[petsc-dev] How to pass user data to a registered PC (PCRegister) ?
Smith, Barry F.
bsmith at mcs.anl.gov
Tue Jan 2 07:50:02 CST 2018
> On Jan 2, 2018, at 7:47 AM, Franck Houssen <franck.houssen at inria.fr> wrote:
> I'll try to fetch/pull the git clone: maybe there is a reg on the code level I am on.
Unlikely.
I'm afraid you need to use the debugger and slog through the call. It seems you are doing things ok so why this happens I cannot explain. We use this paradigm everywhere with options in PETSc and it always works so I am totally lost as to why it fails for you.
Barry
> ----- Mail original -----
>> De: "Barry F. Smith" <bsmith at mcs.anl.gov>
>> À: "Franck Houssen" <franck.houssen at inria.fr>
>> Cc: "For users of the development version of PETSc" <petsc-dev at mcs.anl.gov>
>> Envoyé: Mardi 2 Janvier 2018 13:22:16
>> Objet: Re: [petsc-dev] How to pass user data to a registered PC (PCRegister) ?
>> static PetscErrorCode PCSetFromOptions_Jacobi(PetscOptionItems
>> *PetscOptionsObject,PC pc)
>> PC_Jacobi *jac = (PC_Jacobi*)pc->data;
>> PetscErrorCode ierr;
>> PetscBool flg;
>> PCJacobiType deflt,type;
>> PetscFunctionBegin;
>> ierr = PCJacobiGetType(pc,&deflt);CHKERRQ(ierr);
>> ierr = PetscOptionsHead(PetscOptionsObject,"Jacobi options");CHKERRQ(ierr);
>> ierr = PetscOptionsEnum("-pc_jacobi_type","How to construct diagonal
>> matrix","PCJacobiSetType",PCJacobiTypes,(PetscEnum)deflt,(PetscEnum*)&type,&flg);CHKERRQ(ierr);
>> if (flg) {
>> ierr = PCJacobiSetType(pc,type);CHKERRQ(ierr);
>> ierr = PetscOptionsBool("-pc_jacobi_abs","Use absolute values of diagaonal
>> entries","PCJacobiSetUseAbs",jac->useabs,&jac->useabs,NULL);CHKERRQ(ierr);
>> ierr = PetscOptionsTail();CHKERRQ(ierr);
>> PetscFunctionReturn(0);
>> Note how PetscOptionsHead() is called with the argument PetscOptionsObject
> I do call PetscOptionsHead(PetscOptionsObject, ...);
>> which is passed in from above. My guess is that you don't
>> call it with this argument? You would get behavior you describe if you don't.
>> Please send your REAL setupfromoptions_mypc() not just pseudo code.
> #define SETERRABT(msg) SETERRABORT(PETSC_COMM_WORLD,PETSC_ERR_ARG_NULL,msg)
> static PetscErrorCode setUpGenEOPCFromOptions(PetscOptionItems * PetscOptionsObject, PC pcPC) {
> // Get the context.
> if (!pcPC) SETERRABT("GenEO preconditioner is invalid");
> geneoContext * gCtx = (geneoContext *) pcPC->data;
> if (!gCtx) SETERRABT("GenEO preconditioner without context");
> // Check arguments.
> PetscErrorCode pcRC = PetscOptionsHead(PetscOptionsObject, "GenEO options");
> CHKERRQ(pcRC);
> pcRC = PetscOptionsBegin(PETSC_COMM_WORLD, NULL, "GenEO options", "GenEO options");
> CHKERRQ(pcRC);
> PetscBool pcHasOpt = PETSC_FALSE;
> PetscInt nbArgs = 2;
> char *args[2];
> pcRC = PetscOptionsStringArray("-geneo_lvl", "GenEO levels", "GenEO levels", args, &nbArgs, &pcHasOpt);
> CHKERRQ(pcRC);
> if (pcHasOpt) {
>> Barry
>>> On Jan 2, 2018, at 5:04 AM, Franck Houssen <franck.houssen at inria.fr> wrote:
>>>> Envoyé: Dimanche 31 Décembre 2017 23:41:42
>>>> (PCRegister) ?
>>>>> On Dec 31, 2017, at 8:40 AM, Franck Houssen <franck.houssen at inria.fr>
>>>>> wrote:
>>>>> Seems finally, I got it to work.
>>>>> To get the options to work I had to call PetscOptionsBegin/End
>>>>> after/before
>>>>> PetscOptionsHead/Tail which is not what is done in the jacobi example: is
>>>>> this the right way to go ?
>>>> Something is wrong.
>>> I felt there was something wrong !...
>>>> PetscOptionsBegin/end are called in PCSetFromOptions()
>>>> that is suppose to wrap YOUR PCSetFromOptions_mypc().
>>> OK, sounds logical, that's how I expected things to be done. That's why I
>>> was suspicious: what worked should not !...
>>> I believed maybe the problem was connected to the fact that I do NOT use
>>> compose function, but, according to Matt's explanation, I would say no:
>>> the use of PetscComposeFunction seems independent from the
>>> PCSetFromOptions_mypc problem.
>>> Note: in my case, I believe I do not really need PetscCompose, I just need
>>> one (regular) function to initialize specific stuffs needed in my_pc (at
>>> least for a start). I can go to PetscCompose later if it turns out to be
>>> relevant (that's how I understand this).
>>>> Perhaps you are
>>>> calling PCSetFromOptions_mypc directly which you should never do.
>>> No, I don't call PCSetFromOptions_mypc directly.
>>>> Your PCCreate_mypc() should stick the function pointer for
>>>> PCSetFromOptions_mypc into the ops table like it does PCApply_mypc etc.
>>>> Then you just directly use PCSetFromOptions.
>>> create_mpc(PC pc) { // CB for PCRegister
>>> pcPC->ops->setfromoptions = setupfromoptions_mypc;
>>> static PetscErrorCode setupfromoptions_mypc(PetscOptionItems *
>>> PetscOptionsHead()
>>> PetscOptionsBegin()
>>> PetscOptionsStringArray("-mypc_opt", ..., flag)
>>> cout << "debug " << flag << endl;
>>> PetscOptionsEnd()
>>> PetscOptionsTail()
>>> I got called on setupfromoptions_mypc when I call PCSetUpFromOptions().
>>> If I let PetscOptionsBegin/End, it looks like I read in the "correct"
>>> option data base, I get (cout) : "debug 1" (-my_opt is read)
>>> If I comment PetscOptionsBegin/End, seems I read an incorrect (empty ?)
>>> option data base, I get (cout) : "debug 0"
>>> Looks weird even if it's not blocking for now (I know there is problem but
>>> I can by pass it)
>>>> Barry
>>>>> Franck
>>>>> PetscErrorCode PCSetFromOptions_mypc(PetscOptionItems *
>>>>> PetscOptionsObject,
>>>>> PC pcPC) {
>>>>> PetscOptionsHead
>>>>> PetscOptionsBegin
>>>>> ... // PetscOptionsStringArray
>>>>> PetscOptionsEnd
>>>>> PetscOptionsTail
>>>>>> De: "Franck Houssen" <franck.houssen at inria.fr>
>>>>>> À: "Barry F. Smith" <bsmith at mcs.anl.gov>
>>>>>> Envoyé: Dimanche 31 Décembre 2017 15:01:43
>>>>>> (PCRegister) ?
>>>>>> Using PCSHELL means calling:
>>>>>> - PCShellSetSetUp, PCShellSetApply, PCShellSetDestroy to set callbacks.
>>>>>> - PCShellSetContext/PCShellGetContext to get/set context in callbacks.
>>>>>> To go from PCSHELL to PCRegister, one need to:
>>>>>> - #include <petsc/private/pcimpl.h> // Access to PC data/struct.
>>>>>> - Set callbacks with pc->ops->...
>>>>>> - NO more use ANY shell methods (context, name), but, use pc->data
>>>>>> instead.
>>>>>> - call PCRegister.
>>>>>> Correct ? Did I miss something ?
>>>>>> Seems I get things to work (without compose function).
>>>>>> The last problem I have is in the options: options are passed to
>>>>>> PetscInitialize but not found in the database (I mimic'ed the jacobi
>>>>>> example). Is there specific related to this ?
>>>>>>> Envoyé: Samedi 30 Décembre 2017 17:12:09
>>>>>>> (PCRegister) ?
>>>>>>> Don't get the link. I'll try first with independent function (no
>>>>>>> compose)
>>>>>>> and
>>>>>>> see if this can work at least for a start.
>>>>>>> Franck
>>>>>>>> Envoyé: Vendredi 29 Décembre 2017 17:55:30
>>>>>>>> (PCRegister) ?
>>>>>>>>> On Dec 29, 2017, at 9:03 AM, Franck Houssen <franck.houssen at inria.fr>
>>>>>>>>> wrote:
>>>>>>>>> OK, on the highway now (bad ssh !), I'll try to check this out.
>>>>>>>>>> Envoyé: Jeudi 28 Décembre 2017 18:21:48
>>>>>>>>>> (PCRegister) ?
>>>>>>>>>>> On Dec 28, 2017, at 10:34 AM, Franck Houssen
>>>>>>>>>>>> Envoyé: Jeudi 28 Décembre 2017 16:43:16
>>>>>>>>>>>> (PCRegister) ?
>>>>>>>>>>>> The register is for a new type of PC of which can have many
>>>>>>>>>>>> instantiations
>>>>>>>>>>>> at the same time.
>>>>>>>>>>> OK, I didn't get that that way ! I was looking for a way to plug
>>>>>>>>>>> "my"
>>>>>>>>>>> pc
>>>>>>>>>>> at
>>>>>>>>>>> the command line this way: -pc_type my_pc.
>>>>>>>>>>> I already call PCSetType(pc, PCSHELL) and PCShellSetName(pc,
>>>>>>>>>>> "my_pc"):
>>>>>>>>>>> maybe this already enables "-pc_type shell" or "-pc_type my_pc"...
>>>>>>>>>>> And
>>>>>>>>>>> I
>>>>>>>>>>> didn't know it ! :D I'll try that.
>>>>>>>>>>> I was looking for a way to integrate "my" (external) pc as any
>>>>>>>>>>> other
>>>>>>>>>>> regular/existing petsc pc (bjacobi, ...) like a kind of plugin but
>>>>>>>>>>> still
>>>>>>>>>>> integrated to the cmd line: I believed PCRegister was meant for
>>>>>>>>>>> that.
>>>>>>>>>> Indeed it is exactly what it is meant for. Please try to follow my
>>>>>>>>>> recipe
>>>>>>>>>> and let us know when you get stuck.
>>>>>>>>>>> Not sure if this is actually possible/enabled by the API.
>>>>>>>>>>>> For example
>>>>>>>>>>>> PCRegister("mypctype",mypc_create);
>>>>>>>>>>>> KSPCreate(&ksp1);
>>>>>>>>>>>> KSPCreate(&ksp2);
>>>>>>>>>>>> KSPGetPC(ksp1,&pc1);
>>>>>>>>>>>> KSPGetPC(ksp2,&pc2);
>>>>>>>>>>>> You don't want pc1 and pc2 to have the same dof multiplicities,
>>>>>>>>>>>> domain
>>>>>>>>>>>> intersections etc since they are associated with completely
>>>>>>>>>>>> different
>>>>>>>>>>>> linear systems and presumably meshes etc.
>>>>>>>>>>>> Presumably you want each of pc1, pc2, to have their own version
>>>>>>>>>>>> of
>>>>>>>>>>>> the
>>>>>>>>>>>> data so you need to stick it directly in the PC, for example
>>>>>>>>>>>> PCMypcSetDOFMultiplicities(pc1,stuff);
>>>>>>>>>>>> PCMypcSetDOFMultiplicities(pc2,otherstuff);
>>>>>>>>> OK, I must provide/implement PCMypcSetDOFMultiplicities (add data to
>>>>>>>>> pc
>>>>>>>>> context) besides mypc_create: sounds logical.
>>>>>>>>> Is this OK if PCMypcSetDOFMultiplicities is independent from
>>>>>>>>> mypc_create
>>>>>>>>> I guess yes.
>>>>>>>>> From what I remember/understand, I got lost here: from the jacobi
>>>>>>>>> example,
>>>>>>>>> mypc_create looks to be supposed (?) to call some kind of
>>>>>>>>> Petsc*ComposeFunction to associate PCMypcSetDOFMultiplicities to the
>>>>>>>>> pc
>>>>>>>>> (correct ?)... But, in the jacobi example, PCJacobiGetUseAbs_Jacobi
>>>>>>>>> is
>>>>>>>>> associated to PCJacobiGetUseAbs_C...
>>>>>>>> the _C name is a string name that is used by PETSc to "find" the
>>>>>>>> correct
>>>>>>>> function pointer which is PCJacobiGetUseAbs_Jacobi. There is no
>>>>>>>> _C function.
>>>>>>>>> Which turns out not to be implemented according to git grep ?! Got
>>>>>>>>> lost
>>>>>>>>> here (and looked for a way to pass user data directly to PCRegister):
>>>>>>>>> is
>>>>>>>>> PCMypcSetDOFMultiplicities supposed to be "attached/composed" or
>>>>>>>>> independent from the pc ?
>>>>>>>> composed.
>>>>>>>>>>> git grep PCJacobiGetUseAbs_C
>>>>>>>>> src/ksp/pc/impls/jacobi/jacobi.c: ierr =
>>>>>>>>> PetscObjectComposeFunction((PetscObject)pc,"PCJacobiGetUseAbs_C",PCJacobiGetUseAbs_Jacobi);CHKERRQ(ierr);
>>>>>>>>> PetscUseMethod(pc,"PCJacobiGetUseAbs_C",(PC,PetscBool*),(pc,flg));CHKERRQ(ierr);
>>>>>>>>> Sorry, for the short answer. Hope I succeeded to be clear enough.
>>>>>>>> Just copy jacobi.c and start converting it over to your names and
>>>>>>>> needs
>>>>>>>> and you'll see it is actually really straightforward and not as
>>>>>>>> complicated as you think it is.
>>>>>>>> Barry
>>>>>>>>>>>> You write as many of these Set() functions as you need for your
>>>>>>>>>>>> PCtype.
>>>>>>>>>>>> You
>>>>>>>>>>>> store the data inside the PC_Mypc data structure you create with
>>>>>>>>>>>> mypc_create(). Look at PCCreate_Jacobi() and PCJacobiSetType for
>>>>>>>>>>>> the
>>>>>>>>>>>> pattern.
>>>>>>>>>>>> Barry
>>>>>>>>>>>>> On Dec 28, 2017, at 9:34 AM, Franck Houssen
>>>>>>>>>>>>> At first, I expected the signature would be "PetscErrorCode
>>>>>>>>>>>>> PCRegister(const char sname[],PetscErrorCode (*function)(PC, void
>>>>>>>>>>>>> but
>>>>>>>>>>>>> it turns out to be "PetscErrorCode PCRegister(const char
>>>>>>>>>>>>> sname[],PetscErrorCode (*function)(PC))"
>>>>>>>>>>>>> I try to integrate a PC that needs A but also other informations
>>>>>>>>>>>>> (dof
>>>>>>>>>>>>> multiplicities, domain intersections that the user must provide).
>>>>>>>>>>>>> I
>>>>>>>>>>>>> guess
>>>>>>>>>>>>> I can get A with PCGetOperators in the setup callback of the PC.
>>>>>>>>>>>>> But
>>>>>>>>>>>>> still
>>>>>>>>>>>>> not sure how to pass the other informations if I get to use
>>>>>>>>>>>>> PCRegister.
>>>>>>>>>>>>> I
>>>>>>>>>>>>> looked a few examples in the bitbucket (jacobi:
>>>>>>>>>>>>> src/ksp/ksp/examples/tutorials/ex12.c and
>>>>>>>>>>>>> + SOR: src/ksp/pc/impls/sor/sor.c)... But didn't get any real
>>>>>>>>>>>>> relevant
>>>>>>>>>>>>> answer and feel a bit lost among the numerous pc !...
>>>>>>>>>>>>> The idea is: for now I use PCSetType(pc, PCSHELL) and
>>>>>>>>>>>>> PCShellSetContext
>>>>>>>>>>>>> with a context who knows the extra needed informations which is
>>>>>>>>>>>>> "not
>>>>>>>>>>>>> so
>>>>>>>>>>>>> handy" (that's OK as for now I am both the user and the PC
>>>>>>>>>>>>> provider).
>>>>>>>>>>>>> I'd
>>>>>>>>>>>>> like to package this in a more convenient way (a unique and
>>>>>>>>>>>>> "simple"
>>>>>>>>>>>>> call
>>>>>>>>>>>>> to PCRegister) to decouple the user from the PC machinery.
>>>>>>>>>>>>> Franck
