[petsc-dev] Our pull request work flow is terrible and horrible
    Patrick Sanan
    patrick.sanan at gmail.com
    Thu Jan 11 11:40:44 CST 2018
One idea is to impose a stricter guideline that things on the bitbucket PR
page are things that everyone is actively trying to merge. That way,
maintainers can just look at the bottom of the list to see what's lagging,
instead of having to to work up the list and try to remember which of the
PRs are WIP or proposals or experiments or even abandoned ideas.
This probably requires an itchier trigger finger on declining PRs which
need substantial work.
A related point is that (as happened with the last PR I made), if a big
edit is performed after the original PR is made or even approved, then it's
not always clear "whose court" the PR is in. Maybe it's better to just make
a new PR in this situation. I'm not sure if bitbucket allows you to decline
your own PR (I fear not) - that would make this easier.
2018-01-11 9:00 GMT-08:00 Smith, Barry F. <bsmith at mcs.anl.gov>:
>    what do people suggest to improve it.
>     We can't have valuable pieces of code going stale in there for months.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180111/3a757c70/attachment.html>
