[petsc-dev] How do I collect all the values from a sequential vector on the zeroth processor into a parallel PETSc vector ?
    Franck Houssen
    franck.houssen at inria.fr
    Fri Jan  5 03:29:48 CST 2018
Got it, tested it : all is OK ! Thanks guys.
Franck
----- Mail original -----
> De: "Barry F. Smith" <bsmith at mcs.anl.gov>
> À: "Franck Houssen" <franck.houssen at inria.fr>
> Cc: "Barry F. Smith" <bsmith at mcs.anl.gov>, "Matthew Knepley"
> <knepley at gmail.com>, "For users of the development version of PETSc"
> <petsc-dev at mcs.anl.gov>
> Envoyé: Jeudi 4 Janvier 2018 18:10:03
> Objet: Re: [petsc-dev] How do I collect all the values from a sequential
> Frank,
> This is our bug. I have attached a patch and also fixed it in the PETSc
> repository master branch.
> apply with
> patch -p1 < franck.patch
> if you are using the tarball version of PETSc.
> Barry
> > On Jan 4, 2018, at 2:31 AM, Franck Houssen <franck.houssen at inria.fr> wrote:
> > I attached it in the very first mail.
> > Franck
> >>> more vecScatterGatherRoot.cpp
> > // How do I collect all the values from a sequential vector on the zeroth
> > // ~> g++ -o vecScatterGatherRoot.exe vecScatterGatherRoot.cpp -lpetsc -lm;
> > mpirun -n X vecScatterGatherRoot.exe
> > #include "petsc.h"
> > int main(int argc,char **argv) {
> > PetscInitialize(&argc, &argv, NULL, NULL);
> > int size = 0; MPI_Comm_size(MPI_COMM_WORLD, &size);
> > int rank = 0; MPI_Comm_rank(MPI_COMM_WORLD, &rank);
> > PetscInt globSize = size;
> > Vec globVec; VecCreateMPI(PETSC_COMM_WORLD, 1, globSize, &globVec);
> > VecSetValue(globVec, rank, (PetscScalar) (1.+rank), INSERT_VALUES);
> > VecAssemblyBegin(globVec); VecAssemblyEnd(globVec);
> > VecView(globVec, PETSC_VIEWER_STDOUT_WORLD);
> > PetscViewerFlush(PETSC_VIEWER_STDOUT_WORLD);
> > // Collect all the values from a parallel PETSc vector into a vector on the
> > zeroth processor.
> > Vec locVec = NULL;
> > if (rank == 0) {
> > PetscInt locSize = globSize;
> > VecCreateSeq(PETSC_COMM_SELF, locSize, &locVec); VecSet(locVec, -1.);
> > VecScatter scatCtx; VecScatterCreateToZero(globVec, &scatCtx, &locVec);
> > VecScatterBegin(scatCtx, globVec, locVec, INSERT_VALUES, SCATTER_FORWARD);
> > VecScatterEnd (scatCtx, globVec, locVec, INSERT_VALUES, SCATTER_FORWARD);
> > // Modify sequential vector on the zeroth processor.
> > if (rank == 0) {
> > VecView(locVec, PETSC_VIEWER_STDOUT_SELF);
> > PetscViewerFlush(PETSC_VIEWER_STDOUT_SELF);
> > VecScale(locVec, -1.);
> > MPI_Barrier(MPI_COMM_WORLD);
> > VecSet(globVec, 0.);
> > VecScatterBegin(scatCtx, locVec, globVec, ADD_VALUES, SCATTER_REVERSE);
> > VecScatterEnd (scatCtx, locVec, globVec, ADD_VALUES, SCATTER_REVERSE);
> > PetscFinalize();
> >> version of PETSc" <petsc-dev at mcs.anl.gov>
> >> Envoyé: Mercredi 3 Janvier 2018 18:20:21
> >> Send the complete code as an attachment.
> >>> On Jan 3, 2018, at 11:08 AM, Franck Houssen <franck.houssen at inria.fr>
> >>>> Cc: "Matthew Knepley" <knepley at gmail.com>, "For users of the development
> >>>> Envoyé: Mercredi 3 Janvier 2018 18:01:35
> >>>>> On Jan 3, 2018, at 10:59 AM, Franck Houssen <franck.houssen at inria.fr>
> >>>>> wrote:
> >>>>> I need the exact opposite operation of an entry in the FAQ called "How
> >>>>> do
> >>>>> I
> >>>>> collect all the values from a parallel PETSc vector into a vector on
> >>>>> the
> >>>>> zeroth processor?"
> >>>> You can use VecScatterCreateToZero() then do the scatter with scatter
> >>>> reverse.
> >>> That's what I tried but got an error. Did I miss something ?
> >>>>> tail vecScatterGatherRoot.cpp
> >>> PetscFinalize();
> >>>>> mpirun -n 2 ./vecScatterGatherRoot.exe
> >>> Vec Object: 2 MPI processes
> >>> type: mpi
> >>> Process [0]
> >>> 1.
> >>> Process [1]
> >>> 2.
> >>> Vec Object: 1 MPI processes
> >>> type: seq
> >>> 1.
> >>> 2.
> >>> type: seq
> >>> -1.
> >>> -2.
> >>> [1]PETSC ERROR: [1] VecScatterBegin_MPI_ToOne line 161
> >>> /home/fghoussen/Documents/INRIA/petsc/src/vec/vec/utils/vscat.c
> >>> [1]PETSC ERROR: [1] VecScatterBegin line 1698
> >>> [1]PETSC ERROR: --------------------- Error Message
> >>> [1]PETSC ERROR: Signal received
> >>> [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> >>> for
> >>> trouble shooting.
> >>>>> Shall I use VecScatterCreateToZero "backward", or, use VecScatterCreate
> >>>>> instead ? If yes, how ? (my understanding is that VecScatterCreate can
> >>>>> take only parallel vector as input)
> >>>> This understanding is completely incorrect.
> >>>> Barry
> >>>>> Not sure how to do this.
> >>>>> Its not clear what you want. Do you want a seq vector duplicated on all
> >>>>> procs?
> >>>>> No. The seq vec should "live" only on the master proc. This seq master
> >>>>> vec
> >>>>> should be "converted" into a parallel vector. Not sure how to do that
> >>>>> Do you want it split up? The short
> >>>>> answer is, use the appropriate scatter.
> >>>>> Matt
> >>>>> Franck
> >>>>> In this example, the final VecView of the parallel globVec vector
> >>>>> should
> >>>>> be
> >>>>> [-1., -2.]
> >>>>> type: mpi
> >>>>> Process [0]
> >>>>> 1.
> >>>>> Process [1]
> >>>>> 2.
> >>>>> type: seq
> >>>>> 1.
> >>>>> 2.
> >>>>> type: seq
> >>>>> -1.
> >>>>> -2.
> >>>>> [1]PETSC ERROR:
> >>>>> [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> >>>>> probably memory access out of range
> >>>>> zeroth
> >>>>> -lm;
> >>>>> #include "petsc.h"
> >>>>> Vec locVec = NULL;
> >>>>> if (rank == 0) {
> >>>>> SCATTER_FORWARD);
> >>>>> SCATTER_FORWARD);
> >>>>> if (rank == 0) {
> >>>>> zeroth
> >>>>> PetscFinalize();
> >>>>> What most experimenters take for granted before they begin their
> >>>>> experiments is infinitely more interesting than any results to which
> >>>>> their
> >>>>> experiments lead.
> >>>>> -- Norbert Wiener
> >>>>> https://www.cse.buffalo.edu/~knepley/
> > <vecScatterGatherRoot.cpp>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180105/bd05efdf/attachment-0001.html>
