[petsc-dev] petsc/master: superlu_dist now in PETSC_DIR/lib64
    Satish Balay
    balay at mcs.anl.gov
    Sun Feb 18 21:56:37 CST 2018
Thanks for the report. I pushe a fix so that the libs get installed in PETSC_ARCH/lib
Satish
On Sun, 18 Feb 2018, Eric Chamberland wrote:
> Hi,
> it is not a big issue, but I just wanted to know if it has been noticed that
> super-lu-dist 5.3.0 libs are now in PETSC_DIR/lib64 instead of PETSC_DIR/lib
> like all other libs?
> For me, after installation, it is the only package that have libs installed
> there...  I just added it to my LD_LIBRARY_PATH to fix this.
> ls -la /opt/petsc-master_debug/lib64/
> -rw-r--r-- 1 cmpbib bib 9979496 Feb 18 02:07 libsuperlu_dist.a
> lrwxrwxrwx 1 cmpbib bib      20 Feb 18 02:07 libsuperlu_dist.so ->
> libsuperlu_dist.so.5
> lrwxrwxrwx 1 cmpbib bib      24 Feb 18 02:07 libsuperlu_dist.so.5 ->
> libsuperlu_dist.so.5.3.0
> -rwxr-xr-x 1 cmpbib bib 1484904 Feb 18 02:07 libsuperlu_dist.so.5.3.0
> drwxr-xr-x 2 cmpbib bib    4096 Feb 18 02:07 pkgconfig
> Just wanted to report/ask before letting this go unnoticed... (I tried to find
> what changed this in
> https://bitbucket.org/petsc/petsc/commits/1b100fcba2ec49326473bdc77472cf6cbd490a30?at=master
> but didn't found anything related to lib64)
> Thanks,
> Eric
> logs:
> http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2018.02.18.02h00m01s_configure.log
> http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2018.02.18.02h00m01s_make.log
> http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2018.02.18.02h00m01s_RDict.log
> http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2018.02.18.02h00m01s_CMakeLists.txt
