OK as for now I am both the user and the PC
> > >>>>>>>>>>>>> provider).
> > >>>>>>>>>>>>> I'd
> > >>>>>>>>>>>>> like to package this in a more convenient way (a unique and
> > >>>>>>>>>>>>> "simple"
> > >>>>>>>>>>>>> call
> > >>>>>>>>>>>>> to PCRegister) to decouple the user from the PC machinery.
> > >>>>>>>>>>>>> Franck
