[petsc-dev] need c++ expert help
    Jed Brown
    jed at jedbrown.org
    Mon Jan  1 17:05:33 CST 2018
"Smith, Barry F." <bsmith at mcs.anl.gov> writes:
>  Jed
>   I have merge https://bitbucket.org/petsc/petsc/commits/branch/jed/tests-cxx-linker into barry/more-to-new-test-harness on crank
> using the /sandbox/petsc/petsc.next-2 with arch-linux-gcc-ifc-cmplx which is where the compile/link problem appeared. The error no longer appears and thus appears to compile/link the example correctly.
>    There were some conflicts with the merge in examples I didn't bother to deal with in the test.
>    So what to do? Do I do the merge of jed/tests-cxx-linker  into barry/more-to-new-test-harness properly and then merge into next and hope it breaks nothing on any machine tonight?
Yeah, I've tested a couple environments and will fix promptly if there are issues.
