[petsc-dev] How do I collect all the values from a sequential vector on the zeroth processor into a parallel PETSc vector ?
    Franck Houssen
    franck.houssen at inria.fr
    Wed Jan  3 11:08:39 CST 2018
----- Mail original -----
> De: "Barry F. Smith" <bsmith at mcs.anl.gov>
> À: "Franck Houssen" <franck.houssen at inria.fr>
> Cc: "Matthew Knepley" <knepley at gmail.com>, "For users of the development version of PETSc" <petsc-dev at mcs.anl.gov>
> Envoyé: Mercredi 3 Janvier 2018 18:01:35
> Objet: Re: [petsc-dev] How do I collect all the values from a sequential vector on the zeroth processor into a
> > On Jan 3, 2018, at 10:59 AM, Franck Houssen <franck.houssen at inria.fr>
> > wrote:
> > I need the exact opposite operation of an entry in the FAQ called "How do I
> > collect all the values from a parallel PETSc vector into a vector on the
> > zeroth processor?"
>   You can use VecScatterCreateToZero() then do the scatter with scatter
>   reverse.
That's what I tried but got an error. Did I miss something ?
>> tail vecScatterGatherRoot.cpp
  // How do I collect all the values from a sequential vector on the zeroth processor into a parallel PETSc vector ?
  VecSet(globVec, 0.);
  VecScatterBegin(scatCtx, locVec, globVec, ADD_VALUES, SCATTER_REVERSE);
  VecScatterEnd  (scatCtx, locVec, globVec, ADD_VALUES, SCATTER_REVERSE);
  VecView(globVec, PETSC_VIEWER_STDOUT_WORLD); PetscViewerFlush(PETSC_VIEWER_STDOUT_WORLD);
  PetscFinalize();
>> mpirun -n 2 ./vecScatterGatherRoot.exe
Vec Object: 2 MPI processes
  type: mpi
Process [0]
1.
Process [1]
2.
Vec Object: 1 MPI processes
  type: seq
1.
2.
  type: seq
-1.
-2.
[1]PETSC ERROR: [1] VecScatterBegin_MPI_ToOne line 161 /home/fghoussen/Documents/INRIA/petsc/src/vec/vec/utils/vscat.c
[1]PETSC ERROR: [1] VecScatterBegin line 1698 /home/fghoussen/Documents/INRIA/petsc/src/vec/vec/utils/vscat.c
[1]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[1]PETSC ERROR: Signal received
[1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> > Shall I use VecScatterCreateToZero "backward", or, use VecScatterCreate
> > instead ? If yes, how ? (my understanding is that VecScatterCreate can
> > take only parallel vector as input)
>    This understanding is completely incorrect.
>   Barry
> > Not sure how to do this.
> > Its not clear what you want. Do you want a seq vector duplicated on all
> > procs?
> > No. The seq vec should "live" only on the master proc. This seq master vec
> > should be "converted" into a parallel vector. Not sure how to do that
> > Do you want it split up? The short
> > answer is, use the appropriate scatter.
> >    Matt
> > Franck
> > In this example, the final VecView of the parallel globVec vector should be
> > [-1., -2.]
> >   type: mpi
> > Process [0]
> > 1.
> > Process [1]
> > 2.
> >   type: seq
> > 1.
> > 2.
> >   type: seq
> > -1.
> > -2.
> > [1]PETSC ERROR:
> > [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> > probably memory access out of range
> > >> more vecScatterGatherRoot.cpp
> > // ~> g++ -o vecScatterGatherRoot.exe vecScatterGatherRoot.cpp -lpetsc -lm;
> > mpirun -n X vecScatterGatherRoot.exe
> > #include "petsc.h"
> > int main(int argc,char **argv) {
> >   PetscInitialize(&argc, &argv, NULL, NULL);
> >   int size = 0; MPI_Comm_size(MPI_COMM_WORLD, &size);
> >   int rank = 0; MPI_Comm_rank(MPI_COMM_WORLD, &rank);
> >   PetscInt globSize = size;
> >   Vec globVec; VecCreateMPI(PETSC_COMM_WORLD, 1, globSize, &globVec);
> >   VecSetValue(globVec, rank, (PetscScalar) (1.+rank), INSERT_VALUES);
> >   VecAssemblyBegin(globVec); VecAssemblyEnd(globVec);
> >   // Collect all the values from a parallel PETSc vector into a vector on
> >   the zeroth processor.
> >   Vec locVec = NULL;
> >   if (rank == 0) {
> >     PetscInt locSize = globSize;
> >     VecCreateSeq(PETSC_COMM_SELF, locSize, &locVec); VecSet(locVec, -1.);
> >   VecScatter scatCtx; VecScatterCreateToZero(globVec, &scatCtx, &locVec);
> >   VecScatterBegin(scatCtx, globVec, locVec, INSERT_VALUES,
> >   SCATTER_FORWARD);
> >   VecScatterEnd  (scatCtx, globVec, locVec, INSERT_VALUES,
> >   SCATTER_FORWARD);
> >   // Modify sequential vector on the zeroth processor.
> >   if (rank == 0) {
> >     VecView(locVec, PETSC_VIEWER_STDOUT_SELF);
> >     PetscViewerFlush(PETSC_VIEWER_STDOUT_SELF);
> >     VecScale(locVec, -1.);
> >   MPI_Barrier(MPI_COMM_WORLD);
> >   PetscFinalize();
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which their
> > experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/
