[petsc-dev] [Mike McQuaid] Re: [Homebrew/homebrew-core] PETSc: import from homebrew-science (#23598)
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Sun Feb 25 11:57:27 CST 2018
  So fix the damn script instead of just bitching about it! Jeepers, that is what open source is all about.
  Or if it is so terrible and unfixable then write a new script. The time wasted on mailing lists and arguing with package manager developers would be better spent fixing installer code.
   Barry
> On Feb 25, 2018, at 11:53 AM, Jed Brown <jed at jedbrown.org> wrote:
> "Smith, Barry F." <bsmith at mcs.anl.gov> writes:
>>   Lisandro,
>>    I don't understand this. Are you saying that the PETSc installer installs a bunch of files it shouldn't so you strip them out
>> after the install is run?
>>   The PETSc installer is a nice flexible piece of python code.
> It's so "nice" that it's littered with TODO comments written years ago
> by you about how it should do some of the things that Lisandro's script
> is doing.
> I now also see that it writes an uninstall script that would delete
> /usr/bin if the user installed with --prefix=/usr.
> It also doesn't fix permissions like every normal package does.  (This
> is an issue if the user building the software doesn't have umask 022.)
>> I don't understand why you people who understand which files shouldn't
>> be installed don't just edit the installer to prevent it from
>> installing things it shouldn't instead of writing ad hoc post-install
>> cleanup scripts. Why is "fixing" the installer so difficult that you
>> guys just leave it in a broken state for years? (The reason I don't
>> "fix" it is that I don't know what needs to be fixed since I don't
>> interact with the package managers.
