[petsc-dev] How to get the subsnes from a nonlinear problem
Lulu Liu lulu.liu at kaust.edu.sa
Sun Feb 18 00:59:35 CST 2018
I am trying to use nonlinear elimination (NE) to solve a nonlinear problem,
and I have to solve  a subproblem.  How to get the subsnes from the
original global nonlinear problem? Is there any easy way to do it?
For example, the global problem is defined on 40x40 mesh, and the local
problem (the size is 5x5) is defined in the center of domain [0,1]x[0,1].
Thanks!
This message and its contents, including attachments are intended solely
for the original recipient. If you are not the intended recipient or have
received this message in error, please notify me immediately and delete
this message from your computer system. Any unauthorized use or
distribution is prohibited. Please consider the environment before printing
this email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180218/7f1b6d57/attachment.html>
