[petsc-dev] [Mike McQuaid] Re: [Homebrew/homebrew-core] PETSc: import from homebrew-science (#23598)
Jed Brown jed at jedbrown.org
Fri Feb 23 15:59:08 CST 2018
IMO none of this should be installed.  A couple should go to
lib/petsc/bin/.
Satish Balay <balay at mcs.anl.gov> writes:
> $ ls |cat
> adiforfix.py*
delete?
> configVars.py*
Is this ever run?
> FASTMathInstaller.py*
delete?
> maint/
Not for installation
> parseargs.py*
unused?
> PetscBinaryIO.py*
> PetscBinaryIO_tests.py*
> PetscBinaryIOTrajectory.py*
> petsc_conf.py*
I guess these should be installed as a Python package (setuptools)?
Lisandro?
> petscdiff*
> petsc_gen_xdmf.py*
lib/petsc/bin
> petsclogformat.py*
unused?
> petscmpiexec*
lib/petsc/bin
> petsc-mpiexec.uni*
lib/petsc/bin only for builds with MPIUNI
> petscnagupgrade.py*
> petscnagupgrade.pyc
Not installed
> petscrun*
unused?
> popup*
Move this limited code into PetscPopUpSelect() and remove dependence on
ksh (which nobody installs any more) or delete PetscPopUpSelect() which
is untested (a test exists, but is not compiled/run) and probably
unused.
> portabilitycheck.py*
Move; not sure we should install at all.
> saws/
> sendToJenkins*
delete?
> taucc.py*
unused?
> TOPSGenerator.py*
WTF
> uncrustify.cfg
Not in bin.
> update.py*
delete?
> win32fe/
not for installation
