[petsc-dev] python3 migration [of configure]
Jed Brown
jed at jedbrown.org
Wed Feb 21 13:30:37 CST 2018
I've tried running futurize and python-modernize on BuildSystem.
Futurize appears to be better supported and produces code that does not
depend on the "six" module. The changes are pretty cosmetic and
sensible. There are only a couple files that import "from future" -- if
we removed that dependency manually then I think configure would work
with base Python (no installed libraries). This requires committing to
python-2.6 minimum. I think we should do it now in 'master'.
Satish Balay <balay at mcs.anl.gov> writes:
> Jed probably has a plan for this. The info at this link appears useful.
> https://lwn.net/Articles/747654
> https://fosdem.org/2018/schedule/event/python3/
> Noteable:
> "Python 2.7 support was extended from 2015 to 2020"
> Satish
