[petsc-dev] DMPlex VecView to HDF5
Adrian Croucher a.croucher at auckland.ac.nz
Wed Feb 21 22:12:33 CST 2018
hi Matt,
On 20/02/18 12:32, Matthew Knepley wrote:
> On Mon, Feb 19, 2018 at 4:33 PM, Adrian Croucher
> <a.croucher at auckland.ac.nz <mailto:a.croucher at auckland.ac.nz>> wrote:
>     hi Matt
>     I tried what you suggested and modified
>     DMPlexGetFieldType_Internal() so that all processes have the same
>     field type (ft):
> Yep, this is going to take specifying in the interface that it is
> collective. It looks like it might be used as if it is not.
It looks to me like that may not be the problem, actually. I think I may
have tracked it down though.
In vec/vec/interface/rvector.c:1280, in VecGetSubVector():
       if (n%bs || bs == 1) bs = -1; /* Do not decide block size if we
do not have to */
If there are no cells on one process (n = 0) then n%bs = 0, so if bs > 1
the reassignment bs = -1 doesn't happen.
If I alter it to:
       if (n%bs || bs == 1 || !n) bs = -1; /* Do not decide block size
if we do not have to */
then it also sets bs = -1 on the n = 0 process, and it works fine for my
case.
I'm not sure I fully understand the purpose of this line though, so
don't know if what I've done is always going to be the right thing?
I also wondered if it would be desirable to ensure bs is consistent
across all processes, but am not sure what the right value would be in
that case. I tried doing an MPI_allreduce() on bs, to find the minimum
across processes (so if any were -1 then they all were) and that also
worked for my case.
- Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180222/78c5f27e/attachment.html>
