[petsc-dev] DMPlex VecView to HDF5
Adrian Croucher
a.croucher at auckland.ac.nz
Mon Feb 19 15:33:15 CST 2018
hi Matt
I tried what you suggested and modified DMPlexGetFieldType_Internal() so
that all processes have the same field type (ft):
PetscErrorCode DMPlexGetFieldType_Internal(DM dm, PetscSection section,
PetscInt field, PetscInt *sStart, PetscInt *sEnd,
PetscViewerVTKFieldType *ft)
PetscInt dim, pStart, pEnd, vStart, vEnd, cStart, cEnd,
cEndInterior;
PetscInt vcdof[2] = {0,0}, globalvcdof[2];
PetscErrorCode ierr;
PetscFunctionBegin;
*ft = PETSC_VTK_POINT_FIELD;
ierr = DMGetDimension(dm, &dim);CHKERRQ(ierr);
ierr = DMPlexGetDepthStratum(dm, 0, &vStart, &vEnd);CHKERRQ(ierr);
ierr = DMPlexGetHeightStratum(dm, 0, &cStart, &cEnd);CHKERRQ(ierr);
ierr = DMPlexGetHybridBounds(dm, &cEndInterior, NULL, NULL,
NULL);CHKERRQ(ierr);
cEnd = cEndInterior < 0 ? cEnd : cEndInterior;
ierr = PetscSectionGetChart(section, &pStart, &pEnd);CHKERRQ(ierr);
if (field >= 0) {
if ((vStart >= pStart) && (vStart < pEnd)) {ierr =
PetscSectionGetFieldDof(section, vStart, field, &vcdof[0]);CHKERRQ(ierr);}
if ((cStart >= pStart) && (cStart < pEnd)) {ierr =
PetscSectionGetFieldDof(section, cStart, field, &vcdof[1]);CHKERRQ(ierr);}
} else {
PetscSectionGetDof(section, vStart, &vcdof[0]);CHKERRQ(ierr);}
PetscSectionGetDof(section, cStart, &vcdof[1]);CHKERRQ(ierr);}
ierr = MPI_Allreduce(&vcdof, &globalvcdof, 2, MPIU_INT, MPI_MAX,
PetscObjectComm((PetscObject)dm));CHKERRQ(ierr);
if (globalvcdof[0]) {
*sStart = vStart;
*sEnd = vEnd;
if (globalvcdof[0] == dim) *ft = PETSC_VTK_POINT_VECTOR_FIELD;
else *ft = PETSC_VTK_POINT_FIELD;
} else if (globalvcdof[1]) {
*sStart = cStart;
*sEnd = cEnd;
if (globalvcdof[1] == dim) *ft = PETSC_VTK_CELL_VECTOR_FIELD;
else *ft = PETSC_VTK_CELL_FIELD;
} else SETERRQ(PetscObjectComm((PetscObject) dm),
PETSC_ERR_ARG_WRONG, "Could not classify input Vec for VTK");
PetscFunctionReturn(0);
This succeeded in preventing the error I was originally getting.
However, it just crashes further down the line. The error message is
below- any suggestions on what else might need changing to fix this?
Cheers, Adrian
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Petsc has generated inconsistent data
[0]PETSC ERROR: MPI_Allreduce() called in different locations (code
lines) on different processors
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.8.3-2236-gcb4b83bf76
GIT Date: 2018-02-13 12:48:33 -0700
[0]PETSC ERROR: waiwera on a linux-gnu-c-opt named en-354401 by acro018
Tue Feb 20 10:18:55 2018
[0]PETSC ERROR: Configure options --with-x --download-hdf5
--download-netcdf --download-pnetcdf --download-exodusii
--download-triangle --download-ptscotch --download-chaco --download-hypre
[0]PETSC ERROR: #1 VecSetBlockSize() line 1351 in
/home/acro018/software/PETSc/code/src/vec/vec/interface/vector.c
[0]PETSC ERROR: #2 VecSetBlockSize() line 1351 in
[0]PETSC ERROR: #3 VecCreateMPIWithArray() line 610 in
/home/acro018/software/PETSc/code/src/vec/vec/impls/mpi/pbvec.c
[0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Petsc has generated inconsistent data
[1]PETSC ERROR: MPI_Allreduce() called in different locations (code
[1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
[1]PETSC ERROR: Petsc Development GIT revision: v3.8.3-2236-gcb4b83bf76
[1]PETSC ERROR: waiwera on a linux-gnu-c-opt named en-354401 by acro018
[1]PETSC ERROR: Configure options --with-x --download-hdf5
[1]PETSC ERROR: #1 PetscSplitOwnership() line 88 in
/home/acro018/software/PETSc/code/src/sys/utils/psplit.c
[1]PETSC ERROR: #2 PetscSplitOwnership() line 88 in
[1]PETSC ERROR: #3 PetscLayoutSetUp() line 137 in
/home/acro018/software/PETSc/code/src/vec/is/utils/pmap.c
[2]PETSC ERROR: --------------------- Error Message
[2]PETSC ERROR: Petsc has generated inconsistent data
[2]PETSC ERROR: MPI_Allreduce() called in different locations (code
[2]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
[2]PETSC ERROR: Petsc Development GIT revision: v3.8.3-2236-gcb4b83bf76
[2]PETSC ERROR: waiwera on a linux-gnu-c-opt named en-354401 by acro018
[2]PETSC ERROR: Configure options --with-x --download-hdf5
[2]PETSC ERROR: #1 PetscSplitOwnership() line 88 in
[2]PETSC ERROR: #2 PetscSplitOwnership() line 88 in
[2]PETSC ERROR: #3 PetscLayoutSetUp() line 137 in
[2]PETSC ERROR: #4 VecCreate_MPI_Private() line 489 in
[2]PETSC ERROR: #5 VecCreateMPIWithArray() line 611 in
[2]PETSC ERROR: #6 VecGetSubVector() line 1301 in
/home/acro018/software/PETSc/code/src/vec/vec/interface/rvector.c
[2]PETSC ERROR: #7 PetscSectionGetField_Internal() line 276 in
/home/acro018/software/PETSc/code/src/vec/vec/utils/vsection.c
#4 VecGetSubVector() line 1301 in
[0]PETSC ERROR: #5 PetscSectionGetField_Internal() line 276 in
[0]PETSC ERROR: #6 VecView_Plex_Local_HDF5_Internal() line 169 in
/home/acro018/software/PETSc/code/src/dm/impls/plex/plexhdf5.c
[0]PETSC ERROR: #7 VecView_Plex_Local() line 306 in
/home/acro018/software/PETSc/code/src/dm/impls/plex/plex.c
[0]PETSC ERROR: #8 VecView_Plex_HDF5_Internal() line 214 in
[0]PETSC ERROR: #9 VecView_Plex() line 354 in
[0]PETSC ERROR: #10 VecView() line 586 in
[0]PETSC ERROR: [1]PETSC ERROR: #4 VecCreate_MPI_Private() line 489 in
[1]PETSC ERROR: #5 VecCreateMPIWithArray() line 611 in
[1]PETSC ERROR: #6 VecGetSubVector() line 1301 in
[1]PETSC ERROR: #7 PetscSectionGetField_Internal() line 276 in
[1]PETSC ERROR: #8 VecView_Plex_Local_HDF5_Internal() line 169 in
[1]PETSC ERROR: #9 VecView_Plex_Local() line 306 in
[2]PETSC ERROR: #8 VecView_Plex_Local_HDF5_Internal() line 169 in
[2]PETSC ERROR: #9 VecView_Plex_Local() line 306 in
[2]PETSC ERROR: #10 VecView_Plex_HDF5_Internal() line 214 in
[2]PETSC ERROR: #11 VecView_Plex() line 354 in
[2]PETSC ERROR: #12 VecView() line 586 in
[2]PETSC ERROR: #13 User provided function() line 0 in User file
[1]PETSC ERROR: #10 VecView_Plex_HDF5_Internal() line 214 in
[1]PETSC ERROR: #11 VecView_Plex() line 354 in
[1]PETSC ERROR: #12 VecView() line 586 in
[1]PETSC ERROR: #13 User provided function() line 0 in User file
#11 User provided function() line 0 in User file
On 13/02/18 17:13, Matthew Knepley wrote:
> On Mon, Feb 12, 2018 at 10:57 PM, Adrian Croucher
> <a.croucher at auckland.ac.nz <mailto:a.croucher at auckland.ac.nz>> wrote:
> hi,
> I have a DMPlex which I pass in to DMCreateGlobalVector() to
> create a vector, and then use VecView() to view the vector.
> If the DM happens to contain no points on one process, this still
> works fine if I view the vector using PETSC_VIEWER_STDOUT_WORLD.
> However if I create an HDF5 viewer using PetscViewerHDF5Open() and
> try to view the vector using that, it crashes with the error
> message "Could not classify input Vec for VTK".
> It goes into VecView_Plex_Local_HDF5_Internal(), which calls
> DMPlexGetFieldType_Internal() (plex.c:93). This has some
> conditionals testing if vStart < pEnd or cStart < pEnd, which are
> never satisfied because pEnd = 0. This is what leads to it raising
> the error.
> This function returns the point range sStart, sEnd and field type
> ft. To handle the case where there are no points on the process,
> should it perhaps just return sStart, sEnd = 0,0 and a default (or
> maybe null) value for ft?
> Crap, this is a problem. I will have to put some parallel code in
> there because everyone must agree on the ft.
> Matt
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180220/d9b7681c/attachment.html>
