[petsc-dev] IDR(s) method in PETSc
    simone cammarasana
    cammarasanasimone at gmail.com
    Fri Jan 12 08:23:14 CST 2018
Hello PETSc team,
firtst of all sorry if this is not the right email where I can address my
question to.
I was looking for an IDR(s) implementation on PETSc since it would be
needed for the research I was performing.
I did not find it (I don't know if it is on-working or not contemplated) so
I tried to implement it by myself (since I have Matlab code available)
Code works (solution is exact) but performance are not good as expected
(not so bad, but lightly higher than BicGSTAB)
I would like to share with you and, if someone has a little bit of time to
spend on, I would be grateful if he could help me
I share my preliminary code, sorry for bad "informatic" implementation, I'm
sure is much improvable from this point of view.
It works only in serial mode for the moment
Thank you all for the time
Regards
Simone Cammarasana
___________________________________
Saluti / Regards
*Simone Cammarasana*
Tel. +39 340 0029498
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180112/ff136647/attachment.html>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180112/ff136647/attachment.bin>
